[MOAB-dev] moab compilation errors with recent nek version
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Thu Jul 10 10:54:33 CDT 2014
Prasad, I don't see any MOAB related compilation errors here. Are you
sure the problem setup (SIZE) is correct ? I haven't seen any problems
with NEK+MOAB on blues before.
If you can send the entire make.log, we can help you find the actual
cause. For problem setup related queries, please contact the NEK list.
Vijay
On Thu, Jul 10, 2014 at 10:38 AM, Vegendla, Surya Narayana Prasad
<svegendla at anl.gov> wrote:
> Hi all,
> I seen the following error messages while compiling moab_conjht on
> blues/mira with recent nek version.
> Here I am posting error messages, let me know how to avoid these compilation
> problems.
> Thanks,
> Prasad
> mpif77 -f77=ifort -c  -O2 -r8 -fpconstant -fpp -DMOAB -DPTRSIZE8 -DMPI
> -DLONGINT8 -DUNDERSCORE -DGLOBAL_LONG_LONG
> -I/home/svegendla/nekFiles/moab_conjht -I/home/svegendla/nek5_svn/trunk/nek
> -I./ -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map
> -DHAVE_UNORDERED_SET=tr1/unordered_set
> -I/soft/netcdf/4.0.1-intel-11-serial/include
> -I/home/jain/lib/hdf5-1.8.7//include -isystem
> /home/jain/lib/hdf5-1.8.7//include  -DTEMPLATE_SPECIALIZATION
> -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64
> -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DCGM
> -I/home/jain/install/opt_moab//include
> /home/svegendla/nek5_svn/trunk/nek/3rd_party/moab.f -o obj/moab.o
> mpicc -cc=icc -c  -O2 -DMOAB -DPTRSIZE8 -DMPI -DLONGINT8 -DUNDERSCORE
> -DGLOBAL_LONG_LONG  -DPREFIX=jl_
> /home/svegendla/nek5_svn/trunk/nek/jl/comm.c -o obj/jl_comm.o
> /home/svegendla/nek5_svn/trunk/nek/jl/tensor.c -o obj/jl_tensor.o
> /home/svegendla/nek5_svn/trunk/nek/jl/fail.c -o obj/jl_fail.o
> /home/svegendla/nek5_svn/trunk/nek/jl/fail.c(18): warning #1628: function
> declared with "noreturn" does return
> /home/svegendla/nek5_svn/trunk/nek/jl/fcrystal.c -o obj/jl_fcrystal.o
> /home/svegendla/nek5_svn/trunk/nek/jl/findpts.c -o obj/jl_findpts.o
> ./SIZE(126): error #6404: This name does not have a type, and must have an
> explicit type.   [NIO]
>       common/IOFLAG/nio  ! for logfile verbosity control
> /home/svegendla/nek5_svn/trunk/nek/jl/findpts_local.c -o
> obj/jl_findpts_local.o
> /home/svegendla/nek5_svn/trunk/nek/jl/obbox.c -o obj/jl_obbox.o
> /tmp/ifortnacSYu.i(21993): catastrophic error: Too many errors, exiting
> compilation aborted for /home/svegendla/nek5_svn/trunk/nek/3rd_party/moab.f
> (code 1)
> make: *** [obj/moab.o] Error 1
> make: *** Waiting for unfinished jobs....
