[MOAB-dev] commit/MOAB: danwu: Merged master into error_handling_enhancement
commits-noreply at bitbucket.org
Fri Jun 6 14:01:57 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/d7b65921e6db/
Changeset: d7b65921e6db
Branch: error_handling_enhancement
User: danwu
Date: 2014-06-06 21:01:52
Summary: Merged master into error_handling_enhancement
Affected #: 4 files
diff --git a/src/io/NCHelperGCRM.cpp b/src/io/NCHelperGCRM.cpp
index 25fe9ac..f673aff 100644
--- a/src/io/NCHelperGCRM.cpp
+++ b/src/io/NCHelperGCRM.cpp
@@ -18,12 +18,11 @@
namespace moab {
-const int DEFAULT_MAX_EDGES_PER_CELL = 6;
+// GCRM cells are either pentagons or hexagons, and pentagons are always padded to hexagons
+const int EDGES_PER_CELL = 6;
NCHelperGCRM::NCHelperGCRM(ReadNC* readNC, int fileId, const FileOptions& opts, EntityHandle fileSet)
: UcdNCHelper(readNC, fileId, opts, fileSet)
-, maxEdgesPerCell(DEFAULT_MAX_EDGES_PER_CELL)
-, numCellGroups(0)
, createGatherSet(false)
// Ignore variables containing topological information
@@ -38,7 +37,7 @@ bool NCHelperGCRM::can_read_file(ReadNC* readNC)
std::vector<std::string>& dimNames = readNC->dimNames;
- // If dimension name "vertexDegree" exists then it should be the GCRM grid
+ // If dimension name "cells" exists then it should be the GCRM grid
if (std::find(dimNames.begin(), dimNames.end(), std::string("cells")) != dimNames.end())
return true;
@@ -94,7 +93,7 @@ ErrorCode NCHelperGCRM::init_mesh_vals()
vDim = idx;
nVertices = dimLens[idx];
- // Get number of vertex levels
+ // Get number of layers
if ((vit = std::find(dimNames.begin(), dimNames.end(), "layers")) != dimNames.end())
idx = vit - dimNames.begin();
else {
@@ -179,14 +178,6 @@ ErrorCode NCHelperGCRM::check_existing_mesh()
if (noMesh) {
ErrorCode rval;
- // Restore numCellGroups
- if (0 == numCellGroups) {
- Tag numCellGroupsTag;
- rval = mbImpl->tag_get_handle("__NUM_CELL_GROUPS", 1, MB_TYPE_INTEGER, numCellGroupsTag);
- if (MB_SUCCESS == rval)
- rval = mbImpl->tag_get_data(numCellGroupsTag, &_fileSet, 1, &numCellGroups);
if (localGidVerts.empty()) {
// Get all vertices from tmp_set (it is the input set in no_mesh scenario)
Range local_verts;
@@ -247,14 +238,6 @@ ErrorCode NCHelperGCRM::check_existing_mesh()
// Restore localGidCells
std::copy(gids.rbegin(), gids.rend(), range_inserter(localGidCells));
nLocalCells = localGidCells.size();
- if (numCellGroups > 1) {
- // Restore cellHandleToGlobalID map
- Range::const_iterator rit;
- int i;
- for (rit = local_cells.begin(), i = 0; rit != local_cells.end(); ++rit, i++)
- cellHandleToGlobalID[*rit] = gids[i];
@@ -264,9 +247,7 @@ ErrorCode NCHelperGCRM::check_existing_mesh()
ErrorCode NCHelperGCRM::create_mesh(Range& faces)
- Interface*& mbImpl = _readNC->mbImpl;
int& gatherSetRank = _readNC->gatherSetRank;
- bool& noMixedElements = _readNC->noMixedElements;
bool& noEdges = _readNC->noEdges;
DebugOutput& dbgOut = _readNC->dbgOut;
@@ -317,9 +298,8 @@ ErrorCode NCHelperGCRM::create_mesh(Range& faces)
int verticesOnCellVarId;
int success = NCFUNC(inq_varid)(_fileId, "cell_corners", &verticesOnCellVarId);
ERRORS(success, "Failed to get variable id of cell_corners.");
- std::vector<int> vertices_on_local_cells(nLocalCells * maxEdgesPerCell);
+ std::vector<int> vertices_on_local_cells(nLocalCells * EDGES_PER_CELL);
dbgOut.tprintf(1, " nLocalCells = %d\n", (int)nLocalCells);
- dbgOut.tprintf(1, " maxEdgesPerCell = %d\n", (int)maxEdgesPerCell);
dbgOut.tprintf(1, " vertices_on_local_cells.size() = %d\n", (int)vertices_on_local_cells.size());
#ifdef PNETCDF_FILE
size_t nb_reads = localGidCells.psize();
@@ -337,7 +317,7 @@ ErrorCode NCHelperGCRM::create_mesh(Range& faces)
dbgOut.tprintf(1, " cell_corners endh = %d\n", (int)endh);
NCDF_SIZE read_starts[2] = {static_cast<NCDF_SIZE>(starth - 1), 0};
NCDF_SIZE read_counts[2] = {static_cast<NCDF_SIZE>(endh - starth + 1),
- static_cast<NCDF_SIZE>(maxEdgesPerCell)};
+ static_cast<NCDF_SIZE>(EDGES_PER_CELL)};
// Do a partial read in each subrange
#ifdef PNETCDF_FILE
@@ -350,7 +330,7 @@ ErrorCode NCHelperGCRM::create_mesh(Range& faces)
ERRORS(success, "Failed to read cell_corners data in a loop");
// Increment the index for next subrange
- indexInArray += (endh - starth + 1) * maxEdgesPerCell;
+ indexInArray += (endh - starth + 1) * EDGES_PER_CELL;
#ifdef PNETCDF_FILE
@@ -359,11 +339,25 @@ ErrorCode NCHelperGCRM::create_mesh(Range& faces)
ERRORS(success, "Failed on wait_all.");
#endif
- // GCRM is 0 based, convert vertex indices from 0 to 1 based
- for (std::size_t idx = 0; idx < vertices_on_local_cells.size(); idx++) {
- vertices_on_local_cells[idx] += 1;
+ // Correct vertices_on_local_cells array. Pentagons as hexagons should have
+ // a connectivity like 123455 and not 122345
