[MOAB-dev] Does Moab Coupler only work on 3D meshes?
魏华祎 huayiwei1984 at gmail.com
Wed Jul 8 20:33:34 CDT 2015
Hi, Vijay,
Thanks for your reply.  So it also work on Structured Mesh
Representation of Moab?
Best
Huayi
2015-07-09 6:50 GMT+08:00 Vijay S. Mahadevan <vijay.m at gmail.com>:
> No it should work for any dimension and is not restricted to 3-D. Have
> you tried using the coupler for your problem ? If you have issues,
> send us a test case and the meshes. You can also use mbcoupler_test to
> verify whether the solution defined on your source mesh is being
> transferred correctly onto the target mesh.
> Vijay
> On Wed, Jul 8, 2015 at 5:33 PM, 魏华祎 <huayiwei1984 at gmail.com> wrote:
>> Hi, There,
>> I am trying to use Moab Coupler transfer data between 2d meshes, but I
>> am not sure if  it works on 2d mesh.
>> Please give me some suggestion, thanks very much.
>> Best
>> Huayi
