[MOAB-dev] commit/MOAB: danwu: Merged master into	error_handling_enhancement
    commits-noreply at bitbucket.org
    Wed Jun  4 13:49:12 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/3fb22dc1cc6c/
Changeset:   3fb22dc1cc6c
Branch:      error_handling_enhancement
User:        danwu
Date:        2014-06-04 20:49:05
Summary:     Merged master into error_handling_enhancement
Affected #:  65 files
diff --git a/.gitignore b/.gitignore
index 8acb6bb..6f98827 100644
--- a/.gitignore
+++ b/.gitignore
@@ -100,9 +100,9 @@ Makefile
 Makefile.in
 moab.config
 MOABConfig.cmake
-moab.creator*
-moab.files
-moab.includes
+*.creator*
+*.files
+*.includes
 moab.make
 *.o
 .project
@@ -154,15 +154,18 @@ test/io/*.ccmg
 test/io/ccmio_test
 test/io/cub_file_test
 test/io/exodus_test
+test/io/*.h5m
 test/io/*.g
 test/io/gmsh_test
 test/io/ideas_test
 test/io/nastran_test
+test/io/*.nc
 test/io/read_cgm_basic_test
 test/io/read_cgm_connectivity_test
 test/io/read_cgm_group_test
 test/io/read_cgm_load_test
 test/io/read_cgm_senses_test
+test/io/read_gcrm_nc
 test/io/read_mpas_nc
 test/io/read_nc
 test/io/read_ucd_nc
@@ -171,6 +174,7 @@ test/io/smf_test
 test/io/stl_test
 test/io/tqdcfr
 test/io/vtk_test
+test/io/write_nc
 test/kd_tree_test
 test/kd_tree_time
 test/kd_tree_tool
@@ -186,10 +190,12 @@ test/obb/obb_time
 test/obb/obb_tree_tool
 test/obb_test
 test/oldinc/test_oldinc
+test/parallel/gcrm_par
 test/parallel/*.h5m
 test/parallel/mbparallelcomm_test
 test/parallel/mhdf_parallel
 test/parallel/mpastrvpart
+test/parallel/*.nc
 test/parallel/par_coupler_test
 test/parallel/par_intx_sph
 test/parallel/parallel_hdf5_test
@@ -209,6 +215,7 @@ test/parallel/structured3
 test/parallel/uber_parallel_test
 test/parallel/ucdtrvpart
 test/parallel/*.vtk
+test/parallel/write_nc_par
 test/perf/adj_time
 test/perf/perf
 test/perf/perftool
diff --git a/MeshFiles/unittest/io/Makefile.am b/MeshFiles/unittest/io/Makefile.am
index 3b767aa..94704c1 100644
--- a/MeshFiles/unittest/io/Makefile.am
+++ b/MeshFiles/unittest/io/Makefile.am
@@ -2,7 +2,10 @@ EXTRA_DIST = HommeMapping.nc \
              brick_cubit10.1.cub \
              brick_cubit10.2.cub \
              brick_cubit10.cub \
-             camEul26x48x96.t3.nc \
+             eul26x48x96.t0.nc \
+             eul26x48x96.t1.nc \
+             eul26x48x96.t2.nc \
+             eul26x48x96.t.3.nc \
              fv26x46x72.t.3.nc \
 	     cubtest12.cub \
 	     cubtest14.cub \
@@ -22,6 +25,10 @@ EXTRA_DIST = HommeMapping.nc \
 	     sample.stl \
              three.smf \
              mpasx1.642.t.2.nc \
-             2d_naca0012.cgns
+             2d_naca0012.cgns \
+             cube.sat \
+             cube.stp \
+             cylcube.sat \
+             cylcube.stp \
+             gcrm_r3.nc
diff --git a/MeshFiles/unittest/io/camEul26x48x96.t3.nc b/MeshFiles/unittest/io/camEul26x48x96.t3.nc
deleted file mode 100644
index fafba2a..0000000
Binary files a/MeshFiles/unittest/io/camEul26x48x96.t3.nc and /dev/null differ
diff --git a/MeshFiles/unittest/io/eul26x48x96.t.3.nc b/MeshFiles/unittest/io/eul26x48x96.t.3.nc
new file mode 100644