+ for (int local_cell_idx = 0; local_cell_idx < nLocalCells; local_cell_idx++) {
+ int* pvertex = &vertices_on_local_cells[local_cell_idx * EDGES_PER_CELL];
+ for (int k = 0; k < EDGES_PER_CELL - 2; k++) {
+ if (*(pvertex + k) == *(pvertex + k + 1)) {
+ // Shift the connectivity
+ for (int kk = k + 1; kk < EDGES_PER_CELL - 1; kk++)
+ *(pvertex + kk) = *(pvertex + kk + 1);
+ // No need to try next k
+ break;
+ // GCRM is 0 based, convert vertex indices from 0 to 1 based
+ for (std::size_t idx = 0; idx < vertices_on_local_cells.size(); idx++)
+ vertices_on_local_cells[idx] += 1;
// Create local vertices
EntityHandle start_vertex;
ErrorCode rval = create_local_vertices(vertices_on_local_cells, start_vertex);
@@ -375,22 +369,9 @@ ErrorCode NCHelperGCRM::create_mesh(Range& faces)
ERRORR(rval, "Failed to create local edges for GCRM mesh.");
- // Create local cells, either unpadded or padded
- if (noMixedElements) {
- rval = create_padded_local_cells(vertices_on_local_cells, start_vertex, faces);
- ERRORR(rval, "Failed to create padded local cells for GCRM mesh.");
- else {
- rval = create_local_cells(vertices_on_local_cells, start_vertex, faces);
- ERRORR(rval, "Failed to create local cells for GCRM mesh.");
- // Set tag for numCellGroups
- Tag numCellGroupsTag = 0;
- rval = mbImpl->tag_get_handle("__NUM_CELL_GROUPS", 1, MB_TYPE_INTEGER, numCellGroupsTag, MB_TAG_SPARSE | MB_TAG_CREAT);
- ERRORR(rval, "Failed to get __NUM_CELL_GROUPS tag.");
- rval = mbImpl->tag_set_data(numCellGroupsTag, &_fileSet, 1, &numCellGroups);
- ERRORR(rval, "Failed to set data for __NUM_CELL_GROUPS tag.");
+ // Create local cells with padding
+ rval = create_padded_local_cells(vertices_on_local_cells, start_vertex, faces);
+ ERRORR(rval, "Failed to create local cells for GCRM mesh.");
if (createGatherSet) {
EntityHandle gather_set;
@@ -408,15 +389,9 @@ ErrorCode NCHelperGCRM::create_mesh(Range& faces)
ERRORR(rval, "Failed to create gather set edges for GCRM mesh.");
- // Create gather set cells, either unpadded or padded
- rval = create_padded_gather_set_cells(gather_set, start_gather_set_vertex);
- ERRORR(rval, "Failed to create padded gather set cells for GCRM mesh.");
- else {
- rval = create_gather_set_cells(gather_set, start_gather_set_vertex);
- ERRORR(rval, "Failed to create gather set cells for GCRM mesh.");
+ // Create gather set cells with padding
+ rval = create_padded_gather_set_cells(gather_set, start_gather_set_vertex);
+ ERRORR(rval, "Failed to create gather set cells for GCRM mesh.");
return MB_SUCCESS;
@@ -541,19 +516,13 @@ ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset_allocate(std::vector<ReadNC
// Get ptr to tag space
- if (vdatas[i].entLoc == ReadNC::ENTLOCFACE && numCellGroups > 1) {
- // For a cell variable that is NOT on one contiguous chunk of faces, defer its tag space allocation
- vdatas[i].varDatas[t] = NULL;
- else {
- assert(1 == range->psize());
- void* data;
- int count;
- rval = mbImpl->tag_iterate(vdatas[i].varTags[t], range->begin(), range->end(), count, data);
- ERRORR(rval, "Failed to iterate tag.");
- assert((unsigned)count == range->size());
- vdatas[i].varDatas[t] = data;
+ assert(1 == range->psize());
+ void* data;
+ int count;
+ rval = mbImpl->tag_iterate(vdatas[i].varTags[t], range->begin(), range->end(), count, data);
+ ERRORR(rval, "Failed to iterate tag.");
+ assert((unsigned)count == range->size());
+ vdatas[i].varDatas[t] = data;
@@ -563,7 +532,6 @@ ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset_allocate(std::vector<ReadNC
#ifdef PNETCDF_FILE
ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset_async(std::vector<ReadNC::VarData>& vdatas, std::vector<int>& tstep_nums)
@@ -647,32 +615,9 @@ ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset_async(std::vector<ReadNC::V
success = NCFUNC(wait_all)(_fileId, requests.size(), &requests[0], &statuss[0]);
- // For a cell variable that is NOT on one contiguous chunk of faces, allocate tag space for
- // each cell group, and utilize cellHandleToGlobalID map to read tag data
- Range::iterator iter = facesOwned.begin();
- while (iter != facesOwned.end()) {
- int count;
- void* ptr;
- rval = mbImpl->tag_iterate(vdatas[i].varTags[t], iter, facesOwned.end(), count, ptr);
- ERRORR(rval, "Failed to iterate tag on owned faces.");
- for (int j = 0; j < count; j++) {
- int global_cell_idx = cellHandleToGlobalID[*(iter + j)]; // Global cell index, 1 based
- int local_cell_idx = localGidCells.index(global_cell_idx); // Local cell index, 0 based
- assert(local_cell_idx != -1);
- for (int level = 0; level < vdatas[i].numLev; level++)
- ((double*) ptr)[j * vdatas[i].numLev + level] = tmpdoubledata[local_cell_idx * vdatas[i].numLev + level];
