[MOAB-dev] commit/MOAB: 2 new changesets
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Sat Jul 12 17:49:39 CDT 2014
2 new commits in MOAB:
https://bitbucket.org/fathomteam/moab/commits/f34c493671a4/
Changeset:   f34c493671a4
Branch:      None
User:        judajake
Date:        2014-04-05 01:10:51
Summary:     update vtk moab
I updated the vtk moab to match https://github.com/robertmaynard/Sandbox.
I did one small change to fix a bug with reading materials
Affected #:  19 files
diff --git a/tools/vtkMOABReaderNew/CMakeLists.txt.in b/tools/vtkMOABReaderNew/CMakeLists.txt.in
index 8b8f888..e005289 100644
--- a/tools/vtkMOABReaderNew/CMakeLists.txt.in
+++ b/tools/vtkMOABReaderNew/CMakeLists.txt.in
@@ -13,13 +13,22 @@ find_package(ParaView REQUIRED)
 include(${PARAVIEW_USE_FILE})
 include_directories(${PARAVIEW_INCLUDE_DIRS})
 include_directories(@srcdir@)
+include_directories(@srcdir@/detail)
 set(headers
-  @srcdir@/SimpleMoab.h
-  @srcdir@/CellTypeToType.h
+  @srcdir@/CellSets.h
   @srcdir@/DataSetConverter.h
-  @srcdir@/MixedCellConnectivity.h
-  @srcdir@/vtkMoabReader.h
+  @srcdir@/detail/CellTypeToType.h
+  @srcdir@/detail/ContinousCellInfo.h
+  @srcdir@/detail/LoadGeometry.h
+  @srcdir@/detail/MixedCellConnectivity.h
+  @srcdir@/detail/ReadSparseTag.h
+  @srcdir@/detail/ReduceSpectralMesh.h
+  @srcdir@/detail/UsageTable.h
+  @srcdir@/ExtractShell.h
+  @srcdir@/FaceSets.h
+  @srcdir@/SimpleMoab.h
 add_paraview_plugin(vtkMoabReaderPlugin "5.0"
diff --git a/tools/vtkMOABReaderNew/CellSets.h b/tools/vtkMOABReaderNew/CellSets.h
new file mode 100644
index 0000000..6171aec
--- /dev/null
+++ b/tools/vtkMOABReaderNew/CellSets.h
@@ -0,0 +1,75 @@
+#ifndef __smoab_CellSets_h
+#define __smoab_CellSets_h
+#include "SimpleMoab.h"
+namespace smoab
+class CellSet
+public:
+  CellSet(smoab::EntityHandle p,const smoab::Range& cells):
+    Entity(p),
+    Cells(cells)
+  const smoab::Range& cells() const { return this->Cells; }
+  EntityHandle entity() const { return this->Entity; }
+  bool contains(smoab::EntityHandle c) const
+    return this->Cells.find(c) != this->Cells.end();
+  void erase(smoab::Range cells)
+    //seems that erase() has a bug, so use subtract
+    this->Cells = smoab::subtract(this->Cells,cells);
+private:
+  smoab::EntityHandle Entity;
+  smoab::Range Cells;
+//CellSets are just a vector of CellSets
+typedef std::vector<CellSet> CellSets;
+//templated so it works with FaceCellSets and CellSets
+template<typename T>
+smoab::Range getParents(const T& set)
+  typedef typename T::const_iterator iterator;
+  smoab::Range result;
+  for(iterator i=set.begin(); i != set.end(); ++i)
+    result.insert(i->entity());
+  return result;
+smoab::Range getAllCells(const T& set)
+    smoab::Range c = i->cells();
+    result.insert(c.begin(),c.end());
+  return result;
+#endif
diff --git a/tools/vtkMOABReaderNew/CellTypeToType.h b/tools/vtkMOABReaderNew/CellTypeToType.h
deleted file mode 100644
index 6ff91af..0000000
--- a/tools/vtkMOABReaderNew/CellTypeToType.h
+++ /dev/null
@@ -1,59 +0,0 @@
-#ifndef __smoab_CellTypeToType_h
-#define __smoab_CellTypeToType_h
-#include "SimpleMoab.h"
-#include "vtkCellType.h"
-namespace smoab
-template<int> struct CellTypeToType;
-int vtkCellType(moab::EntityType t, int &num_connect)
-  int ctype = -1;
-  switch (t)
-    case moab::MBEDGE:
-      if (num_connect == 2) ctype = VTK_LINE;
-      else if (num_connect == 3) ctype = VTK_QUADRATIC_EDGE;
-      break;
-    case moab::MBTRI:
-      if (num_connect == 3) ctype = VTK_TRIANGLE;
-      else if (num_connect == 6) ctype = VTK_QUADRATIC_TRIANGLE;
-      else if (num_connect == 7) ctype = VTK_BIQUADRATIC_TRIANGLE;
-      break;
-    case moab::MBQUAD:
-      if (num_connect == 4) ctype = VTK_QUAD;
-      else if (num_connect == 8) ctype = VTK_QUADRATIC_QUAD;
-      else if (num_connect == 9) ctype = VTK_BIQUADRATIC_QUAD;
-      break;
-    case moab::MBPOLYGON:
-      if (num_connect == 4) ctype = VTK_POLYGON;
-      break;
-    case moab::MBTET:
-      if (num_connect == 4) ctype = VTK_TETRA;
-      else if (num_connect == 10) ctype = VTK_QUADRATIC_TETRA;
-      break;
-    case moab::MBPYRAMID:
-      if (num_connect == 5) ctype = VTK_PYRAMID;
-      else if (num_connect == 13) ctype = VTK_QUADRATIC_PYRAMID;
-      break;
-    case moab::MBPRISM:
-      if (num_connect == 6) ctype = VTK_WEDGE;
-      else if (num_connect == 15) ctype = VTK_QUADRATIC_WEDGE;
-      break;
-    case moab::MBHEX:
-      if (num_connect == 8) ctype = VTK_HEXAHEDRON;
-      else if (num_connect == 20) ctype = VTK_QUADRATIC_HEXAHEDRON;
-      else if (num_connect == 21) ctype = VTK_QUADRATIC_HEXAHEDRON, num_connect = 20;
-      else if (num_connect == 27) ctype = VTK_TRIQUADRATIC_HEXAHEDRON;
-      break;
-    default:
-      ctype = -1;
-      break;
-  return ctype;
-#endif // CELLTYPETOTYPE_H
diff --git a/tools/vtkMOABReaderNew/DataSetConverter.h b/tools/vtkMOABReaderNew/DataSetConverter.h
index bfae086..3edadf0 100644
--- a/tools/vtkMOABReaderNew/DataSetConverter.h
+++ b/tools/vtkMOABReaderNew/DataSetConverter.h
@@ -2,20 +2,16 @@
 #define __smoab_DataSetConverter_h
-#include "CellTypeToType.h"
-#include "MixedCellConnectivity.h"
+#include "CellSets.h"
+#include "detail/LoadGeometry.h"
+#include "detail/ReadSparseTag.h"
-#include <vtkCellArray.h>
 #include <vtkCellData.h>
 #include <vtkDoubleArray.h>
 #include <vtkFieldData.h>
 #include <vtkIntArray.h>
 #include <vtkIdTypeArray.h>
 #include <vtkNew.h>
-#include <vtkPointData.h>
-#include <vtkPoints.h>
-#include <vtkUnsignedCharArray.h>
-#include <vtkUnstructuredGrid.h>
 #include <algorithm>
@@ -35,17 +31,13 @@ public:
     Moab(interface.Moab),
     Tag(tag),
     ReadMaterialIds(false),
-    ReadProperties(false),
-    MaterialName("Material")
+    ReadProperties(false)
   void readMaterialIds(bool add) { this->ReadMaterialIds = add; }
   bool readMaterialIds() const { return this->ReadMaterialIds; }
-  void materialIdName(const std::string& name) { this->MaterialName = name; }
-  const std::string& materialIdName() const { return this->MaterialName; }
   void readProperties(bool readProps) { this->ReadProperties = readProps; }
   bool readProperties() const { return this->ReadProperties; }
@@ -54,109 +46,65 @@ public:
   //grid. Currently doesn't support reading properties.
