[MOAB-dev] (Un-)Expected behavior of DMMoabOutput
Gerd Heber gheber at hdfgroup.org
Mon May 11 11:40:39 CDT 2015
Vijay, the problem is not that the GLOBAL_ID tags aren't there.
The problem is that they don't match between the original
and the new file. For example, have a look at the GLOBAL_ID tag for Tet10. In the original file the minimum element ID is 2202 and
the maximum is 6229. In the "copied" file it goes from
1 to 4028, which tells me that DMMoabOutput generates
tags of the right sizes, but reinitializes them rather than
copy the original values. Does that make sense?
G.
-----Original Message-----
From: Vijay S. Mahadevan [mailto:vijay.m at gmail.com]
Sent: Monday, May 11, 2015 11:12 AM
To: Gerd Heber
Cc: MOAB dev
Subject: Re: [MOAB-dev] (Un-)Expected behavior of DMMoabOutput
Gerd, I'm not sure how you're verifying that the GLOBAL_ID tag is not copied but they are.  Here's my output and they look identical, as they should. The LoadFromFile and Output routines in DM internally just call MOAB functions unless you pass some options and so if you see an issue, we should be able to track this down.
Can you verify if the following commands give similar results from your MOAB installation ?
mahadevan at Tachyon ~/Desktop/moabplay > $MOAB_DIR/bin/mbsize -t no_template_test.h5m File no_template_test.h5m:
      Tag Name   Vertex      Tet EntitySet
  MATERIAL_SET        0        0         1
   NEUMANN_SET        0        0         0
 DIRICHLET_SET        0        0         0
GEOM_DIMENSION        0        0         0
     GLOBAL_ID     6772     4028         0
          NAME        0        0        25
      SHAPE_ID        0        0         1
mahadevan at Tachyon ~/Desktop/moabplay > $MOAB_DIR/bin/mbsize -t no_template_test.out.h5m File no_template_test.out.h5m:
  MATERIAL_SET        0        0         1
   NEUMANN_SET        0        0         0
 DIRICHLET_SET        0        0         0
          NAME        0        0        25
      SHAPE_ID        0        0         1
Vijay
On Mon, May 11, 2015 at 7:46 AM, Gerd Heber <gheber at hdfgroup.org> wrote:
> This is maybe just a documentation issue, but I find the behavior
> somewhat counter-intuitive. The attached program just calls
> DMMoabLoadFromFile followed by DMMoabOutput. The in- and output files are attached as well.
> My expectation was that the output file would be pretty much a copy of
> the input file. Not quite. The most notable difference is that the
> GLOBAL_ID tags don't get copied. Is that the expected behavior? If so,
> what's the reasoning behind not copying the GLOBAL_ID tags?
> Thanks for your help.
> G.