index 0000000..fafba2a
Binary files /dev/null and b/MeshFiles/unittest/io/eul26x48x96.t.3.nc differ
diff --git a/MeshFiles/unittest/io/eul26x48x96.t0.nc b/MeshFiles/unittest/io/eul26x48x96.t0.nc
index 0000000..453105a
Binary files /dev/null and b/MeshFiles/unittest/io/eul26x48x96.t0.nc differ
diff --git a/MeshFiles/unittest/io/eul26x48x96.t1.nc b/MeshFiles/unittest/io/eul26x48x96.t1.nc
index 0000000..61a7c8f
Binary files /dev/null and b/MeshFiles/unittest/io/eul26x48x96.t1.nc differ
diff --git a/MeshFiles/unittest/io/eul26x48x96.t2.nc b/MeshFiles/unittest/io/eul26x48x96.t2.nc
index 0000000..239bd83
Binary files /dev/null and b/MeshFiles/unittest/io/eul26x48x96.t2.nc differ
diff --git a/MeshFiles/unittest/io/gcrm_r3.nc b/MeshFiles/unittest/io/gcrm_r3.nc
index 0000000..1c7328b
Binary files /dev/null and b/MeshFiles/unittest/io/gcrm_r3.nc differ
diff --git a/examples/ReadWriteTest.cpp b/examples/ReadWriteTest.cpp
index 0000000..3ae6567
--- /dev/null
+++ b/examples/ReadWriteTest.cpp
@@ -0,0 +1,112 @@
+/** @example ReadWriteTest.cpp \n
+ * \brief Read mesh into MOAB and write some back \n
+ * <b>To run</b>: mpiexec -np 4 ReadWriteTest [input] [output] -O <read_opts> -o <write_opts>\n
+ * used for stress test of reader/writer
+ *  report times to read and write
+ *  example ReadWriteTest ../MeshFiles/io/fv26x46x72.t.3.nc out.nc  \
+ *  -O PARALLEL=READ_PART;PARTITION_METHOD=SQIJ;PARALLEL_RESOLVE_SHARED_ENTS;VARIABLE=T,U;  \
+ *  -o PARALLEL=WRITE_PART;VARIABLE=T,U
+#include "moab/ParallelComm.hpp"
+#include "MBParallelConventions.h"
+#include "moab/Core.hpp"
+#include <iostream>
+#include <time.h>
+using namespace moab;
+using namespace std;
+int main(int argc, char **argv)
+  MPI_Init(&argc, &argv);
+  string options;
+  // Need option handling here for input filename
+  if (argc < 3 ){
+   return 1;
+  char * input_file = argv[1];
+  char * output_file = argv[2];
+  char * read_opts = NULL;
+  char * write_opts = NULL; // tags to write, separated by commas; it is the name of the tag
+  if (argc>3)
+    int index=3;
+    while (index<argc)
+      if (!strcmp( argv[index], "-O")) // this is for reading options, optional
+        read_opts=argv[++index];
+      if (!strcmp( argv[index], "-o"))
+        write_opts=argv[++index];
+      index++;
+  // Get MOAB instance and read the file with the specified options
+  Interface* mb = new Core;
+  if (NULL == mb)
+    return 1;
+  // Get the ParallelComm instance
+  ParallelComm* pcomm = new ParallelComm(mb, MPI_COMM_WORLD);
+  int nprocs = pcomm->proc_config().proc_size();
+  int rank = pcomm->proc_config().proc_rank();
+  EntityHandle set;
+  ErrorCode rval = mb->create_meshset(MESHSET_SET, set);
+  clock_t tt = clock();
+  if (rank == 0)
+    cout << "Reading file " << input_file << "\n  with options: " << read_opts << endl
+         << " on " << nprocs << " processors\n";
+  rval = mb->load_file(input_file, &set, read_opts);
+  if (rval != MB_SUCCESS) {
+    delete mb;
+    return 1;
+  if (0==rank)
+      std::cout << "Time:  "
+            << (clock() - tt) / (double) CLOCKS_PER_SEC << " seconds" << std::endl;
