[MOAB-dev] Build failed in Jenkins: moab32par #419
    jenkins-ci at mcs.anl.gov
    Mon May 12 00:11:54 CDT 2014
See <https://jenkins-ci.mcs.anl.gov/job/moab32par/419/changes>
Changes:
[iulian] enable the gcrm writer test
[...truncated 1107 lines...]
PASS: gmsh_test
PASS: nastran_test
FAIL: read_nc
FAIL: read_ucd_nc
FAIL: read_mpas_nc
FAIL: write_nc
FAIL: read_gcrm_nc
PASS: ideas_test
PASS: stl_test
PASS: smf_test
PASS: read_cgm_load_test
PASS: read_cgm_basic_test
PASS: read_cgm_senses_test
PASS: read_cgm_connectivity_test
PASS: read_cgm_group_test
6 of 20 tests failed
See test/io/test-suite.log
make[4]: *** [test-suite.log] Error 1
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/io'>
make[3]: *** [check-TESTS] Error 2
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/io'>
make[2]: *** [check-am] Error 2
make[2]: Target `check' not remade because of errors.
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/io'>
Making check in dual
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/dual'>
make  dual_test
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/dual'>
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o dual_test dual_test.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o dual_test dual_test.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/dual'>
make  check-TESTS
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/dual'>
PASS: dual_test
1 test passed
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/dual'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/dual'>
Making check in obb
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/obb'>
make  obb_test obb_time obb_tree_tool
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/obb'>
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o obb_test obb_test.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o obb_test obb_test.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o obb_time obb_time.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o obb_time obb_time.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o obb_tree_tool obb_tree_tool.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o obb_tree_tool obb_tree_tool.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/obb'>
make  check-TESTS
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/obb'>
PASS: obb_test
1 test passed
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/obb'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/obb'>
Making check in perf
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/perf'>
Making check in point_location
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/perf/point_location'>
make  point_location tree_searching_perf sploc_searching_perf
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/perf/point_location'>
/bin/sh ../../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o point_location point_location.o ../../../src/libMOAB.la  -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o point_location point_location.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o tree_searching_perf tree_searching_perf.o ../../../src/libMOAB.la  -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o tree_searching_perf tree_searching_perf.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o sploc_searching_perf sploc_searching_perf.o ../../../src/libMOAB.la  -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o sploc_searching_perf sploc_searching_perf.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/perf/point_location'>
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/perf/point_location'>
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/perf'>
make  perf seqperf adj_time perftool tstt_perf_binding
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/perf'>
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o perf perf.o ../../src/libMOAB.la ../../itaps/imesh/libiMesh.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o perf perf.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L./src/mpl -L./src/openpa/src ../../itaps/imesh/.libs/libiMesh.a <https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/src/.libs/libMOAB.a> /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o seqperf seqperf.o ../../src/libMOAB.la ../../itaps/imesh/libiMesh.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o seqperf seqperf.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L./src/mpl -L./src/openpa/src ../../itaps/imesh/.libs/libiMesh.a <https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/src/.libs/libMOAB.a> /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o adj_time adj_time.o ../../src/libMOAB.la ../../itaps/imesh/libiMesh.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o adj_time adj_time.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L./src/mpl -L./src/openpa/src ../../itaps/imesh/.libs/libiMesh.a <https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/src/.libs/libMOAB.a> /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o perftool perftool.o ../../src/libMOAB.la ../../itaps/imesh/libiMesh.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o perftool perftool.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L./src/mpl -L./src/openpa/src ../../itaps/imesh/.libs/libiMesh.a <https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/src/.libs/libMOAB.a> /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src  -I/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/include    -I/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include -isystem /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/include  -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64   -DUSE_MPI -DHDF5_FILE -DHDF5_PARALLEL -DNETCDF_FILE -DCGM -I../../src -I../../src/io/mhdf/include -I../../src -DIS_BUILDING_MB -I../../itaps/imesh -I../../itaps -I../../itaps -I../../itaps/imesh -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -MT tstt_perf_binding.o -MD -MP -MF .deps/tstt_perf_binding.Tpo -c -o tstt_perf_binding.o tstt_perf_binding.cpp
