[MOAB-dev] Parallel Test Failure
Grindeanu, Iulian R.
iulian at mcs.anl.gov
Mon Oct 27 12:24:45 CDT 2014
Hi Friedrich,
What are you trying to do?
Rajeev and Vijay have experience running / building nek5000 with moab.
Iulian
From: Grabner, Friedrich [F.M.Grabner at warwick.ac.uk]
Sent: Monday, October 27, 2014 12:17 PM
To: Grindeanu, Iulian R.
Subject: Re: Parallel Test Failure
Hi Iulian,
I have managed to install it although I believe there is some issue when installing on hpc.
However now when I try to run my moab enabled nek5000 I can only do so if I secure my resources on the system and then manually start my job.
nekmpi [casename] [np]
When I submit a job to the queue I receive the following error:
-bash: BASH_FUNC_module(): line 0: syntax error near unexpected token `)'
-bash: BASH_FUNC_module(): line 0: `BASH_FUNC_module() () { eval $($LMOD_CMD bash "$@");'
-bash: error importing function definition for `BASH_FUNC_module'
/home/eng/esumgy/.bashrc: line 29: module: command not found
mv: cannot stat `pipe.log.8': No such file or directory
mv: cannot stat `pipe.sch': No such file or directory
node6.1259Error re-mmapping shared memory: Cannot allocate memory (err=9)
[node6:01259] Open MPI detected an unexpected PSM error in opening an endpoint: Error re-mmapping shared memory: Cannot allocate memory
mpiexec has exited due to process rank 5 with PID 1259 on
node node6 exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpiexec (as reported here).
Could this be as I haven't correctly installed moab or any of it's prerequisites?
Regards Friedrich
Sent: 27 October 2014 16:54
To: Grabner, Friedrich
Cc: MOAB dev
Subject: RE: Parallel Test Failure
Hi Friedrich,
Thanks for your report.
I could not reproduce your error, so I don't know what is going on.
Are these the only errors you see in your make check?
Can you try a newer version of moab, or hdf5?
We have several nightly builds on our systems that resemble you configuration, for example this one:
http://gnep.mcs.anl.gov:8010/builders/moab-par
more configurations are here:
http://gnep.mcs.anl.gov:8010/waterfall?category=moab
thanks,
Iulian
Sent: Friday, October 24, 2014 8:03 AM
Hi Iulian,
See attached!
Friedrich
Sent: 24 October 2014 13:14
To: Grabner, Friedrich; moab-announce at mcs.anl.gov
can you send your config.log file?
Iulian
From: moab-announce-bounces at mcs.anl.gov [moab-announce-bounces at mcs.anl.gov] on behalf of Grabner, Friedrich [F.M.Grabner at warwick.ac.uk]
Sent: Friday, October 24, 2014 4:22 AM
To: moab-announce at mcs.anl.gov
Subject: [MOAB-announce] Parallel Test Failure
Hi All,
I am trying to install moab-4.6.3 on my HPC system following the instructions on following webpage:
http://trac.mcs.anl.gov/projects/ITAPS/wiki/BuildingAndUsingMOAB
I have run everything exactly as specified on my desktop and successfully installed it however on hpc I receive error:
PASS: pcomm_unit
FAIL: parallel_unit_tests
PASS: uber_parallel_test
FAIL: scdtest
PASS: pcomm_serial
PASS: par_spatial_locator_test
FAIL: parallel_hdf5_test
PASS: mhdf_parallel
PASS: parallel_write_test
3 of 9 tests failed
See test/parallel/test-suite.log
make[4]: *** [test-suite.log] Error 1
make[4]: Leaving directory `/gpfs/home/eng/esumgy/moab-4.6.3/test/parallel'
make[3]: *** [check-TESTS] Error 2
make[3]: Leaving directory `/gpfs/home/eng/esumgy/moab-4.6.3/test/parallel'
make[2]: *** [check-am] Error 2
make[2]: Leaving directory `/gpfs/home/eng/esumgy/moab-4.6.3/test/parallel'
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/gpfs/home/eng/esumgy/moab-4.6.3/test
I have attached my test-suite.log file.
Thanks in advance, Friedrich
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20141027/35a6ccb2/attachment.html>