+      tt = clock();
+  rval = mb->write_file(output_file, 0, write_opts, &set, 1);
+    delete mb;
+    return 1;
+  if (0 == rank)
+    cout << "Writing file " << output_file << "\n  with options: " << write_opts << endl;
+    cout << "Time:  " << (clock() - tt) / (double) CLOCKS_PER_SEC
+        << " seconds" << std::endl;
+    tt = clock();
+  delete mb;
+  MPI_Finalize();
+  return 0;
diff --git a/examples/VisTags.cpp b/examples/VisTags.cpp
index 0000000..efba608
--- /dev/null
+++ b/examples/VisTags.cpp
@@ -0,0 +1,181 @@
+/** @example VisTags.cpp \n
+ * \brief tool for visualizing multi level tags  \n
+ * <b>To run</b>: VisTags  <inp_file><outfile> -O <read_opts> -t <tags> -l <levels>  -d <dim> \n
+ * In this example, it is shown how to create some simple tags for those tags that come from
+ *  climate data, multiple levels.
+ *  you can read directly nc data, or *.h5m file that will have the tag with multi levels
+ *   output will be a vtk file with dense tags of form tag_name_<level>
+ * the tag name might contain a time index too, like T0 or U0
+ * <tag> is a list of tags, separated by commas, no spaces
+ * <levels> is a list of levels, separated by commas, no spaces
+ *  dimension of entities with the tags will be specified with -d (default 2)
+ * an example of use
+ * VisTags gcrm_rc.nc  out.vtk -O VARIABLE=u -t u0,u1 -l 0,1,2 -d 2
+ * (we knew that it had variable u in the file, that it had 256 levels, that there are 2 time
+ *  steps, etc)
+ * or
+ *  VisTags gcrm_rc.nc  out.vtk  -t u0 -l 0,1,2 -d 2
+ *  (it will read all variables, but we need to know that u0 will be created as a tag)
+ *  the out.vtk file will contain u0_0, u0_1, as simple dense double tags
+#include <vector>
+#include <sstream>
+#include <string>
+// Include header for MOAB instance and tag conventions for
+#include "MBTagConventions.hpp"
+#include "moab/FileOptions.hpp"
+int main(int argc, char **argv) {
+    // instantiate & load a file
+    moab::Interface *mb = new moab::Core();
+    moab::ErrorCode rval;
+    if (argc <= 1)
+       return 0;
+    int dimension = 2;
+    char * file_input = argv[1];
+    char * file_output = argv[2];
+    char * tags = NULL; // tags to write, separated by commas; it is the name of the tag
+    // in moab, it may have index after reading (T0, T1, etc)
+    char * levels = NULL; // levels, separated by commas, no spaces ( like 0,1,19 )
+    if (argc>3)
+      int index=3;
+        if (!strcmp( argv[index], "-t"))
+          tags=argv[++index];
+        if (!strcmp( argv[index], "-l"))
+          levels=argv[++index];
+        if (!strcmp( argv[index], "-d"))
+          dimension=atoi(argv[++index]);
+        index++;
+    std::ostringstream opts;
+    opts << ";;TAGS=" << tags << ";LEVELS=" << levels << "\0" ;
+    moab::FileOptions fo(opts.str().c_str());
+    std::vector<std::string> tagsNames;
+    std::vector<int>  levelsArray;
+    fo.get_strs_option("TAGS", tagsNames);
+    fo.get_ints_option("LEVELS", levelsArray);
+    // now create double tags for entities of dimension
+    rval = mb->load_file(file_input, 0, read_opts);
