[MOAB-dev] commit/MOAB: danwu: Updated NC writer to support user-created non-set variables that might not have time or level dimension.
commits-noreply at bitbucket.org
Mon May 12 17:47:13 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/96f41d5bc215/
Changeset: 96f41d5bc215
Branch: master
User: danwu
Date: 2014-05-13 00:47:00
Summary: Updated NC writer to support user-created non-set variables that might not have time or level dimension.
Affected #: 4 files
diff --git a/src/io/NCWriteGCRM.cpp b/src/io/NCWriteGCRM.cpp
index 36160d2..b9f412c 100644
--- a/src/io/NCWriteGCRM.cpp
+++ b/src/io/NCWriteGCRM.cpp
@@ -130,69 +130,94 @@ ErrorCode NCWriteGCRM::collect_variable_data(std::vector<std::string>& var_names
ERRORR(MB_FAILURE, "Can't find one variable.");
WriteNC::VarData& currentVarData = vit->second;
+ std::vector<int>& varDims = currentVarData.varDims;
// Skip edge variables, if there are no edges
if (localEdgesOwned.empty() && currentVarData.entLoc == WriteNC::ENTLOCEDGE)
continue;
- std::vector<int>& varDims = currentVarData.varDims;
+ // Skip set variables, which were already processed in NCWriteHelper::collect_variable_data()
+ if (WriteNC::ENTLOCSET == currentVarData.entLoc)
+ continue;
+ // Set up writeStarts and writeCounts (maximum number of dimensions is 3)
+ currentVarData.writeStarts.resize(3);
+ currentVarData.writeCounts.resize(3);
+ unsigned int dim_idx = 0;
+ // First: time
if (currentVarData.has_tsteps) {
- // Support non-set variables with 3 dimensions like (Time, cells, layers), or
- // 2 dimensions like (Time, cells)
+ // Non-set variables with timesteps
+ // 3 dimensions like (time, cells, layers)
+ // 2 dimensions like (time, cells)
assert(3 == varDims.size() || 2 == varDims.size());
// Time should be the first dimension
assert(tDim == varDims[0]);
- // Set up writeStarts and writeCounts
- currentVarData.writeStarts.resize(3);
- currentVarData.writeCounts.resize(3);
- // First: Time
- currentVarData.writeStarts[0] = 0; // This value is timestep dependent, will be set later
- currentVarData.writeCounts[0] = 1;
- // Next: nVertices / cells / nEdges
- switch (currentVarData.entLoc) {
- case WriteNC::ENTLOCVERT:
- // Vertices
- // Start from the first localGidVerts
- // Actually, this will be reset later for writing
- currentVarData.writeStarts[1] = localGidVertsOwned[0] - 1;
- currentVarData.writeCounts[1] = localGidVertsOwned.size();
- break;
- case WriteNC::ENTLOCFACE:
- // Faces
- // Start from the first localGidCells
- currentVarData.writeStarts[1] = localGidCellsOwned[0] - 1;
- currentVarData.writeCounts[1] = localGidCellsOwned.size();
- break;
- case WriteNC::ENTLOCEDGE:
- // Edges
- // Start from the first localGidEdges
- currentVarData.writeStarts[1] = localGidEdgesOwned[0] - 1;
- currentVarData.writeCounts[1] = localGidEdgesOwned.size();
- break;
- default:
- ERRORR(MB_FAILURE, "Unexpected entity location type for GCRM non-set variable.");
+ currentVarData.writeStarts[dim_idx] = 0; // This value is timestep dependent, will be set later
+ currentVarData.writeCounts[dim_idx] = 1;
+ dim_idx++;
+ else {
+ // Non-set variables without timesteps
+ // 2 dimensions like (cells, layers)
+ // 1 dimension like (cells)
+ assert(2 == varDims.size() || 1 == varDims.size());
