[MOAB-dev] commit/MOAB: danwu: Merged master into error_handling_enhancement
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Wed Jun 11 15:38:20 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/29f64ae95cfd/
Changeset:   29f64ae95cfd
Branch:      error_handling_enhancement
User:        danwu
Date:        2014-06-11 22:38:15
Summary:     Merged master into error_handling_enhancement
Affected #:  16 files
diff --git a/MeshFiles/unittest/io/Makefile.am b/MeshFiles/unittest/io/Makefile.am
index 94704c1..d40e02b 100644
--- a/MeshFiles/unittest/io/Makefile.am
+++ b/MeshFiles/unittest/io/Makefile.am
@@ -5,7 +5,7 @@ EXTRA_DIST = HommeMapping.nc \
              eul26x48x96.t0.nc \
              eul26x48x96.t1.nc \
              eul26x48x96.t2.nc \
-             eul26x48x96.t.3.nc \
+             eul26x48x96.t.3.nc \
              fv26x46x72.t.3.nc \
 	     cubtest12.cub \
 	     cubtest14.cub \
diff --git a/examples/HelloParMOAB.cpp b/examples/HelloParMOAB.cpp
index 5bcc4ab..3611a8d 100644
--- a/examples/HelloParMOAB.cpp
+++ b/examples/HelloParMOAB.cpp
@@ -2,6 +2,12 @@
  * \brief Read mesh into MOAB and resolve/exchange/report shared and ghosted entities \n
  * <b>To run</b>: mpiexec -np 4 HelloMoabPar [filename]\n
+ *  It shows how to load the mesh independently, on multiple
+ *  communicators (with second argument, the number of comms)
+ *  mpiexec -np 8 HelloMoabPar [filename] [nbComms]
 #include "moab/ParallelComm.hpp"
@@ -26,6 +32,10 @@ int main(int argc, char **argv)
     test_file_name = argv[1];
+  int nbComms = 1;
+  if (argc > 2)
+    nbComms = atoi(argv[2]);
   options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS";
   // Get MOAB instance and read the file with the specified options
@@ -33,15 +43,38 @@ int main(int argc, char **argv)
   if (NULL == mb)
     return 1;
+  MPI_Comm comm ;
+  int global_rank, global_size;
+  MPI_Comm_rank( MPI_COMM_WORLD, &global_rank );
+  MPI_Comm_rank( MPI_COMM_WORLD, &global_size );
+  int color = global_rank%nbComms; // for each angle group a different color
+  if (nbComms>1)
+    // split the communicator, into ngroups = nbComms
+    MPI_Comm_split( MPI_COMM_WORLD, color, global_rank, &comm );
+  else
+    comm = MPI_COMM_WORLD;
   // Get the ParallelComm instance
-  ParallelComm* pcomm = new ParallelComm(mb, MPI_COMM_WORLD);
+  ParallelComm* pcomm = new ParallelComm(mb, comm);
   int nprocs = pcomm->proc_config().proc_size();
   int rank = pcomm->proc_config().proc_rank();
-  MPI_Comm comm = pcomm->proc_config().proc_comm();
+  MPI_Comm rcomm = pcomm->proc_config().proc_comm();
+  assert(rcomm==comm);
+  if (global_rank == 0)
+    cout<< " global rank:" <<global_rank << " color:" << color << " rank:" << rank << " of " << nprocs << " processors\n";
+  if (global_rank == 1)
-  if (rank == 0)
+  MPI_Barrier(MPI_COMM_WORLD);
     cout << "Reading file " << test_file_name << "\n  with options: " << options << endl
-         << " on " << nprocs << " processors\n";
+         << " on " << nprocs << " processors on " << nbComms << " communicator(s) \n";
   ErrorCode rval = mb->load_file(test_file_name.c_str(), 0, options.c_str());
   if (rval != MB_SUCCESS) {
@@ -69,9 +102,9 @@ int main(int argc, char **argv)
   for (int i = 0; i < 4; i++)
     nums[i] = (int)owned_entities.num_of_dimension(i);
   vector<int> rbuf(nprocs*4, 0);
-  MPI_Gather(nums, 4, MPI_INT, &rbuf[0], 4, MPI_INT, 0, MPI_COMM_WORLD);
+  MPI_Gather(nums, 4, MPI_INT, &rbuf[0], 4, MPI_INT, 0, comm);
   // Print the stats gathered:
-  if (rank == 0) {
+  if (global_rank == 0) {
     for (int i = 0; i < nprocs; i++)
       cout << " Shared, owned entities on proc " << i << ": " << rbuf[4*i] << " verts, " <<
           rbuf[4*i + 1] << " edges, " << rbuf[4*i + 2] << " faces, " << rbuf[4*i + 3] << " elements" << endl;
@@ -109,7 +142,7 @@ int main(int argc, char **argv)
   // gather the statistics on processor 0
-  if (rank == 0) {
     cout << " \n\n After exchanging one ghost layer: \n";
     for (int i = 0; i < nprocs; i++) {
diff --git a/src/MergeMesh.cpp b/src/MergeMesh.cpp
index 4978f79..cb43b85 100644
--- a/src/MergeMesh.cpp
+++ b/src/MergeMesh.cpp
@@ -5,6 +5,7 @@
 #include "moab/Range.hpp"
 #include "moab/CartVect.hpp"
+#include "Internals.hpp"
 #include <vector>
 #include <algorithm>
 #include <string>
@@ -15,108 +16,123 @@
 namespace moab {
-  moab::ErrorCode MergeMesh::merge_entities(moab::EntityHandle *elems,
-					    int elems_size,
