[MOAB-dev] pytaps: can't import iBase and iMesh
    Huayi Wei
    huayiwei1984 at gmail.com
    Thu Jun 12 19:48:55 CDT 2014
Hi, Paul and Anthony
Finally, I can install PyTAPS on my computer and run it successfully. In
PyTAPS' README file, the instruction is just
|python setup.py --iMesh-path=PATH install
But by my test, one should build PyTAPS first, like following
|python setup.py build
sudo python setup.py install
Of course, one should firstly set the path of the CGM/MOAB/LASSO if they
are not in standard path.
Best
Huayi
On 2014?06?10? 21:55, Huayi Wei wrote:
> Maybe it's better to put some version information of CGM/MOAB/LASSO in
> README file of PyTAPS.  -- Huayi
> On 2014?06?10? 20:47, Huayi Wei wrote:
>> Hi, Paul,
>> My MOAB's version is bd52ba12517416f4b6d2162696a41583b73d52ed, and
>> PyTAPS 's version is 257bf8f93f29e0b1a2269ee94672db19480c9c5c ( the
>> master branch).
>> Best
>> Huayi
>> On 2014?06?10? 20:23, Paul Wilson wrote:
>>> Hi all,
>>> Maybe I missed this piece of the thread, but I wonder if this could
>>> be a poorly/un-documented version mismatch problem?
>>> Which version of MOAB and PyTAPS are you using?
>>> Paul
>>> On 06/09/2014 10:39 PM, Huayi Wei wrote:
>>>> when I launch python, and import iBase and iMesh, the output like this:
>>>> |why at why-XPS-15-9530:~$ python
>>>> Python 2.7.6 (default, Mar 22 2014, 22:59:56)
>>>> [GCC 4.8.2] on linux2
>>>> Type "help", "copyright", "credits" or "license" for more information.
>>>> >>> from itaps import iBase, iMesh
>>>> Traceback (most recent call last):
>>>>    File "<stdin>", line 1, in <module>
>>>> ImportError: /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg/itaps/iMesh.so: undefined symbol: imesh_getentities_
>>>> Huayi
>>>> On 2014å¹´06æoe^10æ---¥ 11:35, Huayi Wei wrote:
>>>>> I put it into /etc/bash.bashrc, like following:
>>>>> export
>>>>> LD_LIBRARY_PATH=/home/why/software/itaps/parallel-shared/lib:$LD_LIBRARY_PATH
>>>>> Huayi
>>>>> On 2014å¹´06æoe^10æ---¥ 11:25, Anthony Scopatz wrote:
>>>>>> Did you export it or just put in in the env?
>>>>>> On Mon, Jun 9, 2014 at 10:24 PM, Huayi Wei
>>>>>> <huayiwei1984 at gmail.com <mailto:huayiwei1984 at gmail.com>> wrote:
>>>>>>     I put it in env, here is my setting:
>>>>>>     |env | grep 'LD'
>>>>>>     LD_LIRARY_PATH=/home/why/software/itaps/parallel-shared/lib
>>>>>>     But the problem is still there.
>>>>>>     Best
>>>>>>     Huayi
>>>>>>     On 2014å¹´06æoe^10æ---¥ 10:54, Huayi Wei wrote:
>>>>>>>     Hi, Anthony,
>>>>>>>     Thanks for your reply. Now I rebuild cgm/moab/lasso with
>>>>>>>     âEUR"enable-shared option, but I still have the same
>>>>>>>     problem. Here is the content of my |setup.cfg| in pytaps dir:
>>>>>>>     |[global]
>>>>>>>     iMesh-path   = /home/why/software/itaps/parallel-shared
>>>>>>>     iGeom-path   = /home/why/software/itaps/parallel-shared
>>>>>>>     iRel-path    = /home/why/software/itaps/parallel-shared
>>>>>>>     [egg_info]
>>>>>>>     tag_build =
>>>>>>>     tag_date = 0
>>>>>>>     tag_svn_revision = 0
>>>>>>>     [build_ext]
>>>>>>>     include-dirs = /home/why/software/itaps/parallel-shared/include
>>>>>>>     The following is the output of the command |sudo python
>>>>>>>     setup.py install|
>>>>>>>     |[sudo] password for why:
>>>>>>>     running install
>>>>>>>     running bdist_egg
>>>>>>>     running egg_info
>>>>>>>     writing requirements to PyTAPS.egg-info/requires.txt
>>>>>>>     writing PyTAPS.egg-info/PKG-INFO
>>>>>>>     writing top-level names to PyTAPS.egg-info/top_level.txt
>>>>>>>     writing dependency_links to PyTAPS.egg-info/dependency_links.txt
>>>>>>>     reading manifest file 'PyTAPS.egg-info/SOURCES.txt'
>>>>>>>     writing manifest file 'PyTAPS.egg-info/SOURCES.txt'
>>>>>>>     installing library code to build/bdist.linux-x86_64/egg
>>>>>>>     running install_lib
>>>>>>>     running build_py
>>>>>>>     running build_ext
>>>>>>>     Checking for usability of iRel...
