[MOAB-dev] DAGMC CMakeFile
    Paul Wilson
    wilsonp at engr.wisc.edu
    Fri Aug 29 11:10:43 CDT 2014
Hi Vijay,
I guess I'm not sure this is the desired behavior.  It's not really a
big deal because dagmc is not that big, but just because dagmc has been
built and exists doesn't mean that all uses of that MOAB installation
will want to link dagmc into the executable.
I think it makes more sense to have a separate dagmc.make or
DAGMCconfig.cmake, but am interested in other thoughts.
Paul
On 08/29/2014 09:18 AM, Vijay S. Mahadevan wrote:
> If configured with dagmc, the linker libs should reflect that for MOAB
> in moab.make and the CMake config file. This is the case for MBCoupler
> and it should be done similarly.
> If you have changes, please submit a PR.
> Vijay
> On Aug 29, 2014 9:12 AM, "Andrew Davis" <davisa at engr.wisc.edu
> <mailto:davisa at engr.wisc.edu>> wrote:
>     Hi Dev's
>     Would there be any objections to the inclusion of an -ldagmc in
>     the MOABconfig.cmake file?
>     Or would the preference be to have a DAGMCconfig.cmake file which
>     looks an awful lot like the MOAB one?
>     Thanks
>     Andy
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Faculty Director, Advanced Computing Infrastructure
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140829/c2aa522a/attachment.html>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140829/c2aa522a/attachment.bin>
