[MOAB-dev] Parallel output writes odd sets
    Kanaev A.A.
    kanaev at ibrae.ac.ru
    Thu Oct 30 11:00:24 CDT 2014
Hello MOAB-dev,
I have a simple program that reads then writes h5m file in parallel
The input file is brick1x1x2p2.h5m
The output file is out.h5m
Output of mbsize -ll brick1x1x2p2.h5m shows there're 29 EntitySets : 1-27 are geometry sets, 28 and 29 are partition sets made by mbpart
I run my program in parallel :  mpiexec.mpich2 -n 2 ./restart brick1x1x2p2.h5m
Output of mbsize -ll out.h5m shows there're 33 EntitySets
Loading another larger mesh prepartitioned for 16 processors,  there're +4 sets when running on 2 cores, +16 when running on 4 cores,  +120 sets when running on 16 cores
(after removing PARALLEL_RESOLVE_SHARED_ENTS option for load_file, there's +97 set for 16 processors)
What are those extra EntitySets?
cpp code + h5m file attached
Thanks
Anton
Type: text/x-c++src
Desc: restart.cpp
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20141030/e9d47034/attachment-0001.cpp>
Desc: brick1x1x2p2.h5m
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20141030/e9d47034/attachment-0002.obj>
Desc: lidp16.h5m
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20141030/e9d47034/attachment-0003.obj>