   //Will read in material ids,  if no material id is assigned to an entity,
   //its cells will be given an unique id
+  template<typename VTKGridType>
   bool fill(const smoab::Range& entities,
-            vtkUnstructuredGrid* grid) const
+            VTKGridType* grid) const
     //create a helper datastructure which can determines all the unique point ids
     //and converts moab connecitvity info to vtk connectivity
-    moab::Range cells;
-    //append all the entities cells together into a single range
+    //get all the cells for each parent entity and create
+    // an entity set of those items
+    int dim = this->Tag->value();
     typedef smoab::Range::const_iterator iterator;
+    smoab::CellSets entitySets;
     for(iterator i=entities.begin(); i!= entities.end(); ++i)
+      smoab::Range entitiesCells;
       if(this->Tag->isComparable())
         //if we are comparable only find the cells that match our tags dimension
-        smoab::Range entitiesCells = this->Interface.findEntitiesWithDimension(*i,Tag->value());
-        cells.insert(entitiesCells.begin(),entitiesCells.end());
+        entitiesCells = this->Interface.findEntitiesWithDimension(*i,dim,true);
       else
-        //this is a bad representation of all other tags, but we are presuming that
-        //neuman and dirichlet are on entitysets with no children
-        this->Moab->get_entities_by_handle(*i,cells);
+        entitiesCells = this->Interface.findHighestDimensionEntities(*i,true);
+      smoab::CellSet set(*i,entitiesCells);
+      entitySets.push_back(set);
-    smoab::Range points;
-    this->loadCellsAndPoints(cells,points,grid);
-    if(this->readMaterialIds())
-      typedef std::vector<smoab::EntityHandle>::const_iterator EntityHandleIterator;
-      typedef std::vector<int>::const_iterator IdConstIterator;
-      typedef std::vector<int>::iterator IdIterator;
-      std::vector<smoab::EntityHandle> searchableCells;
-      searchableCells.reserve(grid->GetNumberOfCells());
-      std::copy(cells.begin(),cells.end(),std::back_inserter(searchableCells));
-      cells.clear(); //release memory we don't need
+    moab::Range cells = smoab::getAllCells(entitySets);
-      std::vector<int> materialIds(entities.size());
-      //first off iterate the entities and determine which ones
-      //have moab material ids
+    //convert the datastructure from a list of cells to a vtk data set
+    detail::LoadGeometry loadGeom(cells,dim,this->Interface);
+    loadGeom.fill(grid);
-        //wrap this area with scope, to remove local variables
+    if(this->readMaterialIds())
-        smoab::MaterialTag tag;
-        IdIterator materialIndex = materialIds.begin();
-        for(iterator i=entities.begin();
-            i != entities.end();
-            ++i, ++materialIndex)
-          moab::Tag mtag = this->Interface.getMoabTag(tag);
-          int value=-1;
-          this->Moab->tag_get_data(mtag,&(*i),1,&value);
-          *materialIndex=static_cast<int>(value);
-        //now determine ids for all entities that don't have materials
-        IdConstIterator maxPos = std::max_element(materialIds.begin(),
-                                                 materialIds.end());
-        int maxMaterial = *maxPos;
-        for(IdIterator i=materialIds.begin(); i!= materialIds.end(); ++i)
-          if(*i==-1)
-            *i = ++maxMaterial;
-      //now we create the material field, and set all the values
-      vtkNew<vtkIntArray> materialSet;
-      materialSet->SetName(this->materialIdName().c_str());
-      materialSet->SetNumberOfValues(grid->GetNumberOfCells());
+      detail::ReadSparseTag materialTagReading(entitySets,
+                                               cells,
+                                               this->Interface);
-      IdConstIterator materialValue = materialIds.begin();
-      for(iterator i=entities.begin(); i!= entities.end(); ++i, ++materialValue)
-        //this is a time vs memory trade off, I don't want to store
-        //the all the cell ids twice over, lets use more time
-        smoab::Range entitiesCells;
-        if(this->Tag->isComparable())
-          {entitiesCells = this->Interface.findEntitiesWithDimension(*i,Tag->value());}
-        else
-          {this->Moab->get_entities_by_handle(*i,entitiesCells);}
-        EntityHandleIterator s_begin = searchableCells.begin();
-        EntityHandleIterator s_end = searchableCells.end();
-        for(iterator j=entitiesCells.begin(); j != entitiesCells.end();++j)
-          EntityHandleIterator result = std::lower_bound(s_begin,
-                                                         s_end,
-                                                         *j);
-          std::size_t newId = std::distance(s_begin,result);
-          materialSet->SetValue(static_cast<int>(newId), *materialValue);
+      smoab::MaterialTag mtag;
+      vtkNew<vtkIntArray> materials;
+      materials->SetName(mtag.name());
+      materialTagReading.fill(materials.GetPointer(),&mtag);
+      grid->GetCellData()->AddArray(materials.GetPointer());
-      grid->GetCellData()->AddArray(materialSet.GetPointer());
+    //by default we always try to load the default tag
+    detail::ReadSparseTag sTagReading(entitySets,
+                                      cells,
+                                      this->Interface);
+    vtkNew<vtkIntArray> sparseTagData;
+    sparseTagData->SetName(this->Tag->name());
+    sTagReading.fill(sparseTagData.GetPointer(),this->Tag);
+    grid->GetCellData()->AddArray(sparseTagData.GetPointer());
     return true;
@@ -165,28 +113,32 @@ public:
   //given a single entity handle create a unstructured grid from it.
   //optional third parameter is the material id to use if readMaterialIds
   //is on, and no material sparse tag is found for this entity
   bool fill(const smoab::EntityHandle& entity,
-            vtkUnstructuredGrid* grid,
+            VTKGridType* grid,
             const int materialId=0) const
+    smoab::Range cells;
-      cells = this->Interface.findEntitiesWithDimension(entity,Tag->value());
+      cells = this->Interface.findEntitiesWithDimension(entity,dim,true);
     else
-      this->Moab->get_entities_by_handle(entity,cells);
+      //load subentities
+      cells = this->Interface.findHighestDimensionEntities(entity,true);
+    const smoab::Range& points = loadGeom.moabPoints();
     if(this->readProperties())
@@ -194,53 +146,34 @@ public:
       this->readProperties(points,grid->GetPointData());
+    smoab::CellSets cellSets;
+    smoab::CellSet set(entity,cells);
+    cellSets.push_back(set);
-      this->readSparseTag(smoab::MaterialTag(),entity,
-                          grid->GetNumberOfCells(),
-                          grid->GetCellData(),
-                          materialId);
-    return true;
+      detail::ReadSparseTag materialTagReading(cellSets,
+                                               cells,
+                                               this->Interface);
-  void loadCellsAndPoints(const smoab::Range& cells,
-                          smoab::Range& points,
-    smoab::MixedCellConnectivity mixConn(cells,this->Moab);
-    //now that mixConn has all the cells properly stored, lets fixup
-    //the ids so that they start at zero and keep the same logical ordering
-    //as before.