-					    const double merge_tol,
-					    const int do_merge,
-					    const int update_sets,
-					    moab::Tag merge_tag,
-					    bool do_higher_dim)
+ErrorCode MergeMesh::merge_entities(EntityHandle *elems,
+    int elems_size, const double merge_tol, const int do_merge,
+    const int update_sets, Tag merge_tag, bool do_higher_dim)
   mergeTol = merge_tol;
-  mergeTolSq = merge_tol*merge_tol;
-  moab::Range tmp_elems;
-  tmp_elems.insert( elems, elems + elems_size);
-  moab::ErrorCode result = merge_entities(tmp_elems, merge_tol, do_merge, update_sets,
-					  (moab::Tag)merge_tag, do_higher_dim);
+  mergeTolSq = merge_tol * merge_tol;
+  Range tmp_elems;
+  tmp_elems.insert(elems, elems + elems_size);
+  ErrorCode result = merge_entities(tmp_elems, merge_tol, do_merge,
+      update_sets, (Tag) merge_tag, do_higher_dim);
   return result;
 /*  This function appears to be not necessary after MOAB conversion
-void MergeMesh::perform_merge(iBase_TagHandle merge_tag)
-  // put into a range
-  moab::ErrorCode result = perform_merge((moab::Tag) merge_tag);
-  if (result != moab::MB_SUCCESS)
-    throw MKException(iBase_FAILURE, "");
-moab::ErrorCode MergeMesh::merge_entities(moab::Range &elems,
-                                          const int ,
-					  bool merge_higher_dim)
+ void MergeMesh::perform_merge(iBase_TagHandle merge_tag)
+ // put into a range
+ ErrorCode result = perform_merge((Tag) merge_tag);
+ if (result != MB_SUCCESS)
+ throw MKException(iBase_FAILURE, "");
+ErrorCode MergeMesh::merge_entities(Range &elems,
+    const double merge_tol, const int do_merge, const int, Tag merge_tag,
+    bool merge_higher_dim)
   //If merge_higher_dim is true, do_merge must also be true
-  if(merge_higher_dim && !do_merge){
-    return moab::MB_FAILURE;
+  if (merge_higher_dim && !do_merge)
+    return MB_FAILURE;
   // get the skin of the entities
-  moab::Skinner skinner(mbImpl);
-  moab::Range skin_range;
-  moab::ErrorCode result = skinner.find_skin(0, elems, 0, skin_range, false, false);
-  if (moab::MB_SUCCESS != result) return result;
+  Skinner skinner(mbImpl);
+  Range skin_range;
+  ErrorCode result = skinner.find_skin(0, elems, 0, skin_range, false,
+      false);
+  if (MB_SUCCESS != result)
+    return result;
   // create a tag to mark merged-to entity; reuse tree_root
-  moab::EntityHandle tree_root = 0;
-  if (0 == merge_tag) {
-    result = mbImpl->tag_get_handle("__merge_tag", 1, moab::MB_TYPE_HANDLE,
-                                    mbMergeTag,
-                                    moab::MB_TAG_DENSE|moab::MB_TAG_EXCL,
-                                    &tree_root);
+  EntityHandle tree_root = 0;
+  if (0 == merge_tag)
+    result = mbImpl->tag_get_handle("__merge_tag", 1, MB_TYPE_HANDLE,
+        mbMergeTag, MB_TAG_DENSE | MB_TAG_EXCL, &tree_root);
+      return result;
-  else mbMergeTag = merge_tag;
+  else
+    mbMergeTag = merge_tag;
   // build a kd tree with the vertices
-  moab::AdaptiveKDTree kd(mbImpl);
+  AdaptiveKDTree kd(mbImpl);
   result = kd.build_tree(skin_range, &tree_root);
+    return result;
   // find matching vertices, mark them
   result = find_merged_to(tree_root, kd, mbMergeTag);
+    return result;
   // merge them if requested
-  if (do_merge) {
+  if (do_merge)
     result = perform_merge(mbMergeTag);
+      return result;
-  if(merge_higher_dim && deadEnts.size() != 0){
+  if (merge_higher_dim && deadEnts.size() != 0)
     result = merge_higher_dimensions(elems);
-    if(moab::MB_SUCCESS != result) return result;
+      return result;
-  return moab::MB_SUCCESS;
+  return MB_SUCCESS;
-moab::ErrorCode MergeMesh::perform_merge(moab::Tag merge_tag)
+ErrorCode MergeMesh::perform_merge(Tag merge_tag)
-  moab::ErrorCode result;
-  if (deadEnts.size()==0){
-    if(printError)std::cout << "\nWarning: Geometries don't have a common face; Nothing to merge" << std::endl;
-    return moab::MB_SUCCESS; //nothing to merge carry on with the program
+  // we start with an empty range of vertices that are "merged to"
+  // they are used (eventually) for higher dim entities
+  mergedToVertices.clear();
+  ErrorCode result;
+  if (deadEnts.size() == 0)
+    if (printError)
+      std::cout
+          << "\nWarning: Geometries don't have a common face; Nothing to merge"
+          << std::endl;
+    return MB_SUCCESS; //nothing to merge carry on with the program
-  if  (mbImpl->type_from_handle(*deadEnts.rbegin()) != moab::MBVERTEX)
