[MOAB-dev] pytaps: can't import iBase and iMesh
Huayi Wei
huayiwei1984 at gmail.com
Tue Jun 10 08:55:52 CDT 2014
Maybe it's better to put some version information of CGM/MOAB/LASSO in
README file of PyTAPS. -- Huayi
On 2014?06?10? 20:47, Huayi Wei wrote:
> Hi, Paul,
> My MOAB's version is bd52ba12517416f4b6d2162696a41583b73d52ed, and
> PyTAPS 's version is 257bf8f93f29e0b1a2269ee94672db19480c9c5c ( the
> master branch).
> Best
> Huayi
> On 2014?06?10? 20:23, Paul Wilson wrote:
>> Hi all,
>> Maybe I missed this piece of the thread, but I wonder if this could
>> be a poorly/un-documented version mismatch problem?
>> Which version of MOAB and PyTAPS are you using?
>> Paul
>> On 06/09/2014 10:39 PM, Huayi Wei wrote:
>>> when I launch python, and import iBase and iMesh, the output like this:
>>> |why at why-XPS-15-9530:~$ python
>>> Python 2.7.6 (default, Mar 22 2014, 22:59:56)
>>> [GCC 4.8.2] on linux2
>>> Type "help", "copyright", "credits" or "license" for more information.
>>> >>> from itaps import iBase, iMesh
>>> Traceback (most recent call last):
>>> File "<stdin>", line 1, in <module>
>>> ImportError: /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg/itaps/iMesh.so: undefined symbol: imesh_getentities_
>>> Huayi
>>> On 2014å¹´06æoe^10æ---¥ 11:35, Huayi Wei wrote:
>>>> I put it into /etc/bash.bashrc, like following:
>>>> export
>>>> LD_LIBRARY_PATH=/home/why/software/itaps/parallel-shared/lib:$LD_LIBRARY_PATH
>>>> Huayi
>>>> On 2014å¹´06æoe^10æ---¥ 11:25, Anthony Scopatz wrote:
>>>>> Did you export it or just put in in the env?
>>>>> On Mon, Jun 9, 2014 at 10:24 PM, Huayi Wei <huayiwei1984 at gmail.com
>>>>> <mailto:huayiwei1984 at gmail.com>> wrote:
>>>>> I put it in env, here is my setting:
>>>>> |env | grep 'LD'
>>>>> LD_LIRARY_PATH=/home/why/software/itaps/parallel-shared/lib
>>>>> But the problem is still there.
>>>>> Best
>>>>> Huayi
>>>>> On 2014å¹´06æoe^10æ---¥ 10:54, Huayi Wei wrote:
>>>>>> Hi, Anthony,
>>>>>> Thanks for your reply. Now I rebuild cgm/moab/lasso with
>>>>>> âEUR"enable-shared option, but I still have the same problem.
>>>>>> Here is the content of my |setup.cfg| in pytaps dir:
>>>>>> |[global]
>>>>>> iMesh-path = /home/why/software/itaps/parallel-shared
>>>>>> iGeom-path = /home/why/software/itaps/parallel-shared
>>>>>> iRel-path = /home/why/software/itaps/parallel-shared
>>>>>> [egg_info]
>>>>>> tag_build =
>>>>>> tag_date = 0
>>>>>> tag_svn_revision = 0
>>>>>> [build_ext]
>>>>>> include-dirs = /home/why/software/itaps/parallel-shared/include
>>>>>> The following is the output of the command |sudo python
>>>>>> setup.py install|
>>>>>> |[sudo] password for why:
>>>>>> running install
>>>>>> running bdist_egg
>>>>>> running egg_info
>>>>>> writing requirements to PyTAPS.egg-info/requires.txt
>>>>>> writing PyTAPS.egg-info/PKG-INFO
>>>>>> writing top-level names to PyTAPS.egg-info/top_level.txt
>>>>>> writing dependency_links to PyTAPS.egg-info/dependency_links.txt
>>>>>> reading manifest file 'PyTAPS.egg-info/SOURCES.txt'
>>>>>> writing manifest file 'PyTAPS.egg-info/SOURCES.txt'
>>>>>> installing library code to build/bdist.linux-x86_64/egg
>>>>>> running install_lib
>>>>>> running build_py
>>>>>> running build_ext
>>>>>> Checking for usability of iRel...
>>>>>> cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iRel.c -o iRel.o
>>>>>> Checking for usability of iMesh...
