[MOAB-dev] msh -> cub -> h5m
    Tim Tautges
    timothy.tautges at cd-adapco.com
    Tue Aug 19 17:36:06 CDT 2014
I suspect the problem is that .msh format doesn't store geometry.  Restoring geometry sets is only possible when reading
from .cub files, because those are the only ones that have geometric topology (which is what those geometry sets
represent, see the MOAB UG/metadata info document).
- tim
On 07/29/2014 05:08 PM, kanaev at ibrae.ac.ru wrote:
> Hello MOAB-dev,
> I got simple geometry/mesh Cubit file brick1x1x2.cub, i can simply convert it to .h5m with mbconvert
> I do export to .MSH format in Cubit, and then import it back and save as .cub file again, when i do mbconvert i got
> message "Element ids are not contiguous!" though it writes .h5m file but GLOBAL_ID tag values for geometry sets are lost
> (e.g. for Surfaces)
> I realise it's mostly Cubit/msh import problem but i'd appreciate any advise on that!
> Anton
Timothy J. Tautges
Manager, Directed Meshing, CD-adapco
Phone: 608-354-1459