- iter += count;
- else {
- void* data = vdatas[i].varDatas[t];
- for (std::size_t idx = 0; idx != tmpdoubledata.size(); idx++)
- ((double*) data)[idx] = tmpdoubledata[idx];
+ void* data = vdatas[i].varDatas[t];
+ for (std::size_t idx = 0; idx != tmpdoubledata.size(); idx++)
+ ((double*) data)[idx] = tmpdoubledata[idx];
break;
@@ -694,17 +639,6 @@ ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset_async(std::vector<ReadNC::V
- for (unsigned int i = 0; i < vdatas.size(); i++) {
- if (noEdges && vdatas[i].entLoc == ReadNC::ENTLOCEDGE)
- continue;
- /*for (unsigned int t = 0; t < tstep_nums.size(); t++) {
- dbgOut.tprintf(2, "Converting variable %s, time step %d\n", vdatas[i].varName.c_str(), tstep_nums[t]);
- ErrorCode tmp_rval = convert_variable(vdatas[i], t);
- if (MB_SUCCESS != tmp_rval)
- rval = tmp_rval;
// Debug output, if requested
if (1 == dbgOut.get_verbosity()) {
dbgOut.printf(1, "Read variables: %s", vdatas.begin()->varName.c_str());
@@ -790,32 +724,9 @@ ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData
assert(ic == pLocalGid->psize());
- int count;
- void* ptr;
- iter += count;
- else {
break;
@@ -836,18 +747,6 @@ ErrorCode NCHelperGCRM::read_ucd_variables_to_nonset(std::vector<ReadNC::VarData
- continue;
- /* for (unsigned int t = 0; t < tstep_nums.size(); t++) {
- rval = tmp_rval;
@@ -865,8 +764,8 @@ ErrorCode NCHelperGCRM::redistribute_local_cells(int start_cell_idx)
// If possible, apply Zoltan partition
if (_readNC->partMethod == ScdParData::RCBZOLTAN) {
#if defined(USE_MPI) && defined(HAVE_ZOLTAN)
- // Read lat/lon coordinates of cell centers
- // then convert to spherical , and use them as input to zoltan partition
+ // Read lat/lon coordinates of cell centers, then convert spherical to
+ // Cartesian, and use them as input to Zoltan partition
int xCellVarId;
int success = NCFUNC(inq_varid)(_fileId, "grid_center_lat", &xCellVarId);
ERRORS(success, "Failed to get variable id of grid_center_lat.");
@@ -874,7 +773,7 @@ ErrorCode NCHelperGCRM::redistribute_local_cells(int start_cell_idx)
NCDF_SIZE read_start = static_cast<NCDF_SIZE>(start_cell_idx - 1);
NCDF_SIZE read_count = static_cast<NCDF_SIZE>(nLocalCells);
success = NCFUNCAG(_vara_double)(_fileId, xCellVarId, &read_start, &read_count, &xCell[0]);
- ERRORS(success, "Failed to read xCell data.");
+ ERRORS(success, "Failed to read grid_center_lat data.");
// Read y coordinates of cell centers
int yCellVarId;
@@ -882,14 +781,12 @@ ErrorCode NCHelperGCRM::redistribute_local_cells(int start_cell_idx)
ERRORS(success, "Failed to get variable id of grid_center_lon.");
std::vector<double> yCell(nLocalCells);
success = NCFUNCAG(_vara_double)(_fileId, yCellVarId, &read_start, &read_count, &yCell[0]);
- ERRORS(success, "Failed to read yCell data.");
+ ERRORS(success, "Failed to read grid_center_lon data.");
+ // Convert lon/lat/rad to x/y/z
std::vector<double> zCell(nLocalCells);
- // convert to xyz cartesian coordinates
- double rad=8000; // this is just approx x is lat, y is lon
- for (int i=0; i<nLocalCells; i++)
+ double rad = 8000.0; // This is just a approximate radius
+ for (int i = 0; i < nLocalCells; i++) {
double cosphi = cos(xCell[i]);
double zmult = sin(xCell[i]);
double xmult = cosphi * cos(yCell[i]);
@@ -898,6 +795,7 @@ ErrorCode NCHelperGCRM::redistribute_local_cells(int start_cell_idx)
yCell[i] = rad * ymult;
zCell[i] = rad * zmult;
// Zoltan partition using RCB; maybe more studies would be good, as to which partition
// is better
@@ -991,20 +889,18 @@ ErrorCode NCHelperGCRM::create_local_vertices(const std::vector<int>& vertices_o
ERRORR(MB_FAILURE, "Couldn't find 'layers' or 'interfaces' variable.");
- // Decide whether down is positive
- char posval[10] = {0};
- int success = NCFUNC(get_att_text)(_fileId, (*vmit).second.varId, "positive", posval);
- if (0 == success && !strncmp(posval, "down", 4)) {
- for (std::vector<double>::iterator dvit = levVals.begin(); dvit != levVals.end(); ++dvit)
- (*dvit) *= -1.0;
+ // Decide whether down is positive
+ char posval[10] = {0};
+ int success = NCFUNC(get_att_text)(_fileId, (*vmit).second.varId, "positive", posval);
+ if (0 == success && !strncmp(posval, "down", 4)) {
+ for (std::vector<double>::iterator dvit = levVals.begin(); dvit != levVals.end(); ++dvit)
+ (*dvit) *= -1.0;
// Read x coordinates for local vertices
double* xptr = arrays[0];
int xVertexVarId;
- int success = NCFUNC(inq_varid)(_fileId, "grid_corner_lon", &xVertexVarId);
+ success = NCFUNC(inq_varid)(_fileId, "grid_corner_lon", &xVertexVarId);
ERRORS(success, "Failed to get variable id of grid_corner_lon.");
size_t indexInArray = 0;
for (Range::pair_iterator pair_iter = localGidVerts.pair_begin();
