[MOAB-dev] commit/MOAB: danwu: Merged ncwriter into master
commits-noreply at bitbucket.org commits-noreply at bitbucket.org
Mon Apr 28 17:02:18 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/7e36def04100/
Changeset:   7e36def04100
Branch:      master
User:        danwu
Date:        2014-04-29 00:02:09
Summary:     Merged ncwriter into master
Affected #:  20 files
diff --git a/.gitignore b/.gitignore
index ba9fe1e..d686ffa 100644
--- a/.gitignore
+++ b/.gitignore
@@ -155,6 +155,7 @@ test/io/*.g
 test/io/gmsh_test
 test/io/ideas_test
 test/io/nastran_test
+test/io/*.nc
 test/io/read_cgm_basic_test
 test/io/read_cgm_connectivity_test
 test/io/read_cgm_group_test
@@ -168,6 +169,7 @@ test/io/smf_test
 test/io/stl_test
 test/io/tqdcfr
 test/io/vtk_test
+test/io/write_nc
 test/kd_tree_test
 test/kd_tree_time
 test/kd_tree_tool
@@ -187,6 +189,7 @@ test/parallel/*.h5m
 test/parallel/mbparallelcomm_test
 test/parallel/mhdf_parallel
 test/parallel/mpastrvpart
+test/parallel/*.nc
 test/parallel/par_coupler_test
 test/parallel/par_intx_sph
 test/parallel/parallel_hdf5_test
@@ -206,6 +209,7 @@ test/parallel/structured3
 test/parallel/uber_parallel_test
 test/parallel/ucdtrvpart
 test/parallel/*.vtk
+test/parallel/write_nc_par
 test/perf/adj_time
 test/perf/perf
 test/perf/perftool
diff --git a/src/ReaderWriterSet.cpp b/src/ReaderWriterSet.cpp
index 5015a7f..1f254b0 100644
--- a/src/ReaderWriterSet.cpp
+++ b/src/ReaderWriterSet.cpp
@@ -48,6 +48,7 @@
 #ifdef NETCDF_FILE
 #  include "ReadNCDF.hpp"
 #  include "WriteNCDF.hpp"
+#  include "WriteNC.hpp"
 #  include "WriteSLAC.hpp"
 #  include "ReadNC.hpp"
 #  include "ReadGCRM.hpp"
@@ -105,7 +106,7 @@ ReaderWriterSet::ReaderWriterSet( Core* mdb, Error* handler )
   const char* exo_sufxs[] = { "exo", "exoII", "exo2", "g", "gen", NULL };
   register_factory( ReadNCDF::factory, WriteNCDF::factory, "Exodus II", exo_sufxs, "EXODUS" );
   register_factory( ReadGCRM::factory, NULL, "GCRM NC", "nc", "GCRM" );
-  register_factory( ReadNC::factory, NULL, "Climate NC", "nc", "NC" );
+  register_factory( ReadNC::factory, WriteNC::factory, "Climate NC", "nc", "NC" );
 #endif
 #ifdef CGNS_FILE
diff --git a/src/io/Makefile.am b/src/io/Makefile.am
index 09fe3d3..1269523 100644
--- a/src/io/Makefile.am
+++ b/src/io/Makefile.am
@@ -17,11 +17,17 @@ if NETCDF_FILE
                      WriteNCDF.cpp WriteNCDF.hpp \
                      WriteSLAC.cpp WriteSLAC.hpp \
                      ReadNC.cpp ReadNC.hpp \
+                     WriteNC.cpp WriteNC.hpp \
                      NCHelper.cpp NCHelper.hpp \
                      NCHelperEuler.cpp NCHelperEuler.hpp \
                      NCHelperFV.cpp NCHelperFV.hpp \
                      NCHelperHOMME.cpp NCHelperHOMME.hpp \
                      NCHelperMPAS.cpp NCHelperMPAS.hpp \
+                     NCWriteHelper.cpp NCWriteHelper.hpp \
+                     NCWriteEuler.cpp NCWriteEuler.hpp \
+                     NCWriteFV.cpp NCWriteFV.hpp \
+                     NCWriteHOMME.cpp NCWriteHOMME.hpp \
+                     NCWriteMPAS.cpp NCWriteMPAS.hpp \
                      ReadGCRM.cpp ReadGCRM.hpp
 else
   MOAB_NETCDF_SRCS =
@@ -30,11 +36,17 @@ endif
 if PNETCDF_FILE
 if !NETCDF_FILE
      MOAB_NETCDF_SRCS += ReadNC.cpp ReadNC.hpp \
 endif
 endif
diff --git a/src/io/NCHelper.cpp b/src/io/NCHelper.cpp
index 9ef1332..0e970d9 100644
--- a/src/io/NCHelper.cpp
+++ b/src/io/NCHelper.cpp
@@ -192,16 +192,16 @@ ErrorCode NCHelper::create_conventional_tags(const std::vector<int>& tstep_nums)
     unsigned int varDimSz = varInfo[mapIter->first].varDims.size();
     if (varDimSz == 0)
       continue;
-    varInfo[mapIter->first].varTags.resize(varDimSz, 0);
+    std::vector<Tag> varDimTags(varDimSz);
     for (unsigned int i = 0; i != varDimSz; i++) {
       Tag tmptag = 0;
       std::string tmptagname = dimNames[varInfo[mapIter->first].varDims[i]];
       mbImpl->tag_get_handle(tmptagname.c_str(), 0, MB_TYPE_OPAQUE, tmptag, MB_TAG_ANY);
-      varInfo[mapIter->first].varTags[i] = tmptag;
+      varDimTags[i] = tmptag;
     rval = mbImpl->tag_get_handle(tag_name.c_str(), varDimSz, MB_TYPE_HANDLE, varNamesDimsTag, MB_TAG_SPARSE | MB_TAG_CREAT);
     ERRORR(rval, "Trouble creating __<var_name>_DIMS tag.");
-    rval = mbImpl->tag_set_data(varNamesDimsTag, &_fileSet, 1, &(varInfo[mapIter->first].varTags[0]));
+    rval = mbImpl->tag_set_data(varNamesDimsTag, &_fileSet, 1, &(varDimTags[0]));
     ERRORR(rval, "Trouble setting data for __<var_name>_DIMS tag.");
     if (MB_SUCCESS == rval)
       dbgOut.tprintf(2, "Tag created for variable %s\n", tag_name.c_str());
@@ -252,21 +252,37 @@ ErrorCode NCHelper::create_conventional_tags(const std::vector<int>& tstep_nums)
     Tag varAttTag = 0;
     rval = mbImpl->tag_get_handle(tag_name.c_str(), 0, MB_TYPE_OPAQUE, varAttTag, MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN);
     ERRORR(rval, "Trouble creating __<var_name>_ATTRIBS tag.");
     std::string varAttVal;
     std::vector<int> varAttLen;
-    rval = create_attrib_string(mapIter->second.varAtts, varAttVal, varAttLen);
-    ERRORR(rval, "Trouble creating attribute strings.");
+    if (mapIter->second.numAtts < 1) {
+      if (dummyVarNames.find(mapIter->first) != dummyVarNames.end()) {
+        // This variable is a dummy dimension variable
+        varAttVal = "DUMMY_VAR";
+      else {
+        // This variable has no attributes
+        varAttVal = "NO_ATTRIBS";