mv -f .deps/tstt_perf_binding.Tpo .deps/tstt_perf_binding.Po
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o tstt_perf_binding tstt_perf_binding.o ../../src/libMOAB.la ../../itaps/imesh/libiMesh.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o tstt_perf_binding tstt_perf_binding.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L./src/mpl -L./src/openpa/src ../../itaps/imesh/.libs/libiMesh.a <https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/src/.libs/libMOAB.a> /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/perf'>
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/perf'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/perf'>
Making check in dagmc
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/dagmc'>
make  dagmc_simple_test dagmc_rayfire_test dagmc_pointinvol_test
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/dagmc'>
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS  -I/homes/fathom/lib32/jenkins/cgm/include -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -lcgm  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -lcubiti19 -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o dagmc_simple_test dagmc_simple_test-dagmc_simple_test.o ../../src/libMOAB.la ../../tools/dagmc/DagMC.lo -lm
libtool: link: mpicxx -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -I/homes/fathom/lib32/jenkins/cgm/include -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o dagmc_simple_test dagmc_simple_test-dagmc_simple_test.o ../../tools/dagmc/DagMC.o  -L./src/mpl -L./src/openpa/src -lpthread -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS  -I/homes/fathom/lib32/jenkins/cgm/include -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -lcgm  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -lcubiti19 -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o dagmc_rayfire_test dagmc_rayfire_test-dagmc_rayfire_test.o ../../src/libMOAB.la ../../tools/dagmc/DagMC.lo -lm
libtool: link: mpicxx -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -I/homes/fathom/lib32/jenkins/cgm/include -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o dagmc_rayfire_test dagmc_rayfire_test-dagmc_rayfire_test.o ../../tools/dagmc/DagMC.o  -L./src/mpl -L./src/openpa/src -lpthread -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS  -I/homes/fathom/lib32/jenkins/cgm/include -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -lcgm  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -lcubiti19 -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o dagmc_pointinvol_test dagmc_pointinvol_test-dagmc_pointinvol_test.o ../../src/libMOAB.la ../../tools/dagmc/DagMC.lo -lm
libtool: link: mpicxx -DTEMPLATE_DEFS_INCLUDED -DHAVE_ACIS -I/homes/fathom/lib32/jenkins/cgm/include -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o dagmc_pointinvol_test dagmc_pointinvol_test-dagmc_pointinvol_test.o ../../tools/dagmc/DagMC.o  -L./src/mpl -L./src/openpa/src -lpthread -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/dagmc'>
make  check-TESTS
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/dagmc'>
PASS: dagmc_simple_test
PASS: dagmc_rayfire_test
PASS: dagmc_pointinvol_test
All 3 tests passed
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/dagmc'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/dagmc'>
Making check in h5file
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/h5file'>
make  h5test h5legacy h5varlen h5sets_test h5regression h5partial h5portable dump_sets
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/h5file'>
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o h5test h5file_test.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o h5test h5file_test.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o h5legacy h5legacy.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o h5legacy h5legacy.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o h5varlen h5varlen.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o h5varlen h5varlen.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o h5sets_test h5sets_test.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o h5sets_test h5sets_test.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o h5regression h5regression.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o h5regression h5regression.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o h5partial h5partial.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o h5partial h5partial.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o h5portable h5portable.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o h5portable h5portable.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
make[3]: `dump_sets' is up to date.
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/h5file'>
make  check-TESTS
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/h5file'>
FAIL: h5test
PASS: h5legacy
FAIL: h5varlen
FAIL: h5sets_test
FAIL: h5regression
FAIL: h5partial
FAIL: h5portable
6 of 7 tests failed
See test/h5file/test-suite.log
make[4]: *** [test-suite.log] Error 1
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/h5file'>
make[3]: *** [check-TESTS] Error 2
make[2]: *** [check-am] Error 2
make[2]: Target `check' not remade because of errors.
