[MOAB-dev] Version4.6 branch should not be used until further	notice
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Fri May 23 01:34:18 CDT 2014
Iulian,
> because I managed to screw it up :(
what was the issue here? I see that you merged master to Version4.6
and resolved conflicts.
I pulled the branch and tested it locally (both debug and optimized)
and didn't see any problems during configure/build/check/install.
Please elaborate why this branch is not usable with the latest merge.
Vijay
On Fri, May 23, 2014 at 10:31 AM, Grindeanu, Iulian R.
> master should be fine, and if you really want Version4.6 branch you should
> use the sha
> 9a27bef6d8f48f3ea358feda14e50fadd4039f00
> git checkout 9a27bef6d8f48f3ea358feda14e50fadd4039f00
> should take you to the correct Version4.6
> Iulian