+    else {
+      rval = create_attrib_string(mapIter->second.varAtts, varAttVal, varAttLen);
+      ERRORR(rval, "Trouble creating attribute string.");
     const void* varAttPtr = varAttVal.c_str();
     int varAttSz = varAttVal.size();
+    if (0 == varAttSz)
+      varAttSz = 1;
     rval = mbImpl->tag_set_by_ptr(varAttTag, &_fileSet, 1, &varAttPtr, &varAttSz);
     ERRORR(rval, "Trouble setting data for __<var_name>_ATTRIBS tag.");
-    if (varAttLen.size() == 0)
-      varAttLen.push_back(0);
     ssTagName << "_LEN";
     tag_name = ssTagName.str();
     Tag varAttLenTag = 0;
+    if (0 == varAttLen.size())
+      varAttLen.push_back(0);
     rval = mbImpl->tag_get_handle(tag_name.c_str(), varAttLen.size(), MB_TYPE_INTEGER, varAttLenTag, MB_TAG_SPARSE | MB_TAG_CREAT);
     ERRORR(rval, "Trouble creating __<var_name>_ATTRIBS_LEN tag.");
     rval = mbImpl->tag_set_data(varAttLenTag, &_fileSet, 1, &varAttLen[0]);
@@ -324,6 +340,11 @@ ErrorCode NCHelper::read_variable_setup(std::vector<std::string>& var_names, std
           dummyVarNames.find(vd.varName) != dummyVarNames.end())
          continue;
+      // Dimension variables were read before creating conventional tags
+      std::vector<std::string>& dimNames = _readNC->dimNames;
+      if (std::find(dimNames.begin(), dimNames.end(), vd.varName) != dimNames.end())
+        continue;
       if (vd.entLoc == ReadNC::ENTLOCSET)
         vsetdatas.push_back(vd);
       else
diff --git a/src/io/NCWriteEuler.cpp b/src/io/NCWriteEuler.cpp
new file mode 100644
index 0000000..4b3f1ff
--- /dev/null
+++ b/src/io/NCWriteEuler.cpp
@@ -0,0 +1,23 @@
+ * NCWriteEuler.cpp
+ *  Created on: Mar 28, 2014
+#include "NCWriteEuler.hpp"
+#include "moab/WriteUtilIface.hpp"
+#define ERRORR(rval, str) \
+  if (MB_SUCCESS != rval) { _writeNC->mWriteIface->report_error("%s", str); return rval; }
+#define ERRORS(err, str) \
+  if (err) { _writeNC->mWriteIface->report_error("%s", str); return MB_FAILURE; }
+namespace moab {
+NCWriteEuler::~NCWriteEuler()
+  // TODO Auto-generated destructor stub
+} /* namespace moab */
diff --git a/src/io/NCWriteEuler.hpp b/src/io/NCWriteEuler.hpp
index 0000000..2cb6486
--- /dev/null
+++ b/src/io/NCWriteEuler.hpp
@@ -0,0 +1,27 @@
+ * NCWriteEuler.hpp
+ *  nc write helper for euler type data (CAM)
+#ifndef NCWRITEEULER_HPP_
+#define NCWRITEEULER_HPP_
+#include "NCWriteHelper.hpp"
+namespace moab {
+class NCWriteEuler: public ScdNCWriteHelper
+public:
+  NCWriteEuler(WriteNC* writeNC, int fileId, const FileOptions& opts, EntityHandle fileSet)
+: ScdNCWriteHelper(writeNC, fileId, opts, fileSet) {}
+  virtual ~NCWriteEuler();
+} // namespace moab
+#endif
diff --git a/src/io/NCWriteFV.cpp b/src/io/NCWriteFV.cpp
index 0000000..8de489f
--- /dev/null
+++ b/src/io/NCWriteFV.cpp
@@ -0,0 +1,23 @@
+ * NCWriteFV.cpp
+ *  Created on: April 9, 2014
+#include "NCWriteFV.hpp"
+namespace moab {
+NCWriteFV::~NCWriteFV()
diff --git a/src/io/NCWriteFV.hpp b/src/io/NCWriteFV.hpp
index 0000000..d3286fc
--- /dev/null
+++ b/src/io/NCWriteFV.hpp
@@ -0,0 +1,27 @@
+ * NCWriteFV.hpp
+ *  nc write helper for FV type data (CAM)
+#ifndef NCWRITEFV_HPP_
+#define NCWRITEFV_HPP_
+namespace moab {
+class NCWriteFV: public ScdNCWriteHelper
+public:
+  NCWriteFV(WriteNC* writeNC, int fileId, const FileOptions& opts, EntityHandle fileSet)
+  virtual ~NCWriteFV();
+#endif // NCWRITEFV_HPP_
diff --git a/src/io/NCWriteHOMME.cpp b/src/io/NCWriteHOMME.cpp
index 0000000..9320f62
--- /dev/null
+++ b/src/io/NCWriteHOMME.cpp
@@ -0,0 +1,316 @@
+ * NCWriteHOMME.cpp
+#include "NCWriteHOMME.hpp"
+#include "MBTagConventions.hpp"
+namespace moab {
+NCWriteHOMME::~NCWriteHOMME()
+ErrorCode NCWriteHOMME::collect_mesh_info()
+  Interface*& mbImpl = _writeNC->mbImpl;
+  std::vector<std::string>& dimNames = _writeNC->dimNames;
+  std::vector<int>& dimLens = _writeNC->dimLens;
+  Tag& mGlobalIdTag = _writeNC->mGlobalIdTag;
+  ErrorCode rval;
+  // Look for time dimension
+  std::vector<std::string>::iterator vecIt;
+  if ((vecIt = std::find(dimNames.begin(), dimNames.end(), "time")) != dimNames.end())
+    tDim = vecIt - dimNames.begin();
+  else {
+    ERRORR(MB_FAILURE, "Couldn't find 'time' dimension.");
+  nTimeSteps = dimLens[tDim];
+  // Get number of levels
+  if ((vecIt = std::find(dimNames.begin(), dimNames.end(), "lev")) != dimNames.end())
+    levDim = vecIt - dimNames.begin();
+  else {
+    ERRORR(MB_FAILURE, "Couldn't find 'lev' dimension.");
+  nLevels = dimLens[levDim];
+  Range local_verts;
+  rval = mbImpl->get_entities_by_dimension(_fileSet, 0, local_verts);
+  ERRORR(rval, "Trouble getting local vertices in current file set.");
+  assert(!local_verts.empty());
+#ifdef USE_MPI
+  bool& isParallel = _writeNC->isParallel;
+  if (isParallel) {
+    ParallelComm*& myPcomm = _writeNC->myPcomm;
+    int rank = myPcomm->proc_config().proc_rank();
+    int procs = myPcomm->proc_config().proc_size();
+    if (procs > 1) {
+      rval = myPcomm->filter_pstatus(local_verts, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &localVertsOwned);
+      ERRORR(rval, "Trouble getting owned vertices in set.");
+      // Assume that PARALLEL_RESOLVE_SHARED_ENTS option is set
+      // We should avoid writing in parallel with overlapped data
+      if (rank > 0)
+        assert("PARALLEL_RESOLVE_SHARED_ENTS option is set" && localVertsOwned.size() < local_verts.size());
+    else
+      localVertsOwned = local_verts;
