[MOAB-dev] commit/MOAB: iulian07: first pass at append option
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Tue Apr 29 16:35:45 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/f48ec38dbf3e/
Changeset:   f48ec38dbf3e
Branch:      master
User:        iulian07
Date:        2014-04-29 23:32:58
Summary:     first pass at append option
small test now for euler only
maybe it should be tested for more formats
assumes that if a dimension is already defined, there should be
a variable with the same name (coordinate)
Affected #:  5 files
diff --git a/src/io/NCWriteHelper.cpp b/src/io/NCWriteHelper.cpp
index 4f95ef8..923fe02 100644
--- a/src/io/NCWriteHelper.cpp
+++ b/src/io/NCWriteHelper.cpp
@@ -209,7 +209,7 @@ ErrorCode NCWriteHelper::collect_variable_data(std::vector<std::string>& var_nam
   return MB_SUCCESS;
-ErrorCode NCWriteHelper::init_file(std::vector<std::string>& var_names)
+ErrorCode NCWriteHelper::init_file(std::vector<std::string>& var_names, bool append)
   std::vector<std::string>& dimNames = _writeNC->dimNames;
   std::set<std::string>& usedCoordinates = _writeNC->usedCoordinates;
@@ -221,6 +221,9 @@ ErrorCode NCWriteHelper::init_file(std::vector<std::string>& var_names)
   int tDim_in_dimNames = tDim;
   int levDim_in_dimNames = levDim;
+  // if append mode, make sure we are in define mode; a simple open will not allow creation of new variables
+  if (append)
+    NCFUNC(redef)(_fileId);
   // First initialize all coordinates, then fill VarData for actual variables (and dimensions)
   // Check that for used coordinates we have found the tags
   for (std::set<std::string>::iterator setIt = usedCoordinates.begin();
@@ -234,6 +237,40 @@ ErrorCode NCWriteHelper::init_file(std::vector<std::string>& var_names)
     WriteNC::VarData& varCoordData = vit->second;
     varCoordData.varDims.resize(1);
+    // if not append, create it for sure
+    // if append, we might already have it, including the tag / variable with the same name
+     * int ncmpi_inq_dimid(int ncid, const char *name, int *idp);
+    if (append)
+      int dimId;
+      if (NCFUNC(inq_dimid)(_fileId, coordName.c_str(), &dimId) == NC_NOERR)
+        // if not found, create it later
+        varCoordData.varDims[0] = dimId;
+        // check that the coordinate is a variable too
+        // Skip dummy coordinate variables (e.g. ncol)
+        dbgOut.tprintf(2, "    file already has coordName %s dim id is %d \n", coordName.c_str(), (int)varCoordData.varDims[0]);
+        if (dummyVarNames.find(coordName) != dummyVarNames.end())
+          continue;
+        // inquire for a variable with the same name
+        int varId;
+        if (NCFUNC(inq_varid)(_fileId, coordName.c_str(), &varId) != NC_NOERR)
+          ERRORR(MB_FAILURE, "we do not have a variable with the same name.");
+        // we should also check that this variable has one dimension, and it is dimId
+        varCoordData.varId = varId;
+        dbgOut.tprintf(2, "    file already has coordinate %s and varId is %d \n", coordName.c_str(), varId);
+        // Update tDim and levDim to actual dimension id
+        if (coordName == dimNames[tDim_in_dimNames])
+          tDim = varCoordData.varDims[0];
+        else if (coordName == dimNames[levDim_in_dimNames])
+          levDim = varCoordData.varDims[0];
+        continue; // maybe more checks are needed here
     /* int nc_def_dim (int ncid, const char *name, size_t len, int *dimidp);
        * example:  status = nc_def_dim(fileId, "lat", 18L, &latid);
@@ -297,9 +334,10 @@ ErrorCode NCWriteHelper::init_file(std::vector<std::string>& var_names)
     // Define the variable now:
-    if (NCFUNC(def_var)(_fileId, var_names[i].c_str(), variableData.varDataType,