@@ -1074,11 +970,10 @@ ErrorCode NCHelperGCRM::create_local_vertices(const std::vector<int>& vertices_o
double* zptr = arrays[2];
- //const double pideg = acos(-1.0) / 180.0;
double rad = 8000.0 + levVals[0];
for (int i = 0; i < nLocalVertices; i++) {
double cosphi = cos(yptr[i]);
- double zmult = sin(yptr[i]);
+ double zmult = sin(yptr[i]);
double xmult = cosphi * cos(xptr[i]);
double ymult = cosphi * sin(xptr[i]);
xptr[i] = rad * xmult;
@@ -1100,7 +995,7 @@ ErrorCode NCHelperGCRM::create_local_edges(EntityHandle start_vertex)
int success = NCFUNC(inq_varid)(_fileId, "cell_edges", &edgesOnCellVarId);
ERRORS(success, "Failed to get variable id of cell_edges.");
- std::vector<int> edges_on_local_cells(nLocalCells * maxEdgesPerCell);
+ std::vector<int> edges_on_local_cells(nLocalCells * EDGES_PER_CELL);
dbgOut.tprintf(1, " edges_on_local_cells.size() = %d\n", (int)edges_on_local_cells.size());
#ifdef PNETCDF_FILE
@@ -1118,7 +1013,7 @@ ErrorCode NCHelperGCRM::create_local_edges(EntityHandle start_vertex)
dbgOut.tprintf(1, " starth = %d\n", (int)starth);
dbgOut.tprintf(1, " endh = %d\n", (int)endh);
- NCDF_SIZE read_counts[2] = {static_cast<NCDF_SIZE>(endh - starth + 1), static_cast<NCDF_SIZE>(maxEdgesPerCell)};
+ NCDF_SIZE read_counts[2] = {static_cast<NCDF_SIZE>(endh - starth + 1), static_cast<NCDF_SIZE>(EDGES_PER_CELL)};
#ifdef PNETCDF_FILE
@@ -1131,7 +1026,7 @@ ErrorCode NCHelperGCRM::create_local_edges(EntityHandle start_vertex)
ERRORS(success, "Failed to read cell_edges data in a loop");
#ifdef PNETCDF_FILE
@@ -1141,9 +1036,8 @@ ErrorCode NCHelperGCRM::create_local_edges(EntityHandle start_vertex)
#endif
// GCRM is 0 based, convert edge indices from 0 to 1 based
- for (std::size_t idx = 0; idx < edges_on_local_cells.size(); idx++) {
- edges_on_local_cells[idx] += 1;
+ for (std::size_t idx = 0; idx < edges_on_local_cells.size(); idx++)
+ edges_on_local_cells[idx] += 1;
// Collect local edges
std::sort(edges_on_local_cells.begin(), edges_on_local_cells.end());
@@ -1217,16 +1111,12 @@ ErrorCode NCHelperGCRM::create_local_edges(EntityHandle start_vertex)
#endif
- // GCRM is 0 based, convert edge indices from 0 to 1 based
- for (int idx = 0; idx < nLocalEdges*2; idx++) {
- vertices_on_local_edges[idx] += 1;
// Populate connectivity data for local edges
// Convert in-place from int (stored in the first half) to EntityHandle
// Reading backward is the trick
for (int edge_vert = nLocalEdges * 2 - 1; edge_vert >= 0; edge_vert--) {
- int global_vert_idx = vertices_on_local_edges[edge_vert]; // Global vertex index, 1 based
+ // Note, indices stored in vertices_on_local_edges are 0 based
+ int global_vert_idx = vertices_on_local_edges[edge_vert] + 1; // Global vertex index, 1 based
int local_vert_idx = localGidVerts.index(global_vert_idx); // Local vertex index, 0 based
assert(local_vert_idx != -1);
conn_arr_edges[edge_vert] = start_vertex + local_vert_idx;
@@ -1235,104 +1125,16 @@ ErrorCode NCHelperGCRM::create_local_edges(EntityHandle start_vertex)
return MB_SUCCESS;
-ErrorCode NCHelperGCRM::create_local_cells(const std::vector<int>& vertices_on_local_cells,
- EntityHandle start_vertex, Range& faces)
- Tag& mGlobalIdTag = _readNC->mGlobalIdTag;
- // Divide local cells into groups based on the number of edges
- Range local_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
- // Insert larger values before smaller ones to increase efficiency
- for (int i = nLocalCells - 1; i >= 0; i--) {
- int num_edges = DEFAULT_MAX_EDGES_PER_CELL;
- local_cells_with_n_edges[num_edges].insert(localGidCells[i]); // Global cell index
- std::vector<int> num_edges_on_cell_groups;
- for (int i = 3; i <= maxEdgesPerCell; i++) {
- if (local_cells_with_n_edges[i].size() > 0)
- num_edges_on_cell_groups.push_back(i);
- numCellGroups = num_edges_on_cell_groups.size();
- EntityHandle* conn_arr_local_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
- for (int i = 0; i < numCellGroups; i++) {
- int num_edges_per_cell = num_edges_on_cell_groups[i];
- int num_group_cells = (int)local_cells_with_n_edges[num_edges_per_cell].size();
- // Create local cells for each non-empty cell group
- EntityHandle start_element;
- ErrorCode rval = _readNC->readMeshIface->get_element_connect(num_group_cells, num_edges_per_cell, MBPOLYGON, 0, start_element,
- conn_arr_local_cells_with_n_edges[num_edges_per_cell], num_group_cells);
- ERRORR(rval, "Failed to create cells");
- faces.insert(start_element, start_element + num_group_cells - 1);
- // Add local cells to the file set
- Range local_cells_range(start_element, start_element + num_group_cells - 1);
- rval = _readNC->mbImpl->add_entities(_fileSet, local_cells_range);
- ERRORR(rval, "Failed to add local cells to the file set.");
- // Get ptr to gid memory for local cells
