[MOAB-dev] pytaps: can't import iBase and iMesh
Paul Wilson
wilsonp at engr.wisc.edu
Tue Jun 10 07:23:44 CDT 2014
Hi all,
Maybe I missed this piece of the thread, but I wonder if this could be a
poorly/un-documented version mismatch problem?
Which version of MOAB and PyTAPS are you using?
Paul
On 06/09/2014 10:39 PM, Huayi Wei wrote:
> when I launch python, and import iBase and iMesh, the output like this:
> |why at why-XPS-15-9530:~$ python
> Python 2.7.6 (default, Mar 22 2014, 22:59:56)
> [GCC 4.8.2] on linux2
> Type "help", "copyright", "credits" or "license" for more information.
> >>> from itaps import iBase, iMesh
> Traceback (most recent call last):
> File "<stdin>", line 1, in <module>
> ImportError: /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg/itaps/iMesh.so: undefined symbol: imesh_getentities_
> Huayi
> On 2014å¹´06æoe^10æ---¥ 11:35, Huayi Wei wrote:
>> I put it into /etc/bash.bashrc, like following:
>> export
>> LD_LIBRARY_PATH=/home/why/software/itaps/parallel-shared/lib:$LD_LIBRARY_PATH
>> Huayi
>> On 2014å¹´06æoe^10æ---¥ 11:25, Anthony Scopatz wrote:
>>> Did you export it or just put in in the env?
>>> On Mon, Jun 9, 2014 at 10:24 PM, Huayi Wei <huayiwei1984 at gmail.com
>>> <mailto:huayiwei1984 at gmail.com>> wrote:
>>> I put it in env, here is my setting:
>>> |env | grep 'LD'
>>> LD_LIRARY_PATH=/home/why/software/itaps/parallel-shared/lib
>>> But the problem is still there.
>>> Best
>>> Huayi
>>> On 2014å¹´06æoe^10æ---¥ 10:54, Huayi Wei wrote:
>>>> Hi, Anthony,
>>>> Thanks for your reply. Now I rebuild cgm/moab/lasso with
>>>> âEUR"enable-shared option, but I still have the same problem.
>>>> Here is the content of my |setup.cfg| in pytaps dir:
>>>> |[global]
>>>> iMesh-path = /home/why/software/itaps/parallel-shared
>>>> iGeom-path = /home/why/software/itaps/parallel-shared
>>>> iRel-path = /home/why/software/itaps/parallel-shared
>>>> [egg_info]
>>>> tag_build =
>>>> tag_date = 0
>>>> tag_svn_revision = 0
>>>> [build_ext]
>>>> include-dirs = /home/why/software/itaps/parallel-shared/include
>>>> The following is the output of the command |sudo python
>>>> setup.py install|
>>>> |[sudo] password for why:
>>>> running install
>>>> running bdist_egg
>>>> running egg_info
>>>> writing requirements to PyTAPS.egg-info/requires.txt
>>>> writing PyTAPS.egg-info/PKG-INFO
>>>> writing top-level names to PyTAPS.egg-info/top_level.txt
>>>> writing dependency_links to PyTAPS.egg-info/dependency_links.txt
>>>> reading manifest file 'PyTAPS.egg-info/SOURCES.txt'
>>>> writing manifest file 'PyTAPS.egg-info/SOURCES.txt'
>>>> installing library code to build/bdist.linux-x86_64/egg
>>>> running install_lib
>>>> running build_py
>>>> running build_ext
>>>> Checking for usability of iRel...
>>>> cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iRel.c -o iRel.o
>>>> Checking for usability of iMesh...
>>>> cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iMesh.c -o iMesh.o
>>>> Checking for usability of iGeom...