>>>>>> cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iMesh.c -o iMesh.o
>>>>>> Checking for usability of iGeom...
>>>>>> cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iGeom.c -o iGeom.o
>>>>>> creating build/bdist.linux-x86_64/egg
>>>>>> creating build/bdist.linux-x86_64/egg/itaps
>>>>>> copying build/lib.linux-x86_64-2.7/itaps/iRel.so -> build/bdist.linux-x86_64/egg/itaps
>>>>>> copying build/lib.linux-x86_64-2.7/itaps/iMesh.so -> build/bdist.linux-x86_64/egg/itaps
>>>>>> copying build/lib.linux-x86_64-2.7/itaps/iMeshExtensions.so -> build/bdist.linux-x86_64/egg/itaps
>>>>>> copying build/lib.linux-x86_64-2.7/itaps/iGeom.so -> build/bdist.linux-x86_64/egg/itaps
>>>>>> copying build/lib.linux-x86_64-2.7/itaps/helpers.py -> build/bdist.linux-x86_64/egg/itaps
>>>>>> copying build/lib.linux-x86_64-2.7/itaps/iBase.so -> build/bdist.linux-x86_64/egg/itaps
>>>>>> copying build/lib.linux-x86_64-2.7/itaps/__init__.py -> build/bdist.linux-x86_64/egg/itaps
>>>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/helpers.py to helpers.pyc
>>>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/__init__.py to __init__.pyc
>>>>>> creating stub loader for itaps/iBase.so
>>>>>> creating stub loader for itaps/iRel.so
>>>>>> creating stub loader for itaps/iMesh.so
>>>>>> creating stub loader for itaps/iGeom.so
>>>>>> creating stub loader for itaps/iMeshExtensions.so
>>>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/iBase.py to iBase.pyc
>>>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/iRel.py to iRel.pyc
>>>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/iMesh.py to iMesh.pyc
>>>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/iGeom.py to iGeom.pyc
>>>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/iMeshExtensions.py to iMeshExtensions.pyc
>>>>>> creating build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>> installing scripts to build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>>>>> running install_scripts
>>>>>> running build_scripts
>>>>>> creating build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>>>>> copying build/scripts-2.7/tagviewer -> build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>>>>> changing mode of build/bdist.linux-x86_64/egg/EGG-INFO/scripts/tagviewer to 755
>>>>>> copying PyTAPS.egg-info/PKG-INFO -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>> copying PyTAPS.egg-info/SOURCES.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>> copying PyTAPS.egg-info/dependency_links.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>> copying PyTAPS.egg-info/not-zip-safe -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>> copying PyTAPS.egg-info/requires.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>> copying PyTAPS.egg-info/top_level.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>> writing build/bdist.linux-x86_64/egg/EGG-INFO/native_libs.txt
>>>>>> creating 'dist/PyTAPS-1.4-py2.7-linux-x86_64.egg' and adding 'build/bdist.linux-x86_64/egg' to it
>>>>>> removing 'build/bdist.linux-x86_64/egg' (and everything under it)
>>>>>> Processing PyTAPS-1.4-py2.7-linux-x86_64.egg
>>>>>> removing '/usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg' (and everything under it)
>>>>>> creating /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg
>>>>>> Extracting PyTAPS-1.4-py2.7-linux-x86_64.egg to /usr/local/lib/python2.7/dist-packages
>>>>>> PyTAPS 1.4 is already the active version in easy-install.pth
>>>>>> Installing tagviewer script to /usr/local/bin
>>>>>> Installed /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg
>>>>>> Processing dependencies for PyTAPS==1.4
>>>>>> Searching for numpy==1.8.1
>>>>>> Best match: numpy 1.8.1
>>>>>> numpy 1.8.1 is already the active version in easy-install.pth
>>>>>> Using /usr/lib/python2.7/dist-packages
>>>>>> Finished processing dependencies for PyTAPS==1.4
>>>>>> In the output, I donâEUR^(TM)t see any information about
>>>>>> linking iMesh.so with MOAB / iGeom.so with CGM / iRel.so with
>>>>>> Lasso.
>>>>>> Best
>>>>>> Huayi
>>>>>> âEUR<
>>>>> âEUR<
>>> âEUR<
>> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal:http://bit.ly/pphw-cal
>> Professor, Engineering Physics. ~http://cnerg.engr.wisc.edu
>> Faculty Director, Advanced Computing Infrastructure
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140610/2b177b71/attachment-0001.html>
