[MOAB-dev] (Un-)Expected behavior of DMMoabOutput
Gerd Heber
gheber at hdfgroup.org
Mon May 11 07:46:18 CDT 2015
This is maybe just a documentation issue, but I find the behavior somewhat
counter-intuitive. The attached program just calls DMMoabLoadFromFile
followed by DMMoabOutput. The in- and output files are attached as well.
My expectation was that the output file would be pretty much a copy
of the input file. Not quite. The most notable difference is that the GLOBAL_ID tags
don't get copied. Is that the expected behavior? If so, what's the reasoning
behind not copying the GLOBAL_ID tags?
Thanks for your help.
G.
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20150511/db3ab351/attachment-0001.c>
Desc: no_template_test.h5m
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20150511/db3ab351/attachment-0002.obj>
Desc: no_template_test.out.h5m
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20150511/db3ab351/attachment-0003.obj>
