[MOAB-dev] commit/MOAB: iulian07: enable the gcrm writer test
    commits-noreply at bitbucket.org
    Sun May 11 21:41:37 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/f64941b0c1b0/
Changeset:   f64941b0c1b0
Branch:      master
User:        iulian07
Date:        2014-05-12 03:06:13
Summary:     enable the gcrm writer test
still to do: check values written to the file
Affected #:  3 files
diff --git a/src/io/NCWriteGCRM.cpp b/src/io/NCWriteGCRM.cpp
index d1a7aaf..36160d2 100644
--- a/src/io/NCWriteGCRM.cpp
+++ b/src/io/NCWriteGCRM.cpp
@@ -42,10 +42,10 @@ ErrorCode NCWriteGCRM::collect_mesh_info()
   nTimeSteps = dimLens[tDim];
   // Get number of levels
-  if ((vecIt = std::find(dimNames.begin(), dimNames.end(), "nVertLevels")) != dimNames.end())
+  if ((vecIt = std::find(dimNames.begin(), dimNames.end(), "layers")) != dimNames.end())
     levDim = vecIt - dimNames.begin();
   else {
-    ERRORR(MB_FAILURE, "Couldn't find 'nVertLevels' dimension.");
+    ERRORR(MB_FAILURE, "Couldn't find 'layers' dimension.");
   nLevels = dimLens[levDim];
@@ -121,33 +121,6 @@ ErrorCode NCWriteGCRM::collect_variable_data(std::vector<std::string>& var_names
   NCWriteHelper::collect_variable_data(var_names, tstep_nums);
-  std::vector<std::string>& dimNames = _writeNC->dimNames;
-  std::vector<int>& dimLens = _writeNC->dimLens;
-  // Dimension numbers for other optional levels
-  std::vector<unsigned int> opt_lev_dims;
-  unsigned int lev_idx;
-  std::vector<std::string>::iterator vecIt;
-  // Get number of vertex levels P1
-  if ((vecIt = std::find(dimNames.begin(), dimNames.end(), "nVertLevelsP1")) != dimNames.end()) {
-    lev_idx = vecIt - dimNames.begin();
-    opt_lev_dims.push_back(lev_idx);
-  // Get number of vertex levels P2
-  if ((vecIt = std::find(dimNames.begin(), dimNames.end(), "nVertLevelsP2")) != dimNames.end()) {
-  // Get number of soil levels
-  if ((vecIt = std::find(dimNames.begin(), dimNames.end(), "nSoilLevels")) != dimNames.end()) {
   std::map<std::string, WriteNC::VarData>& varInfo = _writeNC->varInfo;
   for (size_t i = 0; i < var_names.size(); i++) {
@@ -162,20 +135,11 @@ ErrorCode NCWriteGCRM::collect_variable_data(std::vector<std::string>& var_names
     if (localEdgesOwned.empty() && currentVarData.entLoc == WriteNC::ENTLOCEDGE)
       continue;
-    // If nVertLevels dimension is not found, try other optional levels such as nVertLevelsP1
     std::vector<int>& varDims = currentVarData.varDims;
-    if (std::find(varDims.begin(), varDims.end(), levDim) == varDims.end()) {
-      for (unsigned int j = 0; j < opt_lev_dims.size(); j++) {
-        if (std::find(varDims.begin(), varDims.end(), opt_lev_dims[j]) != varDims.end()) {
-          currentVarData.numLev = dimLens[opt_lev_dims[j]];
-          break;
     if (currentVarData.has_tsteps) {
-      // Support non-set variables with 3 dimensions like (Time, nCells, nVertLevels), or
-      // 2 dimensions like (Time, nCells)
+      // Support non-set variables with 3 dimensions like (Time, cells, layers), or
+      // 2 dimensions like (Time, cells)
       assert(3 == varDims.size() || 2 == varDims.size());
       // Time should be the first dimension
@@ -189,7 +153,7 @@ ErrorCode NCWriteGCRM::collect_variable_data(std::vector<std::string>& var_names
       currentVarData.writeStarts[0] = 0; // This value is timestep dependent, will be set later
       currentVarData.writeCounts[0] = 1;
-      // Next: nVertices / nCells / nEdges
+      // Next: nVertices / cells / nEdges
       switch (currentVarData.entLoc) {
         case WriteNC::ENTLOCVERT:
           // Vertices
diff --git a/src/io/NCWriteHelper.cpp b/src/io/NCWriteHelper.cpp
