[MOAB-dev] msh -> cub -> h5m
    kanaev at ibrae.ac.ru
    Tue Jul 29 17:08:54 CDT 2014
 Hello MOAB-dev,
 I got simple geometry/mesh Cubit file brick1x1x2.cub, i can simply
convert it to .h5m with mbconvert
 I do export to .MSH format in Cubit, and then import it back and
save as .cub file again, when i do mbconvert i got message "Element
ids are not contiguous!" though it writes .h5m file but GLOBAL_ID tag
values for geometry sets are lost (e.g. for Surfaces)
 I realise it's mostly Cubit/msh import problem but i'd appreciate
any advise on that!
 Anton
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140729/e86ab642/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140729/e86ab642/attachment-0002.obj>
Type: text/plain charset=us-ascii
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140729/e86ab642/attachment-0001.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140729/e86ab642/attachment-0003.obj>