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/h5file'>
Making check in parallel
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/parallel'>
make  pcomm_unit parallel_unit_tests uber_parallel_test scdtest pcomm_serial par_spatial_locator_test scdpart read_nc_par ucdtrvpart mpastrvpart gcrm_par   parallel_hdf5_test mhdf_parallel parallel_write_test   mbparallelcomm_test partcheck structured3 parmerge
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/parallel'>
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o pcomm_unit pcomm_unit.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o pcomm_unit pcomm_unit.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o parallel_unit_tests parallel_unit_tests.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o parallel_unit_tests parallel_unit_tests.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o uber_parallel_test uber_parallel_test.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o uber_parallel_test uber_parallel_test.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o scdtest scdtest.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o scdtest scdtest.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o pcomm_serial pcomm_serial.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o pcomm_serial pcomm_serial.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o par_spatial_locator_test par_spatial_locator_test.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o par_spatial_locator_test par_spatial_locator_test.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o scdpart scdpart.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o scdpart scdpart.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o read_nc_par read_nc.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o read_nc_par read_nc.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o ucdtrvpart ucdtrvpart.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o ucdtrvpart ucdtrvpart.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o mpastrvpart mpastrvpart.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mpastrvpart mpastrvpart.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o gcrm_par gcrm_par.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o gcrm_par gcrm_par.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o parallel_hdf5_test parallel_hdf5_test.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o parallel_hdf5_test parallel_hdf5_test.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CC   --mode=link mpicc  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o mhdf_parallel mhdf_parallel.o ../../src/libMOAB.la -lhdf5   -lm
libtool: link: mpicc -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mhdf_parallel mhdf_parallel.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -lz -lm -pthread -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o parallel_write_test parallel_write_test.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o parallel_write_test parallel_write_test.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o mbparallelcomm_test mbparallelcomm_test.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o mbparallelcomm_test mbparallelcomm_test.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o partcheck partcheck.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o partcheck partcheck.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o structured3 structured3.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o structured3 structured3.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o parmerge parmerge.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o parmerge parmerge.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/parallel'>
make  check-TESTS
make[4]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/parallel'>
FAIL: pcomm_unit
FAIL: parallel_unit_tests
FAIL: uber_parallel_test
FAIL: scdtest
FAIL: pcomm_serial
FAIL: par_spatial_locator_test
FAIL: scdpart
FAIL: read_nc_par
FAIL: ucdtrvpart
FAIL: mpastrvpart
FAIL: gcrm_par
FAIL: parallel_hdf5_test
FAIL: mhdf_parallel
FAIL: parallel_write_test
14 of 14 tests failed
See test/parallel/test-suite.log
make[4]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/parallel'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/parallel'>
Making check in oldinc
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/oldinc'>
make  test_oldinc
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/oldinc'>
/bin/sh ../../libtool  --tag=CXX   --mode=link mpicxx  -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align  -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -R/homes/fathom/lib32/jenkins/cgm/lib  -R/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin    -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -lnetcdf     -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib  -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib  -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib  -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -o test_oldinc test_oldinc.o ../../src/libMOAB.la -lm
libtool: link: mpicxx -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -O2 -DNDEBUG -o test_oldinc test_oldinc.o  -L/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -L/homes/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib -L/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -L/homes/fathom/lib32/jenkins/cgm/lib -L/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin ../../src/.libs/libMOAB.a /home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib/libhdf5.so -L/home/fathom/3rdparty/lib32/zlib-1.2.4/gcc/lib /homes/fathom/lib32/jenkins/cgm/lib/libcgm.a -L./src/mpl -L./src/openpa/src /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpichcxx.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpich.so -lrt /homes/fathom/lib32/mpich2-1.5_gcc/lib/libopa.so /homes/fathom/lib32/mpich2-1.5_gcc/lib/libmpl.so -lcubiti19 /homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib/libnetcdf.so -lz /usr/lib/i386-linux-gnu/libcurl.so /usr/lib/openmpi/lib/libmpi_cxx.so /usr/lib/openmpi/lib/libmpi.so /usr/lib/openmpi/lib/libopen-rte.so /usr/lib/openmpi/lib/libopen-pal.so -lm -pthread -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/home/fathom/3rdparty/lib32/hdf5-1.8.8-par-gcc/lib -Wl,-rpath -Wl,/homes/fathom/lib32/mpich2-1.5_gcc/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/lib32/netcdf-4.1.3_gcc/lib -Wl,-rpath -Wl,/usr/lib/openmpi/lib -Wl,-rpath -Wl,/homes/fathom/lib32/jenkins/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/cubit/Cubit32/Cubit-12.2/bin
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/oldinc'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test/oldinc'>
make[1]: *** [check-recursive] Error 1
make[1]: Target `check' not remade because of errors.
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/test'>
Making check in doc
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/doc'>
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/doc'>
make[1]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/'>
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/moab32par/ws/'>
make: *** [check-recursive] Error 1
make: Target `check' not remade because of errors.
Build step 'Execute shell' marked build as failure
