[MOAB-dev] measure.cpp
Elliott Biondo Biondo at wisc.edu
Mon May 19 15:33:05 CDT 2014
Thank you for the responses.
Let me know if you have any specific use case that you'd like to see near
> term to aid in computing element volumes, normals on a face etc.
My use case is very simple. I have meshes that are made up of either
Carteisan hexes or tets. I want an easy way to get the volumes of each mesh
volume element (by supplying a volume element handle, iterator of handles,
etc.). For now, including the build directory and linking against measure.o
works fine, but I will keep an eye out for the additions to ElemUtil.
Elliott Biondo
On Mon, May 19, 2014 at 11:19 AM, Vijay S. Mahadevan <vijay.m at gmail.com>wrote:
> Sorry about the late reply.
> > This kind of function belongs to an "element utility" tool/class, which
> > should serve multiple types of elements;
> As Iulian mentioned, we are currently in the process of doing a
> refactor of the ElemUtil and the spatial coupler classes to provide
> more functionality to both perform discretization and common integral
> operations over different entity types. The volume computation routine
> that you found from measure.cpp is specific for structured grids and
> so if you are unsure of the underlying mesh, I wouldn't recommend
> directly using those functions.
> > Vijay, do you know the status of refactoring elem util class?
> I've been on vacation for a good part of April and May and hence the
> completion of this work has slowed down. I hope to have this branch/PR
> ready for review and then a merge by the second week of June. Let me
> Vijay
> On Sat, May 17, 2014 at 12:28 AM, Grindeanu, Iulian R.
> <iulian at mcs.anl.gov> wrote:
> > Hi,
> > Probably, better would be to use some gauss integration method. There is
> > some work now in mbcoupler to expose more element types and more
> integration
> > / FE / FV types.
> > Right now, in MOAB, this method is used just for mbsize; it is not
> > "installed", so you cannot "include" it. Unless you add your build
> folder in
> > the include . Or how do you (plan to) use it?
> > There are other issues with this method. It uses a local class CartVect,
> > which is a conflict with the namespaced moab::CartVect.
> >  as it stands, volume is computed here using linear decomposition in
> > tetrahedrons, which might not be correct. It is fine for planar faced
> hexas.
> > It could be a too big of approximation for slightly distorted hexas;
> also,
> > depending on how you decompose a hexa in tetras (more than one way is
> > possible), you get different results.
> > Thanks,
> > Iulian
> > ________________________________
> > From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on
> behalf
> > of Elliott Biondo [Biondo at wisc.edu]
> > Sent: Friday, May 16, 2014 1:25 PM
> > To: moab-dev at mcs.anl.gov
> > Subject: [MOAB-dev] measure.cpp
> > I am currently using the function "measure" in measure.cpp to find the
> > volumes of mesh volume elements. Currently I have to link against
> measure.o,
> > which is compiled into the MOAB build directory, but as best as I can
> tell,
> > it is not exposed through the MOAB library. Are there any plans to
> include
> > this capability within the core library of MOAB, so that this function
> could
> > be used in a more formal way?
> > Thanks,
> > Elliott Biondo
> > Elliott D. Biondo
> > Nuclear Regulatory Commission Fellow
> > Computational Nuclear Engineering Research Group (CNERG)
> > Department of Nuclear Engineering and Engineering Physics
> > University of Wisconsin - Madison
> > 434 Engineering Research Building
> > 1500 Engineering Drive
> > Madison, WI 53706
> > Calendar
Elliott D. Biondo
Madison, WI 53706
Calendar<https://www.google.com/calendar/embed?src=elliott.biondo%40gmail.com&ctz=America/Chicago>
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140519/e9121c8f/attachment-0001.html>
