[MOAB-dev] moab compilation errors with recent nek version
    Tim Tautges
    timothy.tautges at cd-adapco.com
    Thu Jul 10 11:07:58 CDT 2014
Vijay,
   This is due to MOAB's include file in nek having an 'implicit none' statement, then including a Nek include file
which uses an implicitly typed variable (common/IOFLAG/nio).  I think in that same moab include file in nek, there are
type statements for all the implicitly-typed nek variables, and nio needs to be added to that.
Or, Nek could forego all that extra debugging it has to do by stopping its use of implicit typing (sorry, but it's true).
- tim
On 07/10/2014 10:54 AM, Vijay S. Mahadevan wrote:
> Prasad, I don't see any MOAB related compilation errors here. Are you
> sure the problem setup (SIZE) is correct ? I haven't seen any problems
> with NEK+MOAB on blues before.
> If you can send the entire make.log, we can help you find the actual
> cause. For problem setup related queries, please contact the NEK list.
> Vijay
> On Thu, Jul 10, 2014 at 10:38 AM, Vegendla, Surya Narayana Prasad
> <svegendla at anl.gov> wrote:
>> Hi all,
>> I seen the following error messages while compiling moab_conjht on
>> blues/mira with recent nek version.
>> Here I am posting error messages, let me know how to avoid these compilation
>> problems.
>> Thanks,
>> Prasad
>> mpif77 -f77=ifort -c  -O2 -r8 -fpconstant -fpp -DMOAB -DPTRSIZE8 -DMPI
>> -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG
>> -I/home/svegendla/nekFiles/moab_conjht -I/home/svegendla/nek5_svn/trunk/nek
>> -I./ -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map
>> -DHAVE_UNORDERED_SET=tr1/unordered_set
>> -I/soft/netcdf/4.0.1-intel-11-serial/include
>> -I/home/jain/lib/hdf5-1.8.7//include -isystem
>> /home/jain/lib/hdf5-1.8.7//include  -DTEMPLATE_SPECIALIZATION
>> -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64
>> -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DCGM
>> -I/home/jain/install/opt_moab//include
>> /home/svegendla/nek5_svn/trunk/nek/3rd_party/moab.f -o obj/moab.o
>> mpicc -cc=icc -c  -O2 -DMOAB -DPTRSIZE8 -DMPI -DLONGINT8 -DUNDERSCORE
>> -DGLOBAL_LONG_LONG  -DPREFIX=jl_
>> /home/svegendla/nek5_svn/trunk/nek/jl/comm.c -o obj/jl_comm.o
>> /home/svegendla/nek5_svn/trunk/nek/jl/tensor.c -o obj/jl_tensor.o
>> /home/svegendla/nek5_svn/trunk/nek/jl/fail.c -o obj/jl_fail.o
>> /home/svegendla/nek5_svn/trunk/nek/jl/fail.c(18): warning #1628: function
>> declared with "noreturn" does return
>> /home/svegendla/nek5_svn/trunk/nek/jl/fcrystal.c -o obj/jl_fcrystal.o
>> /home/svegendla/nek5_svn/trunk/nek/jl/findpts.c -o obj/jl_findpts.o
>> ./SIZE(126): error #6404: This name does not have a type, and must have an
>> explicit type.   [NIO]
>>        common/IOFLAG/nio  ! for logfile verbosity control
>> /home/svegendla/nek5_svn/trunk/nek/jl/findpts_local.c -o
>> obj/jl_findpts_local.o
>> /home/svegendla/nek5_svn/trunk/nek/jl/obbox.c -o obj/jl_obbox.o
>> /tmp/ifortnacSYu.i(21993): catastrophic error: Too many errors, exiting
>> compilation aborted for /home/svegendla/nek5_svn/trunk/nek/3rd_party/moab.f
>> (code 1)
>> make: *** [obj/moab.o] Error 1
>> make: *** Waiting for unfinished jobs....
Timothy J. Tautges
Manager, Directed Meshing, CD-adapco
Phone: 608-354-1459