+    if (rval != moab::MB_SUCCESS) {
+      std::cout <<"not loading file\n";
+      return 1;
+    moab::Range ents;
+    rval = mb->get_entities_by_dimension(0, dimension, ents);
+      std::cout <<"not getting ents\n";
+      return 1;
+    for (size_t i=0; i<tagsNames.size(); i++)
+      std::string tagName = tagsNames[i];
+      moab::Tag tagh;
+      rval = mb->tag_get_handle(tagName.c_str(), tagh);
+        std::cout <<"not getting tag " << tagName.c_str()<<"\n";
+        continue;
+      int len=0;
+      rval = mb->tag_get_length(tagh, len);
+        std::cout <<"not getting tag len" << tagName.c_str()<<"\n";
+        continue;
+      moab::DataType type;
+      rval = mb->tag_get_data_type(tagh, type) ;
+        std::cout <<"not getting tag type " << tagName.c_str()<<"\n";
+        continue;
+      int count;
+      void * dataptr;// assume double tags, for simplicity
+      rval = mb->tag_iterate( tagh,
+          ents.begin(),
+          ents.end(),
+          count,
+          dataptr);
+      if (rval != moab::MB_SUCCESS || count != (int)ents.size()) {
+        std::cout <<"not getting tag iterate right " << tagName.c_str()<<"\n";
+        continue;
+      // now create a new tag, with a new name, concatenated, and copy data there , for each level
+      for (size_t j=0; j<levelsArray.size();j++)
+        int level=levelsArray[j];
+        if (level >= len)
+          std::cout << "level too big at "<< level << "\n";
+          continue;
+        std::ostringstream newTagName;
+        newTagName << tagName <<"_" << level  ;
+        moab::Tag newTagh;
+        rval = mb->tag_get_handle(newTagName.str().c_str(), 1, type, newTagh,
+            moab::MB_TAG_DENSE | moab::MB_TAG_CREAT);
+        if (rval != moab::MB_SUCCESS ) {
+          std::cout <<"not getting new tag " << newTagName.str() <<"\n";
+          continue;
+        void * newDataPtr;
+        rval = mb->tag_iterate( newTagh,
+                            ents.begin(),
+                            ents.end(),
+                            count,
+                            newDataPtr);
+        if (rval != moab::MB_SUCCESS  || count !=(int) ents.size()) {
+          std::cout <<"not getting new tag iterate" << newTagName.str() <<"\n";
+          continue;
+        if (type==moab::MB_TYPE_DOUBLE)
+          double * ptrD = (double*) newDataPtr;
+          double *oldData = (double*)dataptr;
+          for (int k=0; k<count; k++, ptrD++)
+            *ptrD = oldData[level+count*k];
+      mb->tag_delete(tagh);// no need for the tag anymore, write it to the new file
+    rval = mb->write_file(file_output);
+      std::cout <<"can't write file " << file_output << "\n";
+    else
+      std::cout <<"successfully wrote file " << file_output<< "\n";
+    return 0;
diff --git a/itaps/igeom/testSmooth2.cc b/itaps/igeom/testSmooth2.cc
index 7e4fbf4..e6f678b 100644
--- a/itaps/igeom/testSmooth2.cc
+++ b/itaps/igeom/testSmooth2.cc
@@ -173,11 +173,14 @@ int main(int argc, char *argv[]) {
    iBase_EntitySetHandle root_set;
    iMesh_createEntSet(mesh, 0, &root_set, &err);
-   CHECK( "Failed to create a model root set.\n");
