[MOAB-dev] commit/MOAB: danwu: Merged master into error_handling_enhancement
Vijay S. Mahadevan
vijay.m at gmail.com
Thu Mar 27 14:06:09 CDT 2014
Iulian/Rajeev, we need to start reviewing the error handling branch and
merge into master for the next release.
Danqing, please update the branch with any other pending changes. I would
like to bring all the other codes up to date also and test them on buildbot
for various configurations before the release.
Vijay
On Mar 27, 2014 1:50 PM, <commits-noreply at bitbucket.org> wrote:
> 1 new commit in MOAB:
> https://bitbucket.org/fathomteam/moab/commits/5d3eb97e31f9/
> Changeset: 5d3eb97e31f9
> Branch: error_handling_enhancement
> User: danwu
> Date: 2014-03-27 19:50:43
> Summary: Merged master into error_handling_enhancement
> Affected #: 14 files
> diff --git a/.gitignore b/.gitignore
> index 4b78fb6..8acb6bb 100644
> --- a/.gitignore
> +++ b/.gitignore
> @@ -130,6 +130,9 @@ test/bsp_tree_test
> test/CMakeLists.txt
> test/coords_connect_iterate
> test/cropvol_test
> +test/dagmc/dagmc_pointinvol_test
> +test/dagmc/dagmc_rayfire_test
> +test/dagmc/dagmc_simple_test
> test/dual/dual_test
> test/elem_eval_test
> test/file_options_test
> @@ -156,8 +159,10 @@ test/io/gmsh_test
> test/io/ideas_test
> test/io/nastran_test
> test/io/read_cgm_basic_test
> +test/io/read_cgm_connectivity_test
> +test/io/read_cgm_group_test
> test/io/read_cgm_load_test
> -test/io/read_cgm_test
> +test/io/read_cgm_senses_test
> test/io/read_mpas_nc
> test/io/read_nc
> test/io/read_ucd_nc
> diff --git a/MeshFiles/unittest/Makefile.am
> b/MeshFiles/unittest/Makefile.am
> index ab3e23e..bc4f522 100644
> --- a/MeshFiles/unittest/Makefile.am
> +++ b/MeshFiles/unittest/Makefile.am
> @@ -1,4 +1,4 @@
> -SUBDIRS = io
> +SUBDIRS = io dagmc iGeom
> EXTRA_DIST = 125hex.g \
> 16_unmerged_hex.h5m \
> diff --git a/MeshFiles/unittest/dagmc/Makefile.am
> b/MeshFiles/unittest/dagmc/Makefile.am
> new file mode 100644
> index 0000000..0643ad9
> --- /dev/null
> +++ b/MeshFiles/unittest/dagmc/Makefile.am
> @@ -0,0 +1 @@
> +EXTRA_DIST = test_geom.h5m
> diff --git a/MeshFiles/unittest/dagmc/test_geom.h5m
> b/MeshFiles/unittest/dagmc/test_geom.h5m
> index 0000000..18e1d36
> Binary files /dev/null and b/MeshFiles/unittest/dagmc/test_geom.h5m differ
> diff --git a/MeshFiles/unittest/iGeom/Makefile.am
> b/MeshFiles/unittest/iGeom/Makefile.am
> index 0000000..203b676
> --- /dev/null
> +++ b/MeshFiles/unittest/iGeom/Makefile.am
> @@ -0,0 +1 @@
> +EXTRA_DIST = shell.h5m
> diff --git a/configure.ac b/configure.ac
> index 82bf72b..83d8ea5 100644
> --- a/configure.ac
> +++ b/configure.ac
> @@ -1223,6 +1223,7 @@ AC_CONFIG_FILES([Makefile
> src/parallel/Makefile
> src/oldinc/Makefile
> test/Makefile
> + test/dagmc/Makefile
> test/h5file/Makefile
> test/dual/Makefile
> test/obb/Makefile
> @@ -1254,6 +1255,8 @@ AC_CONFIG_FILES([Makefile
> MeshFiles/Makefile
> MeshFiles/unittest/io/Makefile
> + MeshFiles/unittest/iGeom/Makefile
> + MeshFiles/unittest/dagmc/Makefile
> AC_CONFIG_COMMANDS([src/MOAB_FCDefs.h],
> [sed -e "s/FC_FUNC/MOAB_FC_FUNC/" src/FCDefs.h >src/MOAB_FCDefs.h])