- // Finally: layers or other optional levels, it is possible that there is no
- // level dimension (numLev is 0) for this non-set variable
- if (currentVarData.numLev < 1)
- currentVarData.numLev = 1;
- currentVarData.writeStarts[2] = 0;
- currentVarData.writeCounts[2] = currentVarData.numLev;
+ // Next: corners / cells / edges
+ switch (currentVarData.entLoc) {
+ case WriteNC::ENTLOCVERT:
+ // Vertices
+ // Start from the first localGidVerts
+ // Actually, this will be reset later for writing
+ currentVarData.writeStarts[dim_idx] = localGidVertsOwned[0] - 1;
+ currentVarData.writeCounts[dim_idx] = localGidVertsOwned.size();
+ break;
+ case WriteNC::ENTLOCFACE:
+ // Faces
+ // Start from the first localGidCells
+ currentVarData.writeStarts[dim_idx] = localGidCellsOwned[0] - 1;
+ currentVarData.writeCounts[dim_idx] = localGidCellsOwned.size();
+ break;
+ case WriteNC::ENTLOCEDGE:
+ // Edges
+ // Start from the first localGidEdges
+ currentVarData.writeStarts[dim_idx] = localGidEdgesOwned[0] - 1;
+ currentVarData.writeCounts[dim_idx] = localGidEdgesOwned.size();
+ break;
+ default:
+ ERRORR(MB_FAILURE, "Unexpected entity location type for GCRM non-set variable.");
+ dim_idx++;
+ // Finally: layers or other optional levels, it is possible that there is no
+ // level dimension (numLev is 0) for this non-set variable
+ if (currentVarData.numLev > 0) {
+ // Non-set variables with levels
+ assert(3 == varDims.size() || 2 == varDims.size());
+ currentVarData.writeCounts[dim_idx] = currentVarData.numLev;
+ dim_idx++;
+ else {
+ // Non-set variables without levels
// Get variable size
currentVarData.sz = 1;
- for (std::size_t idx = 0; idx != 3; idx++)
+ for (std::size_t idx = 0; idx < dim_idx; idx++)
currentVarData.sz *= currentVarData.writeCounts[idx];
+ } // for (size_t i = 0; i < var_names.size(); i++)
return MB_SUCCESS;
@@ -202,8 +227,6 @@ ErrorCode NCWriteGCRM::write_nonset_variables(std::vector<WriteNC::VarData>& vda
Interface*& mbImpl = _writeNC->mbImpl;
int success;
- Range* pLocalEntsOwned = NULL;
- Range* pLocalGidEntsOwned = NULL;
// For each indexed variable tag, write a time step data
for (unsigned int i = 0; i < vdatas.size(); i++) {
@@ -213,10 +236,9 @@ ErrorCode NCWriteGCRM::write_nonset_variables(std::vector<WriteNC::VarData>& vda
if (localEdgesOwned.empty() && variableData.entLoc == WriteNC::ENTLOCEDGE)
continue;
- // Time should be the first dimension
- assert(tDim == variableData.varDims[0]);
// Get local owned entities of this variable
+ Range* pLocalEntsOwned = NULL;
+ Range* pLocalGidEntsOwned = NULL;
switch (variableData.entLoc) {
// Vertices
@@ -237,15 +259,45 @@ ErrorCode NCWriteGCRM::write_nonset_variables(std::vector<WriteNC::VarData>& vda
- // A typical GCRM non-set variable has 3 dimensions as (time, cells, layers)
+ unsigned int num_timesteps;
+ unsigned int ents_idx = 0;
+ if (variableData.has_tsteps) {
+ num_timesteps = tstep_nums.size();
+ ents_idx++;
+ else {
+ num_timesteps = 1;
+ unsigned int num_lev;
+ if (variableData.numLev > 0) {
+ num_lev = variableData.numLev;
+ else {
+ num_lev = 1;
for (unsigned int t = 0; t < tstep_nums.size(); t++) {
// We will write one time step, and count will be one; start will be different
// Use tag_get_data instead of tag_iterate to copy tag data, as localEntsOwned
// might not be contiguous.