- int count = 0;
- void* data = NULL;
- rval = mbImpl->tag_iterate(mGlobalIdTag, local_cells_range.begin(), local_cells_range.end(), count, data);
- ERRORR(rval, "Failed to iterate global id tag on local cells.");
- assert(count == num_group_cells);
- int* gid_data = (int*) data;
- std::copy(local_cells_with_n_edges[num_edges_per_cell].begin(), local_cells_with_n_edges[num_edges_per_cell].end(), gid_data);
- // Set connectivity array with proper local vertices handles
- for (int j = 0; j < num_group_cells; j++) {
- EntityHandle global_cell_idx = local_cells_with_n_edges[num_edges_per_cell][j]; // Global cell index, 1 based
- // Populate cellHandleToGlobalID map to read cell variables
- cellHandleToGlobalID[start_element + j] = global_cell_idx;
- for (int k = 0; k < num_edges_per_cell; k++) {
- EntityHandle global_vert_idx = vertices_on_local_cells[local_cell_idx * maxEdgesPerCell + k]; // Global vertex index, 1 based
- int local_vert_idx = localGidVerts.index(global_vert_idx); // Local vertex index, 0 based
- assert(local_vert_idx != -1);
- conn_arr_local_cells_with_n_edges[num_edges_per_cell][j * num_edges_per_cell + k] =
- start_vertex + local_vert_idx;
- // make sure that if some nodes are repeated, they are at the end of the connectivity array
- // so, pentagons as hexagons should have a connectivity like 123455 and not 122345
- EntityHandle *pvertex= &(conn_arr_local_cells_with_n_edges[num_edges_per_cell][j * num_edges_per_cell ]);
- for (int k = 0; k < num_edges_per_cell-2; k++)
- if( *(pvertex+k) == *(pvertex+k+1) )
- // shift the connectivity
- for (int kk=k+1; kk<num_edges_per_cell-1; kk++)
- *(pvertex+kk)=*(pvertex+kk+1);
- return MB_SUCCESS;
ErrorCode NCHelperGCRM::create_padded_local_cells(const std::vector<int>& vertices_on_local_cells,
- // Only one group of cells (each cell is represented by a polygon with maxEdgesPerCell edges)
- numCellGroups = 1;
- // Create cells for this cell group
+ // Create cells
EntityHandle* conn_arr_local_cells = NULL;
- ErrorCode rval = _readNC->readMeshIface->get_element_connect(nLocalCells, maxEdgesPerCell, MBPOLYGON, 0, start_element, conn_arr_local_cells,
+ ErrorCode rval = _readNC->readMeshIface->get_element_connect(nLocalCells, EDGES_PER_CELL, MBPOLYGON, 0, start_element, conn_arr_local_cells,
// Might have to create gather mesh later
(createGatherSet ? nLocalCells + nCells : nLocalCells));
ERRORR(rval, "Failed to create cells.");
@@ -1353,14 +1155,15 @@ ErrorCode NCHelperGCRM::create_padded_local_cells(const std::vector<int>& vertic
std::copy(localGidCells.begin(), localGidCells.end(), gid_data);
- // vertices_on_local_cells array was already corrected to have the last vertices padded
- // no need for extra checks considering
+ // vertices_on_local_cells array was already corrected to have
+ // the last vertices repeated for pentagons, e.g. 122345 => 123455
- for (int i = 0; i < maxEdgesPerCell; i++) {
- EntityHandle global_vert_idx = vertices_on_local_cells[local_cell_idx * maxEdgesPerCell + i]; // Global vertex index, 1 based
+ for (int i = 0; i < EDGES_PER_CELL; i++) {
+ // Note, indices stored in vertices_on_local_cells are 1 based
+ EntityHandle global_vert_idx = vertices_on_local_cells[local_cell_idx * EDGES_PER_CELL + i]; // Global vertex index, 1 based
- conn_arr_local_cells[local_cell_idx * maxEdgesPerCell + i] = start_vertex + local_vert_idx;
+ conn_arr_local_cells[local_cell_idx * EDGES_PER_CELL + i] = start_vertex + local_vert_idx;
@@ -1387,8 +1190,8 @@ ErrorCode NCHelperGCRM::create_gather_set_vertices(EntityHandle gather_set, Enti
// Read x coordinates for gather set vertices
int xVertexVarId;
- int success = NCFUNC(inq_varid)(_fileId, "xVertex", &xVertexVarId);
- ERRORS(success, "Failed to get variable id of xVertex.");
+ int success = NCFUNC(inq_varid)(_fileId, "grid_corner_lon", &xVertexVarId);
+ ERRORS(success, "Failed to get variable id of grid_corner_lon.");
NCDF_SIZE read_start = 0;
NCDF_SIZE read_count = static_cast<NCDF_SIZE>(nVertices);
#ifdef PNETCDF_FILE
@@ -1396,49 +1199,44 @@ ErrorCode NCHelperGCRM::create_gather_set_vertices(EntityHandle gather_set, Enti
success = NCFUNC(begin_indep_data)(_fileId);
ERRORS(success, "Failed to begin independent I/O mode.");
success = NCFUNCG(_vara_double)(_fileId, xVertexVarId, &read_start, &read_count, xptr);
- ERRORS(success, "Failed to read xVertex data.");
+ ERRORS(success, "Failed to read grid_corner_lon data.");
success = NCFUNC(end_indep_data)(_fileId);
ERRORS(success, "Failed to end independent I/O mode.");
#else
#endif
// Read y coordinates for gather set vertices
double* yptr = arrays[1];
int yVertexVarId;
- success = NCFUNC(inq_varid)(_fileId, "yVertex", &yVertexVarId);
- ERRORS(success, "Failed to get variable id of yVertex.");
