[MOAB-dev] pytaps: can't import iBase and iMesh
    Huayi Wei
    huayiwei1984 at gmail.com
    Tue Jun 10 07:47:56 CDT 2014
Hi, Paul,
My MOAB's version is  bd52ba12517416f4b6d2162696a41583b73d52ed, and
PyTAPS 's version is 257bf8f93f29e0b1a2269ee94672db19480c9c5c ( the
master branch).
Best
Huayi
On 2014?06?10? 20:23, Paul Wilson wrote:
> Hi all,
> Maybe I missed this piece of the thread, but I wonder if this could be
> a poorly/un-documented version mismatch problem?
> Which version of MOAB and PyTAPS are you using?
> Paul
> On 06/09/2014 10:39 PM, Huayi Wei wrote:
>> when I launch python, and import iBase and iMesh, the output like this:
>> |why at why-XPS-15-9530:~$ python
>> Python 2.7.6 (default, Mar 22 2014, 22:59:56)
>> [GCC 4.8.2] on linux2
>> Type "help", "copyright", "credits" or "license" for more information.
>> >>> from itaps import iBase, iMesh
>> Traceback (most recent call last):
>>    File "<stdin>", line 1, in <module>
>> ImportError: /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg/itaps/iMesh.so: undefined symbol: imesh_getentities_
>> Huayi
>> On 2014å¹´06æoe^10æ---¥ 11:35, Huayi Wei wrote:
>>> I put it into /etc/bash.bashrc, like following:
>>> export
>>> LD_LIBRARY_PATH=/home/why/software/itaps/parallel-shared/lib:$LD_LIBRARY_PATH
>>> Huayi
>>> On 2014å¹´06æoe^10æ---¥ 11:25, Anthony Scopatz wrote:
>>>> Did you export it or just put in in the env?
>>>> On Mon, Jun 9, 2014 at 10:24 PM, Huayi Wei <huayiwei1984 at gmail.com
>>>> <mailto:huayiwei1984 at gmail.com>> wrote:
>>>>     I put it in env, here is my setting:
>>>>     |env | grep 'LD'
>>>>     LD_LIRARY_PATH=/home/why/software/itaps/parallel-shared/lib
>>>>     But the problem is still there.
>>>>     Best
>>>>     Huayi
>>>>     On 2014å¹´06æoe^10æ---¥ 10:54, Huayi Wei wrote:
>>>>>     Hi, Anthony,
>>>>>     Thanks for your reply. Now I rebuild cgm/moab/lasso with
>>>>>     âEUR"enable-shared option, but I still have the same problem.
>>>>>     Here is the content of my |setup.cfg| in pytaps dir:
>>>>>     |[global]
>>>>>     iMesh-path   = /home/why/software/itaps/parallel-shared
>>>>>     iGeom-path   = /home/why/software/itaps/parallel-shared
>>>>>     iRel-path    = /home/why/software/itaps/parallel-shared
>>>>>     [egg_info]
>>>>>     tag_build =
>>>>>     tag_date = 0
>>>>>     tag_svn_revision = 0
>>>>>     [build_ext]
>>>>>     include-dirs = /home/why/software/itaps/parallel-shared/include
>>>>>     The following is the output of the command |sudo python
>>>>>     setup.py install|
>>>>>     |[sudo] password for why:
>>>>>     running install
>>>>>     running bdist_egg
>>>>>     running egg_info
>>>>>     writing requirements to PyTAPS.egg-info/requires.txt
>>>>>     writing PyTAPS.egg-info/PKG-INFO
>>>>>     writing top-level names to PyTAPS.egg-info/top_level.txt
>>>>>     writing dependency_links to PyTAPS.egg-info/dependency_links.txt
>>>>>     reading manifest file 'PyTAPS.egg-info/SOURCES.txt'
>>>>>     writing manifest file 'PyTAPS.egg-info/SOURCES.txt'
>>>>>     installing library code to build/bdist.linux-x86_64/egg
>>>>>     running install_lib
>>>>>     running build_py
>>>>>     running build_ext
>>>>>     Checking for usability of iRel...
>>>>>     cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iRel.c -o iRel.o
>>>>>     Checking for usability of iMesh...
>>>>>     cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iMesh.c -o iMesh.o
>>>>>     Checking for usability of iGeom...
