[MOAB-dev] commit/MOAB: danwu: Added two test cases to write_nc for CAM_EUL, to test writing variable T which is read from three files (each file contains a single timestep).
commits-noreply at bitbucket.org
Fri May 16 13:56:53 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/cf2ba4e531d5/
Changeset: cf2ba4e531d5
Branch: master
User: danwu
Date: 2014-05-16 20:56:36
Summary: Added two test cases to write_nc for CAM_EUL, to test writing variable T which is read from three files (each file contains a single timestep).
Affected #: 3 files
diff --git a/test/io/Makefile.am b/test/io/Makefile.am
index 13b7046..6d01313 100644
--- a/test/io/Makefile.am
+++ b/test/io/Makefile.am
@@ -91,11 +91,12 @@ MOSTLYCLEANFILES = dumped_acis.sat \
mb_write.g \
mb_write2.g \
singlecyl_tmp.ccmg \
+ test_eul_across_files.nc \
+ test_eul_append.nc \
+ test_eul_ghosting.nc \
+ test_eul_T2.nc \
test_eul_T.nc \
test_fv_T.nc \
test_gcrm_vars.nc \
test_homme_T.nc \
- test_mpas_vars.nc \
- test_eul_T2.nc \
- test_eul_append.nc \
- test_eul_ghosting.nc
+ test_mpas_vars.nc
diff --git a/test/io/write_nc.cpp b/test/io/write_nc.cpp
index b0dc3db..d59829d 100644
--- a/test/io/write_nc.cpp
+++ b/test/io/write_nc.cpp
@@ -5,12 +5,18 @@ using namespace moab;
#ifdef MESHDIR
static const char example_eul[] = STRINGIFY(MESHDIR) "/io/eul26x48x96.t.3.nc";
+static const char example_eul_t0[] = STRINGIFY(MESHDIR) "/io/eul26x48x96.t0.nc";
+static const char example_eul_t1[] = STRINGIFY(MESHDIR) "/io/eul26x48x96.t1.nc";
+static const char example_eul_t2[] = STRINGIFY(MESHDIR) "/io/eul26x48x96.t2.nc";
static const char example_fv[] = STRINGIFY(MESHDIR) "/io/fv26x46x72.t.3.nc";
static const char example_homme[] = STRINGIFY(MESHDIR) "/io/homme26x3458.t.3.nc";
static const char example_mpas[] = STRINGIFY(MESHDIR) "/io/mpasx1.642.t.2.nc";
static const char example_gcrm[] = STRINGIFY(MESHDIR) "/io/gcrm_r3.nc";
#else
static const char example_eul[] = "/io/eul26x48x96.t.3.nc";
+static const char example_eul_t0[] = "/io/eul26x48x96.t0.nc";
+static const char example_eul_t1[] = "/io/eul26x48x96.t1.nc";
+static const char example_eul_t2[] = "/io/eul26x48x96.t2.nc";
static const char example_fv[] = "/io/fv26x46x72.t.3.nc";
static const char example_homme[] = "/io/homme26x3458.t.3.nc";
static const char example_mpas[] = "/io/mpasx1.642.t.2.nc";
@@ -48,7 +54,6 @@ void test_homme_check_T();
void test_mpas_read_write_vars();
void test_mpas_check_vars();
// GCRM
void test_gcrm_read_write_vars();
//void test_gcrm_check_vars();
@@ -61,6 +66,10 @@ void test_eul_check_timestep();
void test_eul_read_write_append();
void test_eul_check_append();
+// Test writing variables with timesteps spread across files
+void test_eul_read_write_across_files();
+void test_eul_check_across_files();
#ifdef USE_MPI
// Test mesh with ghosted entities
void test_eul_read_write_ghosting();
@@ -105,6 +114,9 @@ int main(int argc, char* argv[])
result += RUN_TEST(test_eul_read_write_append);
result += RUN_TEST(test_eul_check_append);
+ result += RUN_TEST(test_eul_read_write_across_files);
+ result += RUN_TEST(test_eul_check_across_files);
#ifdef USE_MPI
result += RUN_TEST(test_eul_read_write_ghosting);
result += RUN_TEST(test_eul_check_ghosting);
@@ -210,15 +222,15 @@ void test_eul_check_T()
#endif
NCDF_SIZE start[] = {0, 0, 0, 0};
- NCDF_SIZE count[] = {2, 1, 48, 96}; // Read two timesteps and one level
+ NCDF_SIZE count[] = {3, 1, 48, 96}; // Read three timesteps and one level