> diff --git a/test/Makefile.am b/test/Makefile.am
> index 4797a49..cf79fd3 100644
> --- a/test/Makefile.am
> +++ b/test/Makefile.am
> @@ -1,4 +1,4 @@
> -SUBDIRS = . io dual obb perf
> +SUBDIRS = . io dual obb perf dagmc
> if HDF5_FILE
> SUBDIRS += h5file
> endif
> diff --git a/test/dagmc/Makefile.am b/test/dagmc/Makefile.am
> index 0000000..d092176
> --- /dev/null
> +++ b/test/dagmc/Makefile.am
> @@ -0,0 +1,28 @@
> +LDADD = $(top_builddir)/src/libMOAB.la
> $(top_builddir)/tools/dagmc/DagMC.lo
> +MESHDIR = $(top_srcdir)/MeshFiles/unittest
> +AM_CPPFLAGS += -DSRCDIR=$(srcdir) \
> + -DMESHDIR=$(MESHDIR) \
> + -I$(builddir) -I.. -I$(srcdir)/.. \
> + -I$(top_builddir)/src \
> + -I$(top_srcdir)/src \
> + -I$(top_srcdir)/src/io \
> + -I$(top_srcdir)/src/parallel \
> + -I$(top_srcdir)/tools/dagmc
> +TESTS =
> +if HDF5_FILE
> + TESTS += dagmc_simple_test \
> + dagmc_rayfire_test \
> + dagmc_pointinvol_test
> +endif
> +check_PROGRAMS = $(TESTS)
> +dagmc_simple_test_SOURCES = $(srcdir)/../TestUtil.hpp
> dagmc_simple_test.cpp
> +dagmc_simple_test_CXXFLAGS = $(CGM_CPPFLAGS) $(CXXFLAGS) $(CGM_LIBS)
> +dagmc_rayfire_test_SOURCES = $(srcdir)/../TestUtil.hpp
> dagmc_rayfire_test.cpp
> +dagmc_rayfire_test_CXXFLAGS = $(CGM_CPPFLAGS) $(CXXFLAGS) $(CGM_LIBS)
> +dagmc_pointinvol_test_SOURCES = $(srcdir)/../TestUtil.hpp
> dagmc_pointinvol_test.cpp
> +dagmc_pointinvol_test_CXXFLAGS = $(CGM_CPPFLAGS) $(CXXFLAGS) $(CGM_LIBS)
> diff --git a/test/dagmc/dagmc_pointinvol_test.cpp
> b/test/dagmc/dagmc_pointinvol_test.cpp
> index 0000000..47ee7c1
> --- /dev/null
> +++ b/test/dagmc/dagmc_pointinvol_test.cpp
> @@ -0,0 +1,283 @@
> +#include <iostream>
> +#include "moab/Interface.hpp"
> +#ifndef IS_BUILDING_MB
> +#define IS_BUILDING_MB
> +#endif
> +#include "TestUtil.hpp"
> +#include "Internals.hpp"
> +#include "moab/Core.hpp"
> +#include "DagMC.hpp"
> +using namespace moab;
> +using moab::DagMC;
> +#define DAG DagMC::instance()
> +#define CHKERR(A) do { if (MB_SUCCESS != (A)) { \
> + std::cerr << "Failure (error code " << (A) << ") at " __FILE__ ":" \
> + << __LINE__ << std::endl; \
> + return A; } } while(false)
> +#ifdef MESHDIR
> +static const char input_file[] = STRINGIFY(MESHDIR)
> "/dagmc/test_geom.h5m";
> +#else
> +#endif
> +void dagmc_setup_test()
> + ErrorCode rval = DAG->load_file(input_file); // open the Dag file
> + CHECK_ERR(rval);
> + rval = DAG->init_OBBTree();
> + CHECK_ERR(rval);
> + int num_vols = DAG->num_entities(3);
> + EntityHandle vol;
> + for ( int i = 0 ; i < num_vols ; i++ )
> + vol = DAG->entity_by_index(3,i);
> + //EntityHandle volume = 12682136550675316765;
> + //CHECK_EQUAL(volume,vol);
> +void dagmc_point_in()
> + int result = 0;
> + int expected_result=1;
> + double xyz[3]={0.0,0.0,0.0};
> + int vol_idx=1;
> + EntityHandle vol_h = DAG->entity_by_index(3,vol_idx);
> + ErrorCode rval = DAG->point_in_volume(vol_h,xyz,result);
> + CHECK_ERR(rval);
> + CHECK_EQUAL(expected_result,result);
> +int dagmc_point_in_vol_dir(double origin[3],double dir[3],int vol_idx)
> + int result = 0;
> + double xyz[3];
> + double next_surf_dist;
