[MOAB-dev] Problem with Gmsh format 2.2
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Fri Mar  6 16:13:38 CST 2015
Alexander, thanks for the modifications. We will apply this patch to
the Gmsh reader and it should be available on the next minor release.
Vijay
On Mon, Feb 23, 2015 at 1:44 AM, Alexander Tismer
<alexander.tismer at ihs.uni-stuttgart.de> wrote:
> Hello,
> i try to read a msh file (format 2.2). I come into troubles with the
> PhysicalNames tag.
> So I modified the ReadGmsh.cpp:124
>     if (version != 2.0 && version != 2.1 && version != 2.2) {
>       MB_SET_ERR(MB_FILE_DOES_NOT_EXIST, filename << ": unknown format
> version: " << version);
>       return MB_FILE_DOES_NOT_EXIST;
>     int file_format;
>     if (!tokens.get_integers(1, &file_format) ||
>         !tokens.get_integers(1, &data_size) ||
>         !tokens.match_token("$EndMeshFormat"))
>       return MB_FILE_WRITE_ERROR;
>       // If physical entities in the gmsh file -> discard this
>           const char* const phys_tokens[] = {"$Nodes", "$PhysicalNames", 0};
>           int hasPhys = tokens.match_token( phys_tokens );
>           if (hasPhys == 2) {
>               long num_phys;
>               if (!tokens.get_long_ints(1, &num_phys)) return
>               for (int loop_phys=0; loop_phys<num_phys; loop_phys++) {
>                 long physDim;
>                 long physGroupNum;
>                 char const * physName;
>                 if (!tokens.get_long_ints(1, &physDim)) return
>                 if (!tokens.get_long_ints(1, &physGroupNum)) return
>                 if (!tokens.get_string()) return MB_FILE_WRITE_ERROR;
>               if ( !tokens.match_token("$EndPhysicalNames") ||
>                    !tokens.match_token("$Nodes") ) return
> Maybe this is of intereset for other users. In this case the reader just
> ignores all physicalNames if present.
> Best regards
> Alex
> Alexander Tismer
> Institut für Strömungsmechanik
> und Hydraulische Strömungsmaschinen
> Universität Stuttgart
> Pfaffenwaldring 10
> 70550 Stuttgart
> Tel.:   +49 (0) 711 / 685 63007
> Fax:    +49 (0) 711 / 685 63255
> eMail: alexander.tismer at ihs.uni-stuttgart.de
> http://www.ihs.uni-stuttgart.de