>>>>>     cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iGeom.c -o iGeom.o
>>>>>     creating build/bdist.linux-x86_64/egg
>>>>>     creating build/bdist.linux-x86_64/egg/itaps
>>>>>     copying build/lib.linux-x86_64-2.7/itaps/iRel.so -> build/bdist.linux-x86_64/egg/itaps
>>>>>     copying build/lib.linux-x86_64-2.7/itaps/iMesh.so -> build/bdist.linux-x86_64/egg/itaps
>>>>>     copying build/lib.linux-x86_64-2.7/itaps/iMeshExtensions.so -> build/bdist.linux-x86_64/egg/itaps
>>>>>     copying build/lib.linux-x86_64-2.7/itaps/iGeom.so -> build/bdist.linux-x86_64/egg/itaps
>>>>>     copying build/lib.linux-x86_64-2.7/itaps/helpers.py -> build/bdist.linux-x86_64/egg/itaps
>>>>>     copying build/lib.linux-x86_64-2.7/itaps/iBase.so -> build/bdist.linux-x86_64/egg/itaps
>>>>>     copying build/lib.linux-x86_64-2.7/itaps/__init__.py -> build/bdist.linux-x86_64/egg/itaps
>>>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/helpers.py to helpers.pyc
>>>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/__init__.py to __init__.pyc
>>>>>     creating stub loader for itaps/iBase.so
>>>>>     creating stub loader for itaps/iRel.so
>>>>>     creating stub loader for itaps/iMesh.so
>>>>>     creating stub loader for itaps/iGeom.so
>>>>>     creating stub loader for itaps/iMeshExtensions.so
>>>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iBase.py to iBase.pyc
>>>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iRel.py to iRel.pyc
>>>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iMesh.py to iMesh.pyc
>>>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iGeom.py to iGeom.pyc
>>>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iMeshExtensions.py to iMeshExtensions.pyc
>>>>>     creating build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>     installing scripts to build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>>>>     running install_scripts
>>>>>     running build_scripts
>>>>>     creating build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>>>>     copying build/scripts-2.7/tagviewer -> build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>>>>     changing mode of build/bdist.linux-x86_64/egg/EGG-INFO/scripts/tagviewer to 755
>>>>>     copying PyTAPS.egg-info/PKG-INFO -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>     copying PyTAPS.egg-info/SOURCES.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>     copying PyTAPS.egg-info/dependency_links.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>     copying PyTAPS.egg-info/not-zip-safe -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>     copying PyTAPS.egg-info/requires.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>     copying PyTAPS.egg-info/top_level.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>     writing build/bdist.linux-x86_64/egg/EGG-INFO/native_libs.txt
>>>>>     creating 'dist/PyTAPS-1.4-py2.7-linux-x86_64.egg' and adding 'build/bdist.linux-x86_64/egg' to it
>>>>>     removing 'build/bdist.linux-x86_64/egg' (and everything under it)
>>>>>     Processing PyTAPS-1.4-py2.7-linux-x86_64.egg
>>>>>     removing '/usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg' (and everything under it)
>>>>>     creating /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg
>>>>>     Extracting PyTAPS-1.4-py2.7-linux-x86_64.egg to /usr/local/lib/python2.7/dist-packages
>>>>>     PyTAPS 1.4 is already the active version in easy-install.pth
>>>>>     Installing tagviewer script to /usr/local/bin
>>>>>     Installed /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg
>>>>>     Processing dependencies for PyTAPS==1.4
>>>>>     Searching for numpy==1.8.1
>>>>>     Best match: numpy 1.8.1
>>>>>     numpy 1.8.1 is already the active version in easy-install.pth
>>>>>     Using /usr/lib/python2.7/dist-packages
>>>>>     Finished processing dependencies for PyTAPS==1.4
>>>>>     In the output, I donâEUR^(TM)t see any information about
>>>>>     linking iMesh.so with MOAB / iGeom.so with CGM / iRel.so with
>>>>>     Lasso.
>>>>>     Best
>>>>>     Huayi
>>>>>     âEUR<
>>>>     âEUR<
>> âEUR<
> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal:http://bit.ly/pphw-cal
> Professor, Engineering Physics. ~http://cnerg.engr.wisc.edu
> Faculty Director, Advanced Computing Infrastructure
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140610/7696670c/attachment-0001.html>
