[MOAB-dev] pytaps: can't import iBase and iMesh
Huayi Wei
huayiwei1984 at gmail.com
Tue Jun 10 02:48:12 CDT 2014
Hi, Anthony,
I do some tests on |setup.py|, and notice a strange thing. When I launch
python and do following tests:
|why at why-XPS-15-9530:~$ python
Python 2.7.6 (default, Mar 22 2014, 22:59:56)
[GCC 4.8.2] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import os
>>> os.getenv('LD_LIBRARY_PATH')
'/home/why/software/itaps/parallel-shared/lib'
I can get the value of |LD_LIBRARY_PATH| as I want.
But in |setup.py|, I put |os.getenv(‘LD_LIBRARY_PATH’)| in
|ITAPSCommand._find_defs()| and I get None, please see following codes
and output.
| @staticmethod
def _find_defs(iface, path=None):
if path:
if os.path.isfile(path):
return os.path.normpath(path)
name = os.path.join(path, iface+'-Defs.inc')
if os.path.isfile(name):
return os.path.normpath(name)
name = os.path.join(path, 'lib', iface+'-Defs.inc')
raise Exception("Unable to locate %s-Defs.inc" % iface)
elif iface.upper()+'_DEFS' in os.environ:
name = os.getenv(iface.upper()+"_DEFS")
else:
# try a bunch of places where iXxx-Defs.inc might be located
search = [os.path.join(i, '..', 'lib') for i in
os.getenv('PATH', "").split(':') +
os.getenv('CPATH', "").split(':')] + \
os.getenv('LD_LIBRARY_PATH', "").split(':') + \
['/usr/local/lib', '/usr/lib']
print search
print os.getenv('LD_LIBRARY_PATH')
for i in search:
name = os.path.join(i, iface+'-Defs.inc')
|['/usr/local/sbin/../lib', '/usr/local/bin/../lib', '/usr/sbin/../lib', '/usr/bin/../lib', '/sbin/../lib', '/bin/../lib', '../lib', '', '/usr/local/lib', '/usr/lib']
None
None
None
That means |setup.py| didn’t find right thing. Is is a bug? Can you give
me some furthermore hints? Thanks very much.
Best
Huayi
On 2014年06月10日 11:39, Huayi Wei wrote:
> when I launch python, and import iBase and iMesh, the output like this:
> >>> from itaps import iBase, iMesh
> Traceback (most recent call last):
> File "<stdin>", line 1, in <module>
> ImportError: /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg/itaps/iMesh.so: undefined symbol: imesh_getentities_
> Huayi
> On 2014年06月10日 11:35, Huayi Wei wrote:
>> I put it into /etc/bash.bashrc, like following:
>> export
>> LD_LIBRARY_PATH=/home/why/software/itaps/parallel-shared/lib:$LD_LIBRARY_PATH
>> Huayi
>> On 2014年06月10日 11:25, Anthony Scopatz wrote:
>>> Did you export it or just put in in the env?
>>> On Mon, Jun 9, 2014 at 10:24 PM, Huayi Wei <huayiwei1984 at gmail.com
>>> <mailto:huayiwei1984 at gmail.com>> wrote:
>>> I put it in env, here is my setting:
>>> |env | grep 'LD'
>>> LD_LIRARY_PATH=/home/why/software/itaps/parallel-shared/lib
>>> But the problem is still there.
>>> Best
>>> Huayi
>>> On 2014年06月10日 10:54, Huayi Wei wrote:
>>>> Hi, Anthony,
>>>> Thanks for your reply. Now I rebuild cgm/moab/lasso with
>>>> —enable-shared option, but I still have the same problem. Here
>>>> is the content of my |setup.cfg| in pytaps dir:
>>>> |[global]
>>>> iMesh-path = /home/why/software/itaps/parallel-shared
>>>> iGeom-path = /home/why/software/itaps/parallel-shared
>>>> iRel-path = /home/why/software/itaps/parallel-shared
>>>> [egg_info]
>>>> tag_build =
>>>> tag_date = 0
>>>> tag_svn_revision = 0
>>>> [build_ext]
>>>> include-dirs = /home/why/software/itaps/parallel-shared/include
>>>> The following is the output of the command |sudo python
>>>> setup.py install|
>>>> |[sudo] password for why:
>>>> running install
>>>> running bdist_egg
>>>> running egg_info
>>>> writing requirements to PyTAPS.egg-info/requires.txt
>>>> writing PyTAPS.egg-info/PKG-INFO
>>>> writing top-level names to PyTAPS.egg-info/top_level.txt
>>>> writing dependency_links to PyTAPS.egg-info/dependency_links.txt
>>>> reading manifest file 'PyTAPS.egg-info/SOURCES.txt'
>>>> writing manifest file 'PyTAPS.egg-info/SOURCES.txt'
>>>> installing library code to build/bdist.linux-x86_64/egg
>>>> running install_lib
>>>> running build_py
>>>> running build_ext
>>>> Checking for usability of iRel...