-    vtkIdType numCells, connLen;
-    mixConn.compactIds(numCells,connLen);
-    this->setGridsTopology(mixConn,grid,numCells,connLen);
-    mixConn.moabPoints(points);
+    detail::ReadSparseTag sTagReading(cellSets,
+                                      cells,
+                                      this->Interface);
-    vtkNew<vtkPoints> newPoints;
-    this->addCoordinates(points,newPoints.GetPointer());
-    grid->SetPoints(newPoints.GetPointer());
-  void addCoordinates(smoab::Range pointEntities, vtkPoints* pointContainer) const
-    //since the smoab::range are always unique and sorted
-    //we can use the more efficient coords_iterate
-    //call in moab, which returns moab internal allocated memory
-    pointContainer->SetDataTypeToDouble();
-    pointContainer->SetNumberOfPoints(pointEntities.size());
-    //need a pointer to the allocated vtkPoints memory so that we
-    //don't need to use an extra copy and we can bypass all vtk's check
-    //on out of bounds
-    double *rawPoints = static_cast<double*>(pointContainer->GetVoidPointer(0));
-    this->Moab->get_coords(pointEntities,rawPoints);
+    return true;
 private:
@@ -260,36 +193,6 @@ private:
-  bool readSparseTag(smoab::Tag tag,
-                      smoab::EntityHandle const& entity,
-                      vtkIdType length,
-                      vtkFieldData* field,
-                      vtkIdType defaultValue) const
-    typedef std::vector<moab::Tag>::const_iterator iterator;
-    int value=0;
-    moab::ErrorCode rval = this->Moab->tag_get_data(mtag,&entity,1,&value);
-    if(rval!=moab::MB_SUCCESS)
-      value = defaultValue;
-    materialSet->SetNumberOfValues(length);
-    int *raw = static_cast<int*>(materialSet->GetVoidPointer(0));
-    std::fill(raw,raw+length,value);
-    field->AddArray(materialSet.GetPointer());
-    return true;
   void readDenseTags(std::vector<moab::Tag> &tags,
                      smoab::Range const& entities,
                      vtkFieldData* field) const
@@ -359,36 +262,7 @@ private:
-  void setGridsTopology(smoab::MixedCellConnectivity const& mixedCells,
-                vtkIdType numConnectivity) const
-    //correct the connectivity size to account for the vtk padding
-    const vtkIdType vtkConnectivity = numCells + numConnectivity;
-    vtkNew<vtkIdTypeArray> cellArray;
-    vtkNew<vtkIdTypeArray> cellLocations;
-    vtkNew<vtkUnsignedCharArray> cellTypes;
-    cellArray->SetNumberOfValues(vtkConnectivity);
-    cellLocations->SetNumberOfValues(numCells);
-    cellTypes->SetNumberOfValues(numCells);
-    vtkIdType* rawArray = static_cast<vtkIdType*>(cellArray->GetVoidPointer(0));
-    vtkIdType* rawLocations = static_cast<vtkIdType*>(cellLocations->GetVoidPointer(0));
-    unsigned char* rawTypes = static_cast<unsigned char*>(cellTypes->GetVoidPointer(0));
-    mixedCells.copyToVtkCellInfo(rawArray,rawLocations,rawTypes);
-    vtkNew<vtkCellArray> cells;
-    cells->SetCells(numCells,cellArray.GetPointer());
-    grid->SetCells(cellTypes.GetPointer(),
-                   cellLocations.GetPointer(),
-                   cells.GetPointer(),
-                   NULL,NULL);
diff --git a/tools/vtkMOABReaderNew/ExtractShell.h b/tools/vtkMOABReaderNew/ExtractShell.h
index 0000000..359fbce
--- /dev/null
+++ b/tools/vtkMOABReaderNew/ExtractShell.h
@@ -0,0 +1,80 @@
+#ifndef __smoab_ExtractShell_h
+#define __smoab_ExtractShell_h
+#include "detail/UsageTable.h"
+#include <algorithm>
+namespace smoab{
+class ExtractShell
+  const smoab::Interface& Interface;
+  smoab::CellSets VCells;
+public:
+  ExtractShell(const smoab::CellSets volCells,
+               const smoab::Interface& interface):
+    Interface(interface),
+    VCells(volCells)
+  bool findSkins(smoab::CellSets &surfaceCellSets);
+bool ExtractShell::findSkins(smoab::CellSets &surfaceCellSets)
+  typedef smoab::Range::const_iterator Iterator;
+  typedef smoab::CellSets::const_iterator SetIterator;
+  smoab::Range cellsToRemove;
+  for(SetIterator set = this->VCells.begin();
+      set != this->VCells.end();
+      ++set)
+    const smoab::Range &cells = set->cells();
+    this->Interface.createAdjacencies(set->cells(),2);
+    //we create the usage table for each iteration so that we only
+    //get the shell of each cell set. If we used the table between
+    //sets we would get the shell of the combined sets
+    smoab::detail::UsageTable table;
+    for(Iterator i = cells.begin(); i != cells.end(); ++i)
+      std::vector<smoab::EntityHandle> faceCells =
+                        this->Interface.sideElements(*i,2);
+      //the usage id allows you to label cells when going into the table
+      //so that you can extract multiple shells where each is based on
+      //a single region id.
+      std::vector<int> regionId(1,faceCells.size());
+      table.incrementUsage(faceCells,regionId);
+    smoab::Range surfaceCells = table.singleUsage();
+    //create a new cell set that
+    smoab::CellSet surfaceSet(set->entity(),surfaceCells);
+    surfaceCellSets.push_back(surfaceSet);
+    smoab::Range subsetToRemove = table.multipleUsage();
+    cellsToRemove.insert(subsetToRemove.begin(),subsetToRemove.end());
+  //we will remove all cells that have multiple usages from the moab database
+  //I really don't care if they already existed or not.
+  this->Interface.remove(cellsToRemove);
+  return true;
+#endif // __smoab_ExtractShell_h
diff --git a/tools/vtkMOABReaderNew/FaceSets.h b/tools/vtkMOABReaderNew/FaceSets.h
index 0000000..536f3f9
--- /dev/null
+++ b/tools/vtkMOABReaderNew/FaceSets.h
@@ -0,0 +1,256 @@
+#ifndef __smoab_FaceSets_h
+#define __smoab_FaceSets_h
+#include <set>
+namespace smoab
+class FaceCellSet : public CellSet
+public:
+  FaceCellSet(int id, smoab::EntityHandle p,const smoab::Range& cells):
+    CellSet(p,cells),
+    ID(id)
+  int faceId() const { return ID; }
+  void overrideFaceId(int i) { ID = i; } //USE AT YOUR OWN RISK
+private:
+  int ID;
+typedef std::vector<FaceCellSet> FaceCellSets;
+//class that store the regions that a faces is adjacent too
+struct FacesAdjRegions
+  FacesAdjRegions(int f, smoab::EntityHandle r0, smoab::EntityHandle r1):
+    FaceId(f),
+    Region0(r0),
+    Region1(r1)
+    if (r0 > r1)
+      std::swap(this->Region0,this->Region1);
+  FacesAdjRegions(int f):
+    FaceId(f),
+    Region0(-3),
+    Region1(-2)
+  bool operator<(const FacesAdjRegions& other) const
+    return (this->FaceId < other.FaceId);
+  smoab::EntityHandle otherId(smoab::EntityHandle other) const
+    if(other == Region0)
+      return Region1;
+    return Region0;
+  int FaceId;
+  smoab::EntityHandle Region0;
+  smoab::EntityHandle Region1;
+smoab::FaceCellSets findFaceSets(smoab::CellSets shells,
+                                 smoab::CellSets boundaries,
+                                 std::set<smoab::FacesAdjRegions>& faceMaps)
+  typedef smoab::CellSets::iterator iterator;
+  typedef smoab::FaceCellSets::iterator faceIterator;
+  typedef std::set<smoab::FacesAdjRegions>::const_iterator FaceAdjIterator;
+  //we need to properly label each unique face in shells
+  //we do this by intersecting each shell with each other shell
+  //to find shell on shell contact, and than we intersect each
+  //resulting shell with the boundary conditions
+  //the end result of these intersections will be the new modelfaces
+  int faceId = 1;
+  smoab::FaceCellSets shellFaces;
+  //first intersect each shell with each other shell
+  std::set<smoab::FacesAdjRegions> shellFaceContacts;
+  for(iterator i=shells.begin();i!= shells.end();++i)
+    //copy the cells so we can add a face that represents
+    //all the cells of the region that aren't shared with another region
+    int numCells = i->cells().size(); //size() on range is slow, so cache it
+    for(iterator j = i+1;
+        j != shells.end() && numCells > 0;
+        ++j)
+      //intersect i and j to make a new face
+      smoab::Range intersection = smoab::intersect(i->cells(),j->cells());
+      if(!intersection.empty())
+        //don't want to increment faceId when the intersection is empty
+        smoab::FaceCellSet face(faceId++,i->entity(),intersection);
+        shellFaces.push_back(face);
+        i->erase(intersection);
+        j->erase(intersection);
+        numCells -= intersection.size();
+        //add this to the face map
+        smoab::FacesAdjRegions faceInfo(faceId-1,i->entity(),j->entity());
+        shellFaceContacts.insert(faceInfo);
+    //if all the cells for shell i are used, don't add a new
+    //empty face
+    if(numCells > 0)
+      smoab::FaceCellSet face(faceId++,i->entity(),i->cells());
+      smoab::FacesAdjRegions faceInfo(faceId-1,-1,i->entity());
+  //now we have all the faces that match shell on shell contact
+  //we know process all the new faces to see if they intersect
+  //with any boundary sets. A boundary set can span multiple
+  //shells so we want to process it as a second loop
+  //store the end before we start adding boundary faces, which
+  //we don't need to check agianst other boundaries
+  faceId = 1; //reset the faced id
+  //store in a new face set, expanding the current one causes incorrect results
+  smoab::FaceCellSets faces;
+  for(faceIterator i=shellFaces.begin();i != shellFaces.end();++i)
+    //determine from the shell faces if the new face we are creating
+    //is bounded by two regions or just one
+    smoab::FacesAdjRegions idToSearchFor(i->faceId());
+    FaceAdjIterator adjRegions = shellFaceContacts.find(idToSearchFor);
+    smoab::EntityHandle otherRegionId = adjRegions->otherId(i->entity());
+    for(iterator j=boundaries.begin();j != boundaries.end(); ++j)
+      smoab::Range intersect = smoab::intersect(i->cells(),j->cells());
+      if(!intersect.empty())
+          smoab::FaceCellSet face(faceId++,j->entity(),intersect);
+          faces.push_back(face);
+          i->erase(intersect);
+          numCells -= intersect.size();
+          smoab::FacesAdjRegions faceInfo(faceId-1,i->entity(),otherRegionId);
+          faceMaps.insert(faceInfo);
+    if(numCells > 0)
+  return faces;
+std::vector<T> faceIdsPerCell(const smoab::FaceCellSets& faces)
+  typedef smoab::FaceCellSets::const_iterator iterator;
+  typedef std::vector<smoab::EntityHandle>::const_iterator EntityHandleIterator;
+  typedef smoab::Range::const_iterator RangeIterator;
+  //find all the cells that are in the faceCellSet, and than map
+  //the proper face id to that relative position, here comes lower_bounds!