- variableData.writeStarts[0] = t; // This is start for time
- std::vector<double> tag_data(pLocalEntsOwned->size() * variableData.numLev);
+ if (tDim == variableData.varDims[0])
+ variableData.writeStarts[0] = t; // This is start for time
+ std::vector<double> tag_data(pLocalEntsOwned->size() * num_lev);
ErrorCode rval = mbImpl->tag_get_data(variableData.varTags[t], *pLocalEntsOwned, &tag_data[0]);
- ERRORR(rval, "Trouble getting tag data on owned vertices.");
+ ERRORR(rval, "Trouble getting tag data on owned entities.");
#ifdef PNETCDF_FILE
size_t nb_writes = pLocalGidEntsOwned->psize();
@@ -263,8 +315,8 @@ ErrorCode NCWriteGCRM::write_nonset_variables(std::vector<WriteNC::VarData>& vda
pair_iter != pLocalGidEntsOwned->pair_end(); ++pair_iter, ic++) {
EntityHandle starth = pair_iter->first;
EntityHandle endh = pair_iter->second;
- variableData.writeStarts[1] = (NCDF_SIZE)(starth - 1);
- variableData.writeCounts[1] = (NCDF_SIZE)(endh - starth + 1);
+ variableData.writeStarts[ents_idx] = (NCDF_SIZE)(starth - 1);
+ variableData.writeCounts[ents_idx] = (NCDF_SIZE)(endh - starth + 1);
// Do a partial write, in each subrange
#ifdef PNETCDF_FILE
@@ -280,7 +332,7 @@ ErrorCode NCWriteGCRM::write_nonset_variables(std::vector<WriteNC::VarData>& vda
ERRORS(success, "Failed to read double data in loop");
// We need to increment the index in double array for the
// next subrange
- indexInDoubleArray += (endh - starth + 1) * variableData.numLev;
+ indexInDoubleArray += (endh - starth + 1) * num_lev;
assert(ic == pLocalGidEntsOwned->psize());
#ifdef PNETCDF_FILE
diff --git a/src/io/NCWriteHOMME.cpp b/src/io/NCWriteHOMME.cpp
index d7b865d..7adb909 100644
--- a/src/io/NCWriteHOMME.cpp
+++ b/src/io/NCWriteHOMME.cpp
@@ -94,42 +94,73 @@ ErrorCode NCWriteHOMME::collect_variable_data(std::vector<std::string>& var_name
+ continue;
+ // First: time
- // Support non-set variables with 3 dimensions like (time, lev, ncol)
- assert(3 == currentVarData.varDims.size());
+ // 3 dimensions like (time, lev, ncol)
+ // 2 dimensions like (time, ncol)
- assert(tDim == currentVarData.varDims[0]);
- // First: time
- // Next: lev
- currentVarData.writeStarts[1] = 0;
- currentVarData.writeCounts[1] = currentVarData.numLev;
- // Finally: ncol
- // Vertices
- currentVarData.writeStarts[2] = localGidVertsOwned[0] - 1;
- currentVarData.writeCounts[2] = localGidVertsOwned.size();
- break;
- default:
- ERRORR(MB_FAILURE, "Unexpected entity location type for HOMME non-set variable.");
+ assert(tDim == varDims[0]);
+ dim_idx++;
+ else {
+ // 2 dimensions like (lev, ncol)
+ // 1 dimension like (ncol)
+ // Next: lev
+ dim_idx++;
+ else {
+ // Finally: ncol
+ // Vertices
+ break;
+ default:
+ ERRORR(MB_FAILURE, "Unexpected entity location type for HOMME non-set variable.");
+ dim_idx++;
- for (std::size_t idx = 0; idx != currentVarData.writeCounts.size(); idx++)
@@ -147,9 +178,6 @@ ErrorCode NCWriteHOMME::write_nonset_variables(std::vector<WriteNC::VarData>& vd
WriteNC::VarData& variableData = vdatas[i];
// Assume this variable is on vertices for the time being
@@ -159,16 +187,47 @@ ErrorCode NCWriteHOMME::write_nonset_variables(std::vector<WriteNC::VarData>& vd
- // A typical HOMME non-set variable has 3 dimensions as (time, lev, ncol)
+ unsigned int ncol_idx = 0;
+ ncol_idx++;
+ else {
+ ncol_idx++;
+ else {
+ num_lev = 1;
