[MOAB-dev] (Un-)Expected behavior of DMMoabOutput
Vijay S. Mahadevan
vijay.m at gmail.com
Mon May 11 11:12:07 CDT 2015
Gerd, I'm not sure how you're verifying that the GLOBAL_ID tag is not
copied but they are. Here's my output and they look identical, as
they should. The LoadFromFile and Output routines in DM internally
just call MOAB functions unless you pass some options and so if you
see an issue, we should be able to track this down.
Can you verify if the following commands give similar results from
your MOAB installation ?
mahadevan at Tachyon ~/Desktop/moabplay > $MOAB_DIR/bin/mbsize -t
no_template_test.h5m
File no_template_test.h5m:
Tag Name Vertex Tet EntitySet
MATERIAL_SET 0 0 1
NEUMANN_SET 0 0 0
DIRICHLET_SET 0 0 0
GEOM_DIMENSION 0 0 0
GLOBAL_ID 6772 4028 0
NAME 0 0 25
SHAPE_ID 0 0 1
no_template_test.out.h5m
File no_template_test.out.h5m:
MATERIAL_SET 0 0 1
NEUMANN_SET 0 0 0
DIRICHLET_SET 0 0 0
NAME 0 0 25
SHAPE_ID 0 0 1
Vijay
On Mon, May 11, 2015 at 7:46 AM, Gerd Heber <gheber at hdfgroup.org> wrote:
> This is maybe just a documentation issue, but I find the behavior somewhat
> counter-intuitive. The attached program just calls DMMoabLoadFromFile
> followed by DMMoabOutput. The in- and output files are attached as well.
> My expectation was that the output file would be pretty much a copy
> of the input file. Not quite. The most notable difference is that the GLOBAL_ID tags
> don't get copied. Is that the expected behavior? If so, what's the reasoning
> behind not copying the GLOBAL_ID tags?
> Thanks for your help.
> G.
