[MOAB-dev] Parallel Test Failure
    Grindeanu, Iulian R.
    iulian at mcs.anl.gov
    Mon Oct 27 11:54:31 CDT 2014
Hi Friedrich,
Thanks for your report.
 I could not reproduce your error, so I don't know what is going on.
Are these the only errors you see in your make check?
Can you try a newer version of moab, or hdf5?
We have several nightly builds on our systems that resemble you configuration, for example this one:
http://gnep.mcs.anl.gov:8010/builders/moab-par
more configurations are here:
http://gnep.mcs.anl.gov:8010/waterfall?category=moab
thanks,
Iulian
From: Grabner, Friedrich [F.M.Grabner at warwick.ac.uk]
Sent: Friday, October 24, 2014 8:03 AM
To: Grindeanu, Iulian R.
Subject: Re: Parallel Test Failure
Hi Iulian,
See attached!
Friedrich
Sent: 24 October 2014 13:14
To: Grabner, Friedrich; moab-announce at mcs.anl.gov
Subject: RE: Parallel Test Failure
can you send your config.log file?
Iulian
From: moab-announce-bounces at mcs.anl.gov [moab-announce-bounces at mcs.anl.gov] on behalf of Grabner, Friedrich [F.M.Grabner at warwick.ac.uk]
Sent: Friday, October 24, 2014 4:22 AM
To: moab-announce at mcs.anl.gov
Subject: [MOAB-announce] Parallel Test Failure
Hi All,
I am trying to install moab-4.6.3 on my HPC system following the instructions on following webpage:
http://trac.mcs.anl.gov/projects/ITAPS/wiki/BuildingAndUsingMOAB
I have run everything exactly as specified on my desktop and successfully installed it however on hpc I receive error:
PASS: pcomm_unit
FAIL: parallel_unit_tests
PASS: uber_parallel_test
FAIL: scdtest
PASS: pcomm_serial
PASS: par_spatial_locator_test
FAIL: parallel_hdf5_test
PASS: mhdf_parallel
PASS: parallel_write_test
3 of 9 tests failed
See test/parallel/test-suite.log
make[4]: *** [test-suite.log] Error 1
make[4]: Leaving directory `/gpfs/home/eng/esumgy/moab-4.6.3/test/parallel'
make[3]: *** [check-TESTS] Error 2
make[3]: Leaving directory `/gpfs/home/eng/esumgy/moab-4.6.3/test/parallel'
make[2]: *** [check-am] Error 2
make[2]: Leaving directory `/gpfs/home/eng/esumgy/moab-4.6.3/test/parallel'
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/gpfs/home/eng/esumgy/moab-4.6.3/test
I have attached my test-suite.log file.
Thanks in advance, Friedrich
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20141027/199ddc23/attachment.html>
