[MOAB-dev] measure.cpp
    Grindeanu, Iulian R.
    iulian at mcs.anl.gov
    Fri May 16 13:58:46 CDT 2014
This kind of function belongs to an "element utility" tool/class, which should serve multiple types of elements;
Probably, better would be to use some gauss integration method. There is some work now in mbcoupler to expose more element types and more integration / FE / FV types.
Right now, in MOAB, this method is used just for mbsize; it is not "installed", so you cannot "include" it. Unless you add your build folder in the include . Or how do you (plan to) use it?
There are other issues with this method. It uses a local class CartVect, which is a conflict with the namespaced moab::CartVect.
 as it stands, volume is computed here using linear decomposition in tetrahedrons, which might not be correct. It is fine for planar faced hexas.
It could be a too big of approximation for slightly distorted hexas; also, depending on how you decompose a hexa in tetras (more than one way is possible), you get different results.
Vijay, do you know the status of refactoring elem util class?
Iulian
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] on behalf of Elliott Biondo [Biondo at wisc.edu]
Sent: Friday, May 16, 2014 1:25 PM
To: moab-dev at mcs.anl.gov
Subject: [MOAB-dev] measure.cpp
I am currently using the function "measure" in measure.cpp to find the volumes of mesh volume elements. Currently I have to link against measure.o, which is compiled into the MOAB build directory, but as best as I can tell, it is not exposed through the MOAB library. Are there any plans to include this capability within the core library of MOAB, so that this function could be used in a more formal way?
Elliott Biondo
Elliott D. Biondo
Nuclear Regulatory Commission Fellow
Computational Nuclear Engineering Research Group (CNERG)
Department of Nuclear Engineering and Engineering Physics
University of Wisconsin - Madison
434 Engineering Research Building
1500 Engineering Drive
Madison, WI 53706
Calendar<https://www.google.com/calendar/embed?src=elliott.biondo%40gmail.com&ctz=America/Chicago>
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140516/54980d9d/attachment.html>