> + EntityHandle next_surf;
> + // normalise the vector
> + double dir_norm = (dir[0]*dir[0])+(dir[1]*dir[1])+(dir[2]*dir[2]);
> + dir[0]=dir[0]/sqrt(dir_norm);
> + dir[1]=dir[1]/sqrt(dir_norm);
> + dir[2]=dir[2]/sqrt(dir_norm);
> + ErrorCode rval =
> DAG->ray_fire(vol_h,origin,dir,next_surf,next_surf_dist);
> + xyz[0]=origin[0]+(next_surf_dist*dir[0]);
> + xyz[1]=origin[1]+(next_surf_dist*dir[1]);
> + xyz[2]=origin[2]+(next_surf_dist*dir[2]);
> + std::cout << xyz[0] << " " << xyz[1] << " " << xyz[2] << std::endl;
> + rval = DAG->point_in_volume(vol_h,xyz,result,dir);
> + CHECK_ERR(rval);
> + return result;
> +void dagmc_point_in_vol_1()
> + double dir[3]={ -1.0,0.0,0.0};
> + double origin[3]={0.0,0.0,0.0};
> + int vol_idx=1;
> + int result = dagmc_point_in_vol_dir(origin,dir,vol_idx);
> +void dagmc_point_in_vol_2()
> + int vol_idx=1;
> + double dir[3]={ 1.0,0.0,0.0};
> +void dagmc_point_in_vol_3()
> + int vol_idx=1;
> + double dir[3]={ 0.0,-1.0,0.0};
> +void dagmc_point_in_vol_4()
> + int vol_idx=1;
> + double dir[3]={ 0.0,1.0,0.0};
> +void dagmc_point_in_vol_5()
> + int vol_idx=1;
> + double dir[3]={ 0.0,0.0,-1.0};
> +void dagmc_point_in_vol_6()
> + int vol_idx=1;
> + double dir[3]={ 0.0,0.0,1.0};
> +void dagmc_point_on_corner_1()
> + int vol_idx=1;
> + double dir[3]={ 1.0,1.0,1.0};
> +void dagmc_point_on_corner_2()
> + int vol_idx=1;
> + double dir[3]={ -1.0,1.0,1.0};
> +void dagmc_point_on_corner_3()
> + int expected_result = 1;
> + int vol_idx=1;
> + double dir[3]={ 1.0,1.0,-1.0};
> +void dagmc_point_on_corner_4()
> + int vol_idx=1;
> + double dir[3]={ -1.0,1.0,-1.0};
> +void dagmc_point_on_corner_5()
> + int vol_idx=1;
> + double dir[3]={ 1.0,-1.0,1.0};
> +void dagmc_point_on_corner_6()
> + int vol_idx=1;
> + double dir[3]={ -1.0,-1.0,1.0};
> +void dagmc_point_on_corner_7()
> + int vol_idx=1;
> + double dir[3]={ 1.0,-1.0,-1.0};
> +void dagmc_point_on_corner_8()
> + int vol_idx=1;
> + double dir[3]={ -1.0,-1.0,-1.0};
> +int main(int /* argc */, char** /* argv */)
> + int result = 0;
> + result += RUN_TEST( dagmc_setup_test ); // setup problem
> + result += RUN_TEST( dagmc_point_in ); // point in centre
> + // rays fired along cardinal directions
> + result += RUN_TEST( dagmc_point_in_vol_1); // point in centre
> + result += RUN_TEST( dagmc_point_in_vol_2); // point in centre
> + result += RUN_TEST( dagmc_point_in_vol_3); // point in centre
> + result += RUN_TEST( dagmc_point_in_vol_4); // point in centre
> + result += RUN_TEST( dagmc_point_in_vol_5); // point in centre
> + result += RUN_TEST( dagmc_point_in_vol_6); // point in centre
> + // rays fired at nodes
> + result += RUN_TEST( dagmc_point_on_corner_1);
> + result += RUN_TEST( dagmc_point_on_corner_2);
> + result += RUN_TEST( dagmc_point_on_corner_3);
> + result += RUN_TEST( dagmc_point_on_corner_4);
> + // result += RUN_TEST(
> dagmc_point_in({0.0,0.0,5.0}); // point in centre
> dagmc_point_in({0.0,0.0,-5.0}); // point in centre
> dagmc_point_in({0.0,5.0,0.0}); // point in centre
> dagmc_point_in({0.0,-5.0,0.0}); // point in centre
> dagmc_point_in({5.0,0.0,0.0}); // point in centre