-  std::vector<moab::EntityHandle> merge_tag_val(deadEnts.size());
+  if (mbImpl->type_from_handle(*deadEnts.rbegin()) != MBVERTEX)
+  std::vector<EntityHandle> merge_tag_val(deadEnts.size());
   result = mbImpl->tag_get_data(merge_tag, deadEnts, &merge_tag_val[0]);
-  moab::Range::iterator rit;
+    return result;
+  Range::iterator rit;
   unsigned int i;
-  for (rit = deadEnts.begin(), i = 0; rit != deadEnts.end(); rit++, i++) {
+  for (rit = deadEnts.begin(), i = 0; rit != deadEnts.end(); rit++, i++)
     assert(merge_tag_val[i]);
+    if (MBVERTEX==TYPE_FROM_HANDLE(merge_tag_val[i]) )
+      mergedToVertices.insert(merge_tag_val[i]);
     result = mbImpl->merge_entities(merge_tag_val[i], *rit, false, false);
-    if (moab::MB_SUCCESS != result) {
       return result;
@@ -124,142 +140,249 @@ moab::ErrorCode MergeMesh::perform_merge(moab::Tag merge_tag)
   return result;
-moab::ErrorCode MergeMesh::find_merged_to(moab::EntityHandle &tree_root,
-                                          moab::AdaptiveKDTree &tree,
-					  moab::Tag merge_tag)
+ErrorCode MergeMesh::find_merged_to(EntityHandle &tree_root,
+    AdaptiveKDTree &tree, Tag merge_tag)
-  moab::AdaptiveKDTreeIter iter;
+  AdaptiveKDTreeIter iter;
   // evaluate vertices in this leaf
-  moab::Range leaf_range, leaf_range2;
-  std::vector<moab::EntityHandle> sorted_leaves;
+  Range leaf_range, leaf_range2;
+  std::vector<EntityHandle> sorted_leaves;
   std::vector<double> coords;
-  std::vector<moab::EntityHandle> merge_tag_val, leaves_out;
-  moab::ErrorCode result = tree.get_tree_iterator(tree_root, iter);
-  while (result == moab::MB_SUCCESS) {
-    sorted_leaves.push_back( iter.handle() );
+  std::vector<EntityHandle> merge_tag_val, leaves_out;
+  ErrorCode result = tree.get_tree_iterator(tree_root, iter);
+    return result;
+  while (result == MB_SUCCESS)
+    sorted_leaves.push_back(iter.handle());
     result = iter.step();
-  if (result != moab::MB_ENTITY_NOT_FOUND)
+  if (result != MB_ENTITY_NOT_FOUND)
     return result;
-  std::sort( sorted_leaves.begin(), sorted_leaves.end() );
-  std::vector<moab::EntityHandle>::iterator it;
-  for (it = sorted_leaves.begin(); it != sorted_leaves.end(); ++it) {
+  std::sort(sorted_leaves.begin(), sorted_leaves.end());
+  std::vector<EntityHandle>::iterator it;
+  for (it = sorted_leaves.begin(); it != sorted_leaves.end(); ++it)
     leaf_range.clear();
     result = mbImpl->get_entities_by_handle(*it, leaf_range);
-    coords.resize(3*leaf_range.size());
+      return result;
+    coords.resize(3 * leaf_range.size());
     merge_tag_val.resize(leaf_range.size());
     result = mbImpl->get_coords(leaf_range, &coords[0]);
+      return result;
     result = mbImpl->tag_get_data(merge_tag, leaf_range, &merge_tag_val[0]);
+      return result;
     unsigned int i;
     bool inleaf_merged, outleaf_merged = false;
     unsigned int lr_size = leaf_range.size();
-    for (i = 0, rit = leaf_range.begin(); i != lr_size; rit++, i++) {
-      if (0 != merge_tag_val[i]) continue;
-      moab::CartVect from(&coords[3*i]);
+    for (i = 0, rit = leaf_range.begin(); i != lr_size; rit++, i++)
+      if (0 != merge_tag_val[i])
+        continue;
+      CartVect from(&coords[3 * i]);
       inleaf_merged = false;
       // check close-by leaves too
       leaves_out.clear();
-      result = tree.distance_search(from.array(), mergeTol,
-                                    leaves_out, mergeTol, 1.0e-6, NULL, NULL, &tree_root);
+      result = tree.distance_search(from.array(), mergeTol, leaves_out,
+          mergeTol, 1.0e-6, NULL, NULL, &tree_root);
       leaf_range2.clear();
-      for (std::vector<moab::EntityHandle>::iterator vit = leaves_out.begin();
-           vit != leaves_out.end(); vit++) {
-        if (*vit > *it) { // if we haven't visited this leaf yet in the outer loop
-          result = mbImpl->get_entities_by_handle(*vit, leaf_range2, moab::Interface::UNION);
+      for (std::vector<EntityHandle>::iterator vit = leaves_out.begin();
+          vit != leaves_out.end(); vit++)
+        if (*vit > *it)
+        { // if we haven't visited this leaf yet in the outer loop
+          result = mbImpl->get_entities_by_handle(*vit, leaf_range2,
+              Interface::UNION);
+            return result;
-      if (!leaf_range2.empty()) {
-        coords.resize(3*(lr_size+leaf_range2.size()));
-        merge_tag_val.resize(lr_size+leaf_range2.size());