+  std::vector<smoab::EntityHandle> searchableCells;
+  smoab::Range faceRange = smoab::getAllCells(faces);
+  smoab::RangeToVector(faceRange,searchableCells);
+  //faceIds will be the resulting array
+  std::vector<T> faceIds(searchableCells.size());
+  //construct the start and end iterators for the lower bounds call
+  EntityHandleIterator s_begin = searchableCells.begin();
+  EntityHandleIterator s_end = searchableCells.end();
+  //search the face cell sets
+  for(iterator i=faces.begin(); i!=faces.end(); ++i)
+    T value = static_cast<T>(i->faceId());
+    const smoab::Range& entitiesCells = i->cells();
+    for(RangeIterator j=entitiesCells.begin(); j != entitiesCells.end();++j)
+      EntityHandleIterator result = std::lower_bound(s_begin,
+                                                     s_end,
+                                                     *j);
+      std::size_t newId = std::distance(s_begin,result);
+      faceIds[newId] = value;
+  return faceIds;
+//given a face adjacency, determine the regions spare tag values
+std::pair<T,T> FaceAdjRegionValues(const smoab::FacesAdjRegions& faceAdj,
+                                   smoab::Tag* t,
+  std::pair<T,T> returnValue;
+  const int defaultValue = interface.getDefaultTagVaue<int>(*t);
+   *  IF A REGION IS SET TO -1 WE NEED TO PUSH THAT VALUE DOWN
+   *  AS THE MATERIAL, SINCE THE MOAB DEFAULT TAG VALUE WILL
+   *  BE CONSIDIERED A REGION, AND WE WANT TO SAY IT BOUNDS THE
+   *  VOID REGION
+  int tagValue = defaultValue; //use tagValue to pass in default value
+  if(faceAdj.Region0 != -1)
+    tagValue = interface.getTagData(*t,faceAdj.Region0,tagValue);
+  else
+    tagValue = -1;
+  //set the first region tag value into the pair we are returing
+  returnValue.first = static_cast<T>(tagValue);
+  tagValue = defaultValue; //use tagValue to pass in default value
+  tagValue = interface.getTagData(*t,faceAdj.Region1,tagValue);
+  if(faceAdj.Region1 != -1)
+  else
+    tagValue = -1;
+ returnValue.second = static_cast<T>(tagValue);
+  return returnValue;
+ } //smoab
+#endif
diff --git a/tools/vtkMOABReaderNew/MixedCellConnectivity.h b/tools/vtkMOABReaderNew/MixedCellConnectivity.h
index 1b26d0f..0000000
--- a/tools/vtkMOABReaderNew/MixedCellConnectivity.h
+++ /dev/null
@@ -1,271 +0,0 @@
-#ifndef __smoab_MixedCellConnectivity_h
-#define __smoab_MixedCellConnectivity_h
-#include <algorithm>
-namespace
-template<int N> struct QuadratricOrdering{};
-template<> struct QuadratricOrdering<VTK_QUADRATIC_WEDGE>
-  static const int NUM_VERTS = 15;
-  void reorder(vtkIdType* connectivity) const
-    std::swap_ranges(connectivity+9,connectivity+12,connectivity+12);
-template<> struct QuadratricOrdering<VTK_TRIQUADRATIC_HEXAHEDRON>
-  static const int NUM_VERTS = 27;
-    std::swap_ranges(connectivity+12,connectivity+16,connectivity+16);
-    //move 20 to 22
-    //move 22 to 23
-    //move 23 to 20
-    //swap 20 with 22
-    std::swap(connectivity[20],connectivity[23]);
-    //swap 22 with 23
-    std::swap(connectivity[22],connectivity[23]);
-template<typename QuadraticOrdering>
-void FixQuadraticIdOrdering(vtkIdType* connectivity, vtkIdType numCells,
-                            QuadraticOrdering& ordering)
-  //skip the first index that holds the length of the cells
-  //if we skip it once here, and than properly increment it makes the code
-  //far easier
-  connectivity+=1;
-  for(vtkIdType i=0; i < numCells; ++i)
-    ordering.reorder(connectivity);
-    connectivity += ordering.NUM_VERTS + 1;
-namespace smoab
-class MixedCellConnectivity
-public:
-  MixedCellConnectivity(smoab::Range const& cells, moab::Interface* moab):
-    Connectivity(),
-    UniquePoints(),
-    Info()
-    int count = 0;
-    const std::size_t cellSize=cells.size();
-    while(count != cellSize)
-      EntityHandle* connectivity;
-      int numVerts=0, iterationCount=0;
-      //use the highly efficent calls, since we know that are of the same dimension
-      moab->connect_iterate(cells.begin()+count,
-                            cells.end(),
-                            connectivity,
-                            numVerts,
-                            iterationCount);
-      //if we didn't read anything, break!
-      if(iterationCount == 0)
-        break;
-      //identify the cell type that we currently have,
-      //store that along with the connectivity in a temp storage vector
-      const moab::EntityType type = moab->type_from_handle(*cells.begin()+count);
-      //while all these cells are contiously of the same type,
-      //quadric hexs in vtk have 20 points, but moab has 21 so we
-      //need to store this difference
-      int numVTKVerts = numVerts;
-      int vtkCellType = smoab::vtkCellType(type,numVTKVerts);
-      RunLengthInfo info = { vtkCellType, numVerts, (numVerts-numVTKVerts), iterationCount };
-      this->Info.push_back(info);
-      this->Connectivity.push_back(connectivity);
-      count += iterationCount;
-  void compactIds(vtkIdType& numCells, vtkIdType& connectivityLength)
-    //converts all the ids to be ordered starting at zero, and also
-    //keeping the orginal logical ordering. Stores the result of this
-    //operation in the unstrucutred grid that is passed in
-    //lets determine the total length of the connectivity
-    connectivityLength = 0;
-    numCells = 0;
-    for(InfoConstIterator i = this->Info.begin();
-        i != this->Info.end();
-        ++i)
-      connectivityLength += (*i).numCells * (*i).numVerts;
-      numCells += (*i).numCells;
-    this->UniquePoints.reserve(connectivityLength);
-    this->copyConnectivity(this->UniquePoints);
-    std::sort(this->UniquePoints.begin(),this->UniquePoints.end());
-    typedef std::vector<EntityHandle>::iterator EntityIterator;
-    EntityIterator newEnd = std::unique(this->UniquePoints.begin(),
-                                        this->UniquePoints.end());
-    const std::size_t newSize = std::distance(this->UniquePoints.begin(),newEnd);
-    this->UniquePoints.resize(newSize);
-  void moabPoints(smoab::Range& range) const
-    //from the documentation a reverse iterator is the fastest way
-    //to insert into a range.