// At each timestep, we need to transpose tag format (ncol, lev) back
// to NC format (lev, ncol) for writing
- for (unsigned int t = 0; t < tstep_nums.size(); t++) {
+ for (unsigned int t = 0; t < num_timesteps; t++) {
// Use tag_get_data instead of tag_iterate to copy tag data, as localVertsOwned
// might not be contiguous. We should also transpose for level so that means
// deep copy for transpose
- std::vector<double> tag_data(num_local_verts_owned * variableData.numLev);
+ std::vector<double> tag_data(num_local_verts_owned * num_lev);
ErrorCode rval = mbImpl->tag_get_data(variableData.varTags[t], localVertsOwned, &tag_data[0]);
@@ -182,9 +241,10 @@ ErrorCode NCWriteHOMME::write_nonset_variables(std::vector<WriteNC::VarData>& vd
// Use nonblocking put (request aggregation)
switch (variableData.varDataType) {
case NC_DOUBLE: {
- std::vector<double> tmpdoubledata(num_local_verts_owned * variableData.numLev);
- // Transpose (ncol, lev) back to (lev, ncol)
- jik_to_kji(num_local_verts_owned, 1, variableData.numLev, &tmpdoubledata[0], &tag_data[0]);
+ std::vector<double> tmpdoubledata(num_local_verts_owned * num_lev);
+ if (num_lev > 1)
+ // Transpose (ncol, lev) back to (lev, ncol)
+ jik_to_kji(num_local_verts_owned, 1, num_lev, &tmpdoubledata[0], &tag_data[0]);
size_t indexInDoubleArray = 0;
size_t ic = 0;
@@ -192,8 +252,8 @@ ErrorCode NCWriteHOMME::write_nonset_variables(std::vector<WriteNC::VarData>& vd
pair_iter != localGidVertsOwned.pair_end(); ++pair_iter, ic++) {
- variableData.writeStarts[2] = (NCDF_SIZE)(starth - 1);
- variableData.writeCounts[2] = (NCDF_SIZE)(endh - starth + 1);
+ variableData.writeStarts[ncol_idx] = (NCDF_SIZE)(starth - 1);
+ variableData.writeCounts[ncol_idx] = (NCDF_SIZE)(endh - starth + 1);
#ifdef PNETCDF_FILE
@@ -209,7 +269,7 @@ ErrorCode NCWriteHOMME::write_nonset_variables(std::vector<WriteNC::VarData>& vd
// next subrange
assert(ic == localGidVertsOwned.psize());
#ifdef PNETCDF_FILE
diff --git a/src/io/NCWriteHelper.cpp b/src/io/NCWriteHelper.cpp
index b315637..635b595 100644
--- a/src/io/NCWriteHelper.cpp
+++ b/src/io/NCWriteHelper.cpp
@@ -95,68 +95,88 @@ ErrorCode NCWriteHelper::collect_variable_data(std::vector<std::string>& var_nam
if ((std::find(currentVarData.varDims.begin(), currentVarData.varDims.end(), levDim) != currentVarData.varDims.end()))
currentVarData.numLev = nLevels;
- // Process non-coordinate variables with time steps
- if (currentVarData.has_tsteps) {
- // It might be a set variable, e.g. xtime(Time) or xtime(Time, StrLen)
- Tag indexedTag = 0;
- std::stringstream ssTagNameWithIndex;
- ssTagNameWithIndex << varname << tstep_nums[t];
- rval = mbImpl->tag_get_handle(ssTagNameWithIndex.str().c_str(), indexedTag);
+ // Process set variables
+ if (WriteNC::ENTLOCSET == currentVarData.entLoc) {
+ if (currentVarData.has_tsteps) {
+ // Set variables with timesteps, e.g. xtime(Time) or xtime(Time, StrLen)
+ // TBD
+ else {
+ // Get the tag with varname
+ Tag tag = 0;
+ rval = mbImpl->tag_get_handle(varname.c_str(), tag);
ERRORR(rval, "Can't find one tag.");
- dbgOut.tprintf(2, " found indexed tag %d with name %s\n", tstep_nums[t], ssTagNameWithIndex.str().c_str());
- currentVarData.varTags.push_back(indexedTag);
+ currentVarData.varTags.push_back(tag); // Really, only one for these
+ const void* data;
+ int size;
