[MOAB-dev] commit/MOAB: iulian07: fix issue 7
commits-noreply at bitbucket.org
Wed May 28 17:59:58 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/33d234effb99/
Changeset: 33d234effb99
Branch: master
User: iulian07
Date: 2014-05-29 00:55:55
Summary: fix issue 7
it fixes just the exchange tags method
still need to fix:
reduce tags
send_entities, ghost, settle intersection points, etc.
(All methods that use this parallel communication strategy as in
recv_buffer and send_buffer)
uses the procedure outlined by Danqing in mpitest3
there should be 3 send/receive requests for each processor we communicate with
from current processor
the memory leak as experienced by the test from Anton Kanaev is gone
Affected #: 1 file
diff --git a/src/parallel/ParallelComm.cpp b/src/parallel/ParallelComm.cpp
index bcc555a..769bace 100644
--- a/src/parallel/ParallelComm.cpp
+++ b/src/parallel/ParallelComm.cpp
@@ -7038,8 +7038,8 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
// post ghost irecv's for all interface procs
// index greqs the same as buffer/sharing procs indices
- std::vector<MPI_Request> recv_tag_reqs(2*buffProcs.size(), MPI_REQUEST_NULL),
- sent_ack_reqs(buffProcs.size(), MPI_REQUEST_NULL);
+ std::vector<MPI_Request> recv_tag_reqs(3*buffProcs.size(), MPI_REQUEST_NULL);
+ // sent_ack_reqs(buffProcs.size(), MPI_REQUEST_NULL);
std::vector<unsigned int>::iterator sit;
int ind;
@@ -7054,7 +7054,7 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
success = MPI_Irecv(remoteOwnedBuffs[ind]->mem_ptr, INITIAL_BUFF_SIZE,
MPI_UNSIGNED_CHAR, *sit,
MB_MESG_TAGS_SIZE, procConfig.proc_comm(),
- &recv_tag_reqs[2*ind]);
+ &recv_tag_reqs[3*ind]);
if (success != MPI_SUCCESS) {
result = MB_FAILURE;
RRA("Failed to post irecv in ghost exchange.");
@@ -7064,7 +7064,7 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
// pack and send tags from this proc to others
// make sendReqs vector to simplify initialization
- sendReqs.resize(2*buffProcs.size(), MPI_REQUEST_NULL);
+ sendReqs.resize(3*buffProcs.size(), MPI_REQUEST_NULL);
// take all shared entities if incoming list is empty
Range entities;
@@ -7114,8 +7114,8 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
RRA("Failed to count buffer in pack_send_tag.");
// now send it
- result = send_buffer(*sit, localOwnedBuffs[ind], MB_MESG_TAGS_SIZE, sendReqs[2*ind],
- recv_tag_reqs[2*ind+1], &dum_ack_buff, incoming);
+ result = send_buffer(*sit, localOwnedBuffs[ind], MB_MESG_TAGS_SIZE, sendReqs[3*ind],
+ recv_tag_reqs[3*ind+2], &dum_ack_buff, incoming);
RRA("Failed to send buffer.");
@@ -7123,13 +7123,16 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
// receive/unpack tags
while (incoming) {
MPI_Status status;
+ int index_in_recv_requests;
PRINT_DEBUG_WAITANY(recv_tag_reqs, MB_MESG_TAGS_SIZE, procConfig.proc_rank());
- success = MPI_Waitany(2*buffProcs.size(), &recv_tag_reqs[0], &ind, &status);
+ success = MPI_Waitany(3*buffProcs.size(), &recv_tag_reqs[0], &index_in_recv_requests, &status);
if (MPI_SUCCESS != success) {
- RRA("Failed in waitany in ghost exchange.");
+ RRA("Failed in waitany in tag exchange.");
+ // processor index in the list is divided by 3
+ ind = index_in_recv_requests/3;
PRINT_DEBUG_RECD(status);
// ok, received something; decrement incoming counter
@@ -7139,16 +7142,18 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
std::vector<EntityHandle> dum_vec;
result = recv_buffer(MB_MESG_TAGS_SIZE,
status,
- remoteOwnedBuffs[ind/2],
- recv_tag_reqs[ind/2 * 2], recv_tag_reqs[ind/2 * 2 + 1],
+ remoteOwnedBuffs[ind],
+ recv_tag_reqs[3*ind + 1], // this is for receiving the second message
+ recv_tag_reqs[3*ind + 2], // this would be for ack, but it is not used; consider removing it
incoming,
- localOwnedBuffs[ind/2], sendReqs[ind/2*2], sendReqs[ind/2*2+1],
+ localOwnedBuffs[ind], sendReqs[3*ind+1], // send reg for sendig the second message
+ sendReqs[3*ind+2], // this is for sending the ack
done);
RRA("Failed to resize recv buffer.");
if (done) {
- remoteOwnedBuffs[ind/2]->reset_ptr(sizeof(int));
- result = unpack_tags(remoteOwnedBuffs[ind/2]->buff_ptr,
- dum_vec, true, buffProcs[ind/2]);
+ remoteOwnedBuffs[ind]->reset_ptr(sizeof(int));
+ result = unpack_tags(remoteOwnedBuffs[ind]->buff_ptr,
+ dum_vec, true, buffProcs[ind]);
RRA("Failed to recv-unpack-tag message.");
@@ -7158,8 +7163,8 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
success = MPI_Barrier(procConfig.proc_comm());
else {
- MPI_Status status[2*MAX_SHARING_PROCS];
- success = MPI_Waitall(2*buffProcs.size(), &sendReqs[0], status);
+ MPI_Status status[3*MAX_SHARING_PROCS];
+ success = MPI_Waitall(3*buffProcs.size(), &sendReqs[0], status);
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
