[MOAB-dev] pytaps: can't import iBase and iMesh
    Anthony Scopatz
    scopatz at gmail.com
    Mon Jun  9 22:25:48 CDT 2014
Did you export it or just put in in the env?
On Mon, Jun 9, 2014 at 10:24 PM, Huayi Wei <huayiwei1984 at gmail.com> wrote:
>  I put it in env, here is my setting:
> env | grep 'LD'
> LD_LIRARY_PATH=/home/why/software/itaps/parallel-shared/lib
> But the problem is still there.
> Best
> Huayi
> On 2014年06月10日 10:54, Huayi Wei wrote:
>   Hi, Anthony,
> Thanks for your reply. Now I rebuild cgm/moab/lasso with —enable-shared
> option, but I still have the same problem. Here is the content of my
> setup.cfg in pytaps dir:
> [global]
> iMesh-path   = /home/why/software/itaps/parallel-shared
> iGeom-path   = /home/why/software/itaps/parallel-shared
> iRel-path    = /home/why/software/itaps/parallel-shared
> [egg_info]
> tag_build =
> tag_date = 0
> tag_svn_revision = 0
> [build_ext]
> include-dirs = /home/why/software/itaps/parallel-shared/include
> The following is the output of the command sudo python setup.py install
> [sudo] password for why:
> running install
> running bdist_egg
> running egg_info
> writing requirements to PyTAPS.egg-info/requires.txt
> writing PyTAPS.egg-info/PKG-INFO
> writing top-level names to PyTAPS.egg-info/top_level.txt
> writing dependency_links to PyTAPS.egg-info/dependency_links.txt
> reading manifest file 'PyTAPS.egg-info/SOURCES.txt'
> writing manifest file 'PyTAPS.egg-info/SOURCES.txt'
> installing library code to build/bdist.linux-x86_64/egg
> running install_lib
> running build_py
> running build_ext
> Checking for usability of iRel...
> cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iRel.c -o iRel.o
> Checking for usability of iMesh...
> cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iMesh.c -o iMesh.o
> Checking for usability of iGeom...
> cc -I/home/why/software/itaps/parallel-shared/include -I/usr/include/python2.7 -I/usr/lib/python2.7/dist-packages/numpy/core/include -c iGeom.c -o iGeom.o
> creating build/bdist.linux-x86_64/egg
> creating build/bdist.linux-x86_64/egg/itaps
> copying build/lib.linux-x86_64-2.7/itaps/iRel.so -> build/bdist.linux-x86_64/egg/itaps
> copying build/lib.linux-x86_64-2.7/itaps/iMesh.so -> build/bdist.linux-x86_64/egg/itaps
> copying build/lib.linux-x86_64-2.7/itaps/iMeshExtensions.so -> build/bdist.linux-x86_64/egg/itaps
> copying build/lib.linux-x86_64-2.7/itaps/iGeom.so -> build/bdist.linux-x86_64/egg/itaps
> copying build/lib.linux-x86_64-2.7/itaps/helpers.py -> build/bdist.linux-x86_64/egg/itaps
> copying build/lib.linux-x86_64-2.7/itaps/iBase.so -> build/bdist.linux-x86_64/egg/itaps
> copying build/lib.linux-x86_64-2.7/itaps/__init__.py -> build/bdist.linux-x86_64/egg/itaps
> byte-compiling build/bdist.linux-x86_64/egg/itaps/helpers.py to helpers.pyc
> byte-compiling build/bdist.linux-x86_64/egg/itaps/__init__.py to __init__.pyc
> creating stub loader for itaps/iBase.so
> creating stub loader for itaps/iRel.so
> creating stub loader for itaps/iMesh.so
> creating stub loader for itaps/iGeom.so
> creating stub loader for itaps/iMeshExtensions.so
> byte-compiling build/bdist.linux-x86_64/egg/itaps/iBase.py to iBase.pyc
> byte-compiling build/bdist.linux-x86_64/egg/itaps/iRel.py to iRel.pyc
> byte-compiling build/bdist.linux-x86_64/egg/itaps/iMesh.py to iMesh.pyc
> byte-compiling build/bdist.linux-x86_64/egg/itaps/iGeom.py to iGeom.pyc
> byte-compiling build/bdist.linux-x86_64/egg/itaps/iMeshExtensions.py to iMeshExtensions.pyc
> creating build/bdist.linux-x86_64/egg/EGG-INFO
> installing scripts to build/bdist.linux-x86_64/egg/EGG-INFO/scripts
> running install_scripts
> running build_scripts
> creating build/bdist.linux-x86_64/egg/EGG-INFO/scripts
> copying build/scripts-2.7/tagviewer -> build/bdist.linux-x86_64/egg/EGG-INFO/scripts
> changing mode of build/bdist.linux-x86_64/egg/EGG-INFO/scripts/tagviewer to 755
> copying PyTAPS.egg-info/PKG-INFO -> build/bdist.linux-x86_64/egg/EGG-INFO
> copying PyTAPS.egg-info/SOURCES.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
> copying PyTAPS.egg-info/dependency_links.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
> copying PyTAPS.egg-info/not-zip-safe -> build/bdist.linux-x86_64/egg/EGG-INFO
> copying PyTAPS.egg-info/requires.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
> copying PyTAPS.egg-info/top_level.txt -> build/bdist.linux-x86_64/egg/EGG-INFO
> writing build/bdist.linux-x86_64/egg/EGG-INFO/native_libs.txt
> creating 'dist/PyTAPS-1.4-py2.7-linux-x86_64.egg' and adding 'build/bdist.linux-x86_64/egg' to it
> removing 'build/bdist.linux-x86_64/egg' (and everything under it)
> Processing PyTAPS-1.4-py2.7-linux-x86_64.egg
> removing '/usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg' (and everything under it)
> creating /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg
> Extracting PyTAPS-1.4-py2.7-linux-x86_64.egg to /usr/local/lib/python2.7/dist-packages
> PyTAPS 1.4 is already the active version in easy-install.pth
> Installing tagviewer script to /usr/local/bin
> Installed /usr/local/lib/python2.7/dist-packages/PyTAPS-1.4-py2.7-linux-x86_64.egg
> Processing dependencies for PyTAPS==1.4
> Searching for numpy==1.8.1
> Best match: numpy 1.8.1
> numpy 1.8.1 is already the active version in easy-install.pth
> Using /usr/lib/python2.7/dist-packages
> Finished processing dependencies for PyTAPS==1.4
> In the output, I don’t see any information about linking iMesh.so with
> MOAB / iGeom.so with CGM / iRel.so with Lasso.
> Best
> Huayi
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140609/f09aa982/attachment-0001.html>