+ rval = mbImpl->tag_get_by_ptr(tag, &_fileSet, 1, &data, &size);
+ ERRORR(rval, "Can't get tag values.");
- // The type of the tag is fixed though
+ // Find the type of tag, and use it
DataType type;
- rval = mbImpl->tag_get_data_type(indexedTag, type);
+ rval = mbImpl->tag_get_data_type(tag, type);
ERRORR(rval, "Can't get tag type.");
currentVarData.varDataType = NC_DOUBLE;
if (MB_TYPE_INTEGER == type)
currentVarData.varDataType = NC_INT;
+ assert(0 == currentVarData.memoryHogs.size()); // Nothing so far
+ currentVarData.memoryHogs.push_back((void*)data);
+ if (currentVarData.varDims.empty()) {
+ // Scalar variable
+ currentVarData.writeStarts.push_back(0);
+ currentVarData.writeCounts.push_back(1);
+ else {
+ for (size_t j = 0; j < currentVarData.varDims.size(); j++) {
+ currentVarData.writeCounts.push_back(dimLens[currentVarData.varDims[j]]);
+ // Get variable size
+ currentVarData.sz = 1;
+ for (std::size_t idx = 0; idx != currentVarData.writeCounts.size(); idx++)
+ currentVarData.sz *= currentVarData.writeCounts[idx];
- // Process non-coordinate variables without time steps
+ } // if (WriteNC::ENTLOCSET == currentVarData.entLoc)
+ // Process non-set variables
else {
- // Should be a set variable
- assert(WriteNC::ENTLOCSET == currentVarData.entLoc);
- // Get the tag with varname
- Tag tag = 0;
- rval = mbImpl->tag_get_handle(varname.c_str(), tag);
- ERRORR(rval, "Can't find one tag.");
- currentVarData.varTags.push_back(tag); // Really, only one for these
- const void* data;
- int size;
- rval = mbImpl->tag_get_by_ptr(tag, &_fileSet, 1, &data, &size);
- ERRORR(rval, "Can't get tag values.");
- // Find the type of tag, and use it
+ Tag indexedTag = 0;
+ for (unsigned int t = 0; t < tstep_nums.size(); t++) {
+ std::stringstream ssTagNameWithIndex;
+ ssTagNameWithIndex << varname << tstep_nums[t];
+ rval = mbImpl->tag_get_handle(ssTagNameWithIndex.str().c_str(), indexedTag);
+ ERRORR(rval, "Can't find one tag.");
+ dbgOut.tprintf(2, " found indexed tag %d with name %s\n", tstep_nums[t], ssTagNameWithIndex.str().c_str());
+ currentVarData.varTags.push_back(indexedTag);
+ else {
+ // This should be a user-created non-set variable without timesteps
+ // Treat it like having one, 0th, timestep
+ ssTagNameWithIndex << varname << 0;
+ ERRORR(rval, "Can't find tag for a user-created variable.");
+ dbgOut.tprintf(2, " found indexed tag 0 with name %s\n", ssTagNameWithIndex.str().c_str());
+ // The type of the tag is fixed though
DataType type;
- rval = mbImpl->tag_get_data_type(tag, type);
+ rval = mbImpl->tag_get_data_type(indexedTag, type);
- assert(0 == currentVarData.memoryHogs.size()); // Nothing so far
- currentVarData.memoryHogs.push_back((void*)data);
- if (currentVarData.varDims.empty()) {
- // Scalar variable
- currentVarData.writeStarts.push_back(0);
- currentVarData.writeCounts.push_back(1);
- else {
- for (size_t j = 0; j < currentVarData.varDims.size(); j++) {
- currentVarData.writeCounts.push_back(dimLens[currentVarData.varDims[j]]);
// Process coordinate variables here
// Check that for used coordinates we have found the tags
@@ -231,7 +251,7 @@ ErrorCode NCWriteHelper::collect_variable_data(std::vector<std::string>& var_nam
assert(0 == varCoordData.memoryHogs.size()); // Nothing so far
varCoordData.memoryHogs.push_back((void*)data);
+ } // for (std::set<std::string>::iterator setIt ...