+  else
+    localVertsOwned = local_verts; // Not running in parallel, but still with MPI
+#else
+#endif
+  std::vector<int> gids(localVertsOwned.size());
+  rval = mbImpl->tag_get_data(mGlobalIdTag, localVertsOwned, &gids[0]);
+  ERRORR(rval, "Trouble getting global IDs on local vertices.");
+  // Restore localGidVerts
+  std::copy(gids.rbegin(), gids.rend(), range_inserter(localGidVertsOwned));
+  nLocalVerticesOwned = localGidVertsOwned.size();
+  return MB_SUCCESS;
+ErrorCode NCWriteHOMME::collect_variable_data(std::vector<std::string>& var_names)
+  NCWriteHelper::collect_variable_data(var_names);
+  std::map<std::string, WriteNC::VarData>& varInfo = _writeNC->varInfo;
+  for (size_t i = 0; i < var_names.size(); i++) {
+    std::string varname = var_names[i];
+    std::map<std::string, WriteNC::VarData>::iterator vit = varInfo.find(varname);
+    if (vit == varInfo.end())
+      ERRORR(MB_FAILURE, "Can't find one variable.");
+    WriteNC::VarData& currentVarData = vit->second;
+    if (currentVarData.has_tsteps) {
+      // Support non-set variables with 3 dimensions like (time, lev, ncol)
+      assert(3 == currentVarData.varDims.size());
+      // Time should be the first dimension
+      assert(tDim == currentVarData.varDims[0]);
+      // Set up writeStarts and writeCounts
+      currentVarData.writeStarts.resize(3);
+      currentVarData.writeCounts.resize(3);
+      // First: time
+      currentVarData.writeStarts[0] = 0; // This value is timestep dependent, will be set later
+      currentVarData.writeCounts[0] = 1;
+      // Next: lev
+      currentVarData.writeStarts[1] = 0;
+      currentVarData.writeCounts[1] = currentVarData.numLev;
+      // Finally: ncol
+      switch (currentVarData.entLoc) {
+        case WriteNC::ENTLOCVERT:
+          // Vertices
+          // Start from the first localGidVerts
+          // Actually, this will be reset later for writing
+          currentVarData.writeStarts[2] = localGidVertsOwned[0] - 1;
+          currentVarData.writeCounts[2] = nLocalVerticesOwned;
+          break;
+        default:
+          ERRORR(MB_FAILURE, "Unexpected entity location type for HOMME non-set variable.");
+    // Get variable size
+    currentVarData.sz = 1;
+    for (std::size_t idx = 0; idx != currentVarData.writeCounts.size(); idx++)
+      currentVarData.sz *= currentVarData.writeCounts[idx];
+ErrorCode NCWriteHOMME::write_values(std::vector<std::string>& var_names)
+  std::set<std::string>& usedCoordinates = _writeNC->usedCoordinates;
+  std::set<std::string>& dummyVarNames = _writeNC->dummyVarNames;
+  int success;
+  // Now look at requested var_names; if they have time, we will have a list, and write one at a time
+  // Need to transpose from lev dimension
+  // For each variable tag in the indexed lists, write a time step data
+  // Assume the first dimension is time (need to check); if not, just write regularly
+    std::map<std::string, WriteNC::VarData>::iterator vit = varInfo.find(var_names[i]);
+      ERRORR(MB_FAILURE, "Can't find variable requested.");
+    WriteNC::VarData& variableData = vit->second;
+    int numTimeSteps = (int)variableData.varTags.size();
+    if (variableData.has_tsteps) {
+      assert(tDim == variableData.varDims[0]);
+      // Assume this variable is on vertices for the time being
+      switch (variableData.entLoc) {
+          // Vertices
+          break;
+        default:
+      // A typical variable has 3 dimensions as (time, lev, ncol)
+      // At each timestep, we need to transpose tag format (ncol, lev) back
+      // to NC format (lev, ncol) for writing
+      // FIXME: Should use tstep_nums (from writing options) later
+      for (int j = 0; j < numTimeSteps; j++) {
+        // We will write one time step, and count will be one; start will be different
+        // Use tag_get_data instead of tag_iterate to get values, as localVertsOwned
+        // might not be contiguous. We should also transpose for level so that means
+        // deep copy for transpose
+        variableData.writeStarts[0] = j; // This is time, again
+        std::vector<double> tag_data(nLocalVerticesOwned * variableData.numLev);
+        ErrorCode rval = mbImpl->tag_get_data(variableData.varTags[j], localVertsOwned, &tag_data[0]);
+        ERRORR(rval, "Trouble getting tag data on owned vertices.");
+#ifdef PNETCDF_FILE
+        size_t nb_writes = localGidVertsOwned.psize();
+        std::vector<int> requests(nb_writes), statuss(nb_writes);
+        size_t idxReq = 0;
+#endif
+        // Now write from memory directly
+        switch (variableData.varDataType) {
+          case NC_DOUBLE: {
+            std::vector<double> tmpdoubledata(nLocalVerticesOwned * variableData.numLev);
+            // Transpose (ncol, lev) back to (lev, ncol)
+            jik_to_kji(nLocalVerticesOwned, 1, variableData.numLev, &tmpdoubledata[0], &tag_data[0]);
+            size_t indexInDoubleArray = 0;
+            size_t ic = 0;
+            for (Range::pair_iterator pair_iter = localGidVertsOwned.pair_begin();
+                pair_iter != localGidVertsOwned.pair_end(); ++pair_iter, ic++) {
+              EntityHandle starth = pair_iter->first;
+              EntityHandle endh = pair_iter->second;
+              variableData.writeStarts[2] = (NCDF_SIZE)(starth - 1);
+              variableData.writeCounts[2] = (NCDF_SIZE)(endh - starth + 1);
+              // Do a partial write, in each subrange
