[MOAB-dev] DAGMC CMakeFile
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Fri Aug 29 11:24:12 CDT 2014
> I guess I'm not sure this is the desired behavior.  It's not really a big
> deal because dagmc is not that big, but just because dagmc has been built
> and exists doesn't mean that all uses of that MOAB installation will want to
> link dagmc into the executable.
Sure that is fine. If you want, we can create a new variable that's
still part of moab.make that can be used by a dagmc based application
to link appropriately.
> I think it makes more sense to have a separate dagmc.make or
> DAGMCconfig.cmake, but am interested in other thoughts.
I'm against creating more files. moab.make and MOABConfig.cmake should
be a one stop shop for all things MOAB related. A user makefile should
include moab.make and know everything it needs to know about the
particular build.
Vijay
On Fri, Aug 29, 2014 at 11:10 AM, Paul Wilson <wilsonp at engr.wisc.edu> wrote:
> Hi Vijay,
> Paul
> On 08/29/2014 09:18 AM, Vijay S. Mahadevan wrote:
> If configured with dagmc, the linker libs should reflect that for MOAB in
> moab.make and the CMake config file. This is the case for MBCoupler and it
> should be done similarly.
> If you have changes, please submit a PR.
> Vijay
> On Aug 29, 2014 9:12 AM, "Andrew Davis" <davisa at engr.wisc.edu> wrote:
>> Hi Dev's
>> Would there be any objections to the inclusion of an -ldagmc in the
>> MOABconfig.cmake file?
>> Or would the preference be to have a DAGMCconfig.cmake file which looks an
>> awful lot like the MOAB one?
>> Thanks
>> Andy
> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
> Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
> Faculty Director, Advanced Computing Infrastructure