+   if (err != iBase_SUCCESS)
+     std::cerr << " Error code: " << err << " failed to create a model set"
+                 << "  At        : " << __FILE__ << ':' << __LINE__  << std::endl;
    iMesh_load(mesh, root_set, filename.c_str(), NULL, &err, filename.length(), 0);
+     std::cerr << " Error code: " << err << " failed load the file"
    std::string opts("SMOOTH;");
    // new constructor
diff --git a/src/CMakeLists.txt b/src/CMakeLists.txt
index 40f7a59..5b5cd8f 100644
--- a/src/CMakeLists.txt
+++ b/src/CMakeLists.txt
@@ -73,7 +73,6 @@
     io/GmshUtil.cpp
     io/ReadABAQUS.cpp
     io/ReadGmsh.cpp
-    io/ReadGCRM.cpp
     io/ReadIDEAS.cpp
     io/ReadMCNP5.cpp
     io/ReadNASTRAN.cpp
@@ -132,6 +131,7 @@
       io/NCHelperFV.cpp
       io/NCHelperHOMME.cpp
       io/NCHelperMPAS.cpp
+      io/NCHelperGCRM.cpp
       SpectralMeshTool.cpp
     include_directories(
diff --git a/src/LocalDiscretization/SpectralQuad.cpp b/src/LocalDiscretization/SpectralQuad.cpp
index d7355e6..7b581cb 100644
--- a/src/LocalDiscretization/SpectralQuad.cpp
+++ b/src/LocalDiscretization/SpectralQuad.cpp
@@ -109,7 +109,10 @@ bool SpectralQuad::reverseEvalFcn(const double *posn, const double *verts, const
   double dist = opt_findpt_2(&_data, (const double **)_xyz, x_star, r, &c);
     // if it did not converge, get out with throw...
   if (dist > 0.9e+30)
-    throw Map::EvaluationError();
+    std::vector<CartVect> dummy;
+    throw Map::EvaluationError(CartVect(x_star), dummy);
     //c tells us if we landed inside the element or exactly on a face, edge, or node
     // also, dist shows the distance to the computed point.
     //copy parametric coords back
diff --git a/src/ReaderWriterSet.cpp b/src/ReaderWriterSet.cpp
index 5015a7f..47c4c2b 100644
--- a/src/ReaderWriterSet.cpp
+++ b/src/ReaderWriterSet.cpp
@@ -48,15 +48,14 @@
 #ifdef NETCDF_FILE
 #  include "ReadNCDF.hpp"
 #  include "WriteNCDF.hpp"
+#  include "WriteNC.hpp"
 #  include "WriteSLAC.hpp"
 #  include "ReadNC.hpp"
-#  include "ReadGCRM.hpp"
 #endif
 // 2nd include of ReadNC in case we have pnetcdf and not netcdf
 #ifdef PNETCDF_FILE
 #endif
 #ifdef CGNS_FILE
@@ -104,8 +103,7 @@ ReaderWriterSet::ReaderWriterSet( Core* mdb, Error* handler )
 #ifdef NETCDF_FILE
   const char* exo_sufxs[] = { "exo", "exoII", "exo2", "g", "gen", NULL };
   register_factory( ReadNCDF::factory, WriteNCDF::factory, "Exodus II", exo_sufxs, "EXODUS" );
-  register_factory( ReadGCRM::factory, NULL, "GCRM NC", "nc", "GCRM" );
-  register_factory( ReadNC::factory, NULL, "Climate NC", "nc", "NC" );
+  register_factory( ReadNC::factory, WriteNC::factory, "Climate NC", "nc", "NC" );
 #endif
 #ifdef CGNS_FILE
diff --git a/src/TupleList.cpp b/src/TupleList.cpp
index 113e826..095a01d 100644
--- a/src/TupleList.cpp
+++ b/src/TupleList.cpp
@@ -267,7 +267,7 @@ int TupleList::find(unsigned int key_num, sint value)
     else
       // Sequential search: if tuple_list is not sorted
-      for (long index = 0; index < n; index++)
+      for (uint index = 0; index < n; index++)
         if (vi[index * mi + key_num] == (long) uvalue)