-        result = mbImpl->get_coords(leaf_range2, &coords[3*lr_size]);
-        result = mbImpl->tag_get_data(merge_tag, leaf_range2, &merge_tag_val[lr_size]);
+      if (!leaf_range2.empty())
+        coords.resize(3 * (lr_size + leaf_range2.size()));
+        merge_tag_val.resize(lr_size + leaf_range2.size());
+        result = mbImpl->get_coords(leaf_range2, &coords[3 * lr_size]);
+          return result;
+        result = mbImpl->tag_get_data(merge_tag, leaf_range2,
+            &merge_tag_val[lr_size]);
+          return result;
       // check other verts in this leaf
-      for (unsigned int j = i+1; j < merge_tag_val.size(); j++) {
-        moab::EntityHandle to_ent = j >= lr_size ? leaf_range2[j-lr_size] :
-	  leaf_range[j];
-        if (*rit == to_ent) continue;
-        if ((from - moab::CartVect(&coords[3*j])).length_squared() < mergeTolSq) {
+      for (unsigned int j = i + 1; j < merge_tag_val.size(); j++)
+        EntityHandle to_ent =
+            j >= lr_size ? leaf_range2[j - lr_size] : leaf_range[j];
+        if (*rit == to_ent)
+          continue;
+        if ((from - CartVect(&coords[3 * j])).length_squared()
+            < mergeTolSq)
           merge_tag_val[j] = *rit;
-          if (j < lr_size){
-	    inleaf_merged = true;}
-          else{
-	    outleaf_merged = true;}
+          if (j < lr_size)
+            inleaf_merged = true;
+          else
+            outleaf_merged = true;
           deadEnts.insert(to_ent);
-      if (outleaf_merged) {
-	result = mbImpl->tag_set_data(merge_tag, leaf_range2, &merge_tag_val[leaf_range.size()]);
-	outleaf_merged = false;
+      if (outleaf_merged)
+        result = mbImpl->tag_set_data(merge_tag, leaf_range2,
+            &merge_tag_val[leaf_range.size()]);
+          return result;
+        outleaf_merged = false;
-      if (inleaf_merged) {
-	result = mbImpl->tag_set_data(merge_tag, leaf_range, &merge_tag_val[0]);
+      if (inleaf_merged)
+        result = mbImpl->tag_set_data(merge_tag, leaf_range, &merge_tag_val[0]);
+          return result;
 //Determine which higher dimensional entities should be merged
-moab::ErrorCode MergeMesh::merge_higher_dimensions(moab::Range &elems)
-  Range skinEnts, adj, matches, moreDeadEnts;  moab::ErrorCode result;
+ErrorCode MergeMesh::merge_higher_dimensions(Range &elems)
+  // apply a different strategy
+  // look at the vertices that were merged to, earlier, and find all entities adjacent to them
+  // elems (input) are used just for initial connectivity
+  ErrorCode result;
+  Range verts;
+  result = mbImpl->get_connectivity(elems, verts);
+  if (MB_SUCCESS!=result)
+    return result;
+  // all higher dim entities that will be merged will be connected to the vertices that were
+  // merged earlier; we will look at these vertices only
+  Range vertsOfInterest=intersect(this->mergedToVertices, verts);
   //Go through each dimension
-  for(int dim = 1; dim <3; dim++){
+  Range possibleEntsToMerge, conn, matches, moreDeadEnts;
+  for (int dim = 1; dim < 3; dim++)
+    moreDeadEnts.clear();
+    possibleEntsToMerge.clear();
+    result = mbImpl->get_adjacencies(vertsOfInterest,
+                                             dim, false, possibleEntsToMerge,
+      return result;
+    //Go through each possible entity and see if it shares vertices with another entity of same dimension
+    for (Range::iterator pit = possibleEntsToMerge.begin();
+        pit != possibleEntsToMerge.end(); pit++)
+      EntityHandle eh=*pit;//possible entity to be matched
+      conn.clear();
+      //Get the vertices connected to it in a range
+      result = mbImpl->get_connectivity(&eh, 1, conn);
+        return result;
+      matches.clear();
+      // now retrieve all entities connected to all conn vertices
+      result = mbImpl->get_adjacencies(conn, dim, false, matches,
+                                                   Interface::INTERSECT);
+        return result;
+      if (matches.size() > 1)
+        for (Range::iterator matchIt = matches.begin();
+            matchIt != matches.end(); matchIt++)
+          EntityHandle to_remove=*matchIt;
+          if (to_remove != eh)
+            moreDeadEnts.insert(to_remove);
+            result = mbImpl->merge_entities(eh, to_remove, false, false);
+              return result;
+            possibleEntsToMerge.erase(to_remove);
+    //Delete the entities of dimension dim
+    result = mbImpl->delete_entities(moreDeadEnts);