// Read variable T on 48 * 96 quads (first level)
- double T_vals_lev1[2 * 48 * 96];
+ double T_vals_lev1[3 * 48 * 96];
success = NCFUNC(get_vara_double)(ncid, T_id, start, count, T_vals_lev1);
CHECK_EQUAL(0, success);
// Read variable T on 48 * 96 quads (last level)
- double T_vals_lev26[2 * 48 * 96];
+ double T_vals_lev26[3 * 48 * 96];
start[1] = 25;
success = NCFUNC(get_vara_double)(ncid, T_id, start, count, T_vals_lev26);
@@ -244,10 +256,15 @@ void test_eul_check_T()
CHECK_REAL_EQUAL(232.6458, T_vals_lev1[2304], eps); // Median quad
CHECK_REAL_EQUAL(200.6828, T_vals_lev1[4607], eps); // Last quad
// Timestep 1
- CHECK_REAL_EQUAL(241.7352, T_vals_lev1[0 + 4608], eps); // First quad
+ CHECK_REAL_EQUAL(241.7353, T_vals_lev1[0 + 4608], eps); // First quad
CHECK_REAL_EQUAL(234.7536, T_vals_lev1[2303 + 4608], eps); // Median quad
CHECK_REAL_EQUAL(234.4739, T_vals_lev1[2304 + 4608], eps); // Median quad
CHECK_REAL_EQUAL(198.2482, T_vals_lev1[4607 + 4608], eps); // Last quad
+ // Timestep 2
+ CHECK_REAL_EQUAL(224.1966, T_vals_lev1[0 + 4608*2], eps); // First quad
+ CHECK_REAL_EQUAL(236.1358, T_vals_lev1[2303 + 4608*2], eps); // Median quad
+ CHECK_REAL_EQUAL(235.9430, T_vals_lev1[2304 + 4608*2], eps); // Median quad
+ CHECK_REAL_EQUAL(218.7719, T_vals_lev1[4607 + 4608*2], eps); // Last quad
// Check T values at some strategically chosen places (last level)
// Timestep 0
@@ -260,6 +277,11 @@ void test_eul_check_T()
CHECK_REAL_EQUAL(299.9290, T_vals_lev26[2303 + 4608], eps); // Median quad
CHECK_REAL_EQUAL(299.7614, T_vals_lev26[2304 + 4608], eps); // Median quad
CHECK_REAL_EQUAL(241.1057, T_vals_lev26[4607 + 4608], eps); // Last quad
+ // Timestep 2
+ CHECK_REAL_EQUAL(232.7547, T_vals_lev26[0 + 4608*2], eps); // First quad
+ CHECK_REAL_EQUAL(300.2307, T_vals_lev26[2303 + 4608*2], eps); // Median quad
+ CHECK_REAL_EQUAL(299.2372, T_vals_lev26[2304 + 4608*2], eps); // Median quad
+ CHECK_REAL_EQUAL(242.8274, T_vals_lev26[4607 + 4608*2], eps); // Last quad
eps = 1e-10;
@@ -1055,6 +1077,165 @@ void test_eul_check_append()
+ int procs = 1;
+#ifdef USE_MPI
+ MPI_Comm_size(MPI_COMM_WORLD, &procs);
+#endif
+// We will not test NC writer in parallel without pnetcdf support
+#ifndef PNETCDF_FILE
+ if (procs > 1)
+ return;
+#endif
+ Core moab;
+ Interface& mb = moab;
+ std::string read_opts;
+ EntityHandle set;
+ ErrorCode rval = mb.create_meshset(MESHSET_SET, set);
+ CHECK_ERR(rval);
+ // This file contains single timestep 2 (option TIMESTEP=0 will be implicitly used)
+ // Read T as tag T2 with option TIMESTEPBASE=2
+ get_eul_read_options(read_opts);
+ read_opts += ";VARIABLE=T;TIMESTEPBASE=2;DEBUG_IO=0";
+ rval = mb.load_file(example_eul_t2, &set, read_opts.c_str());
+ CHECK_ERR(rval);
+ // This file contains single timestep 0 (option TIMESTEP=0 will be implicitly used)
+ // Read T as tag T0 with option TIMESTEPBASE=0
+ read_opts += ";VARIABLE=T;TIMESTEPBASE=0;NOMESH;DEBUG_IO=0";
+ rval = mb.load_file(example_eul_t0, &set, read_opts.c_str());
+ CHECK_ERR(rval);
+ // This file contains single timestep 1 (option TIMESTEP=0 will be implicitly used)
+ // Read T as tag T1 with option TIMESTEPBASE=1
+ read_opts += ";VARIABLE=T;TIMESTEPBASE=1;NOMESH;DEBUG_IO=0";
+ rval = mb.load_file(example_eul_t1, &set, read_opts.c_str());
+ CHECK_ERR(rval);
+ // Write variable T with 3 timesteps
+ std::string write_opts = ";;VARIABLE=T;TIMESTEP=0,1,2;DEBUG_IO=0";
+#ifdef USE_MPI
+ // Use parallel options
+ write_opts += ";PARALLEL=WRITE_PART";
+#endif