+              // Wait outside this loop
+              success = NCFUNCREQP(_vara_double)(_fileId, variableData.varId,
+                  &(variableData.writeStarts[0]), &(variableData.writeCounts[0]),
+                             &(tmpdoubledata[indexInDoubleArray]), &requests[idxReq++]);
+#else
+              success = NCFUNCAP(_vara_double)(_fileId, variableData.varId,
+                             &(tmpdoubledata[indexInDoubleArray]));
+#endif
+              ERRORS(success, "Failed to read double data in loop");
+              // We need to increment the index in double array for the
+              // next subrange
+              indexInDoubleArray += (endh - starth + 1) * variableData.numLev;
+            assert(ic == localGidVertsOwned.psize());
+            success = ncmpi_wait_all(_fileId, requests.size(), &requests[0], &statuss[0]);
+            ERRORS(success, "Failed on wait_all.");
+#endif
+            break;
+          default:
+            ERRORR(MB_FAILURE, "Not implemented yet.");
+    } // if (variableData.has_tsteps)
+    else {
+        case NC_DOUBLE:
+          success = NCFUNCAP(_vara_double)(_fileId, variableData.varId, &variableData.writeStarts[0],
+                    &variableData.writeCounts[0], (double*)(variableData.memoryHogs[0]));
+          ERRORS(success, "Failed to write double data.");
+          break;
+        default:
+  // Write coordinates used by requested var_names
+  // Use independent I/O mode put, since this write is only for the root processor
+  // CAUTION: if the NetCDF ID is from a previous call to ncmpi_create rather than ncmpi_open,
+  // all processors need to call ncmpi_begin_indep_data(). If only the root processor does so,
+  // ncmpi_begin_indep_data() call will be blocked forever :(
+  // Enter independent I/O mode
+  success = NCFUNC(begin_indep_data)(_fileId);
+  ERRORS(success, "Failed to begin independent I/O mode.");
+#endif
+  int rank = 0;
+#ifdef USE_MPI
+  if (isParallel) {
+    rank = myPcomm->proc_config().proc_rank();
+#endif
+  if (0 == rank) {
+    for (std::set<std::string>::iterator setIt = usedCoordinates.begin();
+        setIt != usedCoordinates.end(); ++setIt) {
+      const std::string& coordName = *setIt;
+      // Skip dummy coordinate variables (e.g. ncol)
+      if (dummyVarNames.find(coordName) != dummyVarNames.end())
+        continue;
+      std::map<std::string, WriteNC::VarData>::iterator vit = varInfo.find(coordName);
+        ERRORR(MB_FAILURE, "Can't find one coordinate variable.");
+      WriteNC::VarData& varCoordData = vit->second;
+      switch (varCoordData.varDataType) {
+        case NC_DOUBLE:
+          // Independent I/O mode put
+          success = NCFUNCP(_vara_double)(_fileId, varCoordData.varId, &varCoordData.writeStarts[0],
+                    &varCoordData.writeCounts[0], (double*)(varCoordData.memoryHogs[0]));
+          break;
+        case NC_INT:
+          success = NCFUNCP(_vara_int)(_fileId, varCoordData.varId, &varCoordData.writeStarts[0],
+                    &varCoordData.writeCounts[0], (int*)(varCoordData.memoryHogs[0]));
+          ERRORS(success, "Failed to write int data.");
+          break;
+        default:
+  // End independent I/O mode
+  success = NCFUNC(end_indep_data)(_fileId);
+  ERRORS(success, "Failed to end independent I/O mode.");
+#endif
diff --git a/src/io/NCWriteHOMME.hpp b/src/io/NCWriteHOMME.hpp
index 0000000..7bb99d9
--- /dev/null
+++ b/src/io/NCWriteHOMME.hpp
@@ -0,0 +1,37 @@
+ * NCWriteHOMME.hpp
+ *  nc write helper for HOMME type data (CAM)
+#ifndef NCWRITEHOMME_HPP_
+#define NCWRITEHOMME_HPP_
+namespace moab {
+class NCWriteHOMME: public UcdNCWriteHelper
+public:
+  NCWriteHOMME(WriteNC* writeNC, int fileId, const FileOptions& opts, EntityHandle fileSet)
+: UcdNCWriteHelper(writeNC, fileId, opts, fileSet) {}
+  virtual ~NCWriteHOMME();
+private:
+  //! Implementation of NCWriteHelper::collect_mesh_info()
+  virtual ErrorCode collect_mesh_info();
+  //! Collect data for specified variables
+  virtual ErrorCode collect_variable_data(std::vector<std::string>& var_names);
+  //! Implementation of NCWriteHelper::write_values()
+  virtual ErrorCode write_values(std::vector<std::string>& var_names);
+#endif
diff --git a/src/io/NCWriteHelper.cpp b/src/io/NCWriteHelper.cpp
index 0000000..4f95ef8
--- /dev/null
+++ b/src/io/NCWriteHelper.cpp
@@ -0,0 +1,622 @@
+ * NCWriteHelper.cpp
+ *      Author: iulian
+#include "NCWriteMPAS.hpp"
+#include <sstream>
+namespace moab {
+//! Get appropriate helper instance for WriteNC class; based on some info in the file set
+NCWriteHelper* NCWriteHelper::get_nc_helper(WriteNC* writeNC, int fileId, const FileOptions& opts, EntityHandle fileSet)
+  std::string& grid_type = writeNC->grid_type;
+  if (grid_type == "CAM_EUL")
+    return new (std::nothrow) NCWriteEuler(writeNC, fileId, opts, fileSet);
+  else if (grid_type == "CAM_FV")
+    return new (std::nothrow) NCWriteFV(writeNC, fileId, opts, fileSet);
+  else if (grid_type == "CAM_SE")
+    return new (std::nothrow) NCWriteHOMME(writeNC, fileId, opts, fileSet);
+  else if (grid_type == "MPAS")
+    return new (std::nothrow) NCWriteMPAS(writeNC, fileId, opts, fileSet);
+  // Unknown NetCDF grid
+  return NULL;
+ErrorCode NCWriteHelper::collect_variable_data(std::vector<std::string>& var_names)
+  DebugOutput& dbgOut = _writeNC->dbgOut;
+  ErrorCode rval;
+  usedCoordinates.clear();