           return index;
diff --git a/src/io/Makefile.am b/src/io/Makefile.am
index f556335..c0ab2ca 100644
--- a/src/io/Makefile.am
+++ b/src/io/Makefile.am
@@ -17,12 +17,19 @@ if NETCDF_FILE
                      WriteNCDF.cpp WriteNCDF.hpp \
                      WriteSLAC.cpp WriteSLAC.hpp \
                      ReadNC.cpp ReadNC.hpp \
+                     WriteNC.cpp WriteNC.hpp \
                      NCHelper.cpp NCHelper.hpp \
                      NCHelperEuler.cpp NCHelperEuler.hpp \
                      NCHelperFV.cpp NCHelperFV.hpp \
                      NCHelperHOMME.cpp NCHelperHOMME.hpp \
                      NCHelperMPAS.cpp NCHelperMPAS.hpp \
-                     ReadGCRM.cpp ReadGCRM.hpp
+                     NCHelperGCRM.cpp NCHelperGCRM.hpp \
+                     NCWriteHelper.cpp NCWriteHelper.hpp \
+                     NCWriteEuler.cpp NCWriteEuler.hpp \
+                     NCWriteFV.cpp NCWriteFV.hpp \
+                     NCWriteHOMME.cpp NCWriteHOMME.hpp \
+                     NCWriteMPAS.cpp NCWriteMPAS.hpp \
+                     NCWriteGCRM.cpp NCWriteGCRM.hpp
 else
   MOAB_NETCDF_SRCS =
 endif
@@ -30,12 +37,19 @@ endif
 if PNETCDF_FILE
 if !NETCDF_FILE
      MOAB_NETCDF_SRCS += ReadNC.cpp ReadNC.hpp \
 endif
 endif
diff --git a/src/io/NCHelper.hpp b/src/io/NCHelper.hpp
index 12e3b0e..c6c73c6 100644
--- a/src/io/NCHelper.hpp
+++ b/src/io/NCHelper.hpp
@@ -35,6 +35,9 @@ public:
   //! Create NC conventional tags
   ErrorCode create_conventional_tags(const std::vector<int>& tstep_nums);
+  //! Update time tag values if timesteps spread across files
+  ErrorCode update_time_tag_vals();
 protected:
   //! Separate set and non-set variables (common to scd mesh and ucd mesh)
   ErrorCode read_variables_setup(std::vector<std::string>& var_names,
diff --git a/src/io/NCHelperEuler.cpp b/src/io/NCHelperEuler.cpp
index 9f67a71..ce0856f 100644
--- a/src/io/NCHelperEuler.cpp
+++ b/src/io/NCHelperEuler.cpp
@@ -317,14 +317,14 @@ ErrorCode NCHelperEuler::init_mesh_vals()
   for (mit = varInfo.begin(); mit != varInfo.end(); ++mit) {
     ReadNC::VarData& vd = (*mit).second;
-    vd.entLoc = ReadNC::ENTLOCSET;
+    // Default entLoc is ENTLOCSET
     if (std::find(vd.varDims.begin(), vd.varDims.end(), tDim) != vd.varDims.end()) {
       if ((std::find(vd.varDims.begin(), vd.varDims.end(), iCDim) != vd.varDims.end()) &&
           (std::find(vd.varDims.begin(), vd.varDims.end(), jCDim) != vd.varDims.end()))
         vd.entLoc = ReadNC::ENTLOCFACE;
-    vd.numLev = 1;
+    // Default numLev is 0
     if (std::find(vd.varDims.begin(), vd.varDims.end(), levDim) != vd.varDims.end())
       vd.numLev = nLevels;
diff --git a/src/io/NCHelperFV.cpp b/src/io/NCHelperFV.cpp
index a85e834..2dc0fb3 100644
--- a/src/io/NCHelperFV.cpp
+++ b/src/io/NCHelperFV.cpp
@@ -316,7 +316,7 @@ ErrorCode NCHelperFV::init_mesh_vals()
@@ -329,7 +329,7 @@ ErrorCode NCHelperFV::init_mesh_vals()
         vd.entLoc = ReadNC::ENTLOCEWEDGE;
-    vd.numLev = 1;
This diff is so big that we needed to truncate the remainder.
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