+ if (procs > 1)
+ rval = mb.write_file("test_par_eul_across_files.nc", 0, write_opts.c_str(), &set, 1);
+ else
+ rval = mb.write_file("test_eul_across_files.nc", 0, write_opts.c_str(), &set, 1);
+ CHECK_ERR(rval);
+ int rank = 0;
+ int procs = 1;
+#ifdef USE_MPI
+ MPI_Comm_rank(MPI_COMM_WORLD, &rank);
+#endif
+ if (procs > 1)
+ return;
+#endif
+ if (0 == rank) {
+ int ncid;
+ int success;
+ std::string filename;
+ if (procs > 1)
+ filename = "test_par_eul_across_files.nc";
+ else
+ filename = "test_eul_across_files.nc";
+#ifdef PNETCDF_FILE
+ success = NCFUNC(open)(MPI_COMM_SELF, filename.c_str(), NC_NOWRITE, MPI_INFO_NULL, &ncid);
+#else
+ success = NCFUNC(open)(filename.c_str(), NC_NOWRITE, &ncid);
+#endif
+ CHECK_EQUAL(0, success);
+ int T_id;
+ success = NCFUNC(inq_varid)(ncid, "T", &T_id);
+ // Enter independent I/O mode
+ success = NCFUNC(begin_indep_data)(ncid);
+#endif
+ NCDF_SIZE start[] = {0, 0, 0, 0};
+ // Read variable T on 48 * 96 quads (first level)
+ success = NCFUNC(get_vara_double)(ncid, T_id, start, count, T_vals_lev1);
+ // Read variable T on 48 * 96 quads (last level)
+ start[1] = 25;
+ success = NCFUNC(get_vara_double)(ncid, T_id, start, count, T_vals_lev26);
+ // End independent I/O mode
+ success = NCFUNC(end_indep_data)(ncid);
+#endif
+ double eps = 0.0001;
+ // Check T values at some strategically chosen places (first level)
+ // Timestep 0
+ CHECK_REAL_EQUAL(252.8529, T_vals_lev1[0], eps); // First quad
+ CHECK_REAL_EQUAL(232.6670, T_vals_lev1[2303], eps); // Median quad
+ CHECK_REAL_EQUAL(232.6458, T_vals_lev1[2304], eps); // Median quad
+ CHECK_REAL_EQUAL(200.6828, T_vals_lev1[4607], eps); // Last quad
+ // Timestep 1
+ CHECK_REAL_EQUAL(234.7536, T_vals_lev1[2303 + 4608], eps); // Median quad
+ CHECK_REAL_EQUAL(234.4739, T_vals_lev1[2304 + 4608], eps); // Median quad
+ CHECK_REAL_EQUAL(198.2482, T_vals_lev1[4607 + 4608], eps); // Last quad
+ // Timestep 2
+ // Check T values at some strategically chosen places (last level)
+ // Timestep 0
+ CHECK_REAL_EQUAL(253.1395, T_vals_lev26[0], eps); // First quad
+ CHECK_REAL_EQUAL(299.0477, T_vals_lev26[2303], eps); // Median quad
+ CHECK_REAL_EQUAL(300.0627, T_vals_lev26[2304], eps); // Median quad
+ CHECK_REAL_EQUAL(241.1817, T_vals_lev26[4607], eps); // Last quad
+ // Timestep 1
+ CHECK_REAL_EQUAL(242.9252, T_vals_lev26[0 + 4608], eps); // First quad
+ CHECK_REAL_EQUAL(299.9290, T_vals_lev26[2303 + 4608], eps); // Median quad
+ CHECK_REAL_EQUAL(299.7614, T_vals_lev26[2304 + 4608], eps); // Median quad
+ CHECK_REAL_EQUAL(241.1057, T_vals_lev26[4607 + 4608], eps); // Last quad
+ // Timestep 2
+ success = NCFUNC(close)(ncid);
#ifdef USE_MPI
// NC writer should filter entities that are not owned, e.g. ghosted elements
diff --git a/test/parallel/Makefile.am b/test/parallel/Makefile.am
index 2736605..b42ba0b 100644
--- a/test/parallel/Makefile.am
+++ b/test/parallel/Makefile.am
@@ -124,11 +124,12 @@ MOSTLYCLEANFILES = mhdf_ll.h5m tmp0.h5m tmp1.h5m tmp2.h5m tmp3.h5m \
test_mpas_no_mixed_elements.h5m \
test_mpas_rcbzoltan.h5m \
test_mpas_rcbzoltan_no_mixed_elements.h5m \
+ test_par_eul_across_files.nc \
+ test_par_eul_append.nc \
+ test_par_eul_ghosting.nc \
+ test_par_eul_T2.nc \
test_par_eul_T.nc \
test_par_fv_T.nc \
test_par_gcrm_vars.nc \
test_par_homme_T.nc \
- test_par_mpas_vars.nc \
- test_par_eul_T2.nc \
- test_par_eul_append.nc \
- test_par_eul_ghosting.nc
+ test_par_mpas_vars.nc
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