+    currentVarData.has_tsteps = false;
+    if ((std::find(currentVarData.varDims.begin(), currentVarData.varDims.end(), tDim) != currentVarData.varDims.end())
+        && (currentVarData.varDims.size() > 1)) // So it is not time itself
+      currentVarData.has_tsteps = true;
+    currentVarData.numLev = 1;
+    if ((std::find(currentVarData.varDims.begin(), currentVarData.varDims.end(), levDim) != currentVarData.varDims.end()))
+      currentVarData.numLev = nLevels;
+    dbgOut.tprintf(2, "    for variable %s varDims.size %d \n", varname.c_str(), (int)currentVarData.varDims.size());
+    for (size_t j = 0; j < currentVarData.varDims.size(); j++) {
+      std::string dimName = dimNames[currentVarData.varDims[j]];
+      vit = varInfo.find(dimName);
+      usedCoordinates.insert(dimName); // Collect those used, we will need to write them to the file
+      dbgOut.tprintf(2, "    for variable %s need dimension %s with length %d\n", varname.c_str(), dimName.c_str(), dimLens[currentVarData.varDims[j]]);
+    // Process coordinate variables later
+    if (usedCoordinates.find(varname) != usedCoordinates.end())
+      continue;
+    // Process non-set variables with time steps
+      int index = 0;
+      while (true) {
+        Tag indexedTag = 0;
+        std::stringstream ssTagNameWithIndex;
+        ssTagNameWithIndex << varname << index;
+        rval = mbImpl->tag_get_handle(ssTagNameWithIndex.str().c_str(), indexedTag);
+          break;
+        dbgOut.tprintf(2, "    found indexed tag %d with name %s\n", index, ssTagNameWithIndex.str().c_str());
+        currentVarData.varTags.push_back(indexedTag);
+        index++; // We should get out of the loop at some point
+        // The type of the tag is fixed though
+        DataType type;
+        rval = mbImpl->tag_get_data_type(indexedTag, type);
+        ERRORR(rval, "Can't get tag type.");
+        currentVarData.varDataType = NC_DOUBLE;
+        if (MB_TYPE_INTEGER == type)
+          currentVarData.varDataType = NC_INT;
+    // Process set variables that are not coordinate variables
+    else {
+      // Get the tag with varname
+      Tag tag = 0;
+      rval = mbImpl->tag_get_handle(varname.c_str(), tag);
+      ERRORR(rval, "Can't find one tag.");
+      currentVarData.varTags.push_back(tag); // Really, only one for these
+      const void* data;
+      int size;
+      rval = mbImpl->tag_get_by_ptr(tag, &_fileSet, 1, &data, &size);
+      ERRORR(rval, "Can't get tag values.");
+      // Find the type of tag, and use it
+      DataType type;
+      rval = mbImpl->tag_get_data_type(tag, type);
+      assert(0 == currentVarData.memoryHogs.size()); // Nothing so far
+      currentVarData.memoryHogs.push_back((void*)data);
+      if (currentVarData.varDims.empty()) {
+        // Scalar variable
+        currentVarData.writeStarts.push_back(0);
+        currentVarData.writeCounts.push_back(1);
+      else {
+        assert(1 == currentVarData.varDims.size());
+        currentVarData.writeCounts.push_back(dimLens[currentVarData.varDims[0]]);
+  // Check that for used coordinates we have found the tags
+    Tag coordTag = 0;
+    rval = mbImpl->tag_get_handle(coordName.c_str(), coordTag);
+    varCoordData.varTags.push_back(coordTag); // Really, only one for these
+    const void* data;
+    int sizeCoordinate;
+    rval = mbImpl->tag_get_by_ptr(coordTag, &_fileSet, 1, &data, &sizeCoordinate);
+    ERRORR(rval, "Can't get coordinate values.");
+    dbgOut.tprintf(2, "    found coordinate tag with name %s and length %d\n", coordName.c_str(),
+        sizeCoordinate);
+    // Get dimension length (the only dimension of this coordinate variable, with the same name)
+    assert(1 == varCoordData.varDims.size());
+    int coordDimLen = dimLens[varCoordData.varDims[0]];
+    if (dummyVarNames.find(coordName) != dummyVarNames.end()) {
+      // For a dummy coordinate variable, the tag size is always 1
+      // The number of coordinates should be set to dimension length, instead of 1
+      assert(1 == sizeCoordinate);
+      sizeCoordinate = coordDimLen;
+    else {
+      // The number of coordinates should be exactly the same as dimension length
+      assert(sizeCoordinate == coordDimLen);
+    // This is the length
+    varCoordData.sz = sizeCoordinate;
+    varCoordData.writeStarts.resize(1);
+    varCoordData.writeStarts[0] = 0;
+    varCoordData.writeCounts.resize(1);
+    varCoordData.writeCounts[0] = sizeCoordinate;
+    DataType type;
+    rval = mbImpl->tag_get_data_type(coordTag, type);
+    varCoordData.varDataType = NC_DOUBLE;
+      varCoordData.varDataType = NC_INT;
+    assert(0 == varCoordData.memoryHogs.size()); // Nothing so far
+    varCoordData.memoryHogs.push_back((void*)data);
+ErrorCode NCWriteHelper::init_file(std::vector<std::string>& var_names)
+  std::map<std::string, WriteNC::AttData>& globalAtts = _writeNC->globalAtts;
+  int tDim_in_dimNames = tDim;
+  int levDim_in_dimNames = levDim;
+  // First initialize all coordinates, then fill VarData for actual variables (and dimensions)
+    varCoordData.varDims.resize(1);
+    /* int nc_def_dim (int ncid, const char *name, size_t len, int *dimidp);
+       * example:  status = nc_def_dim(fileId, "lat", 18L, &latid);
+    // Actually define a dimension
+    if (NCFUNC(def_dim)(_fileId, coordName.c_str(), (size_t)varCoordData.sz,
+        &varCoordData.varDims[0]) != NC_NOERR)
+     ERRORR(MB_FAILURE, "Failed to generate dimension.");