> dagmc_point_in({-5.0,0.0,0.0}); // point in centre
> + return result;
> diff --git a/test/dagmc/dagmc_rayfire_test.cpp
> b/test/dagmc/dagmc_rayfire_test.cpp
> index 0000000..57aa625
> --- /dev/null
> +++ b/test/dagmc/dagmc_rayfire_test.cpp
> @@ -0,0 +1,180 @@
> +#endif
> +using moab::DagMC;
> +#ifdef MESHDIR
> +#else
> +#endif
> +double eps = 1.0e-6;
> + CHECK_ERR(rval);
> + CHECK_ERR(rval);
> + EntityHandle vol_h;
> + vol_h = DAG->entity_by_index(3,i);
> + // EntityHandle volume = 12682136550675316765;
> + // CHECK_EQUAL(volume,vol);
> +void dagmc_origin_face_rayfire()
> + int vol_idx = 1;
> + double dir[3]={-1.0,0.0,0.0};
> + DAG->ray_fire(vol_h,origin,dir,next_surf,next_surf_dist);
> + double expected_next_surf_dist=5.0;
> + CHECK_REAL_EQUAL(expected_next_surf_dist,next_surf_dist,eps);
> +void dagmc_outside_face_rayfire()
> + int vol_idx = 1;
> + double dir[3]={1.0,0.0,0.0}; // ray along x direction
> + double origin[3]={-10.0,0.0,0.0}; // origin at -10 0 0
> + std::cout << next_surf_dist << std::endl;
> + double expected_next_surf_dist=15.0;
> +void dagmc_outside_face_rayfire_orient_exit()
> + DagMC::RayHistory history;
> + int vol_idx = 1;
> + DAG->ray_fire(vol_h,origin,dir,next_surf,next_surf_dist,&history,0,1);
> +void dagmc_outside_face_rayfire_orient_entrance()
> + int vol_idx = 1;
> DAG->ray_fire(vol_h,origin,dir,next_surf,next_surf_dist,&history,0.0,-1);
> +void dagmc_outside_face_rayfire_history_fail()
> + int vol_idx = 1;
> + double xyz[3];
> + history.reset();
> + // ray fired exactly along boundary shared by 2 facets on a single
> surface,
> + // needs two ray_fires to cross, this is expected and ok
> + // first ray fire with history
> + // second ray fire with history
> + DAG->ray_fire(vol_h,xyz,dir,next_surf,next_surf_dist,&history,0,1);
> + // this fire should hit graveyard, i.e. next_surf = 0
> + // using history with this geom, there should be no next surface, i.e. 0
> + EntityHandle ZERO = 0;
> + CHECK_EQUAL(ZERO ,next_surf);
> +void dagmc_outside_face_rayfire_history()
> + int vol_idx = 1;
> + double xyz[3];
> + history.reset();
> + std::cout << next_surf << " " << history.size() << std::endl;
> + // ray fired execacyl
> + int result = 0;
> + result += RUN_TEST( dagmc_origin_face_rayfire ); // point in
> centre
> + result += RUN_TEST( dagmc_outside_face_rayfire );
> + result += RUN_TEST( dagmc_outside_face_rayfire_orient_exit ); // fire
> ray from point outside volume looking for exit intersections
> + result += RUN_TEST( dagmc_outside_face_rayfire_orient_entrance ); //
> fire ray from point outside volume looking for entrance intersection
> + result += RUN_TEST( dagmc_outside_face_rayfire_history_fail ); // fire
> ray from point outside geometry using ray history
> + result += RUN_TEST( dagmc_outside_face_rayfire_history ); // fire ray
> + return result;
> diff --git a/test/dagmc/dagmc_simple_test.cpp
> b/test/dagmc/dagmc_simple_test.cpp
> index 0000000..bf253f6
> --- /dev/null
> +++ b/test/dagmc/dagmc_simple_test.cpp
> @@ -0,0 +1,137 @@
> +#endif
> +using moab::DagMC;
> +#ifdef MESHDIR
