[MOAB-dev] measure.cpp
Paul Wilson
wilsonp at engr.wisc.edu
Mon May 19 15:41:42 CDT 2014
Elliott,
Given the limited needs of our current application, you could implement
a specific version of these methods in your own project based on the
same standard algorithms used here.
Paul
On 05/19/2014 03:33 PM, Elliott Biondo wrote:
> Thank you for the responses.
> Let me know if you have any specific use case that you'd like to
> see near
> term to aid in computing element volumes, normals on a face etc.
> My use case is very simple. I have meshes that are made up of either
> Carteisan hexes or tets. I want an easy way to get the volumes of each
> mesh volume element (by supplying a volume element handle, iterator of
> handles, etc.). For now, including the build directory and linking
> against measure.o works fine, but I will keep an eye out for the
> additions to ElemUtil.
> Thanks,
> Elliott Biondo
> On Mon, May 19, 2014 at 11:19 AM, Vijay S. Mahadevan
> <vijay.m at gmail.com <mailto:vijay.m at gmail.com>> wrote:
> Sorry about the late reply.
> > This kind of function belongs to an "element utility"
> tool/class, which
> > should serve multiple types of elements;
> As Iulian mentioned, we are currently in the process of doing a
> refactor of the ElemUtil and the spatial coupler classes to provide
> more functionality to both perform discretization and common integral
> operations over different entity types. The volume computation routine
> that you found from measure.cpp is specific for structured grids and
> so if you are unsure of the underlying mesh, I wouldn't recommend
> directly using those functions.
> > Vijay, do you know the status of refactoring elem util class?
> I've been on vacation for a good part of April and May and hence the
> completion of this work has slowed down. I hope to have this branch/PR
> ready for review and then a merge by the second week of June. Let me
> know if you have any specific use case that you'd like to see near
> Vijay
> On Sat, May 17, 2014 at 12:28 AM, Grindeanu, Iulian R.
> <iulian at mcs.anl.gov <mailto:iulian at mcs.anl.gov>> wrote:
> > Hi,
> tool/class, which
> > Probably, better would be to use some gauss integration method.
> There is
> > some work now in mbcoupler to expose more element types and more
> integration
> > / FE / FV types.
> > Right now, in MOAB, this method is used just for mbsize; it is not
> > "installed", so you cannot "include" it. Unless you add your
> build folder in
> > the include . Or how do you (plan to) use it?
> > There are other issues with this method. It uses a local class
> CartVect,
> > which is a conflict with the namespaced moab::CartVect.
> > as it stands, volume is computed here using linear decomposition in
> > tetrahedrons, which might not be correct. It is fine for planar
> faced hexas.
> > It could be a too big of approximation for slightly distorted
> hexas; also,
> > depending on how you decompose a hexa in tetras (more than one
> way is
> > possible), you get different results.
> > Thanks,
> > Iulian
> > ________________________________
> > From: moab-dev-bounces at mcs.anl.gov
> <mailto:moab-dev-bounces at mcs.anl.gov>
> [moab-dev-bounces at mcs.anl.gov
> <mailto:moab-dev-bounces at mcs.anl.gov>] on behalf
> > of Elliott Biondo [Biondo at wisc.edu <mailto:Biondo at wisc.edu>]
> > Sent: Friday, May 16, 2014 1:25 PM
> > To: moab-dev at mcs.anl.gov <mailto:moab-dev at mcs.anl.gov>
> > Subject: [MOAB-dev] measure.cpp
> > I am currently using the function "measure" in measure.cpp to
> find the
> > volumes of mesh volume elements. Currently I have to link
> against measure.o,
> > which is compiled into the MOAB build directory, but as best as
> I can tell,
> > it is not exposed through the MOAB library. Are there any plans
> to include
> > this capability within the core library of MOAB, so that this
> function could
> > be used in a more formal way?
> > Thanks,
> > Elliott Biondo
> > Elliott D. Biondo
> > Nuclear Regulatory Commission Fellow
> > Computational Nuclear Engineering Research Group (CNERG)
> > Department of Nuclear Engineering and Engineering Physics
> > University of Wisconsin - Madison
> > 434 Engineering Research Building
> > 1500 Engineering Drive
> > Madison, WI 53706
> > Calendar
> Elliott D. Biondo
> Madison, WI 53706
> Calendar
> <https://www.google.com/calendar/embed?src=elliott.biondo%40gmail.com&ctz=America/Chicago>
Paul Wilson ~ UW-Madison ~ 608-263-0807 ~ cal: http://bit.ly/pphw-cal
Professor, Engineering Physics. ~ http://cnerg.engr.wisc.edu
Faculty Director, Advanced Computing Infrastructure
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140519/ac4886a1/attachment.html>
Type: application/pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140519/ac4886a1/attachment.bin>