-    std::copy(this->UniquePoints.rbegin(),
-              this->UniquePoints.rend(),
-              moab::range_inserter(range));
-  //copy the connectivity from the moab held arrays to the user input vector
-  void copyConnectivity(std::vector<EntityHandle>& output) const
-    //walk the info to find the length of each sub connectivity array,
-    //and insert them into the vector, ordering is implied by the order
-    //the connecitivy sub array are added to this class
-    ConnConstIterator c = this->Connectivity.begin();
-        ++i,++c)
-      //remember our Connectivity is a vector of pointers whose
-      //length is held in the info vector.
-      const int numUnusedPoints = (*i).numUnusedVerts;
-      if(numUnusedPoints==0)
-        const int connLength = (*i).numCells * (*i).numVerts;
-        std::copy(*c,*c+connLength,std::back_inserter(output));
-      else
-        //we have cell connectivity that we need to skip,
-        //so we have to manual copy each cells connectivity
-        const int size = (*i).numCells;
-        const int numPoints = (*i).numVerts;
-        for(int i=0; i < size; ++i)
-          std::copy(*c,*c+numPoints,std::back_inserter(output));
-        c+=numPoints + (*i).numUnusedVerts;
-  //copy the information from this contianer to a vtk cell array, and
-  //related lookup information
-  void copyToVtkCellInfo(vtkIdType* cellArray,
-                         vtkIdType* cellLocations,
-                         unsigned char* cellTypes) const
-    vtkIdType currentVtkConnectivityIndex = 0;
-        ++i, ++c)
-      //for this group of the same cell type we need to fill the cellTypes
-      const int numCells = (*i).numCells;
-      const int numVerts = (*i).numVerts;
-      std::fill_n(cellTypes,
-                  numCells,
-                  static_cast<unsigned char>((*i).type));
-      //for each cell in this collection that have the same type
-      //grab the raw array now, so we can properly increment for each vert in each cell
-      EntityHandle* moabConnectivity = *c;
-      for(int j=0;j < numCells; ++j)
-        cellLocations[j]= currentVtkConnectivityIndex;
-        //cell arrays start and end are different, since we
-        //have to account for element that states the length of each cell
-        cellArray[0]=numVerts;
-        for(int k=0; k < numVerts; ++k, ++moabConnectivity )
-          //this is going to be a root of some failures when we start
-          //reading really large datasets under 32bit.
-          //fyi, don't use a range ds for unique points, distance
-          //function is horribly slow they need to override it
-          EntityConstIterator result = std::lower_bound(
-                                         this->UniquePoints.begin(),
-                                         this->UniquePoints.end(),
-                                         *moabConnectivity);
-          std::size_t newId = std::distance(this->UniquePoints.begin(),
-                                            result);
-          cellArray[k+1] = static_cast<vtkIdType>(newId);
-        //skip any extra unused points, which is currnetly only
-        //the extra center point in moab quadratic hex
-        moabConnectivity+=(*i).numUnusedVerts;
-        currentVtkConnectivityIndex += numVerts+1;
-        cellArray += numVerts+1;
-      //For Tri-Quadratic-Hex and Quadratric-Wedge Moab and VTK
-      //Differ on the order of the edge ids. For wedge we need to swap
-      //indices 9,10,11 with 12,13,14 for each cell. For Hex we sawp
-      //12,13,14,15 with 16,17,18,19
-      int vtkCellType = (*i).type;
-      vtkIdType* connectivity = cellArray - (numCells * (numVerts+1));
-      if(vtkCellType == VTK_TRIQUADRATIC_HEXAHEDRON)
-        ::QuadratricOrdering<VTK_TRIQUADRATIC_HEXAHEDRON> newOrdering;
-        ::FixQuadraticIdOrdering(connectivity, numCells, newOrdering);
-      else if(vtkCellType == VTK_QUADRATIC_WEDGE)
-        ::QuadratricOrdering<VTK_QUADRATIC_WEDGE> newOrdering;
-      cellLocations += numCells;
-      cellTypes += numCells;
-private:
-  std::vector<EntityHandle*> Connectivity;
-  std::vector<EntityHandle> UniquePoints;
-  struct RunLengthInfo{ int type; int numVerts; int numUnusedVerts; int numCells; };
-  std::vector<RunLengthInfo> Info;
-  typedef std::vector<EntityHandle>::const_iterator EntityConstIterator;
-  typedef std::vector<EntityHandle*>::const_iterator ConnConstIterator;
-  typedef std::vector<RunLengthInfo>::const_iterator InfoConstIterator;
-#endif // __smoab_MixedCellConnectivity_h
diff --git a/tools/vtkMOABReaderNew/SimpleMoab.h b/tools/vtkMOABReaderNew/SimpleMoab.h
index 8fc54e6..4fb734c 100644
--- a/tools/vtkMOABReaderNew/SimpleMoab.h
+++ b/tools/vtkMOABReaderNew/SimpleMoab.h
@@ -5,6 +5,8 @@
 #include "moab/Core.hpp"
 #include "moab/Interface.hpp"
 #include "moab/Range.hpp"
+#include "moab/CN.hpp"
 #include "MBTagConventions.hpp"
 #include <iostream>
@@ -26,12 +28,6 @@ using moab::intersect;
 using moab::subtract;
 using moab::unite;
-//forward declare this->Moab for Tag
-struct Interface;
-//forward declar the DataSetConverter so it can be a friend of Interface
-class DataSetConverter;
 class Tag
   const std::string Name_;
@@ -66,10 +62,24 @@ public:
   GeomTag(int d):Tag("GEOM_DIMENSION"),dim(d){}
   GeomTag():Tag("GEOM_DIMENSION"), dim(0){}
+  virtual ~GeomTag(){}
   bool isComparable() const { return dim > 0; }
   int value() const { return dim; }
+//forward declare this->Moab for Tag
+struct Interface;
+//forward declare the DataSetConverter so it can be a friend of Interface
+class DataSetConverter;
+//forward declare the LoadGeometry so it can be a friend of Interface
+namespace detail{ class LoadGeometry; }
+namespace detail{ class LoadPoly; }
 //light weight wrapper on a moab this->Moab that exposes only the reduced class
 //that we need
 class Interface
@@ -102,6 +112,37 @@ public:
+  template<typename T>
+  T getDefaultTagVaue(moab::Tag tag) const
+    T defaultValue;
+    this->Moab->tag_get_default_value(tag,&defaultValue);
+    return defaultValue;
+  T getDefaultTagVaue(smoab::Tag tag) const
+    return this->getDefaultTagVaue<T>(getMoabTag(tag));
+  T getTagData(moab::Tag tag, const smoab::EntityHandle& entity, T value) const
+    this->Moab->tag_get_data(tag,&entity,1,&value);
+    return value;
+  T getTagData(smoab::Tag tag, const smoab::EntityHandle& entity, T value = T()) const
+    return this->getTagData(getMoabTag(tag),entity,value);
   //returns the moab name for the given entity handle if it has a sparse Name tag
   std::string name(const smoab::EntityHandle& entity) const
@@ -119,6 +160,19 @@ public:
     return std::string(name);
+  //returns the geometeric dimension of an entity.
