[MOAB-dev] pytaps: can't import iBase and iMesh
    Huayi Wei
    huayiwei1984 at gmail.com
    Mon Jun  9 22:39:05 CDT 2014
when I launch python, and import iBase and iMesh, the output like this:
|why at why-XPS-15-9530:~$ python
Python 2.7.6 (default, Mar 22 2014, 22:59:56)
[GCC 4.8.2] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> from itaps import iBase, iMesh
Traceback (most recent call last):
   File "<stdin>", line 1, in <module>
ImportError: /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg/itaps/iMesh.so: undefined symbol: imesh_getentities_
Huayi
On 2014年06月10日 11:35, Huayi Wei wrote:
> I put it into /etc/bash.bashrc, like following:
> export
> LD_LIBRARY_PATH=/home/why/software/itaps/parallel-shared/lib:$LD_LIBRARY_PATH
> Huayi
> On 2014年06月10日 11:25, Anthony Scopatz wrote:
>> Did you export it or just put in in the env?
>> On Mon, Jun 9, 2014 at 10:24 PM, Huayi Wei <huayiwei1984 at gmail.com
>> <mailto:huayiwei1984 at gmail.com>> wrote:
>>     I put it in env, here is my setting:
>>     |env | grep 'LD'
>>     LD_LIRARY_PATH=/home/why/software/itaps/parallel-shared/lib
>>     But the problem is still there.
>>     Best
>>     Huayi
>>     On 2014年06月10日 10:54, Huayi Wei wrote:
>>>     Hi, Anthony,
>>>     Thanks for your reply. Now I rebuild cgm/moab/lasso with
>>>     —enable-shared option, but I still have the same problem. Here
>>>     is the content of my |setup.cfg| in pytaps dir:
>>>     |[global]
>>>     iMesh-path   = /home/why/software/itaps/parallel-shared
>>>     iGeom-path   = /home/why/software/itaps/parallel-shared
>>>     iRel-path    = /home/why/software/itaps/parallel-shared
>>>     [egg_info]
>>>     tag_build =
>>>     tag_date = 0
>>>     tag_svn_revision = 0
>>>     [build_ext]
>>>     include-dirs = /home/why/software/itaps/parallel-shared/include
>>>     The following is the output of the command |sudo python setup.py
>>>     install|
>>>     |[sudo] password for why:
>>>     running install
>>>     running bdist_egg
>>>     running egg_info
>>>     writing requirements to PyTAPS.egg-info/requires.txt
>>>     writing PyTAPS.egg-info/PKG-INFO
>>>     writing top-level names to PyTAPS.egg-info/top_level.txt
>>>     writing dependency_links to PyTAPS.egg-info/dependency_links.txt
>>>     reading manifest file 'PyTAPS.egg-info/SOURCES.txt'
>>>     writing manifest file 'PyTAPS.egg-info/SOURCES.txt'
>>>     installing library code to build/bdist.linux-x86_64/egg
>>>     running install_lib
>>>     running build_py
>>>     running build_ext
>>>     Checking for usability of iRel...
>>>     cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iRel.c -o iRel.o
>>>     Checking for usability of iMesh...
>>>     cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iMesh.c -o iMesh.o
>>>     Checking for usability of iGeom...
>>>     cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iGeom.c -o iGeom.o
>>>     creating build/bdist.linux-x86_64/egg
>>>     creating build/bdist.linux-x86_64/egg/itaps
>>>     copying build/lib.linux-x86_64-2.7/itaps/iRel.so -> build/bdist.linux-x86_64/egg/itaps
>>>     copying build/lib.linux-x86_64-2.7/itaps/iMesh.so -> build/bdist.linux-x86_64/egg/itaps
>>>     copying build/lib.linux-x86_64-2.7/itaps/iMeshExtensions.so -> build/bdist.linux-x86_64/egg/itaps
>>>     copying build/lib.linux-x86_64-2.7/itaps/iGeom.so -> build/bdist.linux-x86_64/egg/itaps
>>>     copying build/lib.linux-x86_64-2.7/itaps/helpers.py -> build/bdist.linux-x86_64/egg/itaps
>>>     copying build/lib.linux-x86_64-2.7/itaps/iBase.so -> build/bdist.linux-x86_64/egg/itaps
>>>     copying build/lib.linux-x86_64-2.7/itaps/__init__.py -> build/bdist.linux-x86_64/egg/itaps
>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/helpers.py to helpers.pyc
>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/__init__.py to __init__.pyc
>>>     creating stub loader for itaps/iBase.so
>>>     creating stub loader for itaps/iRel.so
>>>     creating stub loader for itaps/iMesh.so
>>>     creating stub loader for itaps/iGeom.so
>>>     creating stub loader for itaps/iMeshExtensions.so
>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iBase.py to iBase.pyc
>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iRel.py to iRel.pyc
>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iMesh.py to iMesh.pyc
>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iGeom.py to iGeom.pyc
>>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iMeshExtensions.py to iMeshExtensions.pyc
>>>     creating build/bdist.linux-x86_64/egg/EGG-INFO
>>>     installing scripts to build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>>     running install_scripts
>>>     running build_scripts
>>>     creating build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>>     copying build/scripts-2.7/tagviewer -> build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>>     changing mode of build/bdist.linux-x86_64/egg/EGG-INFO/scripts/tagviewer to 755
>>>     copying PyTAPS.egg-info/PKG-INFO -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>     copying PyTAPS.egg-info/SOURCES.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>     copying PyTAPS.egg-info/dependency_links.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>     copying PyTAPS.egg-info/not-zip-safe -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>     copying PyTAPS.egg-info/requires.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>     copying PyTAPS.egg-info/top_level.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>>     writing build/bdist.linux-x86_64/egg/EGG-INFO/native_libs.txt
>>>     creating 'dist/PyTAPS-1.4-py2.7-linux-x86_64.egg' and adding 'build/bdist.linux-x86_64/egg' to it
>>>     removing 'build/bdist.linux-x86_64/egg' (and everything under it)
>>>     Processing PyTAPS-1.4-py2.7-linux-x86_64.egg
>>>     removing '/usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg' (and everything under it)
>>>     creating /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg
>>>     Extracting PyTAPS-1.4-py2.7-linux-x86_64.egg to /usr/local/lib/python2.7/dist-packages
>>>     PyTAPS 1.4 is already the active version in easy-install.pth
>>>     Installing tagviewer script to /usr/local/bin
>>>     Installed /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg
>>>     Processing dependencies for PyTAPS==1.4
>>>     Searching for numpy==1.8.1
>>>     Best match: numpy 1.8.1
>>>     numpy 1.8.1 is already the active version in easy-install.pth
>>>     Using /usr/lib/python2.7/dist-packages
>>>     Finished processing dependencies for PyTAPS==1.4
>>>     In the output, I don’t see any information about linking
>>>     iMesh.so with MOAB / iGeom.so with CGM / iRel.so with Lasso.
>>>     Best
>>>     Huayi
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140610/f5e29d24/attachment-0001.html>
