[MOAB-dev] commit/MOAB: 2 new changesets
commits-noreply at bitbucket.org
Mon Jul 14 19:20:17 CDT 2014
2 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/a2d1746d29ab/
Changeset: a2d1746d29ab
Branch: None
User: vijaysm
Date: 2014-07-15 02:14:47
Summary: Add extra argument to MB_OPTIONAL_TOOL routine to take a default enabler option and one when --enable-tools is specified.
Affected #: 1 file
diff --git a/configure.ac b/configure.ac
index 890f70d..102c05d 100644
--- a/configure.ac
+++ b/configure.ac
@@ -584,7 +584,7 @@ AC_ARG_WITH([vtk],
],[WITH_VTK=])
VTKMOAB_DEFAULT=no
-if test "x$WITH_VTK" != "xno" -a "x$WITH_VTK" != "x"; then
+if (test "x$WITH_VTK" != "xno" && test "x$WITH_VTK" != "x"); then
VTKMOAB_DEFAULT=yes
fi
@@ -610,7 +610,7 @@ AC_ARG_WITH( [vtk-lib-suffix],
# Optional Tools
# Define a macro to avoid typing this for each individual tool
- # Usage: MB_OPTIONAL_TOOL( name, default )
+ # Usage: MB_OPTIONAL_TOOL( name, default, default_if_tools_enabled )
# name - name of option
# default - yes/no, $ENABLE_TOOLS overrides this if set
# Actions:
@@ -618,8 +618,9 @@ AC_ARG_WITH( [vtk-lib-suffix],
# creates ENABLE_${tool} automake conditional
AC_DEFUN([MB_OPTIONAL_TOOL],[
mb_default_$1=$2
if test "x" != "x$ENABLE_TOOLS"; then
- mb_default_$1="$ENABLE_TOOLS"
+ mb_default_$1=$3
fi
AC_ARG_ENABLE( [$1],
[AC_HELP_STRING([--enable-$1],[Build tool: $1])
@@ -637,26 +638,26 @@ AC_HELP_STRING([--enable-tools],[Build all tools by default])
AC_HELP_STRING([--disable-tools],[Disable all tools by default])],
[ENABLE_TOOLS=$enableval],[ENABLE_TOOLS=] )
# Individual tools
-MB_OPTIONAL_TOOL([mbconvert], [yes])
-MB_OPTIONAL_TOOL([hexmodops], [yes])
-MB_OPTIONAL_TOOL([qvdual], [no] )
-MB_OPTIONAL_TOOL([vtkMOABReader],[${VTKMOAB_DEFAULT}] )
-MB_OPTIONAL_TOOL([vtkMOABReaderNew],[${VTKMOAB_DEFAULT}] )
-MB_OPTIONAL_TOOL([mbsize], [yes])
-MB_OPTIONAL_TOOL([mbskin], [yes])
-MB_OPTIONAL_TOOL([mbtagprop], [yes])
-MB_OPTIONAL_TOOL([mbmem], [yes])
-MB_OPTIONAL_TOOL([mcnpmit], [no])
-MB_OPTIONAL_TOOL([mbcoupler], [$ENABLE_mcnpmit] )
-MB_OPTIONAL_TOOL([spheredecomp], [yes])
-MB_OPTIONAL_TOOL([mbsurfplot], [yes])
-MB_OPTIONAL_TOOL([mbzoltan], [${WITH_ZOLTAN}] )
-MB_OPTIONAL_TOOL([dagmc], [yes])
-MB_OPTIONAL_TOOL([gsets], [yes])
-MB_OPTIONAL_TOOL([mbdepth], [yes])
-MB_OPTIONAL_TOOL([refiner], [no])
-MB_OPTIONAL_TOOL([h5mtools], [yes])
-MB_OPTIONAL_TOOL([mbcslam], [no])
+MB_OPTIONAL_TOOL([mbconvert], [yes], [yes])
+MB_OPTIONAL_TOOL([hexmodops], [yes], [yes])
+MB_OPTIONAL_TOOL([qvdual], [${VTKMOAB_DEFAULT}], [${VTKMOAB_DEFAULT}])
+MB_OPTIONAL_TOOL([vtkMOABReader],[${VTKMOAB_DEFAULT}], [${VTKMOAB_DEFAULT}])
+MB_OPTIONAL_TOOL([vtkMOABReaderNew],[${VTKMOAB_DEFAULT}], [${VTKMOAB_DEFAULT}])
+MB_OPTIONAL_TOOL([mbsize], [yes], [yes])
+MB_OPTIONAL_TOOL([mbskin], [yes], [yes])
+MB_OPTIONAL_TOOL([mbtagprop], [yes], [yes])
+MB_OPTIONAL_TOOL([mbmem], [yes], [yes])
+MB_OPTIONAL_TOOL([mcnpmit], [no], [yes])
+MB_OPTIONAL_TOOL([mbcoupler], [no], [yes] )
+MB_OPTIONAL_TOOL([spheredecomp], [yes], [yes])
+MB_OPTIONAL_TOOL([mbsurfplot], [yes], [yes])
+MB_OPTIONAL_TOOL([mbzoltan], [${WITH_ZOLTAN}], [${WITH_ZOLTAN}] )
+MB_OPTIONAL_TOOL([dagmc], [no], [yes])
+MB_OPTIONAL_TOOL([gsets], [yes], [yes])
+MB_OPTIONAL_TOOL([mbdepth], [yes], [yes])
+MB_OPTIONAL_TOOL([refiner], [no], [yes])
+MB_OPTIONAL_TOOL([h5mtools], [yes], [yes])
+MB_OPTIONAL_TOOL([mbcslam], [no], [yes])
if test "xyes" = "x$ENABLE_refiner"; then
if test "xyes" != "x$WITH_MPI"; then
@@ -809,8 +810,7 @@ AC_DEFUN([FATHOM_MERGE_LISTS],[
$1="${$1} $2"
-if test "xno" != "x$WITH_VTK" -a "x" != "x$WITH_VTK"; then
AC_PATH_X
AC_PATH_XTRA
if test "xyes" = "x$no_x"; then
https://bitbucket.org/fathomteam/moab/commits/5317f24e46c4/
Changeset: 5317f24e46c4
Branch: vijaysm/config_tools
User: vijaysm
Date: 2014-07-15 02:19:52
Summary: Make h5mtools depend on actual HDF5 configuration
Affected #: 1 file
index 102c05d..a86f98d 100644
--- a/configure.ac
+++ b/configure.ac
@@ -656,7 +656,7 @@ MB_OPTIONAL_TOOL([dagmc], [no], [yes])
-MB_OPTIONAL_TOOL([h5mtools], [yes], [yes])
+MB_OPTIONAL_TOOL([h5mtools], [${HAVE_HDF5}], [${HAVE_HDF5}])
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