+    int errCode = NCFUNC(def_var)(_fileId, var_names[i].c_str(), variableData.varDataType,
         (int)variableData.varDims.size(), &(variableData.varDims[0]),
-        &variableData.varId) != NC_NOERR)
+        &variableData.varId);
+    if ( errCode != NC_NOERR)
       ERRORR(MB_FAILURE, "Failed to create coordinate variable.");
     dbgOut.tprintf(2, "    for variable %s variable id is %d \n", var_names[i].c_str(), variableData.varId);
diff --git a/src/io/NCWriteHelper.hpp b/src/io/NCWriteHelper.hpp
index b05fe12..ed2443a 100644
--- a/src/io/NCWriteHelper.hpp
+++ b/src/io/NCWriteHelper.hpp
@@ -34,7 +34,7 @@ public:
   //! Initialize file: this is where all defines are done
   //! The VarData dimension ids are filled up after define
-  ErrorCode init_file(std::vector<std::string>& var_names);
+  ErrorCode init_file(std::vector<std::string>& var_names, bool _append);
 protected:
   template <typename T> void jik_to_kji(size_t ni, size_t nj, size_t nk, T* dest, T* source)
@@ -50,7 +50,7 @@ protected:
   //! Allow NCWriteHelper to directly access members of WriteNC
   WriteNC* _writeNC;
-  //! Cache some information from ReadNC
+  //! Cache some information from WriteNC
   int _fileId;
   const FileOptions& _opts;
   EntityHandle _fileSet;
diff --git a/src/io/WriteNC.cpp b/src/io/WriteNC.cpp
index e665e26..98f4e3b 100644
--- a/src/io/WriteNC.cpp
+++ b/src/io/WriteNC.cpp
@@ -33,7 +33,7 @@ WriteNC::WriteNC(Interface* impl) :
 #ifdef USE_MPI
   myPcomm(NULL),
 #endif
-  noMesh(false), noVars(false),
+  noMesh(false), noVars(false), append(false),
   mGlobalIdTag(0), isParallel(false),
   myHelper(NULL)
@@ -84,23 +84,42 @@ ErrorCode WriteNC::write_file(const char* file_name,
   rval = process_conventional_tags(*file_set);
   ERRORR(rval, "Trouble processing conventional tags.");
-  // Create the file ; assume we will overwrite always, for the time being
-  dbgOut.tprintf(1, "creating file %s\n", file_name);
+  // Create or append the file
+  if (append)
+    dbgOut.tprintf(1, "opening file %s for appending \n", file_name);
+  else
+    dbgOut.tprintf(1, "creating file %s\n", file_name);
   fileName = file_name;
   int success;
+  if (append)
 #ifdef PNETCDF_FILE
-  int cmode = overwrite ? NC_CLOBBER : NC_NOCLOBBER;
-  if (isParallel)
-    success = NCFUNC(create)(myPcomm->proc_config().proc_comm(), file_name, cmode, MPI_INFO_NULL, &fileId);
-  else
-    success = NCFUNC(create)(MPI_COMM_SELF, file_name, cmode, MPI_INFO_NULL, &fileId);
+    int omode = NC_WRITE;
+    if (isParallel)
+      success = NCFUNC(open)(myPcomm->proc_config().proc_comm(), file_name, omode, MPI_INFO_NULL, &fileId);
+    else
+      success = NCFUNC(open)(MPI_COMM_SELF, file_name, omode, MPI_INFO_NULL, &fileId);
 #else
-  // This is a regular netcdf file
-  success = NCFUNC(create)(file_name, overwrite ? NC_CLOBBER : NC_NOCLOBBER, &fileId);
+    // This is a regular netcdf file
+    success = NCFUNC(open)(file_name, overwrite ? NC_CLOBBER : NC_NOCLOBBER, &fileId);
 #endif
-  ERRORS(success, "Failed to create file.");
+    ERRORS(success, "Failed to open file for appending.");
+  else // case when the file is new, will be overwritten, most likely
+#ifdef PNETCDF_FILE
+    int cmode = overwrite ? NC_CLOBBER : NC_NOCLOBBER;
+    if (isParallel)
+      success = NCFUNC(create)(myPcomm->proc_config().proc_comm(), file_name, cmode, MPI_INFO_NULL, &fileId);
+    else
+      success = NCFUNC(create)(MPI_COMM_SELF, file_name, cmode, MPI_INFO_NULL, &fileId);
+#else
+    success = NCFUNC(create)(file_name, overwrite ? NC_CLOBBER : NC_NOCLOBBER, &fileId);
+#endif
+    ERRORS(success, "Failed to create file.");
   if (NULL != myHelper)
     delete myHelper;
@@ -116,7 +135,7 @@ ErrorCode WriteNC::write_file(const char* file_name,
   rval = myHelper->collect_variable_data(var_names);
