[MOAB-dev] Does Moab Coupler only work on 3D meshes?
Vijay S. Mahadevan vijay.m at gmail.com
Wed Jul 8 17:50:13 CDT 2015
No it should work for any dimension and is not restricted to 3-D. Have
you tried using the coupler for your problem ? If you have issues,
send us a test case and the meshes. You can also use mbcoupler_test to
verify whether the solution defined on your source mesh is being
transferred correctly onto the target mesh.
Vijay
On Wed, Jul 8, 2015 at 5:33 PM, 魏华祎 <huayiwei1984 at gmail.com> wrote:
> Hi, There,
> I am trying to use Moab Coupler transfer data between 2d meshes, but I
> am not sure if  it works on 2d mesh.
> Please give me some suggestion, thanks very much.
> Best
> Huayi