>>>>>>>     cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iRel.c -o iRel.o
>>>>>>>     Checking for usability of iMesh...
>>>>>>>     cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iMesh.c -o iMesh.o
>>>>>>>     Checking for usability of iGeom...
>>>>>>>     cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iGeom.c -o iGeom.o
>>>>>>>     creating build/bdist.linux-x86_64/egg
>>>>>>>     creating build/bdist.linux-x86_64/egg/itaps
>>>>>>>     copying build/lib.linux-x86_64-2.7/itaps/iRel.so -> build/bdist.linux-x86_64/egg/itaps
>>>>>>>     copying build/lib.linux-x86_64-2.7/itaps/iMesh.so -> build/bdist.linux-x86_64/egg/itaps
>>>>>>>     copying build/lib.linux-x86_64-2.7/itaps/iMeshExtensions.so -> build/bdist.linux-x86_64/egg/itaps
>>>>>>>     copying build/lib.linux-x86_64-2.7/itaps/iGeom.so -> build/bdist.linux-x86_64/egg/itaps
>>>>>>>     copying build/lib.linux-x86_64-2.7/itaps/helpers.py -> build/bdist.linux-x86_64/egg/itaps
>>>>>>>     copying build/lib.linux-x86_64-2.7/itaps/iBase.so -> build/bdist.linux-x86_64/egg/itaps
>>>>>>>     copying build/lib.linux-x86_64-2.7/itaps/__init__.py -> build/bdist.linux-x86_64/egg/itaps
>>>>>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/helpers.py to helpers.pyc
>>>>>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/__init__.py to __init__.pyc
>>>>>>>     creating stub loader for itaps/iBase.so
>>>>>>>     creating stub loader for itaps/iRel.so
>>>>>>>     creating stub loader for itaps/iMesh.so
>>>>>>>     creating stub loader for itaps/iGeom.so
>>>>>>>     creating stub loader for itaps/iMeshExtensions.so
>>>>>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iBase.py to iBase.pyc
>>>>>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iRel.py to iRel.pyc
>>>>>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iMesh.py to iMesh.pyc
>>>>>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iGeom.py to iGeom.pyc
>>>>>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iMeshExtensions.py to iMeshExtensions.pyc
>>>>>>>     creating build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>>>     installing scripts to build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>>>>>>     running install_scripts
>>>>>>>     running build_scripts
>>>>>>>     creating build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>>>>>>     copying build/scripts-2.7/tagviewer -> build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>>>>>>     changing mode of build/bdist.linux-x86_64/egg/EGG-INFO/scripts/tagviewer to 755
>>>>>>>     copying PyTAPS.egg-info/PKG-INFO -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>>>     copying PyTAPS.egg-info/SOURCES.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>>>     copying PyTAPS.egg-info/dependency_links.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>>>     copying PyTAPS.egg-info/not-zip-safe -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>>>     copying PyTAPS.egg-info/requires.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>>>     copying PyTAPS.egg-info/top_level.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>>>>>     writing build/bdist.linux-x86_64/egg/EGG-INFO/native_libs.txt
>>>>>>>     creating 'dist/PyTAPS-1.4-py2.7-linux-x86_64.egg' and adding 'build/bdist.linux-x86_64/egg' to it
>>>>>>>     removing 'build/bdist.linux-x86_64/egg' (and everything under it)
>>>>>>>     Processing PyTAPS-1.4-py2.7-linux-x86_64.egg
>>>>>>>     removing '/usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg' (and everything under it)
>>>>>>>     creating /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg
>>>>>>>     Extracting PyTAPS-1.4-py2.7-linux-x86_64.egg to /usr/local/lib/python2.7/dist-packages
>>>>>>>     PyTAPS 1.4 is already the active version in easy-install.pth
>>>>>>>     Installing tagviewer script to /usr/local/bin
>>>>>>>     Installed /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg
>>>>>>>     Processing dependencies for PyTAPS==1.4
>>>>>>>     Searching for numpy==1.8.1
>>>>>>>     Best match: numpy 1.8.1
>>>>>>>     numpy 1.8.1 is already the active version in easy-install.pth
>>>>>>>     Using /usr/lib/python2.7/dist-packages
>>>>>>>     Finished processing dependencies for PyTAPS==1.4
>>>>>>>     In the output, I donâEUR^(TM)t see any information about
>>>>>>>     linking iMesh.so with MOAB / iGeom.so with CGM / iRel.so
>>>>>>>     with Lasso.
>>>>>>>     Best
>>>>>>>     Huayi
>>>>>>>     âEUR<
>>>>>>     âEUR<
>>>> âEUR<
>>> Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal:http://bit.ly/pphw-cal
>>> Professor, Engineering Physics. ~http://cnerg.engr.wisc.edu
>>> Faculty Director, Advanced Computing Infrastructure
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140613/089a8544/attachment-0001.html>