+      return result;
+#if 0
+  Range skinEnts, adj, matches, moreDeadEnts;
+  ErrorCode result;
+  //Go through each dimension
     skinEnts.clear();
     result = skinner.find_skin(0, elems, dim, skinEnts, false, false);
     //Go through each skin entity and see if it shares adjacancies with another entity
-    for(moab::Range::iterator skinIt = skinEnts.begin(); skinIt != skinEnts.end(); skinIt++){
+    for (Range::iterator skinIt = skinEnts.begin();
+        skinIt != skinEnts.end(); skinIt++)
       adj.clear();
       //Get the adjacencies 1 dimension lower
-      result = mbImpl->get_adjacencies(&(*skinIt), 1, dim-1, false, adj);
-      if(result != moab::MB_SUCCESS) return result;
+      result = mbImpl->get_adjacencies(&(*skinIt), 1, dim - 1, false, adj);
+        return result;
       //See what other entities share these adjacencies
       matches.clear();
-      result = mbImpl->get_adjacencies(adj, dim, false, matches, moab::Interface::INTERSECT);
+      result = mbImpl->get_adjacencies(adj, dim, false, matches,
+        return result;
       //If there is more than one entity, then we have some to merge and erase
-      if(matches.size() > 1){
-	for(moab::Range::iterator matchIt = matches.begin(); matchIt != matches.end(); matchIt++){
-	  if(*matchIt != *skinIt){
-	    moreDeadEnts.insert(*matchIt);
-	    result = mbImpl->merge_entities(*skinIt, *matchIt, false, false);
-	    skinEnts.erase(*matchIt);
+          if (*matchIt != *skinIt)
+            moreDeadEnts.insert(*matchIt);
+            result = mbImpl->merge_entities(*skinIt, *matchIt, false, false);
+              return result;
+            skinEnts.erase(*matchIt);
-    if(result != moab::MB_SUCCESS)return result;
+      return result;
+#endif
-}//End namespace moab
+} //End namespace moab
diff --git a/src/io/NCHelperGCRM.cpp b/src/io/NCHelperGCRM.cpp
index f673aff..25ed53c 100644
--- a/src/io/NCHelperGCRM.cpp
+++ b/src/io/NCHelperGCRM.cpp
@@ -248,6 +248,7 @@ ErrorCode NCHelperGCRM::check_existing_mesh()
 ErrorCode NCHelperGCRM::create_mesh(Range& faces)
   int& gatherSetRank = _readNC->gatherSetRank;
+  int& trivialPartitionShift = _readNC->trivialPartitionShift;
   bool& noEdges = _readNC->noEdges;
   DebugOutput& dbgOut = _readNC->dbgOut;
@@ -267,19 +268,24 @@ ErrorCode NCHelperGCRM::create_mesh(Range& faces)
     createGatherSet = true;
   if (procs >= 2) {
+    // Shift rank to obtain a rotated trivial partition
+    int shifted_rank = rank;
+    if (trivialPartitionShift > 0)
+      shifted_rank = (rank + trivialPartitionShift) % procs;
     // Compute the number of local cells on this proc
     nLocalCells = int(std::floor(1.0 * nCells / procs));
     // The starting global cell index in the GCRM file for this proc
-    int start_cell_idx = rank * nLocalCells;
+    int start_cell_idx = shifted_rank * nLocalCells;
     // Number of extra cells after equal split over procs
     int iextra = nCells % procs;
     // Allocate extra cells over procs
-    if (rank < iextra)
+    if (shifted_rank < iextra)
       nLocalCells++;
-    start_cell_idx += std::min(rank, iextra);
+    start_cell_idx += std::min(shifted_rank, iextra);
     start_cell_idx++; // 0 based -> 1 based
diff --git a/src/io/NCHelperHOMME.cpp b/src/io/NCHelperHOMME.cpp
index 3665d01..716f624 100644
--- a/src/io/NCHelperHOMME.cpp
+++ b/src/io/NCHelperHOMME.cpp
@@ -248,6 +248,7 @@ ErrorCode NCHelperHOMME::create_mesh(Range& faces)
   bool& spectralMesh = _readNC->spectralMesh;
   int rank = 0;
   int procs = 1;
@@ -349,24 +350,29 @@ ErrorCode NCHelperHOMME::create_mesh(Range& faces)
     tmp_conn[4 * i + 3] = tmp_conn2[i + 3 * num_quads];
-  // Need to know whether we'll be creating gather mesh later, to make sure we allocate enough space
-  // in one shot
+  // Need to know whether we'll be creating gather mesh later, to make sure
+  // we allocate enough space in one shot
   bool create_gathers = false;
   if (rank == gatherSetRank)
     create_gathers = true;
+  if (procs >= 2 && trivialPartitionShift > 0)
   // Compute the number of local quads, accounting for coarse or fine representation
   // spectral_unit is the # fine quads per coarse quad, or spectralOrder^2
   int spectral_unit = (spectralMesh ? _spectralOrder * _spectralOrder : 1);
   // num_coarse_quads is the number of quads instantiated in MOAB; if !spectralMesh, num_coarse_quads = num_fine_quads
   num_coarse_quads = int(std::floor(1.0 * num_quads / (spectral_unit * procs)));