+ success = NCFUNC(inq_varid)(_fileId, "grid_corner_lat", &yVertexVarId);
+ ERRORS(success, "Failed to get variable id of grid_corner_lat.");
#ifdef PNETCDF_FILE
// Enter independent I/O mode, since this read is only for the gather processor
success = NCFUNCG(_vara_double)(_fileId, yVertexVarId, &read_start, &read_count, yptr);
- ERRORS(success, "Failed to read yVertex data.");
+ ERRORS(success, "Failed to read grid_corner_lat data.");
#else
#endif
- // Read z coordinates for gather set vertices
- int zVertexVarId;
- success = NCFUNC(inq_varid)(_fileId, "zVertex", &zVertexVarId);
- ERRORS(success, "Failed to get variable id of zVertex.");
-#ifdef PNETCDF_FILE
- // Enter independent I/O mode, since this read is only for the gather processor
- success = NCFUNC(begin_indep_data)(_fileId);
- ERRORS(success, "Failed to begin independent I/O mode.");
- success = NCFUNCG(_vara_double)(_fileId, zVertexVarId, &read_start, &read_count, zptr);
- ERRORS(success, "Failed to read zVertex data.");
- success = NCFUNC(end_indep_data)(_fileId);
- ERRORS(success, "Failed to end independent I/O mode.");
-#else
-#endif
+ double rad = 8000.0 + levVals[0];
+ for (int i = 0; i < nVertices; i++) {
+ double cosphi = cos(yptr[i]);
+ double xmult = cosphi * cos(xptr[i]);
+ double ymult = cosphi * sin(xptr[i]);
+ xptr[i] = rad * xmult;
+ yptr[i] = rad * ymult;
+ zptr[i] = rad * zmult;
// Get ptr to GID memory for gather set vertices
int count = 0;
@@ -1504,8 +1302,8 @@ ErrorCode NCHelperGCRM::create_gather_set_edges(EntityHandle gather_set, EntityH
for (int edge_vert = nEdges * 2 - 1; edge_vert >= 0; edge_vert--) {
- int gather_set_vert_idx = vertices_on_gather_set_edges[edge_vert]; // Global vertex index, 1 based
- gather_set_vert_idx--; // 1 based -> 0 based
+ // Note, indices stored in vertices_on_gather_set_edges are 0 based
+ int gather_set_vert_idx = vertices_on_gather_set_edges[edge_vert]; // Global vertex index, 0 based
// Connectivity array is shifted by where the gather set vertices start
conn_arr_gather_set_edges[edge_vert] = gather_set_start_vertex + gather_set_vert_idx;
@@ -1513,121 +1311,15 @@ ErrorCode NCHelperGCRM::create_gather_set_edges(EntityHandle gather_set, EntityH
return MB_SUCCESS;
-ErrorCode NCHelperGCRM::create_gather_set_cells(EntityHandle gather_set, EntityHandle gather_set_start_vertex)
- // Read number of edges on each gather set cell
- int nEdgesOnCellVarId;
- int success = NCFUNC(inq_varid)(_fileId, "nEdgesOnCell", &nEdgesOnCellVarId);
- ERRORS(success, "Failed to get variable id of nEdgesOnCell.");
- std::vector<int> num_edges_on_gather_set_cells(nCells);
- NCDF_SIZE read_start = 0;
- NCDF_SIZE read_count = static_cast<NCDF_SIZE>(nCells);
- success = NCFUNCG(_vara_int)(_fileId, nEdgesOnCellVarId, &read_start, &read_count, &num_edges_on_gather_set_cells[0]);
- ERRORS(success, "Failed to read nEdgesOnCell data.");
-#else
-#endif
- // Read vertices on each gather set cell (connectivity)
- int verticesOnCellVarId;
- success = NCFUNC(inq_varid)(_fileId, "verticesOnCell", &verticesOnCellVarId);
- ERRORS(success, "Failed to get variable id of verticesOnCell.");
- std::vector<int> vertices_on_gather_set_cells(nCells * maxEdgesPerCell);
- NCDF_SIZE read_starts[2] = {0, 0};
- NCDF_SIZE read_counts[2] = {static_cast<NCDF_SIZE>(nCells), static_cast<NCDF_SIZE>(maxEdgesPerCell)};
- success = NCFUNCG(_vara_int)(_fileId, verticesOnCellVarId, read_starts, read_counts, &vertices_on_gather_set_cells[0]);
- ERRORS(success, "Failed to read verticesOnCell data.");
-#else
-#endif
- // Divide gather set cells into groups based on the number of edges
- Range gather_set_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
- // Insert larger values before smaller values to increase efficiency
- for (int i = nCells - 1; i >= 0; i--) {
- int num_edges = num_edges_on_gather_set_cells[i];
- gather_set_cells_with_n_edges[num_edges].insert(i + 1); // 0 based -> 1 based
- EntityHandle* conn_arr_gather_set_cells_with_n_edges[DEFAULT_MAX_EDGES_PER_CELL + 1];
- for (int num_edges_per_cell = 3; num_edges_per_cell <= maxEdgesPerCell; num_edges_per_cell++) {
- int num_group_cells = gather_set_cells_with_n_edges[num_edges_per_cell].size();
- if (num_group_cells > 0) {
- conn_arr_gather_set_cells_with_n_edges[num_edges_per_cell], num_group_cells);
- ERRORR(rval, "Failed to create cells.");
- // Add cells to the gather set
- Range gather_set_cells_range(start_element, start_element + num_group_cells - 1);
- rval = mbImpl->add_entities(gather_set, gather_set_cells_range);
- ERRORR(rval, "Failed to add cells to the gather set.");
- int gather_set_cell_idx = gather_set_cells_with_n_edges[num_edges_per_cell][j]; // Global cell index, 1 based