> +#else
> +#endif
> +void dagmc_load_file()
> + CHECK_ERR(rval);
> +void dagmc_build_obb()
> + ErrorCode rval = DAG->init_OBBTree();
> + CHECK_ERR(rval);
> +void dagmc_num_vols()
> + int expect_num_vols=2;
> + CHECK_EQUAL(expect_num_vols,num_vols);
> +void dagmc_entity_handle()
> + //EntityHandle expect_vol_h = 12682136550675316765;
> + //CHECK_EQUAL(expect_vol_h,vol_h);
> + int result = 0;
> + int expect_result=1;
> + int vol_idx=1;
> + CHECK_EQUAL(expect_result,result);
> +void dagmc_rayfire()
> + const double eps = 1e-6; // epsilon for test, faceting tol?
> + int vol_idx=1;
> + // note model is cube of side 10, centred at 0,0,0, so ray fire along
> + // any unit direction should be exactly 5.0
> + double dir[3]={0.0,0.0,1.0};
> + double expect_next_surf_dist=5.0;
> + ErrorCode rval = DAG->ray_fire(vol_h,xyz,dir,next_surf,next_surf_dist);
> + CHECK_REAL_EQUAL(expect_next_surf_dist,next_surf_dist,eps);
> +void dagmc_closest_to()
> + int vol_idx=1;
> + double xyz[3]={-6.0,0.0,0.0};
> + double distance; // distance from point to nearest surface
> + double expect_distance=1.0;
> + ErrorCode rval = DAG->closest_to_location(vol_h,xyz,distance);
> + // distance should be 1.0 cm
> + CHECK_REAL_EQUAL(expect_distance,distance,eps);
> +void dagmc_test_boundary()
> + int vol_idx=1;
> + int surf_idx=1;
> + EntityHandle surf_h = DAG->entity_by_index(2,surf_idx);
> + double xyz[3]={0.0,0.0,5.0};
> + int result;
> + int expect_result=0;
> + ErrorCode rval = DAG->test_volume_boundary(vol_h,surf_h,xyz,dir,result);
> + // check ray leaving volume
> + int result = 0;
> + result += RUN_TEST( dagmc_load_file ); // test ray fire
> + result += RUN_TEST( dagmc_build_obb ); // build the obb
> + result += RUN_TEST( dagmc_num_vols ); // make sure the num of vols
> correct
> + // result += RUN_TEST( dagmc_entity_handle); // check the entity
> handle correct
> + result += RUN_TEST( dagmc_point_in); // check entity by point
> + result += RUN_TEST( dagmc_rayfire ) ; // ensure ray fire distance
> is correct
> + result += RUN_TEST( dagmc_closest_to ); // check the distance to
> surface nearest point
> + result += RUN_TEST( dagmc_test_boundary ); // check particle entering
> leaving
> + return result;
> diff --git a/tools/dagmc/DagMC.cpp b/tools/dagmc/DagMC.cpp
> index 87f84cb..6e2260a 100755
> --- a/tools/dagmc/DagMC.cpp
> +++ b/tools/dagmc/DagMC.cpp
> @@ -536,6 +536,7 @@ ErrorCode DagMC::ray_fire(const EntityHandle vol,
> const double point[3], const double dir[3],
> EntityHandle& next_surf, double& next_surf_dist,
> RayHistory* history, double user_dist_limit,
> + int ray_orientation,
> OrientedBoxTreeTool::TrvStats* stats ) {
> // take some stats that are independent of nps
> @@ -591,9 +592,6 @@ ErrorCode DagMC::ray_fire(const EntityHandle vol,
> // min_tolerance_intersections is passed but not used in this call
> const int min_tolerance_intersections = 0;
> - // only get exit intersections
> - const int desired_orientation = 1;
> // numericalPrecision is used for box.intersect_ray and find triangles
> in the
> // neighborhood of edge/node intersections.
