[MOAB-dev] Version4.6 branch should not be used until further notice
    Grindeanu, Iulian R.
    iulian at mcs.anl.gov
    Fri May 23 07:04:59 CDT 2014
So I thought you wanted a branch off Version4.6 (new_branch_for_release4.6.3), that will be merged with master, on which we should create the release 4.6.3 tag
The way it is now, Version4.6 has my local experiments; It is usable. We should at least delete the tag 4.6.3 on it, it should contain more fixes (merge again with the master)
It seems to be complicated to revert / undo the merge, and it could have more problems down the road.
http://sethrobertson.github.io/GitFixUm/fixup.html
I would like to create the branch_for_release4.6.3 from version
9a27bef6d8f48f3ea358feda14e50fadd4039f00
and leave Version4.6 at that level. If possible;
If not, delete the tag 4.6.3, and merge more fixes to Version4.6, and call it 4.6.3
The one outstanding issue is the issue 7, I did not fix yet.
Iulian
Sent: Friday, May 23, 2014 1:34 AM
To: Grindeanu, Iulian R.
Cc: MOAB dev
Subject: Re: [MOAB-dev] Version4.6 branch should not be used until further notice
Iulian,
> because I managed to screw it up :(
what was the issue here? I see that you merged master to Version4.6
and resolved conflicts.
I pulled the branch and tested it locally (both debug and optimized)
and didn't see any problems during configure/build/check/install.
Please elaborate why this branch is not usable with the latest merge.
Vijay
On Fri, May 23, 2014 at 10:31 AM, Grindeanu, Iulian R.
> master should be fine, and if you really want Version4.6 branch you should
> use the sha
> git checkout 9a27bef6d8f48f3ea358feda14e50fadd4039f00
> should take you to the correct Version4.6
> Iulian
