[MOAB-dev] Parallel output writes odd sets
Timothy Tautges timothy.tautges at cd-adapco.com
Thu Oct 30 23:10:42 CDT 2014
Are you using iMeshP? I wonder if those are Part sets.
On Oct 30, 2014 10:37 PM, "Grindeanu, Iulian R." <iulian at mcs.anl.gov> wrote:
> Hi Anton,
> most of those extra sets are the shared sets between parts.
> also, there are some sets that comprise all entities on a task
> some of them are used during ghosting
> You should have all the original sets, too.
> If it becomes a problem for you, please raise an issue on bitbucket, and
> we may offer an option to not write them
> (maybe there is one now, but I do not know it)
> Iulian
> From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on
> behalf of Kanaev A.A. [kanaev at ibrae.ac.ru]
> Sent: Thursday, October 30, 2014 11:00 AM
> To: moab-dev at mcs.anl.gov
> Subject: [MOAB-dev] Parallel output writes odd sets
> Hello MOAB-dev,
> I have a simple program that reads then writes h5m file in parallel
> The input file is brick1x1x2p2.h5m
> The output file is out.h5m
> Output of mbsize -ll brick1x1x2p2.h5m shows there're 29 EntitySets : 1-27
> are geometry sets, 28 and 29 are partition sets made by mbpart
> I run my program in parallel :  mpiexec.mpich2 -n 2 ./restart
> brick1x1x2p2.h5m
> Output of mbsize -ll out.h5m shows there're 33 EntitySets
> Loading another larger mesh prepartitioned for 16 processors,  there're +4
> sets when running on 2 cores, +16 when running on 4 cores,  +120 sets when
> running on 16 cores
> (after removing PARALLEL_RESOLVE_SHARED_ENTS option for load_file, there's
> +97 set for 16 processors)
> What are those extra EntitySets?
> cpp code + h5m file attached
> Thanks
> Anton
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20141030/5cd11614/attachment.html>