>>>> cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iGeom.c -o iGeom.o
>>>> creating build/bdist.linux-x86_64/egg
>>>> creating build/bdist.linux-x86_64/egg/itaps
>>>> copying build/lib.linux-x86_64-2.7/itaps/iRel.so -> build/bdist.linux-x86_64/egg/itaps
>>>> copying build/lib.linux-x86_64-2.7/itaps/iMesh.so -> build/bdist.linux-x86_64/egg/itaps
>>>> copying build/lib.linux-x86_64-2.7/itaps/iMeshExtensions.so -> build/bdist.linux-x86_64/egg/itaps
>>>> copying build/lib.linux-x86_64-2.7/itaps/iGeom.so -> build/bdist.linux-x86_64/egg/itaps
>>>> copying build/lib.linux-x86_64-2.7/itaps/helpers.py -> build/bdist.linux-x86_64/egg/itaps
>>>> copying build/lib.linux-x86_64-2.7/itaps/iBase.so -> build/bdist.linux-x86_64/egg/itaps
>>>> copying build/lib.linux-x86_64-2.7/itaps/__init__.py -> build/bdist.linux-x86_64/egg/itaps
>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/helpers.py to helpers.pyc
>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/__init__.py to __init__.pyc
>>>> creating stub loader for itaps/iBase.so
>>>> creating stub loader for itaps/iRel.so
>>>> creating stub loader for itaps/iMesh.so
>>>> creating stub loader for itaps/iGeom.so
>>>> creating stub loader for itaps/iMeshExtensions.so
>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/iBase.py to iBase.pyc
>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/iRel.py to iRel.pyc
>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/iMesh.py to iMesh.pyc
>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/iGeom.py to iGeom.pyc
>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/iMeshExtensions.py to iMeshExtensions.pyc
>>>> creating build/bdist.linux-x86_64/egg/EGG-INFO
>>>> installing scripts to build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>>> running install_scripts
>>>> running build_scripts
>>>> creating build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>>> copying build/scripts-2.7/tagviewer -> build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>>> changing mode of build/bdist.linux-x86_64/egg/EGG-INFO/scripts/tagviewer to 755
>>>> copying PyTAPS.egg-info/PKG-INFO -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>> copying PyTAPS.egg-info/SOURCES.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>> copying PyTAPS.egg-info/dependency_links.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>> copying PyTAPS.egg-info/not-zip-safe -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>> copying PyTAPS.egg-info/requires.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>> copying PyTAPS.egg-info/top_level.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>> writing build/bdist.linux-x86_64/egg/EGG-INFO/native_libs.txt
>>>> creating 'dist/PyTAPS-1.4-py2.7-linux-x86_64.egg' and adding 'build/bdist.linux-x86_64/egg' to it
>>>> removing 'build/bdist.linux-x86_64/egg' (and everything under it)
>>>> Processing PyTAPS-1.4-py2.7-linux-x86_64.egg
>>>> removing '/usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg' (and everything under it)
>>>> creating /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg
>>>> Extracting PyTAPS-1.4-py2.7-linux-x86_64.egg to /usr/local/lib/python2.7/dist-packages
>>>> PyTAPS 1.4 is already the active version in easy-install.pth
>>>> Installing tagviewer script to /usr/local/bin
>>>> Installed /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg
>>>> Processing dependencies for PyTAPS==1.4
>>>> Searching for numpy==1.8.1
>>>> Best match: numpy 1.8.1
>>>> numpy 1.8.1 is already the active version in easy-install.pth
>>>> Using /usr/lib/python2.7/dist-packages
>>>> Finished processing dependencies for PyTAPS==1.4
>>>> In the output, I donâEUR^(TM)t see any information about
>>>> linking iMesh.so with MOAB / iGeom.so with CGM / iRel.so with
>>>> Lasso.
>>>> Best
>>>> Huayi
>>>> âEUR<
>>> âEUR<
> âEUR<
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Faculty Director, Advanced Computing Infrastructure
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140610/fe129c10/attachment-0001.html>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140610/fe129c10/attachment-0001.bin>