   // start_idx is the starting index in the HommeMapping connectivity list for this proc, before converting to coarse quad representation
-  start_idx = 4 * rank * num_coarse_quads * spectral_unit;
+  start_idx = 4 * shifted_rank * num_coarse_quads * spectral_unit;
   // iextra = # coarse quads extra after equal split over procs
   int iextra = num_quads % (procs * spectral_unit);
     num_coarse_quads++;
-  start_idx += 4 * spectral_unit * std::min(rank, iextra);
+  start_idx += 4 * spectral_unit * std::min(shifted_rank, iextra);
   // num_fine_quads is the number of quads in the connectivity list in HommeMapping file assigned to this proc
   num_fine_quads = spectral_unit * num_coarse_quads;
diff --git a/src/io/NCHelperMPAS.cpp b/src/io/NCHelperMPAS.cpp
index 65a6c37..6851c75 100644
--- a/src/io/NCHelperMPAS.cpp
+++ b/src/io/NCHelperMPAS.cpp
@@ -287,6 +287,7 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
   Interface*& mbImpl = _readNC->mbImpl;
   bool& noMixedElements = _readNC->noMixedElements;
@@ -306,19 +307,24 @@ ErrorCode NCHelperMPAS::create_mesh(Range& faces)
   if (procs >= 2) {
     // The starting global cell index in the MPAS file for this proc
       nLocalCells++;
diff --git a/src/io/NCWriteHOMME.cpp b/src/io/NCWriteHOMME.cpp
index abfe4ff..3dd61c1 100644
--- a/src/io/NCWriteHOMME.cpp
+++ b/src/io/NCWriteHOMME.cpp
@@ -246,9 +246,11 @@ ErrorCode NCWriteHOMME::write_nonset_variables(std::vector<WriteNC::VarData>& vd
       switch (variableData.varDataType) {
         case NC_DOUBLE: {
           std::vector<double> tmpdoubledata(num_local_verts_owned * num_lev);
-          if (num_lev > 1)
+          if (num_lev > 1) {
             // Transpose (ncol, lev) back to (lev, ncol)
-            jik_to_kji(num_local_verts_owned, 1, num_lev, &tmpdoubledata[0], &tag_data[0]);
+            // Note, num_local_verts_owned is not used by jik_to_kji_stride()
+            jik_to_kji_stride(num_local_verts_owned, 1, num_lev, &tmpdoubledata[0], &tag_data[0], localGidVertsOwned);
           size_t indexInDoubleArray = 0;
           size_t ic = 0;
diff --git a/src/io/NCWriteHelper.hpp b/src/io/NCWriteHelper.hpp
index 42425d2..8e817e3 100644
--- a/src/io/NCWriteHelper.hpp
+++ b/src/io/NCWriteHelper.hpp
@@ -44,16 +44,6 @@ protected:
   // Write non-set variables (implemented in child classes)
   virtual ErrorCode write_nonset_variables(std::vector<WriteNC::VarData>& vdatas, std::vector<int>& tstep_nums) = 0;
-  template <typename T> void jik_to_kji(size_t ni, size_t nj, size_t nk, T* dest, T* source)
-    size_t nik = ni * nk, nij = ni * nj;
-    for (std::size_t k = 0; k != nk; k++)
-      for (std::size_t j = 0; j != nj; j++)
-        for (std::size_t i = 0; i != ni; i++)
-          dest[k*nij + j*ni + i] = source[j*nik + i*nk + k];
-protected:
   //! Allow NCWriteHelper to directly access members of WriteNC
   WriteNC* _writeNC;
@@ -99,6 +89,15 @@ private:
   //! Implementation of NCWriteHelper::write_nonset_variables()
   virtual ErrorCode write_nonset_variables(std::vector<WriteNC::VarData>& vdatas, std::vector<int>& tstep_nums);
+  template <typename T> void jik_to_kji(size_t ni, size_t nj, size_t nk, T* dest, T* source)
+    size_t nik = ni * nk, nij = ni * nj;
+    for (std::size_t k = 0; k != nk; k++)
+      for (std::size_t j = 0; j != nj; j++)
+        for (std::size_t i = 0; i != ni; i++)
+          dest[k*nij + j*ni + i] = source[j*nik + i*nk + k];
 protected:
   //! Dimensions of my local part of grid
   int lDims[6];
@@ -117,6 +116,25 @@ public:
   virtual ~UcdNCWriteHelper() {}
 protected:
+  //! This version takes as input the moab range, from which we actually need just the
+  //! size of each sequence, for a proper transpose of the data
+  template <typename T> void jik_to_kji_stride(size_t , size_t nj, size_t nk, T* dest, T* source, Range& localGid)
+    std::size_t idxInSource = 0; // Position of the start of the stride
+    // For each subrange, we will transpose a matrix of size
+    // subrange*nj*nk (subrange takes the role of ni)
+    for (Range::pair_iterator pair_iter = localGid.pair_begin();
+        pair_iter != localGid.pair_end(); ++pair_iter) {
+      std::size_t size_range = pair_iter->second - pair_iter->first + 1;
+      std::size_t nik = size_range * nk, nij = size_range * nj;
+          for (std::size_t i = 0; i != size_range; i++)
+            dest[idxInSource + k*nij + j*size_range + i] = source[idxInSource + j*nik + i*nk + k];
