[MOAB-dev] commit/MOAB: iulian07: few comments on using intx_imesh
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Mon Jan 6 15:44:13 CST 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/865fccf72dad/
Changeset:   865fccf72dad
Branch:      master
User:        iulian07
Date:        2014-01-06 22:43:21
Summary:     few comments on using intx_imesh
Affected #:  1 file
diff --git a/tools/mbcslam/README b/tools/mbcslam/README
new file mode 100644
index 0000000..3501d1c
--- /dev/null
+++ b/tools/mbcslam/README
@@ -0,0 +1,26 @@
+module for intersection + transport methods in moab
+contains several utilities and "make check" tests
+the core is the intersection class, Intx2Mesh, with 2 derived
+classes, Intx2MeshInPlane and Intx2MeshOnSphere
+it takes 2 mesh sets that overlap in plane or on a sphere, and
+creates an output set with convex polygons. Each convex polygon
+in the output set has 2 parents, each parent in one of the input sets
+"convex" is understood either on a gnomonic plane of a
+sphere or in a plane
+the input files can be visualized in visit or paraview, and for that we prefer
+conversion to vtk, if needed.
+True writing/reading works in parallel only with hdf5 format
+example for advection:
+create_dp  ~/source/MOABsource/MeshFiles/unittest/mpas_p8.h5m HN16DP.h5m -t 0.1 -dt 0.05
+then
+intx_imesh
+mbconvert out.h5m out.vtk
+compare the TracerAverage plot on HN16DP.h5m with the plot on out.vtk
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
