[MOAB-dev] Problem with Gmsh format 2.2
    Alexander Tismer
    alexander.tismer at ihs.uni-stuttgart.de
    Mon Feb 23 01:44:21 CST 2015
Hello,
i try to read a msh file (format 2.2). I come into troubles with the
PhysicalNames tag.
So I modified the ReadGmsh.cpp:124
     if (version != 2.0 && version != 2.1 && version != 2.2) {
       MB_SET_ERR(MB_FILE_DOES_NOT_EXIST, filename << ": unknown format
version: " << version);
       return MB_FILE_DOES_NOT_EXIST;
     int file_format;
     if (!tokens.get_integers(1, &file_format) ||
         !tokens.get_integers(1, &data_size) ||
         !tokens.match_token("$EndMeshFormat"))
       return MB_FILE_WRITE_ERROR;
       // If physical entities in the gmsh file -> discard this
           const char* const phys_tokens[] = {"$Nodes",
"$PhysicalNames", 0};
           int hasPhys = tokens.match_token( phys_tokens );
           if (hasPhys == 2) {
               long num_phys;
               if (!tokens.get_long_ints(1, &num_phys)) return
               for (int loop_phys=0; loop_phys<num_phys; loop_phys++) {
                 long physDim;
                 long physGroupNum;
                 char const * physName;
                 if (!tokens.get_long_ints(1, &physDim)) return
                 if (!tokens.get_long_ints(1, &physGroupNum)) return
                 if (!tokens.get_string()) return MB_FILE_WRITE_ERROR;
               if ( !tokens.match_token("$EndPhysicalNames") ||
                    !tokens.match_token("$Nodes") ) return
Maybe this is of intereset for other users. In this case the reader just
ignores all physicalNames if present.
Best regards
Alex
Alexander Tismer
Institut für Strömungsmechanik
und Hydraulische Strömungsmaschinen
Universität Stuttgart
Pfaffenwaldring 10
70550 Stuttgart
Tel.:   +49 (0) 711 / 685 63007
Fax:    +49 (0) 711 / 685 63255
eMail: alexander.tismer at ihs.uni-stuttgart.de
http://www.ihs.uni-stuttgart.de
