[MOAB-dev] pytaps: can't import iBase and iMesh
Huayi Wei huayiwei1984 at gmail.com
Mon Jun 9 22:35:28 CDT 2014
I put it into /etc/bash.bashrc, like following:
export
LD_LIBRARY_PATH=/home/why/software/itaps/parallel-shared/lib:$LD_LIBRARY_PATH
Huayi
On 2014年06月10日 11:25, Anthony Scopatz wrote:
> Did you export it or just put in in the env?
> On Mon, Jun 9, 2014 at 10:24 PM, Huayi Wei <huayiwei1984 at gmail.com
> <mailto:huayiwei1984 at gmail.com>> wrote:
>     I put it in env, here is my setting:
>     |env | grep 'LD'
>     LD_LIRARY_PATH=/home/why/software/itaps/parallel-shared/lib
>     But the problem is still there.
>     Best
>     Huayi
>     On 2014年06月10日 10:54, Huayi Wei wrote:
>>     Hi, Anthony,
>>     Thanks for your reply. Now I rebuild cgm/moab/lasso with
>>     —enable-shared option, but I still have the same problem. Here is
>>     the content of my |setup.cfg| in pytaps dir:
>>     |[global]
>>     iMesh-path   = /home/why/software/itaps/parallel-shared
>>     iGeom-path   = /home/why/software/itaps/parallel-shared
>>     iRel-path    = /home/why/software/itaps/parallel-shared
>>     [egg_info]
>>     tag_build =
>>     tag_date = 0
>>     tag_svn_revision = 0
>>     [build_ext]
>>     include-dirs = /home/why/software/itaps/parallel-shared/include
>>     The following is the output of the command |sudo python setup.py
>>     install|
>>     |[sudo] password for why:
>>     running install
>>     running bdist_egg
>>     running egg_info
>>     writing requirements to PyTAPS.egg-info/requires.txt
>>     writing PyTAPS.egg-info/PKG-INFO
>>     writing top-level names to PyTAPS.egg-info/top_level.txt
>>     writing dependency_links to PyTAPS.egg-info/dependency_links.txt
>>     reading manifest file 'PyTAPS.egg-info/SOURCES.txt'
>>     writing manifest file 'PyTAPS.egg-info/SOURCES.txt'
>>     installing library code to build/bdist.linux-x86_64/egg
>>     running install_lib
>>     running build_py
>>     running build_ext
>>     Checking for usability of iRel...
>>     cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iRel.c -o iRel.o
>>     Checking for usability of iMesh...
>>     cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iMesh.c -o iMesh.o
>>     Checking for usability of iGeom...
>>     cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iGeom.c -o iGeom.o
>>     creating build/bdist.linux-x86_64/egg
>>     creating build/bdist.linux-x86_64/egg/itaps
>>     copying build/lib.linux-x86_64-2.7/itaps/iRel.so -> build/bdist.linux-x86_64/egg/itaps
>>     copying build/lib.linux-x86_64-2.7/itaps/iMesh.so -> build/bdist.linux-x86_64/egg/itaps
>>     copying build/lib.linux-x86_64-2.7/itaps/iMeshExtensions.so -> build/bdist.linux-x86_64/egg/itaps
>>     copying build/lib.linux-x86_64-2.7/itaps/iGeom.so -> build/bdist.linux-x86_64/egg/itaps
>>     copying build/lib.linux-x86_64-2.7/itaps/helpers.py -> build/bdist.linux-x86_64/egg/itaps
>>     copying build/lib.linux-x86_64-2.7/itaps/iBase.so -> build/bdist.linux-x86_64/egg/itaps
>>     copying build/lib.linux-x86_64-2.7/itaps/__init__.py -> build/bdist.linux-x86_64/egg/itaps
>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/helpers.py to helpers.pyc
>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/__init__.py to __init__.pyc
>>     creating stub loader for itaps/iBase.so
>>     creating stub loader for itaps/iRel.so
>>     creating stub loader for itaps/iMesh.so
>>     creating stub loader for itaps/iGeom.so
>>     creating stub loader for itaps/iMeshExtensions.so
>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iBase.py to iBase.pyc
>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iRel.py to iRel.pyc
>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iMesh.py to iMesh.pyc
>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iGeom.py to iGeom.pyc
>>     byte-compiling build/bdist.linux-x86_64/egg/itaps/iMeshExtensions.py to iMeshExtensions.pyc
>>     creating build/bdist.linux-x86_64/egg/EGG-INFO
>>     installing scripts to build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>     running install_scripts
>>     running build_scripts
>>     creating build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>     copying build/scripts-2.7/tagviewer -> build/bdist.linux-x86_64/egg/EGG-INFO/scripts
>>     changing mode of build/bdist.linux-x86_64/egg/EGG-INFO/scripts/tagviewer to 755
>>     copying PyTAPS.egg-info/PKG-INFO -> build/bdist.linux-x86_64/egg/EGG-INFO
>>     copying PyTAPS.egg-info/SOURCES.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>     copying PyTAPS.egg-info/dependency_links.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>     copying PyTAPS.egg-info/not-zip-safe -> build/bdist.linux-x86_64/egg/EGG-INFO
>>     copying PyTAPS.egg-info/requires.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>     copying PyTAPS.egg-info/top_level.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
>>     writing build/bdist.linux-x86_64/egg/EGG-INFO/native_libs.txt
>>     creating 'dist/PyTAPS-1.4-py2.7-linux-x86_64.egg' and adding 'build/bdist.linux-x86_64/egg' to it
>>     removing 'build/bdist.linux-x86_64/egg' (and everything under it)
>>     Processing PyTAPS-1.4-py2.7-linux-x86_64.egg
>>     removing '/usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg' (and everything under it)
>>     creating /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg
>>     Extracting PyTAPS-1.4-py2.7-linux-x86_64.egg to /usr/local/lib/python2.7/dist-packages
>>     PyTAPS 1.4 is already the active version in easy-install.pth
>>     Installing tagviewer script to /usr/local/bin
>>     Installed /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg
>>     Processing dependencies for PyTAPS==1.4
>>     Searching for numpy==1.8.1
>>     Best match: numpy 1.8.1
>>     numpy 1.8.1 is already the active version in easy-install.pth
>>     Using /usr/lib/python2.7/dist-packages
>>     Finished processing dependencies for PyTAPS==1.4
>>     In the output, I don’t see any information about linking iMesh.so
>>     with MOAB / iGeom.so with CGM / iRel.so with Lasso.
>>     Best
>>     Huayi
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140610/1e74495f/attachment-0001.html>