+  int dimension(const smoab::EntityHandle& entity) const
+    return this->Moab->dimension_from_handle(entity);
+  smoab::EntityType entityType(const smoab::EntityHandle& entity) const
+    return this->Moab->type_from_handle(entity);
   smoab::EntityHandle getRoot() const { return this->Moab->get_root_set(); }
@@ -133,6 +187,17 @@ public:
+  //given a single entity handle find all items in that mesh set that aren't
+  //them selves entitysets. If recurse is true we also recurse sub entitysets
+  smoab::Range findAllMeshEntities(smoab::EntityHandle const& entity,
+                                   bool recurse=false) const
+    this->Moab->get_entities_by_handle(entity,result,recurse);
+    return result;
   //Find all entities with a given tag. We don't use geom as a tag as that
   //isn't a fast operation. Yes finding the intersection of geom entities and
   //a material / boundary tag will be more work, but it is rarely done currently
@@ -179,60 +244,55 @@ public:
   //Find all entities from a given root of a given dimensionality
   smoab::Range findEntitiesWithDimension(const smoab::EntityHandle root,
-                                         int dimension) const
+                                         const int dimension,
-    this->Moab->get_entities_by_dimension(root,dimension,result);
+    this->Moab->get_entities_by_dimension(root,dimension,result,recurse);
-    smoab::Range children;
-    this->Moab->get_child_meshsets(root,children,0);
-    for(iterator i=children.begin(); i !=children.end();++i)
+    if(recurse)
-      this->Moab->get_entities_by_dimension(*i,dimension,result);
+      smoab::Range children;
+      this->Moab->get_child_meshsets(root,children,0);
+      for(iterator i=children.begin(); i !=children.end();++i)
+        this->Moab->get_entities_by_dimension(*i,dimension,result);
     return result;
-  smoab::Range findAdjacentEntities(const smoab::EntityHandle& entity,
-    const int adjType = static_cast<int>(smoab::INTERSECT);
-    smoab::Range result;
-    const bool create_if_missing = false;
-    this->Moab->get_adjacencies(&entity,
-                                1,
-                                dimension,
-                                create_if_missing,
-                                result,
-                                adjType);
-    return result;
-  smoab::Range findAdjacentEntities(const smoab::Range& range,
-                                    int dimension,
-                                    const smoab::adjacency_type type = smoab::UNION) const
+  smoab::Range findHighestDimensionEntities(const smoab::EntityHandle& entity,
-    //the smoab and moab adjacent intersection enums are in the same order
-    const int adjType = static_cast<int>(type);
-    this->Moab->get_adjacencies(range,dimension,
-                                result,
-                                adjType);
+    //the goal is to load all entities that are not entity sets of this
+    //node, while also subsetting by the highest dimension
-    return result;
+    //lets find the entities of only the highest dimension
+    int num_ents=0;
+    int dim=3;
+    while(num_ents<=0&&dim>0)
+      this->Moab->get_number_entities_by_dimension(entity,dim,num_ents,recurse);
+      --dim;
+    ++dim; //reincrement to correct last decrement
+    if(num_ents > 0)
+      //we have found entities of a given dimension
+      return this->findEntitiesWithDimension(entity,dim,recurse);
+    return smoab::Range();
   //Find all elements in the database that have children and zero parents.
   //this doesn't find
-  smoab::Range findEntityRootParents(smoab::EntityHandle const& root) const
+  smoab::Range findEntityRootParents(const smoab::EntityHandle& root) const
     smoab::Range parents;
@@ -258,7 +318,7 @@ public:
   //finds entities that have zero children and zero parents
-  smoab::Range findDetachedEntities(moab::EntityHandle const& root) const
+  smoab::Range findDetachedEntities(const moab::EntityHandle& root) const
     smoab::Range detached;
@@ -284,7 +344,7 @@ public:
   //find all children of the entity passed in that has multiple parents
-  smoab::Range findEntitiesWithMultipleParents(smoab::EntityHandle const& root)
+  smoab::Range findEntitiesWithMultipleParents(const smoab::EntityHandle& root) const
     smoab::Range multipleParents;
     typedef moab::Range::const_iterator iterator;
@@ -305,8 +365,114 @@ public:
+  //find all entities that are adjacent to a single entity
+  smoab::Range findAdjacencies(const smoab::EntityHandle& entity,
+                               int dimension) const
+    const int adjType = static_cast<int>(smoab::INTERSECT);
+    const bool create_if_missing = false;
+    this->Moab->get_adjacencies(&entity,
+                                1,
+                                dimension,
+                                create_if_missing,
+                                result,
+                                adjType);
+    return result;
+  smoab::Range findAdjacencies(const smoab::Range& range,
+                                    int dimension,
+                                    const smoab::adjacency_type type = smoab::UNION) const
+    //the smoab and moab adjacent intersection enums are in the same order
+    const int adjType = static_cast<int>(type);
+    this->Moab->get_adjacencies(range,dimension,
+                                result,
+                                adjType);
+    return result;
+  //create adjacencies, only works when the dimension requested is lower than
+  //dimension of the range of entities
+  smoab::Range createAdjacencies(const smoab::Range& range,
+                                 int dimension,
+    const bool create_if_missing = true;
+                                result,
+                                adjType);
+    return result;
+  int numChildMeshSets(const smoab::EntityHandle& root) const
+    int numChildren;
+    this->Moab->num_child_meshsets(root,&numChildren);
+    return numChildren;
+  smoab::Range getChildSets(const smoab::EntityHandle& root) const
+    return children;
+  //remove a collection of entities from the database
+  void remove(smoab::Range const& toDelete) const
+    this->Moab->delete_entities(toDelete);
+  //a entityHandle with value zero means no side element was found
+  smoab::EntityHandle sideElement(smoab::EntityHandle const& cell,
+                                  int dim, int side) const
+    smoab::EntityHandle result(0);
+    this->Moab->side_element(cell,dim,side,result);
+    return result;
+  //returns all the existing side elements of a cell, elements that
+  //are zero mean that side element doesn't exist
+  std::vector<smoab::EntityHandle> sideElements(
+                                    smoab::EntityHandle const& cell,
+                                    int dim) const
+    const EntityType volumeCellType = this->Moab->type_from_handle(cell);
+    const int numSides = static_cast<int>(moab::CN::NumSubEntities(
+                                          volumeCellType, dim));
+    std::vector<smoab::EntityHandle> result(numSides);
+    for (int side = 0; side < numSides; ++side)
+      smoab::EntityHandle *sideElem = &result[side]; //get memory of vector
+      this->Moab->side_element(cell,dim,side,*sideElem);
+    return result;
   //prints all elements in a range objects
-  void printRange(smoab::Range const& range)
+  void printRange(const smoab::Range& range) const
     typedef Range::const_iterator iterator;
     for(iterator i=range.begin(); i!=range.end(); ++i)
@@ -315,12 +481,25 @@ public:
       this->Moab->list_entity(*i);
   friend class smoab::DataSetConverter;
+  friend class smoab::detail::LoadGeometry;
+  friend class smoab::detail::LoadPoly;
 private:
   moab::Interface* Moab;
+void RangeToVector(const smoab::Range &range,
+                   std::vector<smoab::EntityHandle>& vector )
+  vector.reserve(range.size());
+  std::copy(range.begin(),
+            range.end(),
+            std::back_inserter(vector));
 #endif
diff --git a/tools/vtkMOABReaderNew/detail/CellTypeToType.h b/tools/vtkMOABReaderNew/detail/CellTypeToType.h
index 0000000..b2955e4
--- /dev/null
+++ b/tools/vtkMOABReaderNew/detail/CellTypeToType.h
@@ -0,0 +1,147 @@
+#ifndef __smoab_detail_CellTypeToType_h
+#define __smoab_detail_CellTypeToType_h