- gather_set_cell_idx--; // 1 based -> 0 based
- EntityHandle gather_set_vert_idx = vertices_on_gather_set_cells[gather_set_cell_idx * maxEdgesPerCell + k]; // Global vertex index, 1 based
- // Connectivity array is shifted by where the gather set vertices start
- conn_arr_gather_set_cells_with_n_edges[num_edges_per_cell][j * num_edges_per_cell + k] =
- gather_set_start_vertex + gather_set_vert_idx;
ErrorCode NCHelperGCRM::create_padded_gather_set_cells(EntityHandle gather_set, EntityHandle gather_set_start_vertex)
-#else
-#endif
EntityHandle* conn_arr_gather_set_cells = NULL;
// Don't need to specify allocation number here, because we know enough cells were created before
- ErrorCode rval = _readNC->readMeshIface->get_element_connect(nCells, maxEdgesPerCell, MBPOLYGON, 0, start_element, conn_arr_gather_set_cells);
+ ErrorCode rval = _readNC->readMeshIface->get_element_connect(nCells, EDGES_PER_CELL, MBPOLYGON, 0, start_element, conn_arr_gather_set_cells);
@@ -1637,41 +1329,46 @@ ErrorCode NCHelperGCRM::create_padded_gather_set_cells(EntityHandle gather_set,
+ int success = NCFUNC(inq_varid)(_fileId, "cell_corners", &verticesOnCellVarId);
+ ERRORS(success, "Failed to get variable id of cell_corners.");
// Utilize the memory storage pointed by conn_arr_gather_set_cells
int* vertices_on_gather_set_cells = (int*) conn_arr_gather_set_cells;
+ NCDF_SIZE read_counts[2] = {static_cast<NCDF_SIZE>(nCells), static_cast<NCDF_SIZE>(EDGES_PER_CELL)};
#ifdef PNETCDF_FILE
success = NCFUNCG(_vara_int)(_fileId, verticesOnCellVarId, read_starts, read_counts, vertices_on_gather_set_cells);
+ ERRORS(success, "Failed to read cell_corners data.");
#else
#endif
- // Correct gather set cell vertices array in the same way as local cell vertices array,
- // replace the padded vertices with the last vertices in the corresponding cells
+ // Correct gather set cell vertices array in the same way as local cell vertices array
+ // Pentagons as hexagons should have a connectivity like 123455 and not 122345
for (int gather_set_cell_idx = 0; gather_set_cell_idx < nCells; gather_set_cell_idx++) {
- int num_edges = num_edges_on_gather_set_cells[gather_set_cell_idx];
- int idx_in_gather_set_vert_arr = gather_set_cell_idx * maxEdgesPerCell;
- int last_vert_idx = vertices_on_gather_set_cells[idx_in_gather_set_vert_arr + num_edges - 1];
- for (int i = num_edges; i < maxEdgesPerCell; i++)
- vertices_on_gather_set_cells[idx_in_gather_set_vert_arr + i] = last_vert_idx;
+ int* pvertex = vertices_on_gather_set_cells + gather_set_cell_idx * EDGES_PER_CELL;
+ break;
// Populate connectivity data for gather set cells
- for (int cell_vert = nCells * maxEdgesPerCell - 1; cell_vert >= 0; cell_vert--) {
- int gather_set_vert_idx = vertices_on_gather_set_cells[cell_vert]; // Global vertex index, 1 based
+ for (int cell_vert = nCells * EDGES_PER_CELL - 1; cell_vert >= 0; cell_vert--) {
+ // Note, indices stored in vertices_on_gather_set_cells are 0 based
+ int gather_set_vert_idx = vertices_on_gather_set_cells[cell_vert]; // Global vertex index, 0 based
conn_arr_gather_set_cells[cell_vert] = gather_set_start_vertex + gather_set_vert_idx;
diff --git a/src/io/NCHelperGCRM.hpp b/src/io/NCHelperGCRM.hpp
index b415bd2..2887e86 100644
--- a/src/io/NCHelperGCRM.hpp
+++ b/src/io/NCHelperGCRM.hpp
@@ -52,11 +52,7 @@ private:
//! Create local edges (optional)
ErrorCode create_local_edges(EntityHandle start_vertex);
- //! Create local cells without padding (cells are divided into groups based on the number of edges)
- ErrorCode create_local_cells(const std::vector<int>& vertices_on_local_cells,
- EntityHandle start_vertex, Range& faces);
- //! Create local cells with padding (padded cells will have the same number of edges)
+ //! Create local cells with padding (pentagons are padded to hexagons)
ErrorCode create_padded_local_cells(const std::vector<int>& vertices_on_local_cells,
@@ -66,17 +62,11 @@ private:
//! Create gather set edges (optional)
ErrorCode create_gather_set_edges(EntityHandle gather_set, EntityHandle gather_set_start_vertex);
- //! Create gather set cells without padding (cells are divided into groups based on the number of edges)
- ErrorCode create_gather_set_cells(EntityHandle gather_set, EntityHandle gather_set_start_vertex);
- //! Create gather set cells with padding (padded cells will have the same number of edges)
+ //! Create gather set cells with padding (pentagons are padded to hexagons)
ErrorCode create_padded_gather_set_cells(EntityHandle gather_set, EntityHandle gather_set_start_vertex);
private:
- int maxEdgesPerCell;
- int numCellGroups;
bool createGatherSet;
- std::map<EntityHandle, int> cellHandleToGlobalID;
Range facesOwned;
diff --git a/test/io/read_gcrm_nc.cpp b/test/io/read_gcrm_nc.cpp
