[MOAB-dev] DAGMC CMakeFile
    Paul Wilson
    wilsonp at engr.wisc.edu
    Fri Aug 29 11:37:55 CDT 2014
Hi again,
On 08/29/2014 11:24 AM, Vijay S. Mahadevan wrote:
>> I guess I'm not sure this is the desired behavior.  It's not really a big
>> deal because dagmc is not that big, but just because dagmc has been built
>> and exists doesn't mean that all uses of that MOAB installation will want to
>> link dagmc into the executable.
> Sure that is fine. If you want, we can create a new variable that's
> still part of moab.make that can be used by a dagmc based application
> to link appropriately.
>> I think it makes more sense to have a separate dagmc.make or
>> DAGMCconfig.cmake, but am interested in other thoughts.
> I'm against creating more files. moab.make and MOABConfig.cmake should
> be a one stop shop for all things MOAB related. A user makefile should
> include moab.make and know everything it needs to know about the
> particular build.
That makes sense...
So conceptually, there could be a DAGMC_LINK_LIBS variable that was
always part of MOAB_LINK_LIBS, but had no value unless a DAGMC variable
was defined?
Paul
> Vijay
> On Fri, Aug 29, 2014 at 11:10 AM, Paul Wilson <wilsonp at engr.wisc.edu> wrote:
>> Hi Vijay,
>> Paul
>> On 08/29/2014 09:18 AM, Vijay S. Mahadevan wrote:
>> If configured with dagmc, the linker libs should reflect that for MOAB in
>> moab.make and the CMake config file. This is the case for MBCoupler and it
>> should be done similarly.
>> If you have changes, please submit a PR.
>> Vijay
>> On Aug 29, 2014 9:12 AM, "Andrew Davis" <davisa at engr.wisc.edu> wrote:
>>> Hi Dev's
>>> Would there be any objections to the inclusion of an -ldagmc in the
>>> MOABconfig.cmake file?
>>> Or would the preference be to have a DAGMCconfig.cmake file which looks an
>>> awful lot like the MOAB one?
>>> Thanks
>>> Andy
>> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
>> Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
>> Faculty Director, Advanced Computing Infrastructure
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140829/bb9bba75/attachment-0001.bin>