+      idxInSource += (size_range*nj*nk);
   //! Dimension numbers for nCells, nEdges and nVertices
   int cDim, eDim, vDim;
diff --git a/src/io/ReadNC.cpp b/src/io/ReadNC.cpp
index 7607927..bdf6d3b 100644
--- a/src/io/ReadNC.cpp
+++ b/src/io/ReadNC.cpp
@@ -19,7 +19,7 @@ ReadNC::ReadNC(Interface* impl) :
   myPcomm(NULL),
 #endif
   noMesh(false), noVars(false), spectralMesh(false), noMixedElements(false), noEdges(false),
-  gatherSetRank(-1), tStepBase(-1), myHelper(NULL)
+  gatherSetRank(-1), tStepBase(-1), trivialPartitionShift(0), myHelper(NULL)
   assert(impl != NULL);
   impl->query_interface(readMeshIface);
@@ -280,6 +280,12 @@ ErrorCode ReadNC::parse_options(const FileOptions& opts, std::vector<std::string
     SET_ERR(rval, "Invalid value for TIMESTEPBASE option");
+  rval = opts.get_int_option("TRIVIAL_PARTITION_SHIFT", 1, trivialPartitionShift);
+  if (MB_TYPE_OUT_OF_RANGE == rval) {
+    readMeshIface->report_error("Invalid value for TRIVIAL_PARTITION_SHIFT option");
+    return rval;
 #ifdef USE_MPI
   isParallel = (opts.match_option("PARALLEL", "READ_PART") != MB_ENTITY_NOT_FOUND);
diff --git a/src/io/ReadNC.hpp b/src/io/ReadNC.hpp
index 1b81d15..b4ec60b 100644
--- a/src/io/ReadNC.hpp
+++ b/src/io/ReadNC.hpp
@@ -209,6 +209,7 @@ private:
   bool noEdges;
   int gatherSetRank;
   int tStepBase;
+  int trivialPartitionShift;
   //! Helper class instance
   NCHelper* myHelper;
diff --git a/src/io/WriteHDF5.cpp b/src/io/WriteHDF5.cpp
index 337cb96..b53508e 100644
--- a/src/io/WriteHDF5.cpp
+++ b/src/io/WriteHDF5.cpp
@@ -2567,7 +2567,43 @@ ErrorCode WriteHDF5::serial_create_file( const char* filename,
     rval = assign_ids( ex_itor->range, ex_itor->first_id );
     CHK_MB_ERR_0(rval);
+  // create set tables
+  writeSets = !setSet.range.empty();
+  if (writeSets)
+    long contents_len, children_len, parents_len;
+    setSet.total_num_ents = setSet.range.size();
+    setSet.max_num_ents = setSet.total_num_ents;
+    rval = create_set_meta(setSet.total_num_ents, first_id);
+    CHK_MB_ERR_0(rval);
+    setSet.first_id = (id_t) first_id;
+    rval = assign_ids(setSet.range, setSet.first_id);
+    rval = count_set_size(setSet.range, contents_len, children_len,
+        parents_len);
+    rval = create_set_tables(contents_len, children_len, parents_len);
+    setSet.offset = 0;
+    setContentsOffset = 0;
+    setChildrenOffset = 0;
+    setParentsOffset = 0;
+    writeSetContents = !!contents_len;
+    writeSetChildren = !!children_len;
+    writeSetParents = !!parents_len;
+    maxNumSetContents = contents_len;
+    maxNumSetChildren = children_len;
+    maxNumSetParents = parents_len;
+  } // if(!setSet.range.empty())
+  // create adjacency table after set table, because sets do not have yet an id
+  // some entities are adjacent to sets (exodus?)
     // create node adjacency table
   id_t num_adjacencies;
 #ifdef MB_H5M_WRITE_NODE_ADJACENCIES
@@ -2605,39 +2641,6 @@ ErrorCode WriteHDF5::serial_create_file( const char* filename,
-    // create set tables
-  writeSets = !setSet.range.empty();
-  if (writeSets)
-    long contents_len, children_len, parents_len;
-    setSet.total_num_ents = setSet.range.size();
-    setSet.max_num_ents = setSet.total_num_ents;
-    rval = create_set_meta( setSet.total_num_ents, first_id );
-    CHK_MB_ERR_0(rval);
-    setSet.first_id = (id_t)first_id;
-    rval = assign_ids( setSet.range, setSet.first_id );
-    rval = count_set_size( setSet.range, contents_len, children_len, parents_len );
-    rval = create_set_tables( contents_len, children_len, parents_len );
-    setSet.offset = 0;
-    setContentsOffset = 0;
-    setChildrenOffset = 0;
-    setParentsOffset = 0;
-    writeSetContents = !!contents_len;
-    writeSetChildren = !!children_len;
-    writeSetParents = !!parents_len;
-    maxNumSetContents = contents_len;
-    maxNumSetChildren = children_len;
-    maxNumSetParents = parents_len;
-  } // if(!setSet.range.empty())
   dbgOut.tprint( 1, "Gathering Tags\n" );
diff --git a/src/io/WriteHDF5.hpp b/src/io/WriteHDF5.hpp
index 256a217..555d4ca 100644
--- a/src/io/WriteHDF5.hpp
+++ b/src/io/WriteHDF5.hpp
@@ -104,7 +104,7 @@ public:
     Range range;
     //! The first Id allocated by the mhdf library.  Entities in range have sequential IDs.
     id_t first_id;
-    //! The offset at which to begin writting this processor's data.
+    //! The offset at which to begin writing this processor's data.