> rval = obbTree.ray_intersect_sets( dists, surfs, facets,
> @@ -601,7 +599,7 @@ ErrorCode DagMC::ray_fire(const EntityHandle vol,
> min_tolerance_intersections,
> point, dir, &nonneg_ray_len,
> stats, &neg_ray_len, &vol, &senseTag,
> - &desired_orientation,
> + &ray_orientation,
> history ? &(history->prev_facets) :
> NULL );
> assert( MB_SUCCESS == rval );
> if(MB_SUCCESS != rval) return rval;
> diff --git a/tools/dagmc/DagMC.hpp b/tools/dagmc/DagMC.hpp
> index 9e71601..fe39082 100755
> --- a/tools/dagmc/DagMC.hpp
> +++ b/tools/dagmc/DagMC.hpp
> @@ -170,6 +170,9 @@ public:
> * by this query will also be added to the history.
> * @param dist_limit Optional distance limit. If provided and > 0, no
> intersections at a
> * distance further than this value will be returned.
> + * @param ray_orientation Optional ray orientation. If provided
> determines intersections
> + * along the normal provided, e.g. if -1 allows
> intersections back along the
> + * the ray direction, Default is 1, i.e. exit
> intersections
> * @param stats Optional TrvStats object used to measure performance of
> underlying OBB
> * ray-firing query. See OrientedBoxTreeTool.hpp for
> details.
> @@ -178,6 +181,7 @@ public:
> const double ray_start[3], const double ray_dir[3],
> RayHistory* history = NULL, double dist_limit = 0,
> + int ray_orientation = 1,
> OrientedBoxTreeTool::TrvStats* stats = NULL );
> /**\brief Test if a point is inside or outside a volume
> diff --git a/tools/dagmc/ray_fire_test.cc b/tools/dagmc/ray_fire_test.cc
> index 7e5ce30..cc73a38 100644
> --- a/tools/dagmc/ray_fire_test.cc
> +++ b/tools/dagmc/ray_fire_test.cc
> @@ -277,7 +277,8 @@ int main( int argc, char* argv[] )
> ray_t ray = rays[i];
> std::cout << " Ray: point = " << ray.p << " dir = " << ray.v <<
> std::endl;
> - rval = dagmc.ray_fire( vol, ray.p.array(), ray.v.array(), surf,
> dist, NULL, 0, trv_stats );
> + // added ray orientation
> + rval = dagmc.ray_fire( vol, ray.p.array(), ray.v.array(), surf,
> dist, NULL, 0, 1, trv_stats );
> if(MB_SUCCESS != rval) {
> std::cerr << "ERROR: ray_fire() failed!" << std::endl;
> @@ -326,8 +327,8 @@ int main( int argc, char* argv[] )
> << " " << uvw << " " << uvw%uvw << std::endl;
> uavg += uvw[0]; vavg += uvw[1]; wavg += uvw[2];
> #endif
> - dagmc.ray_fire(vol, xyz.array(), uvw.array(), surf, dist, NULL, 0,
> trv_stats );
> + dagmc.ray_fire(vol, xyz.array(), uvw.array(), surf, dist, NULL, 0, 1,
> trv_stats );
> if( surf == 0){ random_rays_missed++; }
> Repository URL: https://bitbucket.org/fathomteam/moab/
> This is a commit notification from bitbucket.org. You are receiving
> this because you have the service enabled, addressing the recipient of
> this email.
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140327/1029a043/attachment-0001.html>
