[MOAB-dev] Why kdtree's take so long to initialize
Tim Tautges (ANL)
tautges at mcs.anl.gov
Wed Feb 12 14:44:01 CST 2014
Hi all,
I spent the morning trying to figure out why kdtree's in MOAB take so long to initialize. As often happens, I spent
time in the code, when I should have spent time in my brain first. I wrote a FAQ item on it, at
https://trac.mcs.anl.gov/projects/ITAPS/wiki/KdTreeCost. Really, it's a simple matter of non-vertex elements not being
wholly contained in tree node boxes, and the box-element overlap test not being a simple box comparison.
I recently implemented a BVH tree that should perform much better for searching elements rather than points, with
initialization being much faster too.
- tim
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone (gvoice): (608) 354-1459 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