return MB_SUCCESS;
@@ -626,44 +646,75 @@ ErrorCode ScdNCWriteHelper::collect_variable_data(std::vector<std::string>& var_
+ continue;
+ // Set up writeStarts and writeCounts (maximum number of dimensions is 4)
+ currentVarData.writeStarts.resize(4);
+ currentVarData.writeCounts.resize(4);
+ // First: time
- // Support non-set variables with 4 dimensions like (time, lev, lat, lon)
- assert(4 == currentVarData.varDims.size());
+ // 4 dimensions like (time, lev, lat, lon)
+ // 3 dimensions like (time, lat, lon)
+ assert(4 == varDims.size() || 3 == varDims.size());
- currentVarData.writeStarts.resize(4);
- currentVarData.writeCounts.resize(4);
- // First: time
- // Next: lev
- // Finally: lat and lon
- // Faces
- currentVarData.writeStarts[2] = lCDims[1];
- currentVarData.writeCounts[2] = lCDims[4] - lCDims[1] + 1;
- currentVarData.writeStarts[3] = lCDims[0];
- currentVarData.writeCounts[3] = lCDims[3] - lCDims[0] + 1;
- break;
- default:
- ERRORR(MB_FAILURE, "Unexpected entity location type for structured mesh non-set variable.");
+ dim_idx++;
+ else {
+ // 3 dimensions like (lev, lat, lon)
+ // 2 dimensions like (lat, lon)
+ // Next: lev
+ dim_idx++;
+ else {
+ // Finally: lat and lon
+ // Faces
+ currentVarData.writeStarts[dim_idx] = lCDims[1];
+ currentVarData.writeCounts[dim_idx] = lCDims[4] - lCDims[1] + 1;
+ currentVarData.writeStarts[dim_idx + 1] = lCDims[0];
+ currentVarData.writeCounts[dim_idx + 1] = lCDims[3] - lCDims[0] + 1;
+ break;
+ default:
+ ERRORR(MB_FAILURE, "Unexpected entity location type for structured mesh non-set variable.");
+ dim_idx += 2;
return MB_SUCCESS;
@@ -681,9 +732,6 @@ ErrorCode ScdNCWriteHelper::write_nonset_variables(std::vector<WriteNC::VarData>
// Assume this variable is on faces for the time being
@@ -693,20 +741,51 @@ ErrorCode ScdNCWriteHelper::write_nonset_variables(std::vector<WriteNC::VarData>
- // A typical CAM-EUL or CAM-FV non-set variable has 4 dimensions as (time, lev, lat, lon)
- // At each timestep, we need to transpose tag format (lat, lon, lev) back
- // to NC format (lev, lat, lon) for writing
- size_t ni = variableData.writeCounts[3]; // lon
- size_t nj = variableData.writeCounts[2]; // lat
- size_t nk = variableData.writeCounts[1]; // lev
+ unsigned int lat_idx = 0;
+ unsigned int lon_idx = 1;
+ lat_idx++;
+ lon_idx++;
+ else {
+ lat_idx++;
+ lon_idx++;
+ else {
+ num_lev = 1;
- variableData.writeCounts[0] = 1; // We will write one time step
+ size_t ni = variableData.writeCounts[lon_idx]; // lon
+ size_t nj = variableData.writeCounts[lat_idx]; // lat
+ // At each timestep, we need to transpose tag format (lat, lon, lev) back
+ // to NC format (lev, lat, lon) for writing
// Use tag_iterate to get tag data (assume that localCellsOwned is contiguous)
// We should also transpose for level so that means deep copy for transpose
int count;
void* dataptr;
ErrorCode rval = mbImpl->tag_iterate(variableData.varTags[t], localCellsOwned.begin(), localCellsOwned.end(), count, dataptr);
@@ -718,9 +797,10 @@ ErrorCode ScdNCWriteHelper::write_nonset_variables(std::vector<WriteNC::VarData>
// nonblocking put (request aggregation) later
case NC_DOUBLE: {
