[MOAB-dev] Parallel output writes odd sets
Grindeanu, Iulian R. iulian at mcs.anl.gov
Thu Oct 30 22:37:22 CDT 2014
Hi Anton,
most of those extra sets are the shared sets between parts.
also, there are some sets that comprise all entities on a task
some of them are used during ghosting
You should have all the original sets, too.
If it becomes a problem for you, please raise an issue on bitbucket, and we may offer an option to not write them
(maybe there is one now, but I do not know it)
Iulian
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Kanaev A.A. [kanaev at ibrae.ac.ru]
Sent: Thursday, October 30, 2014 11:00 AM
To: moab-dev at mcs.anl.gov
Subject: [MOAB-dev] Parallel output writes odd sets
Hello MOAB-dev,
I have a simple program that reads then writes h5m file in parallel
The input file is brick1x1x2p2.h5m
The output file is out.h5m
Output of mbsize -ll brick1x1x2p2.h5m shows there're 29 EntitySets : 1-27 are geometry sets, 28 and 29 are partition sets made by mbpart
I run my program in parallel :  mpiexec.mpich2 -n 2 ./restart brick1x1x2p2.h5m
Output of mbsize -ll out.h5m shows there're 33 EntitySets
Loading another larger mesh prepartitioned for 16 processors,  there're +4 sets when running on 2 cores, +16 when running on 4 cores,  +120 sets when running on 16 cores
(after removing PARALLEL_RESOLVE_SHARED_ENTS option for load_file, there's +97 set for 16 processors)
What are those extra EntitySets?
cpp code + h5m file attached
Thanks
Anton