+#include "vtkCellType.h"
+namespace smoab{ namespace detail{
+template<int N> struct QuadratricOrdering{};
+template<> struct QuadratricOrdering<VTK_QUADRATIC_WEDGE>
+  static const int NUM_VERTS = 15;
+  void reorder(vtkIdType* connectivity) const
+    std::swap_ranges(connectivity+9,connectivity+12,connectivity+12);
+template<> struct QuadratricOrdering<VTK_TRIQUADRATIC_HEXAHEDRON>
+  static const int NUM_VERTS = 27;
+    std::swap_ranges(connectivity+12,connectivity+16,connectivity+16);
+    //move 20 to 22
+    //move 22 to 23
+    //move 23 to 20
+    //swap 20 with 22
+    std::swap(connectivity[20],connectivity[23]);
+    //swap 22 with 23
+    std::swap(connectivity[22],connectivity[23]);
+template<typename QuadraticOrdering>
+void FixQuadraticIdOrdering(vtkIdType* connectivity, vtkIdType numCells,
+                            QuadraticOrdering& ordering)
+  //skip the first index that holds the length of the cells
+  //if we skip it once here, and than properly increment it makes the code
+  //far easier
+  connectivity+=1;
+  for(vtkIdType i=0; i < numCells; ++i)
+    ordering.reorder(connectivity);
+    connectivity += ordering.NUM_VERTS + 1;
+int vtkCellType(moab::EntityType t, int &num_connect)
+  int ctype = -1;
+  switch (t)
+    case moab::MBEDGE:
+      if (num_connect == 2) ctype = VTK_LINE;
+      else if (num_connect == 3) ctype = VTK_QUADRATIC_EDGE;
+      break;
+    case moab::MBTRI:
+      if (num_connect == 3) ctype = VTK_TRIANGLE;
+      else if (num_connect == 6) ctype = VTK_QUADRATIC_TRIANGLE;
+      else if (num_connect == 7) ctype = VTK_BIQUADRATIC_TRIANGLE;
+      break;
+    case moab::MBQUAD:
+      if (num_connect == 4) ctype = VTK_QUAD;
+      else if (num_connect == 8) ctype = VTK_QUADRATIC_QUAD;
+      else if (num_connect == 9) ctype = VTK_BIQUADRATIC_QUAD;
+      break;
+    case moab::MBPOLYGON:
+      if (num_connect == 4) ctype = VTK_POLYGON;
+      break;
+    case moab::MBTET:
+      if (num_connect == 4) ctype = VTK_TETRA;
+      else if (num_connect == 10) ctype = VTK_QUADRATIC_TETRA;
+      break;
+    case moab::MBPYRAMID:
+      if (num_connect == 5) ctype = VTK_PYRAMID;
+      else if (num_connect == 13) ctype = VTK_QUADRATIC_PYRAMID;
+      break;
+    case moab::MBPRISM:
+      if (num_connect == 6) ctype = VTK_WEDGE;
+      else if (num_connect == 15) ctype = VTK_QUADRATIC_WEDGE;
+      break;
+    case moab::MBHEX:
+      if (num_connect == 8) ctype = VTK_HEXAHEDRON;
+      else if (num_connect == 20) ctype = VTK_QUADRATIC_HEXAHEDRON;
+      else if (num_connect == 21) ctype = VTK_QUADRATIC_HEXAHEDRON, num_connect = 20;
+      else if (num_connect == 27) ctype = VTK_TRIQUADRATIC_HEXAHEDRON;
+      break;
+    default:
+      ctype = -1;
+      break;
+  return ctype;
+int vtkLinearCellType(moab::EntityType t, int &num_connect)
+  int ctype = -1;
+  switch (t)
+      ctype = VTK_LINE;
+      num_connect = 2;
+      break;
+    case moab::MBTRI:
+      ctype = VTK_TRIANGLE;
+      num_connect = 3;
+      break;
+      ctype = VTK_QUAD;
+      num_connect = 4;
+      break;
+      ctype = VTK_POLYGON;
+      num_connect = 4;
+      break;
+    case moab::MBTET:
+      ctype = VTK_TETRA;
+      num_connect = 4;
+      break;
+      ctype = VTK_PYRAMID;
+      num_connect = 5;
+      break;
+      ctype = VTK_WEDGE;
+      num_connect = 6;
+      break;
+    case moab::MBHEX:
+      ctype = VTK_HEXAHEDRON;
+      num_connect = 8;
+      break;
+    default:
+      break;
+  return ctype;
+} } //namespace smaob::detail
+#endif // CELLTYPETOTYPE_H
diff --git a/tools/vtkMOABReaderNew/detail/ContinousCellInfo.h b/tools/vtkMOABReaderNew/detail/ContinousCellInfo.h
index 0000000..28319df
--- /dev/null
+++ b/tools/vtkMOABReaderNew/detail/ContinousCellInfo.h
@@ -0,0 +1,18 @@
+#ifndef __smoab_detail_ContinousCellInfo_h
+#define __smoab_detail_ContinousCellInfo_h
+namespace smoab { namespace detail {
+struct ContinousCellInfo
+  int type;
+  int numVerts;
+  int numUnusedVerts;
+  int numCells;
+} } //namespace smoab::detail
+#endif
diff --git a/tools/vtkMOABReaderNew/detail/LinearCellConnectivity.h b/tools/vtkMOABReaderNew/detail/LinearCellConnectivity.h
index 0000000..1b94548
--- /dev/null
+++ b/tools/vtkMOABReaderNew/detail/LinearCellConnectivity.h
@@ -0,0 +1,219 @@
+#ifndef __smoab_LinearCellConnectivity_h
+#define __smoab_LinearCellConnectivity_h
+#include "CellTypeToType.h"
+#include "ContinousCellInfo.h"
+#include <vector>
+namespace internal
+  //we want a subset of the real connetivity array,
+  //this does that for use with a super easy wrapper
+  struct SubsetArray
+    SubsetArray(EntityHandle* realConn,
+                int numCells,
+                int currentVertsPerCell,
+                int newVertsPerCell):
+      Array()
+      const int size = numCells*newVertsPerCell;
+      this->Array.reserve(size);
+      if(currentVertsPerCell == newVertsPerCell)
+        std::copy(realConn,realConn+size, std::back_inserter(this->Array));
+      else
+        //skip copy only the first N points which we want
+        //since moab stores linear points first per cell
+        EntityHandle *pos = realConn;
+        for(int i=0; i < numCells;++i)
+          std::copy(pos,pos+newVertsPerCell,std::back_inserter(this->Array));
+          pos += currentVertsPerCell;
+    typedef std::vector<EntityHandle>::const_iterator const_iterator;
+    typedef std::vector<EntityHandle>::iterator iterator;
+    const_iterator begin() const { return this->Array.begin(); }
+    iterator begin() { return this->Array.begin(); }
+    const_iterator end() const { return this->Array.end(); }
+    iterator end(){ return this->Array.end(); }
+  private:
+    std::vector<EntityHandle> Array;
+class LinearCellConnectivity
+public:
+  LinearCellConnectivity(smoab::Range const& cells, moab::Interface* moab):
+    Connectivity(),
+    UniquePoints(),
+    Info()
+    int count = 0;
+    const std::size_t cellSize=cells.size();
+    while(count != cellSize)
+      EntityHandle* connectivity;
+      int numVerts=0, iterationCount=0;
+      //use the highly efficent calls, since we know that are of the same dimension
+      moab->connect_iterate(cells.begin()+count,
+                            cells.end(),
+                            connectivity,
+                            numVerts,
+                            iterationCount);
+      //if we didn't read anything, break!
+      if(iterationCount == 0)
+        break;
+      //identify the cell type that we currently have,
+      //store that along with the connectivity in a temp storage vector
+      const moab::EntityType type = moab->type_from_handle(*cells.begin()+count);
+      int vtkNumVerts;
+      int vtkCellType = smoab::detail::vtkLinearCellType(type,vtkNumVerts);
+      ContinousCellInfo info = { vtkCellType, vtkNumVerts, 0, iterationCount };
+      this->Info.push_back(info);
+      //we need to copy only a subset of the connectivity array
+      internal::SubsetArray conn(connectivity,iterationCount,numVerts,vtkNumVerts);
+      this->Connectivity.push_back(conn);
+      count += iterationCount;
+  void compactIds(vtkIdType& numCells, vtkIdType& connectivityLength)
+    //converts all the ids to be ordered starting at zero, and also
+    //keeping the orginal logical ordering. Stores the result of this
+    //operation in the unstrucutred grid that is passed in
+    //lets determine the total length of the connectivity
+    connectivityLength = 0;
+    numCells = 0;
+    for(InfoConstIterator i = this->Info.begin();
+        i != this->Info.end();
+        ++i)
+      connectivityLength += (*i).numCells * (*i).numVerts;
+      numCells += (*i).numCells;
+    this->UniquePoints.reserve(connectivityLength);
+    this->copyConnectivity(this->UniquePoints);
+    std::sort(this->UniquePoints.begin(),this->UniquePoints.end());
+    typedef std::vector<EntityHandle>::iterator EntityIterator;
+    EntityIterator newEnd = std::unique(this->UniquePoints.begin(),
+                                        this->UniquePoints.end());
+    const std::size_t newSize = std::distance(this->UniquePoints.begin(),newEnd);
+    this->UniquePoints.resize(newSize);
+  void moabPoints(smoab::Range& range) const
+    //from the documentation a reverse iterator is the fastest way
+    //to insert into a range.