+    dbgOut.tprintf(2, "    for coordName %s dim id is %d \n", coordName.c_str(), (int)varCoordData.varDims[0]);
+    // Update tDim and levDim to actual dimension id
+    if (coordName == dimNames[tDim_in_dimNames])
+      tDim = varCoordData.varDims[0];
+    else if (coordName == dimNames[levDim_in_dimNames])
+      levDim = varCoordData.varDims[0];
+    // Create a variable with the same name, and its only dimension the one we just defined
+     * int nc_def_var (int ncid, const char *name, nc_type xtype,
+                       int ndims, const int dimids[], int *varidp);
+       example: http://www.unidata.ucar.edu/software/netcdf/docs/netcdf-c/nc_005fdef_005fvar.html#nc_005fdef_005fvar
+      continue;
+    // Define a coordinate variable
+    if (NCFUNC(def_var)(_fileId, coordName.c_str(), varCoordData.varDataType,
+        1, &(varCoordData.varDims[0]), &varCoordData.varId) != NC_NOERR)
+      ERRORR(MB_FAILURE, "Failed to create coordinate variable.");
+    dbgOut.tprintf(2, "    for coordName %s variable id is %d \n", coordName.c_str(), varCoordData.varId);
+  // Now look at requested variables, and update from the index in dimNames to the actual dimension id
+    // Skip coordinate variables
+    if (usedCoordinates.find(var_names[i]) != usedCoordinates.end())
+      continue;
+    int numDims = (int)variableData.varDims.size();
+    // The index is for dimNames; we need to find out the actual dimension id (from above)
+    for (int j = 0; j < numDims; j++) {
+      std::string dimName = dimNames[variableData.varDims[j]];
+      std::map<std::string, WriteNC::VarData>::iterator vit2 = varInfo.find(dimName);
+      if (vit2 == varInfo.end())
+        ERRORR(MB_FAILURE, "Can't find coordinate variable requested.");
+      WriteNC::VarData& coordData = vit2->second;
+      // Index in dimNames to actual dimension id
+      variableData.varDims[j] = coordData.varDims[0]; // This one, being a coordinate, is the only one
+      dbgOut.tprintf(2, "          dimension with index %d name %s has ID %d \n",
+          j, dimName.c_str(), variableData.varDims[j]);
+    // Define the variable now:
+    if (NCFUNC(def_var)(_fileId, var_names[i].c_str(), variableData.varDataType,
+        (int)variableData.varDims.size(), &(variableData.varDims[0]),
+        &variableData.varId) != NC_NOERR)
+    dbgOut.tprintf(2, "    for variable %s variable id is %d \n", var_names[i].c_str(), variableData.varId);
+    // Now define the variable, with all dimensions
+  // Define global attributes (exactly copied from the original file for the time being)
+  // Should we modify some of them (e.g. revision_Id) later?
+  std::map<std::string, WriteNC::AttData>::iterator attIt;
+  for (attIt = globalAtts.begin(); attIt != globalAtts.end(); ++attIt) {
+    const std::string& attName = attIt->first;
+    WriteNC::AttData& attData = attIt->second;
+    NCDF_SIZE& attLen = attData.attLen;
+    nc_type& attDataType = attData.attDataType;
+    const std::string& attValue = attData.attValue;
+    switch (attDataType) {
+      case NC_BYTE:
+      case NC_CHAR:
+        if (NC_NOERR != NCFUNC(put_att_text)(_fileId, NC_GLOBAL, attName.c_str(), attLen, attValue.c_str()))
+          ERRORR(MB_FAILURE, "Failed to define text type attribute.");
+        break;
+      case NC_DOUBLE:
+        if (NC_NOERR != NCFUNC(put_att_double)(_fileId, NC_GLOBAL, attName.c_str(), NC_DOUBLE, 1, (double*)attValue.c_str()))
+          ERRORR(MB_FAILURE, "Failed to define double type attribute.");
+        break;
+      case NC_FLOAT:
+        if (NC_NOERR != NCFUNC(put_att_float)(_fileId, NC_GLOBAL, attName.c_str(), NC_FLOAT, 1, (float*)attValue.c_str()))
+          ERRORR(MB_FAILURE, "Failed to define float type attribute.");
+        break;
+      case NC_INT:
+        if (NC_NOERR != NCFUNC(put_att_int)(_fileId, NC_GLOBAL, attName.c_str(), NC_INT, 1, (int*)attValue.c_str()))
+          ERRORR(MB_FAILURE, "Failed to define int type attribute.");
+        break;
+      case NC_SHORT:
+        if (NC_NOERR != NCFUNC(put_att_short)(_fileId, NC_GLOBAL, attName.c_str(), NC_SHORT, 1, (short*)attValue.c_str()))
+          ERRORR(MB_FAILURE, "Failed to define short type attribute.");
+        break;
+      default:
+        ERRORR(MB_FAILURE, "Unknown attribute data type.");
+  // Take it out of define mode
+  if (NC_NOERR != NCFUNC(enddef)(_fileId))
+    ERRORR(MB_FAILURE, "Failed to close define mode.");
+ErrorCode ScdNCWriteHelper::collect_mesh_info()
+  ErrorCode rval;
+  else if ((vecIt = std::find(dimNames.begin(), dimNames.end(), "t")) != dimNames.end())
+  else {
+    ERRORR(MB_FAILURE, "Couldn't find 'time' or 't' dimension.");
+  else if ((vecIt = std::find(dimNames.begin(), dimNames.end(), "ilev")) != dimNames.end())
+  else {
+    ERRORR(MB_FAILURE, "Couldn't find 'lev' or 'ilev' dimension.");
+  // __<dim_name>_LOC_MINMAX (for slon, slat, lon and lat)
+  Tag convTag = 0;
+  rval = mbImpl->tag_get_handle("__slon_LOC_MINMAX", 0, MB_TYPE_INTEGER, convTag, MB_TAG_ANY);
+  ERRORR(rval, "Trouble getting conventional tag __slon_LOC_MINMAX.");
+  int val[2];
+  rval = mbImpl->tag_get_data(convTag, &_fileSet, 1, val);
+  ERRORR(rval, "Trouble getting values for conventional tag __slon_LOC_MINMAX.");
+  lDims[0] = val[0];
+  lDims[3] = val[1];
+  rval = mbImpl->tag_get_handle("__slat_LOC_MINMAX", 0, MB_TYPE_INTEGER, convTag, MB_TAG_ANY);