index 35d6bcb..c4a2290 100644
--- a/test/io/read_gcrm_nc.cpp
+++ b/test/io/read_gcrm_nc.cpp
@@ -48,7 +48,7 @@ int main(int argc, char* argv[])
result += RUN_TEST(test_read_nomesh);
result += RUN_TEST(test_read_novars);
result += RUN_TEST(test_read_no_edges);
- //result += RUN_TEST(test_gather_onevar);
+ result += RUN_TEST(test_gather_onevar);
#ifdef USE_MPI
fail = MPI_Finalize();
@@ -494,7 +494,80 @@ void test_read_no_edges()
void test_gather_onevar()
- // TBD
+ Core moab;
+ Interface& mb = moab;
+ EntityHandle file_set;
+ ErrorCode rval = mb.create_meshset(MESHSET_SET, file_set);
+ CHECK_ERR(rval);
+ std::string opts;
+ get_options(opts);
+ // Read cell variable vorticity and create gather set on processor 0
+ opts += ";VARIABLE=vorticity;GATHER_SET=0";
+ rval = mb.load_file(example, &file_set, opts.c_str());
+ CHECK_ERR(rval);
+#ifdef USE_MPI
+ ParallelComm* pcomm = ParallelComm::get_pcomm(&mb, 0);
+ int rank = pcomm->proc_config().proc_rank();
+ Range cells, cells_owned;
+ rval = mb.get_entities_by_type(file_set, MBPOLYGON, cells);
+ CHECK_ERR(rval);
+ // Get local owned cells
+ rval = pcomm->filter_pstatus(cells, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &cells_owned);
+ CHECK_ERR(rval);
+ EntityHandle gather_set = 0;
+ if (0 == rank) {
+ // Get gather set
+ ReadUtilIface* readUtilIface;
+ mb.query_interface(readUtilIface);
+ rval = readUtilIface->get_gather_set(gather_set);
+ CHECK_ERR(rval);
+ assert(gather_set != 0);
+ Tag vorticity_tag0, gid_tag;
+ rval = mb.tag_get_handle("vorticity0", layers, MB_TYPE_DOUBLE, vorticity_tag0, MB_TAG_DENSE);
+ CHECK_ERR(rval);
+ rval = mb.tag_get_handle(GLOBAL_ID_TAG_NAME, 1, MB_TYPE_INTEGER, gid_tag, MB_TAG_DENSE);
+ CHECK_ERR(rval);
+ pcomm->gather_data(cells_owned, vorticity_tag0, gid_tag, gather_set, 0);
+ if (0 == rank) {
+ // Get gather set cells
+ Range gather_set_cells;
+ rval = mb.get_entities_by_type(gather_set, MBPOLYGON, gather_set_cells);
+ CHECK_ERR(rval);
+ CHECK_EQUAL((size_t)642, gather_set_cells.size());
+ CHECK_EQUAL((size_t)1, gather_set_cells.psize());
+ // Check vorticity0 tag values on 4 gather set cells: first cell, two median cells, and last cell
+ EntityHandle cell_ents[] = {gather_set_cells[0], gather_set_cells[320],
+ gather_set_cells[321], gather_set_cells[641]};
+ double vorticity0_val[4 * layers];
+ rval = mb.tag_get_data(vorticity_tag0, cell_ents, 4, vorticity0_val);
+ CHECK_ERR(rval);
+ // Only check first two layers
+ // Layer 0
+ CHECK_REAL_EQUAL(3.629994, vorticity0_val[0 * layers], eps);
+ CHECK_REAL_EQUAL(0.131688, vorticity0_val[1 * layers], eps);
+ CHECK_REAL_EQUAL(-0.554888, vorticity0_val[2 * layers], eps);
+ CHECK_REAL_EQUAL(-0.554888, vorticity0_val[3 * layers], eps);
+ // Layer 1
+ CHECK_REAL_EQUAL(3.629944, vorticity0_val[0 * layers + 1], eps);
+ CHECK_REAL_EQUAL(0.131686, vorticity0_val[1 * layers + 1], eps);
+ CHECK_REAL_EQUAL(-0.554881, vorticity0_val[2 * layers + 1], eps);
+ CHECK_REAL_EQUAL(-0.554881, vorticity0_val[3 * layers + 1], eps);
+#endif
void get_options(std::string& opts)
diff --git a/test/parallel/gcrm_par.cpp b/test/parallel/gcrm_par.cpp
index b2dae0a..c6b6fe4 100644
--- a/test/parallel/gcrm_par.cpp
+++ b/test/parallel/gcrm_par.cpp
@@ -54,8 +54,8 @@ int main(int argc, char* argv[])
result += RUN_TEST(test_read_mesh_parallel_rcbzoltan);
#endif
- //result += RUN_TEST(test_gather_onevar_on_rank0);
- //result += RUN_TEST(test_gather_onevar_on_rank1);
+ result += RUN_TEST(test_gather_onevar_on_rank0);
+ result += RUN_TEST(test_gather_onevar_on_rank1);
result += RUN_TEST(test_multiple_loads_of_same_file);
@@ -508,33 +508,39 @@ void gather_one_cell_var(int gather_set_rank)
- Tag ke_tag0, gid_tag;
- rval = mb.tag_get_handle("ke0", 1, MB_TYPE_DOUBLE, ke_tag0, MB_TAG_DENSE);
CHECK_ERR(rval);
CHECK_ERR(rval);
- pcomm->gather_data(cells_owned, ke_tag0, gid_tag, gather_set, gather_set_rank);
+ pcomm->gather_data(cells_owned, vorticity_tag0, gid_tag, gather_set, gather_set_rank);
if (gather_set_rank == rank) {
- CHECK_EQUAL((size_t)2, gather_set_cells.psize());
- // Check ke0 tag values on 4 gather set cells: first pentagon, last pentagon,
- // first hexagon and last hexagon
- EntityHandle cell_ents[] = {gather_set_cells[0], gather_set_cells[11],
- gather_set_cells[12], gather_set_cells[641]};
- double ke0_val[4];
- rval = mb.tag_get_data(ke_tag0, &cell_ents[0], 4, ke0_val);
- CHECK_REAL_EQUAL(15.001, ke0_val[0], eps);
- CHECK_REAL_EQUAL(15.012, ke0_val[1], eps);
- CHECK_REAL_EQUAL(16.013, ke0_val[2], eps);
- CHECK_REAL_EQUAL(16.642, ke0_val[3], eps);
+ rval = mb.tag_get_data(vorticity_tag0, &cell_ents[0], 4, vorticity0_val);
+ // Layer 0
+ // Layer 1
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