+    std::copy(this->UniquePoints.rbegin(),
+              this->UniquePoints.rend(),
+              moab::range_inserter(range));
+  //copy the connectivity from the moab held arrays to the user input vector
+  void copyConnectivity(std::vector<EntityHandle>& output) const
+    //walk the info to find the length of each sub connectivity array,
+    //and insert them into the vector, ordering is implied by the order
+    //the connecitivy sub array are added to this class
+    ConnConstIterator c = this->Connectivity.begin();
+        ++i,++c)
+      //remember our Connectivity is a vector of pointers whose
+      //length is held in the info vector.
+      const int numUnusedPoints = (*i).numUnusedVerts;
+      const int connLength = (*i).numCells * (*i).numVerts;
+      std::copy(c->begin(),c->end(),std::back_inserter(output));
+  //copy the information from this contianer to a vtk cell array, and
+  //related lookup information
+  void copyToVtkCellInfo(vtkIdType* cellArray) const
+        ++i, ++c)
+      //for this group of the same cell type we need to fill the cellTypes
+      const int numCells = (*i).numCells;
+      const int numVerts = (*i).numVerts;
+      //for each cell in this collection that have the same type
+      //grab the raw array now, so we can properly increment for each vert in each cell
+      internal::SubsetArray::const_iterator moabConnectivity = c->begin();
+      for(int j=0;j < numCells; ++j)
+        //cell arrays start and end are different, since we
+        //have to account for element that states the length of each cell
+        cellArray[0]=numVerts;
+        for(int k=0; k < numVerts; ++k, ++moabConnectivity )
+          //this is going to be a root of some failures when we start
+          //reading really large datasets under 32bit.
+          //fyi, don't use a range ds for unique points, distance
+          //function is horribly slow they need to override it
+          EntityConstIterator result = std::lower_bound(
+                                         this->UniquePoints.begin(),
+                                         this->UniquePoints.end(),
+                                         *moabConnectivity);
+          std::size_t newId = std::distance(this->UniquePoints.begin(),
+                                            result);
+          cellArray[k+1] = static_cast<vtkIdType>(newId);
+        cellArray += numVerts+1;
+private:
+  std::vector<internal::SubsetArray> Connectivity;
+  std::vector<EntityHandle> UniquePoints;
+  std::vector<detail::ContinousCellInfo> Info;
+  typedef std::vector<EntityHandle>::const_iterator EntityConstIterator;
+  typedef std::vector<internal::SubsetArray>::const_iterator ConnConstIterator;
+  typedef std::vector<detail::ContinousCellInfo>::const_iterator InfoConstIterator;
+#endif // __smoab_LinearCellConnectivity_h
This diff is so big that we needed to truncate the remainder.
https://bitbucket.org/fathomteam/moab/commits/dcd789d7817e/
Changeset:   dcd789d7817e
Branch:      master
User:        vijaysm
Date:        2014-07-13 00:49:31
Summary:     Merged in judajake/moab/update_vtk_plugin (pull request #23)
Update VTKReader Paraview plugin for MOAB
 set(headers
--- /dev/null
@@ -0,0 +1,75 @@
+namespace smoab
+class CellSet
+public:
+    Entity(p),
+    Cells(cells)
+private:
+  return result;
+  return result;
+#endif
+++ /dev/null
@@ -1,59 +0,0 @@
-namespace smoab
-  int ctype = -1;
-  switch (t)
-      break;
-    case moab::MBTRI:
-      break;
-      break;
-      break;
-    case moab::MBTET:
-      break;
-      break;
-      break;
-    case moab::MBHEX:
-      break;
-    default:
-      ctype = -1;
-      break;
-  return ctype;
@@ -2,20 +2,16 @@
 #include <vtkNew.h>
     Tag(tag),
       else
-          int value=-1;
-          if(*i==-1)
+                                               cells,
+                                               this->Interface);
-        else
-                                                         s_end,
-                                                         *j);
+                                      cells,
+                                      this->Interface);
     return true;
     else
-                          materialId);
-    return true;
+                                               cells,
+                                               this->Interface);
-    //as before.
+                                      cells,
+                                      this->Interface);
+    return true;
 private:
-                      vtkIdType length,
-    int value=0;
-    return true;
-                   NULL,NULL);
--- /dev/null
@@ -0,0 +1,80 @@
+namespace smoab{
+class ExtractShell
+public:
+    VCells(volCells)
+      ++set)
+  return true;
--- /dev/null
@@ -0,0 +1,256 @@
+#include <set>
+namespace smoab
+public:
+    CellSet(p,cells),
+    ID(id)
+private:
+  int ID;
+    FaceId(f),
+    Region0(r0),
+    Region1(r1)
+    if (r0 > r1)
+    FaceId(f),
+    Region0(-3),
+    Region1(-2)
+      return Region1;
+    return Region0;
+  int FaceId;
+  int faceId = 1;
+        ++j)
+    //empty face
+    if(numCells > 0)
+    if(numCells > 0)
+  return faces;
+                                                     s_end,
+                                                     *j);
+  return faceIds;
+                                   smoab::Tag* t,
+   *  VOID REGION
+  else
+    tagValue = -1;
+  else
+    tagValue = -1;
+ } //smoab
+#endif
+++ /dev/null
@@ -1,271 +0,0 @@
-namespace
-    //move 20 to 22
-    //move 22 to 23
-    //move 23 to 20
-    //swap 20 with 22
-    //swap 22 with 23
-  //far easier
-  connectivity+=1;
-namespace smoab
-public:
-    Connectivity(),
-    UniquePoints(),
-    Info()
-    int count = 0;
-                            cells.end(),
-                            connectivity,
-                            numVerts,
-                            iterationCount);
-        break;
-    numCells = 0;
-        ++i)
-        ++i,++c)
-      else
-        ++i, ++c)
-                  numCells,
-                                            result);
-private:
@@ -5,6 +5,8 @@
 #include <iostream>
 using moab::unite;
-struct Interface;
 class Tag
+struct Interface;
 //that we need
 class Interface
+    T defaultValue;
+    return value;
+    return result;
+    if(recurse)
     return result;
-                                1,
-                                dimension,
-                                result,
-                                adjType);
-    return result;
-                                    int dimension,
-                                result,
-                                adjType);
-    return result;
+    int num_ents=0;
+    int dim=3;
+      --dim;
+    if(num_ents > 0)
   //this doesn't find
+                                1,
+                                dimension,
+                                result,
+                                adjType);
+    return result;
+                                    int dimension,
+                                result,
+                                adjType);
+    return result;
+                                 int dimension,
+                                result,
+                                adjType);
+    return result;
+    int numChildren;
+    return children;
+    return result;
+                                    int dim) const
+    return result;
 private:
+            range.end(),
 #endif
--- /dev/null
@@ -0,0 +1,147 @@
+    //move 20 to 22
+    //move 22 to 23
+    //move 23 to 20
+    //swap 20 with 22
+    //swap 22 with 23
+  //far easier
+  connectivity+=1;
+  int ctype = -1;
+  switch (t)
+      break;
+    case moab::MBTRI:
+      break;
+      break;
+      break;
+    case moab::MBTET:
+      break;
+      break;
+      break;
+    case moab::MBHEX:
+      break;
+    default:
+      ctype = -1;
+      break;
+  return ctype;
+  int ctype = -1;
+  switch (t)
+      ctype = VTK_LINE;
+      num_connect = 2;
+      break;
+    case moab::MBTRI:
+      num_connect = 3;
+      break;
+      ctype = VTK_QUAD;
+      num_connect = 4;
+      break;
+      num_connect = 4;
+      break;
+    case moab::MBTET:
+      num_connect = 4;
+      break;
+      num_connect = 5;
+      break;
+      num_connect = 6;
+      break;
+    case moab::MBHEX:
+      num_connect = 8;
+      break;
+    default:
+      break;
+  return ctype;
--- /dev/null
@@ -0,0 +1,18 @@
+  int type;
+  int numVerts;
+  int numCells;
+#endif
--- /dev/null
@@ -0,0 +1,219 @@
+#include <vector>
+namespace internal
+                int numCells,
+      Array()
+      else
+  private:
+public:
+    Connectivity(),
+    UniquePoints(),
+    Info()
+    int count = 0;
+                            cells.end(),
+                            connectivity,
+                            numVerts,
+                            iterationCount);
+        break;
+      int vtkNumVerts;
+    numCells = 0;
+        ++i)
+        ++i,++c)
+        ++i, ++c)
+                                            result);
+private:
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