+  ERRORR(rval, "Trouble getting conventional tag __slat_LOC_MINMAX.");
+  ERRORR(rval, "Trouble getting values for conventional tag __slat_LOC_MINMAX.");
+  lDims[1] = val[0];
+  lDims[4] = val[1];
+  rval = mbImpl->tag_get_handle("__lon_LOC_MINMAX", 0, MB_TYPE_INTEGER, convTag, MB_TAG_ANY);
+  ERRORR(rval, "Trouble getting conventional tag __lon_LOC_MINMAX.");
+  ERRORR(rval, "Trouble getting values for conventional tag __lon_LOC_MINMAX.");
+  lCDims[0] = val[0];
+  lCDims[3] = val[1];
+  rval = mbImpl->tag_get_handle("__lat_LOC_MINMAX", 0, MB_TYPE_INTEGER, convTag, MB_TAG_ANY);
+  ERRORR(rval, "Trouble getting conventional tag __lat_LOC_MINMAX.");
+  ERRORR(rval, "Trouble getting values for conventional tag __lat_LOC_MINMAX.");
+  lCDims[1] = val[0];
+  lCDims[4] = val[1];
+ErrorCode ScdNCWriteHelper::collect_variable_data(std::vector<std::string>& var_names)
+      // Support non-set variables with 4 dimensions like (time, lev, lat, lon)
+      assert(4 == currentVarData.varDims.size());
+      currentVarData.writeStarts.resize(4);
+      currentVarData.writeCounts.resize(4);
+      // First: time
+      // Next: lev
+      // Finally: lat (or slat) and lon (or slon)
+        case WriteNC::ENTLOCFACE:
+          // Faces
+          currentVarData.writeStarts[2] = lCDims[1];
+          currentVarData.writeCounts[2] = lCDims[4] - lCDims[1] + 1;
+          currentVarData.writeStarts[3] = lCDims[0];
+          currentVarData.writeCounts[3] = lCDims[3] - lCDims[0] + 1;
+          break;
+        default:
+ErrorCode ScdNCWriteHelper::write_values(std::vector<std::string>& var_names)
+  ErrorCode rval;
+  int success;
+  // If not, just write regularly
+  // For parallel write, we assume that the data ranges do not overlap across processors (this is true
+  // for Euler and FV variables on quads)
+  // While overlapped writing might still work, we should better not take that risk
+  // Use collective I/O mode put (synchronous write) for the time being, we can try nonblocking put
+  // (request aggregation) later
+      // Get entities of this variable
+      Range ents;
+          // Faces
+          rval = mbImpl->get_entities_by_dimension(_fileSet, 2, ents);
+          ERRORR(rval, "Can't get entities for faces.");
+          break;
+        default:
+      // A typical variable has 4 dimensions as (time, lev, lat, lon)
+      // At each timestep, we need to transpose tag format (lat, lon, lev) back
+      // to NC format (lev, lat, lon) for writing
+      size_t ni = variableData.writeCounts[3]; // lon
+      size_t nj = variableData.writeCounts[2]; // lat
+      size_t nk = variableData.writeCounts[1]; // lev
+      variableData.writeCounts[0] = 1; // We will write one time step
+        // We will write values directly from tag_iterate, but we should also transpose for level
+        // so that means deep copy for transpose
+        int count;
+        void* dataptr;
+        rval = mbImpl->tag_iterate(variableData.varTags[j], ents.begin(), ents.end(), count, dataptr);
+        assert(count == (int)ents.size());
+          case NC_DOUBLE: {
+            std::vector<double> tmpdoubledata(ni*nj*nk);
+            // Transpose (lat, lon, lev) back to (lev, lat, lon)
+            jik_to_kji(ni, nj, nk, &tmpdoubledata[0], (double*)(dataptr));
+                      &variableData.writeStarts[0], &variableData.writeCounts[0],
+                      &tmpdoubledata[0]);
+            break;
+          default:
+    else {
+        case NC_DOUBLE:
+          break;
+        default:
+#endif
+  int rank = 0;
+#ifdef USE_MPI
+  if (isParallel) {
+#endif
+  if (0 == rank) {
+      // Skip dummy coordinate variables (if any)
+        continue;
+        case NC_DOUBLE:
+          break;
+        case NC_INT:
+          break;
+        default:
+#endif
diff --git a/src/io/NCWriteHelper.hpp b/src/io/NCWriteHelper.hpp
index 0000000..b05fe12
--- /dev/null
+++ b/src/io/NCWriteHelper.hpp
@@ -0,0 +1,125 @@
+ * NCWriteHelper.hpp
+ * Purpose       : Climate NC writer file helper; abstract, will be implemented for each type
+#ifndef NCWRITEHELPER_HPP_
+#define NCWRITEHELPER_HPP_
+#include "WriteNC.hpp"
+namespace moab {
+class NCWriteHelper
+public:
+  NCWriteHelper(WriteNC* writeNC, int fileId, const FileOptions& opts, EntityHandle fileSet)
+: _writeNC(writeNC), _fileId(fileId), _opts(opts), _fileSet(fileSet),
+  nTimeSteps(0), nLevels(1), tDim(-1), levDim(-1) {}
+  virtual ~NCWriteHelper() {};
+  //! Get appropriate helper instance for WriteNC class based on some info in the file set
+  static NCWriteHelper* get_nc_helper(WriteNC* writeNC, int fileId, const FileOptions& opts, EntityHandle fileSet);
+  //! Collect necessary info about local mesh
+  virtual ErrorCode collect_mesh_info() = 0;
+  //! Take the info from VarData and write first the coordinates, then the actual variables
+  virtual ErrorCode write_values(std::vector<std::string>& var_names) = 0;
+  //! Initialize file: this is where all defines are done
+  //! The VarData dimension ids are filled up after define
+  ErrorCode init_file(std::vector<std::string>& var_names);
+protected:
+  template <typename T> void jik_to_kji(size_t ni, size_t nj, size_t nk, T* dest, T* source)
+    size_t nik = ni * nk, nij = ni * nj;
+    for (std::size_t k = 0; k != nk; k++)
+      for (std::size_t j = 0; j != nj; j++)
+        for (std::size_t i = 0; i != ni; i++)
+          dest[k*nij + j*ni + i] = source[j*nik + i*nk + k];
+protected:
+  //! Allow NCWriteHelper to directly access members of WriteNC
+  WriteNC* _writeNC;
+  //! Cache some information from ReadNC
+  int _fileId;
+  const FileOptions& _opts;
+  EntityHandle _fileSet;
+  //! Dimensions of time and level
+  int nTimeSteps, nLevels;
+  //! Dimension numbers for time and level
+  int tDim, levDim;
+//! Child helper class for scd mesh, e.g. CAM_EL or CAM_FV
+class ScdNCWriteHelper : public NCWriteHelper
+public:
+  ScdNCWriteHelper(WriteNC* writeNC, int fileId, const FileOptions& opts, EntityHandle fileSet)
+: NCWriteHelper(writeNC, fileId, opts, fileSet)
+    for (unsigned int i = 0; i < 6; i++) {
+      lDims[i] = -1;
+      lCDims[i] = -1;
+  virtual ~ScdNCWriteHelper() {}
+private:
+protected:
+  //! Dimensions of my local part of grid
+  int lDims[6];
+  //! Center dimensions of my local part of grid
+  int lCDims[6];
+//! Child helper class for ucd mesh, e.g. CAM_SE (HOMME) or MPAS
+class UcdNCWriteHelper : public NCWriteHelper
+public:
+  UcdNCWriteHelper(WriteNC* writeNC, int fileId, const FileOptions& opts, EntityHandle fileSet)
+: NCWriteHelper(writeNC, fileId, opts, fileSet),
+  nLocalCellsOwned(0), nLocalEdgesOwned(0), nLocalVerticesOwned(0),
+  cDim(-1), eDim(-1), vDim(-1) {}
+  virtual ~UcdNCWriteHelper() {}
+protected:
+  //! Dimensions of my local owned part of grid
+  int nLocalCellsOwned;
+  int nLocalEdgesOwned;
+  int nLocalVerticesOwned;
+  //! Dimension numbers for nCells, nEdges and nVertices
+  int cDim, eDim, vDim;
+  //! Local owned cells, edges and vertices
+  Range localCellsOwned, localEdgesOwned, localVertsOwned;
+  //! Local global ID for owned cells, edges and vertices
+  Range localGidCellsOwned, localGidEdgesOwned, localGidVertsOwned;
+#endif
diff --git a/src/io/NCWriteMPAS.cpp b/src/io/NCWriteMPAS.cpp
index 0000000..72dc35f
--- /dev/null
+++ b/src/io/NCWriteMPAS.cpp
@@ -0,0 +1,33 @@
+ * NCWriteMPAS.cpp
+namespace moab {
+NCWriteMPAS::~NCWriteMPAS()
+ErrorCode NCWriteMPAS::collect_mesh_info()
+  return MB_NOT_IMPLEMENTED;
+ErrorCode NCWriteMPAS::write_values(std::vector<std::string>& /* var_names */)
diff --git a/src/io/NCWriteMPAS.hpp b/src/io/NCWriteMPAS.hpp
index 0000000..702984f
--- /dev/null
+++ b/src/io/NCWriteMPAS.hpp
@@ -0,0 +1,34 @@
+ * NCWriteMPAS.hpp
+ *  nc write helper for MPAS type data (CAM)
+#ifndef NCWRITEMPAS_HPP_
+#define NCWRITEMPAS_HPP_
+namespace moab {
+class NCWriteMPAS: public UcdNCWriteHelper
+public:
+  NCWriteMPAS(WriteNC* writeNC, int fileId, const FileOptions& opts, EntityHandle fileSet)
+  virtual ~NCWriteMPAS();
+private:
+#endif
diff --git a/src/io/ReadNC.cpp b/src/io/ReadNC.cpp
index a0e02b4..0a41cfa 100644
--- a/src/io/ReadNC.cpp
+++ b/src/io/ReadNC.cpp
@@ -118,6 +118,28 @@ ErrorCode ReadNC::load_file(const char* file_name, const EntityHandle* file_set,
     ERRORR(rval, "Trouble checking mesh from last read.\n");
+  // Create some conventional tags, e.g. __NUM_DIMS
+  // Keep a flag on the file set to prevent conventional tags from being created again on a second read
+  Tag convTagsCreated = 0;
+  int def_val = 0;
+  rval = mbImpl->tag_get_handle("__CONV_TAGS_CREATED", 1, MB_TYPE_INTEGER, convTagsCreated,
+                                MB_TAG_SPARSE | MB_TAG_CREAT, &def_val);
+  ERRORR(rval, "Trouble getting _CONV_TAGS_CREATED tag.");
+  int create_conv_tags_flag = 0;
+  rval = mbImpl->tag_get_data(convTagsCreated, &tmp_set, 1, &create_conv_tags_flag);
+  if (0 == create_conv_tags_flag) {
+    // Read dimension variables to create tags like __<var_name>_DIMS
+    rval = myHelper->read_variables(dimNames, tstep_nums);
+    ERRORR(rval, "Trouble reading dimension variables.");
+    rval = myHelper->create_conventional_tags(tstep_nums);
+    ERRORR(rval, "Trouble creating NC conventional tags.");
+    create_conv_tags_flag = 1;
+    rval = mbImpl->tag_set_data(convTagsCreated, &tmp_set, 1, &create_conv_tags_flag);
+    ERRORR(rval, "Trouble setting data for _CONV_TAGS_CREATED tag.");
   // Create mesh vertex/edge/face sequences
   Range faces;
   if (!noMesh) {
@@ -125,26 +147,10 @@ ErrorCode ReadNC::load_file(const char* file_name, const EntityHandle* file_set,
     ERRORR(rval, "Trouble creating mesh.");
-  // Read variables onto grid
+  // Read specified variables onto grid
   if (!noVars) {
     rval = myHelper->read_variables(var_names, tstep_nums);
-    if (MB_FAILURE == rval)
-      return rval;
-  else {
-    // Read dimension variables by default (the dimensions that are also variables)
-    std::vector<std::string> dim_var_names;
-    for (unsigned int i = 0; i < dimNames.size(); i++) {
-      std::map<std::string, VarData>::iterator mit = varInfo.find(dimNames[i]);
-      if (mit != varInfo.end())
-        dim_var_names.push_back(dimNames[i]);
-    if (!dim_var_names.empty()) {
-      rval = myHelper->read_variables(dim_var_names, tstep_nums);
-        return rval;
+    ERRORR(rval, "Trouble reading specified variables.");
 #ifdef USE_MPI
@@ -175,12 +181,6 @@ ErrorCode ReadNC::load_file(const char* file_name, const EntityHandle* file_set,
 #endif
-  // Create NC conventional tags when loading header info only
-  if (noMesh && noVars) {
-    rval = myHelper->create_conventional_tags(tstep_nums);
-    ERRORR(rval, "Trouble creating NC conventional tags.");
   mbImpl->release_interface(scdi);
   scdi = NULL;
This diff is so big that we needed to truncate the remainder.
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