- std::vector<double> tmpdoubledata(ni*nj*nk);
- // Transpose (lat, lon, lev) back to (lev, lat, lon)
- jik_to_kji(ni, nj, nk, &tmpdoubledata[0], (double*)(dataptr));
+ std::vector<double> tmpdoubledata(ni*nj*num_lev);
+ if (num_lev > 1)
+ // Transpose (lat, lon, lev) back to (lev, lat, lon)
+ jik_to_kji(ni, nj, num_lev, &tmpdoubledata[0], (double*)(dataptr));
success = NCFUNCAP(_vara_double)(_fileId, variableData.varId,
&variableData.writeStarts[0], &variableData.writeCounts[0],
&tmpdoubledata[0]);
diff --git a/src/io/NCWriteMPAS.cpp b/src/io/NCWriteMPAS.cpp
index ac0f70a..6a40dad 100644
--- a/src/io/NCWriteMPAS.cpp
+++ b/src/io/NCWriteMPAS.cpp
@@ -157,13 +157,13 @@ ErrorCode NCWriteMPAS::collect_variable_data(std::vector<std::string>& var_names
continue;
// If nVertLevels dimension is not found, try other optional levels such as nVertLevelsP1
if (std::find(varDims.begin(), varDims.end(), levDim) == varDims.end()) {
for (unsigned int j = 0; j < opt_lev_dims.size(); j++) {
if (std::find(varDims.begin(), varDims.end(), opt_lev_dims[j]) != varDims.end()) {
@@ -173,60 +173,86 @@ ErrorCode NCWriteMPAS::collect_variable_data(std::vector<std::string>& var_names
+ continue;
+ // First: Time
- // Support non-set variables with 3 dimensions like (Time, nCells, nVertLevels), or
+ // 3 dimensions like (Time, nCells, nVertLevels)
// 2 dimensions like (Time, nCells)
- // First: Time
- // Next: nVertices / nCells / nEdges
- // Vertices
- break;
- // Faces
- break;
- // Edges
- break;
- default:
- ERRORR(MB_FAILURE, "Unexpected entity location type for MPAS non-set variable.");
+ dim_idx++;
+ else {
+ // 2 dimensions like (nCells, nVertLevels)
+ // 1 dimension like (nCells)
+ // Next: nVertices / nCells / nEdges
+ // Vertices
+ break;
+ // Faces
+ break;
+ // Edges
+ break;
+ default:
+ ERRORR(MB_FAILURE, "Unexpected entity location type for MPAS non-set variable.");
+ dim_idx++;
+ // Finally: nVertLevels or other optional levels, it is possible that there is no
+ // level dimension (numLev is 0) for this non-set variable, e.g. (Time, nCells)
- // Finally: nVertLevels or other optional levels, it is possible that there is no
- // level dimension (numLev is 0) for this non-set variable, e.g. (Time, nCells)
+ dim_idx++;
+ else {
+ // 2 dimensions like (Time, nCells)
@@ -238,8 +264,6 @@ ErrorCode NCWriteMPAS::write_nonset_variables(std::vector<WriteNC::VarData>& vda
int success;
// For each variable tag in the indexed lists, write a time step data
@@ -249,10 +273,9 @@ ErrorCode NCWriteMPAS::write_nonset_variables(std::vector<WriteNC::VarData>& vda
continue;
// Vertices
@@ -273,15 +296,45 @@ ErrorCode NCWriteMPAS::write_nonset_variables(std::vector<WriteNC::VarData>& vda
- // A typical MPAS non-set variable has 3 dimensions as (Time, nCells, nVertLevels)
+ ents_idx++;
+ else {
+ else {
+ num_lev = 1;
#ifdef PNETCDF_FILE
@@ -299,8 +352,8 @@ ErrorCode NCWriteMPAS::write_nonset_variables(std::vector<WriteNC::VarData>& vda
#ifdef PNETCDF_FILE
@@ -316,7 +369,7 @@ ErrorCode NCWriteMPAS::write_nonset_variables(std::vector<WriteNC::VarData>& vda
// next subrange
#ifdef PNETCDF_FILE
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