     //! Always zero except for parallel IO.
     long offset;
     //! Offset for adjacency data.  Always zero except for parallel IO
diff --git a/src/moab/MergeMesh.hpp b/src/moab/MergeMesh.hpp
index 489bb3e..8eef9a8 100644
--- a/src/moab/MergeMesh.hpp
+++ b/src/moab/MergeMesh.hpp
@@ -7,73 +7,69 @@
 namespace moab {
 class AdaptiveKDTree;
-class MergeMesh
+class MergeMesh
 public:
-    /* \brief Constructor
-  MergeMesh(moab::Interface *mbImpl, bool printErrorIn = true);
-    /* \brief Destructor
+  /* \brief Constructor
+  MergeMesh(Interface *mbImpl, bool printErrorIn = true);
+  /* \brief Destructor
   virtual ~MergeMesh();
-    /* \brief Merge vertices in elements passed in
-   moab::ErrorCode merge_entities(moab::EntityHandle *elems,
-                      int elems_size,
-                      const int do_merge = true,
-                      const int update_sets = false,
-		      moab::Tag merge_tag = 0,
-		      bool do_higher_dim = true);
-  moab::ErrorCode merge_entities(moab::Range &elems,
+  /* \brief Merge vertices in elements passed in
+  ErrorCode merge_entities(EntityHandle *elems, int elems_size,
+      const double merge_tol, const int do_merge = true, const int update_sets =
+          false, Tag merge_tag = 0, bool do_higher_dim = true);
+  ErrorCode merge_entities(Range &elems, const double merge_tol,
+      const int do_merge = true, const int update_sets = false,
+      Tag merge_tag = 0, bool do_higher_dim = true);
   //Identify higher dimension to be merged
-  moab::ErrorCode merge_higher_dimensions(moab::Range &elems);
+  ErrorCode merge_higher_dimensions(Range &elems);
-      //- perform the actual merge
-  moab::ErrorCode perform_merge(moab::Tag merged_to);
+  //- perform the actual merge
+  ErrorCode perform_merge(Tag merged_to);
 private:
   //iMesh_Instance imeshImpl;
   double mergeTol, mergeTolSq;
-  moab::Tag mergeTag;
+  Tag mergeTag;
+  //- given a kdtree, set tag on vertices in leaf nodes with vertices
+  //- to which they should be merged
+  ErrorCode find_merged_to(EntityHandle &tree_root,
+      AdaptiveKDTree &tree, Tag merged_to);
+  Interface *mbImpl;
-    //- given a kdtree, set tag on vertices in leaf nodes with vertices
-    //- to which they should be merged
-  moab::ErrorCode find_merged_to(moab::EntityHandle &tree_root,
-				 moab::Tag merged_to);
-  moab::Interface *mbImpl;
+  //- the tag pointing to the entity to which an entity will be merged
+  Tag mbMergeTag;
-    //- the tag pointing to the entity to which an entity will be merged
-  moab::Tag mbMergeTag;
+  //- entities which will go away after the merge
+  Range deadEnts;
-    //- entities which will go away after the merge
-  moab::Range deadEnts;
+  // vertices that were merged with other vertices, and were left in the database
+  Range mergedToVertices;
   //Allow a warning to be suppressed when no merging is done
   bool printError;
-  inline MergeMesh::MergeMesh(Interface *impl, bool printErrorIn)
-    : mbImpl(impl), printError(printErrorIn)
+inline MergeMesh::MergeMesh(Interface *impl, bool printErrorIn) :
+    mbImpl(impl), printError(printErrorIn)
-inline MergeMesh::~MergeMesh()
+inline MergeMesh::~MergeMesh()
-  if (mbMergeTag) mbImpl->tag_delete(mbMergeTag);
+  if (mbMergeTag)
+    mbImpl->tag_delete(mbMergeTag);
diff --git a/src/parallel/WriteHDF5Parallel.cpp b/src/parallel/WriteHDF5Parallel.cpp
index be692ba..7bd14b8 100644
--- a/src/parallel/WriteHDF5Parallel.cpp
+++ b/src/parallel/WriteHDF5Parallel.cpp
@@ -420,8 +420,17 @@ ErrorCode WriteHDF5Parallel::parallel_create_file( const char* filename,
   if (MB_SUCCESS != rval) return error(rval);
   if (times) times[FILEID_EXCHANGE_TIME] = timer.elapsed();
+  /**************** Create meshset tables *********************/
-    /**************** Create adjacency tables *********************/
+  debug_barrier();
+  dbgOut.tprint(1,"creating meshset table\n");
+  topState.start("creating meshset tables");
+  rval = create_meshset_tables(times);
+  topState.end(rval);
+  if (MB_SUCCESS != rval) return error(rval);
+  if (times) times[CREATE_SET_TIME] = timer.elapsed();
+  /**************** Create adjacency tables *********************/
   debug_barrier();
   dbgOut.tprint(1,"creating adjacency table\n");
@@ -431,15 +440,7 @@ ErrorCode WriteHDF5Parallel::parallel_create_file( const char* filename,
   if (times) times[CREATE_ADJ_TIME] = timer.elapsed();
-    /**************** Create meshset tables *********************/
-  debug_barrier();
-  dbgOut.tprint(1,"creating meshset table\n");
-  topState.start("creating meshset tables");
-  rval = create_meshset_tables(times);
-  topState.end(rval);
-  if (MB_SUCCESS != rval) return error(rval);
-  if (times) times[CREATE_SET_TIME] = timer.elapsed();
     /**************** Create tag data *********************/
This diff is so big that we needed to truncate the remainder.
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