   ERRORR(rval, "Trouble collecting variable data.");
-  rval = myHelper->init_file(var_names);
+  rval = myHelper->init_file(var_names, append);
   ERRORR(rval, "Failed to initialize file.");
   rval = myHelper->write_values(var_names);
@@ -148,6 +167,10 @@ ErrorCode WriteNC::parse_options(const FileOptions& opts, std::vector<std::strin
   if (MB_SUCCESS == rval)
     noMesh = true;
+  rval = opts.get_null_option("APPEND");
+  if (MB_SUCCESS == rval)
+    append = true;
   if (2 <= dbgOut.get_verbosity()) {
     if (!var_names.empty()) {
       std::cerr << "Variables requested: ";
diff --git a/src/io/WriteNC.hpp b/src/io/WriteNC.hpp
index 1c5d78e..5827680 100644
--- a/src/io/WriteNC.hpp
+++ b/src/io/WriteNC.hpp
@@ -185,6 +185,7 @@ private:
   //! Write options
   bool noMesh;
   bool noVars;
+  bool append;
   //! Cached tags for writing. This will be important for ordering the data, in parallel
   Tag mGlobalIdTag;
diff --git a/test/io/write_nc.cpp b/test/io/write_nc.cpp
index 2d9bdae..f48e4c6 100644
--- a/test/io/write_nc.cpp
+++ b/test/io/write_nc.cpp
@@ -36,6 +36,7 @@ static const char example_mpas[] = "/io/mpasx1.642.t.2.nc";
 // CAM-EUL
 void test_eul_read_write_T();
 void test_eul_check_T();
+void test_eul_read_write_append();
 // CAM-FV
 void test_fv_read_write_T();
@@ -68,12 +69,12 @@ int main(int argc, char* argv[])
   result += RUN_TEST(test_eul_read_write_T);
   result += RUN_TEST(test_eul_check_T);
+  result += RUN_TEST(test_eul_read_write_append);
   result += RUN_TEST(test_fv_read_write_T);
-  result += RUN_TEST(test_fv_check_T);
   result += RUN_TEST(test_homme_read_write_T);
   result += RUN_TEST(test_homme_check_T);
-  //result += RUN_TEST(test_mpas_read_write_vars);
-  //result += RUN_TEST(test_mpas_check_vars);
+ // result += RUN_TEST(test_mpas_read_write_vars);
+ // result += RUN_TEST(test_mpas_check_vars);
 #ifdef USE_MPI
   fail = MPI_Finalize();
@@ -234,6 +235,61 @@ void test_eul_check_T()
+// We read and write variables T and U; U after we write T, so we append
+// we will also write gw, just to test the file after writing
+  int procs = 1;
+#ifdef USE_MPI
+  MPI_Comm_size(MPI_COMM_WORLD, &procs);
+#endif
+// We will not test NC writer in parallel without pnetcdf support
+#ifndef PNETCDF_FILE
+  if (procs > 1)
+    return;
+#endif
+  Core moab;
+  Interface& mb = moab;
+  std::string read_opts;
+  get_eul_read_options(read_opts);
+  EntityHandle set;
+  ErrorCode rval = mb.create_meshset(MESHSET_SET, set);
+  CHECK_ERR(rval);
+  // Load non-set variable T, set variable gw, and the mesh
+  read_opts += ";DEBUG_IO=0;VARIABLE=T,U,gw";
+  rval = mb.load_file(example_eul, &set, read_opts.c_str());
+  CHECK_ERR(rval);
+  // Write variables T and gw
+  std::string write_opts;
+  write_opts = std::string(";;VARIABLE=T,gw;DEBUG_IO=0");
+#ifdef USE_MPI
+  // Use parallel options
+  write_opts += std::string(";PARALLEL=WRITE_PART");
+#endif
+  if (procs > 1)
+    rval = mb.write_file("test_par_eul_TU.nc", 0, write_opts.c_str(), &set, 1);
+  else
+    rval = mb.write_file("test_eul_TU.nc", 0, write_opts.c_str(), &set, 1);
+  CHECK_ERR(rval);
+  // append to the file variable U
+  std::string write_opts2;
+  write_opts2 = std::string(";;VARIABLE=U;DEBUG_IO=0;APPEND");
+#ifdef USE_MPI
+  write_opts2 += std::string(";PARALLEL=WRITE_PART");
+#endif
+  if (procs > 1)
+    rval = mb.write_file("test_par_eul_TU.nc", 0, write_opts2.c_str(), &set, 1);
+  else
+    rval = mb.write_file("test_eul_TU.nc", 0, write_opts2.c_str(), &set, 1);
+  CHECK_ERR(rval);
 // We also write coordinate variables slat and slon to the output file, so that
 // it can be recognized by NC reader later in test_fv_check_T()
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