index 1a8a7eb..b315637 100644
--- a/src/io/NCWriteHelper.cpp
+++ b/src/io/NCWriteHelper.cpp
@@ -10,6 +10,7 @@
 #include "NCWriteFV.hpp"
 #include "NCWriteHOMME.hpp"
 #include "NCWriteMPAS.hpp"
+#include "NCWriteGCRM.hpp"
 #include "moab/WriteUtilIface.hpp"
 #include "MBTagConventions.hpp"
@@ -36,6 +37,8 @@ NCWriteHelper* NCWriteHelper::get_nc_helper(WriteNC* writeNC, int fileId, const
     return new (std::nothrow) NCWriteHOMME(writeNC, fileId, opts, fileSet);
   else if (grid_type == "MPAS")
     return new (std::nothrow) NCWriteMPAS(writeNC, fileId, opts, fileSet);
+  else if (grid_type == "GCRM")
+    return new (std::nothrow) NCWriteGCRM(writeNC, fileId, opts, fileSet);
   // Unknown NetCDF grid
   return NULL;
diff --git a/test/io/write_nc.cpp b/test/io/write_nc.cpp
index c71b6c8..58e203e 100644
--- a/test/io/write_nc.cpp
+++ b/test/io/write_nc.cpp
@@ -8,11 +8,13 @@ static const char example_eul[] = STRINGIFY(MESHDIR) "/io/camEul26x48x96.t3.nc";
 static const char example_fv[] = STRINGIFY(MESHDIR) "/io/fv26x46x72.t.3.nc";
 static const char example_homme[] = STRINGIFY(MESHDIR) "/io/homme26x3458.t.3.nc";
 static const char example_mpas[] = STRINGIFY(MESHDIR) "/io/mpasx1.642.t.2.nc";
+static const char example_gcrm[] = STRINGIFY(MESHDIR) "/io/gcrm_r3.nc";
 #else
 static const char example_eul[] = "/io/camEul26x48x96.t3.nc";
 static const char example_fv[] = "/io/fv26x46x72.t.3.nc";
 static const char example_homme[] = "/io/homme26x3458.t.3.nc";
 static const char example_mpas[] = "/io/mpasx1.642.t.2.nc";
+static const char example_gcrm[] =  "/io/gcrm_r3.nc";
 #endif
 #ifdef USE_MPI
@@ -46,6 +48,11 @@ void test_homme_check_T();
 void test_mpas_read_write_vars();
 void test_mpas_check_vars();
+// GCRM
+void test_gcrm_read_write_vars();
+//void test_gcrm_check_vars();
 // Test timestep option
 void test_eul_read_write_timestep();
 void test_eul_check_timestep();
@@ -89,6 +96,9 @@ int main(int argc, char* argv[])
   result += RUN_TEST(test_mpas_read_write_vars);
   result += RUN_TEST(test_mpas_check_vars);
+  result += RUN_TEST(test_gcrm_read_write_vars);
+  //result += RUN_TEST(test_gcrm_check_vars);
   result += RUN_TEST(test_eul_read_write_timestep);
   result += RUN_TEST(test_eul_check_timestep);
@@ -715,6 +725,51 @@ void test_mpas_check_vars()
+// Write vertex variable vorticity, edge variable u and cell veriable ke
+  int procs = 1;
+#ifdef USE_MPI
+  MPI_Comm_size(MPI_COMM_WORLD, &procs);
+#endif
+// We will not test NC writer in parallel without pnetcdf support
+#ifndef PNETCDF_FILE
+  if (procs > 1)
+    return;
+#endif
+  Core moab;
+  Interface& mb = moab;
+  std::string read_opts;
+  // we can use the same base options as mpas, because the zoltan can apply too
+  get_mpas_read_options(read_opts);
+  EntityHandle set;
+  ErrorCode rval = mb.create_meshset(MESHSET_SET, set);
+  CHECK_ERR(rval);
+  // Read non-set variables vorticity (cells) and u (corners)
+  read_opts += ";VARIABLE=vorticity,u;DEBUG_IO=0";
+  if (procs > 1)
+    read_opts += ";PARALLEL_RESOLVE_SHARED_ENTS";
+  rval = mb.load_file(example_gcrm, &set, read_opts.c_str());
+  CHECK_ERR(rval);
+  // Write variables vorticity, u
+  std::string write_opts = ";;VARIABLE=vorticity,u;DEBUG_IO=0";
+#ifdef USE_MPI
+  // Use parallel options
+  write_opts += ";PARALLEL=WRITE_PART";
+#endif
+  if (procs > 1)
+    rval = mb.write_file("test_par_gcrm_vars.nc", 0, write_opts.c_str(), &set, 1);
+  else
+    rval = mb.write_file("test_gcrm_vars.nc", 0, write_opts.c_str(), &set, 1);
+  CHECK_ERR(rval);
 // Read non-set variable T on all 3 timesteps, and write only timestep 2
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
