[MOAB-dev] measure.cpp
    Elliott Biondo
    Biondo at wisc.edu
    Fri May 16 13:25:06 CDT 2014
I am currently using the function "measure" in measure.cpp to find the
volumes of mesh volume elements. Currently I have to link against
measure.o, which is compiled into the MOAB build directory, but as best as
I can tell, it is not exposed through the MOAB library. Are there any plans
to include this capability within the core library of MOAB, so that this
function could be used in a more formal way?
Elliott Biondo
Elliott D. Biondo
Nuclear Regulatory Commission Fellow
Computational Nuclear Engineering Research Group (CNERG)
Department of Nuclear Engineering and Engineering Physics
University of Wisconsin - Madison
434 Engineering Research Building
1500 Engineering Drive
Madison, WI 53706
Calendar<https://www.google.com/calendar/embed?src=elliott.biondo%40gmail.com&ctz=America/Chicago>
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20140516/5fd546be/attachment.html>