>>>> cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iRel.c -o iRel.o
>>>> Checking for usability of iMesh...
>>>> cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iMesh.c -o iMesh.o
>>>> Checking for usability of iGeom...
>>>> cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iGeom.c -o iGeom.o
>>>> creating build/bdist.linux-x86_64/egg
>>>> creating build/bdist.linux-x86_64/egg/itaps
>>>> copying build/lib.linux-x86_64-2.7/itaps/iRel.so -> build/bdist.linux-x86_64/egg/itaps
>>>> copying build/lib.linux-x86_64-2.7/itaps/iMesh.so -> build/bdist.linux-x86_64/egg/itaps
>>>> copying build/lib.linux-x86_64-2.7/itaps/iMeshExtensions.so -> build/bdist.linux-x86_64/egg/itaps
>>>> copying build/lib.linux-x86_64-2.7/itaps/iGeom.so -> build/bdist.linux-x86_64/egg/itaps
>>>> copying build/lib.linux-x86_64-2.7/itaps/helpers.py -> build/bdist.linux-x86_64/egg/itaps
>>>> copying build/lib.linux-x86_64-2.7/itaps/iBase.so -> build/bdist.linux-x86_64/egg/itaps
>>>> copying build/lib.linux-x86_64-2.7/itaps/__init__.py -> build/bdist.linux-x86_64/egg/itaps
>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/helpers.py to helpers.pyc
>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/__init__.py to __init__.pyc
>>>> creating stub loader for itaps/iBase.so
>>>> creating stub loader for itaps/iRel.so
>>>> creating stub loader for itaps/iMesh.so
>>>> creating stub loader for itaps/iGeom.so
>>>> creating stub loader for itaps/iMeshExtensions.so
>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/iBase.py to iBase.pyc
>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/iRel.py to iRel.pyc
>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/iMesh.py to iMesh.pyc
>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/iGeom.py to iGeom.pyc
>>>> byte-compiling build/bdist.linux-x86_64/egg/itaps/iMeshExtensions.py to iMeshExtensions.pyc
>>>> creating build/bdist.linux-x86_64/egg/EGG-INFO
>>>> installing scripts to build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>>> running install_scripts
>>>> running build_scripts
>>>> creating build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>>> copying build/scripts-2.7/tagviewer -> build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>>> changing mode of build/bdist.linux-x86_64/egg/EGG-INFO/scripts/tagviewer to 755
>>>> copying PyTAPS.egg-info/PKG-INFO -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>> copying PyTAPS.egg-info/SOURCES.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>> copying PyTAPS.egg-info/dependency_links.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>> copying PyTAPS.egg-info/not-zip-safe -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>> copying PyTAPS.egg-info/requires.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>> copying PyTAPS.egg-info/top_level.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>> writing build/bdist.linux-x86_64/egg/EGG-INFO/native_libs.txt
>>>> creating 'dist/PyTAPS-1.4-py2.7-linux-x86_64.egg' and adding 'build/bdist.linux-x86_64/egg' to it
>>>> removing 'build/bdist.linux-x86_64/egg' (and everything under it)
>>>> Processing PyTAPS-1.4-py2.7-linux-x86_64.egg
>>>> removing '/usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg' (and everything under it)
>>>> creating /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg
>>>> Extracting PyTAPS-1.4-py2.7-linux-x86_64.egg to /usr/local/lib/python2.7/dist-packages
>>>> PyTAPS 1.4 is already the active version in easy-install.pth
>>>> Installing tagviewer script to /usr/local/bin
>>>> Installed /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg
>>>> Processing dependencies for PyTAPS==1.4
>>>> Searching for numpy==1.8.1
>>>> Best match: numpy 1.8.1
>>>> numpy 1.8.1 is already the active version in easy-install.pth
>>>> Using /usr/lib/python2.7/dist-packages
>>>> Finished processing dependencies for PyTAPS==1.4
>>>> In the output, I don’t see any information about linking
>>>> iMesh.so with MOAB / iGeom.so with CGM / iRel.so with Lasso.
>>>> Best
>>>> Huayi
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140610/fbb0d044/attachment-0001.html>
