[MOAB-dev] commit/MOAB: danwu: Merged master into ncwriter
commits-noreply at bitbucket.org
Mon Apr 28 12:45:52 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/5ffa5b78d70f/
Changeset: 5ffa5b78d70f
Branch: ncwriter
User: danwu
Date: 2014-04-28 19:45:45
Summary: Merged master into ncwriter
Affected #: 10 files
diff --git a/src/LocalDiscretization/SpectralQuad.cpp b/src/LocalDiscretization/SpectralQuad.cpp
index d7355e6..7b581cb 100644
--- a/src/LocalDiscretization/SpectralQuad.cpp
+++ b/src/LocalDiscretization/SpectralQuad.cpp
@@ -109,7 +109,10 @@ bool SpectralQuad::reverseEvalFcn(const double *posn, const double *verts, const
double dist = opt_findpt_2(&_data, (const double **)_xyz, x_star, r, &c);
// if it did not converge, get out with throw...
if (dist > 0.9e+30)
- throw Map::EvaluationError();
+ std::vector<CartVect> dummy;
+ throw Map::EvaluationError(CartVect(x_star), dummy);
//c tells us if we landed inside the element or exactly on a face, edge, or node
// also, dist shows the distance to the computed point.
//copy parametric coords back
diff --git a/src/io/mhdf/include/mhdf.h b/src/io/mhdf/include/mhdf.h
index db36d63..b602bdf 100644
--- a/src/io/mhdf/include/mhdf.h
+++ b/src/io/mhdf/include/mhdf.h
@@ -67,7 +67,7 @@ extern "C" {
* named \c max_id . This attribute, if present, should contain the
* value of the largest entity ID used internally to the file. It can
* be used to verify that the code reading the file is using an integer
- * type of sufficient size to accomodate the entity IDs.
+ * type of sufficient size to accommodate the entity IDs.
* The \c tstt group contains four sub-groups, a datatype object, and a
* dataset object. The four sub-groups are: \c nodes, \c elements,
@@ -101,12 +101,12 @@ extern "C" {
* The \c coordinates
* DataSet contains the coordinates of all vertices in the mesh.
- * The DataSet should contain floating point values and have a dimenions
+ * The DataSet should contain floating point values and have a dimensions
* \f$ n \times d \f$, where \c n is the number of vertices and \c d
* is the number of coordinate values for each vertex.
- * The \c coodinates DataSet must have an integer attribute named \c start_id .
- * The vertices are then defined to have IDs begining with this value
+ * The \c coordinates DataSet must have an integer attribute named \c start_id .
+ * The vertices are then defined to have IDs beginning with this value
* and increasing sequentially in the order that they are defined in the
* \c coordinates table.
@@ -128,7 +128,7 @@ extern "C" {
* optional subgroup named \c tags. The \c tags subgroup is described in the
* \ref Dense "section on dense tag storage".
- * The \c connectivty DataSet is an \f$ n \times m \f$ array of integer
+ * The \c connectivity DataSet is an \f$ n \times m \f$ array of integer
* values. The DataSet contains one row for each of the \c n contained
* elements, where the connectivity of each element contains \c m IDs. For
* all element types supported by MOAB, with the exception of polyhedra,
@@ -146,14 +146,14 @@ extern "C" {
* The \c sets group contains the definitions of any entity sets stored
* in the file. It contains 1 to 4 DataSets and the optional \c tags
* subgroup. The \c contents, \c parents, and \c children data sets
- * are one dimensional arrays containing the concatenation of of the
+ * are one dimensional arrays containing the concatenation of the
* corresponding lists for all of the sets represented in the file.
* The \c lists DataSet is a \f$ n \times 4 \f$ table, having one
* row of four integer values for each set. The first three values
* for each set are the indices into the \c contents, \c children,
* and \c parents DataSets, respectively, at which the \em last value
- * for the set is stored. The contents, child, and parent lists for
+ * for set is stored. The contents, child, and parent lists for
* sets are stored in the corresponding datasets in the same order as
* the sets are listed in the \c lists DataSet, such that the index of
* the first value in one of those tables is one greater than the
@@ -168,7 +168,7 @@ extern "C" {
* stored at position 0 of the \c parents DataSet and the second at position
* 1.
- * The fourth colum of the \c lists DataSet is a series of bit flags
+ * The fourth column of the \c lists DataSet is a series of bit flags
* defining some properties of the sets. The four bit values currently
* defined are:
* - 0x1 owner
@@ -180,7 +180,7 @@ extern "C" {
* data set, that the contents list for the corresponding set is stored
* using a single range compression. Rather than storing the IDs of the
* contained entities individually, each ID \c i is followed by a count
- * \c n indicating that the set contains the cotiguous range of IDs
+ * \c n indicating that the set contains the contiguous range of IDs
* \f$ [i, i+n-1] \f$.
* The three least significant bits specify intended properties of the
@@ -208,16 +208,16 @@ extern "C" {
* may also be stored in the "dense" format as described in the
- * Each sub-group of the \c tags group contains the defintion for
+ * Each sub-group of the \c tags group contains the definition for
* a single tag. The name of each sub-group is the name of the
* corresponding tag. Non-printable characters, characters
* prohibited in group names in the HDF5 file format, and the
* backslash ('\') character are encoded
* in the name string by a backslash ('\') character followed by
- * the ASCII value of the character expressed as a pair of hexidecimal
+ * the ASCII value of the character expressed as a pair of hexadecimal
* digits. Thus the backslash character would be represented as \c \5C .
* Each tag group should also contain a comment which contains the
- * unenconded tag name.
+ * unencoded tag name.
* The tag sub-group may have any or all of the following four attributes:
* \c default, \c global, \c is_handle, and \c variable_length.
diff --git a/src/moab/BoundBox.hpp b/src/moab/BoundBox.hpp
index c74707a..3f1f07f 100644
--- a/src/moab/BoundBox.hpp
+++ b/src/moab/BoundBox.hpp
@@ -14,6 +14,15 @@ namespace moab {
BoundBox(const CartVect &min, const CartVect &max) :
bMin(min), bMax(max) {}
BoundBox(const double *corners);
+ // constructor used in element maps
+ BoundBox(std::vector<CartVect> points): bMin(DBL_MAX), bMax(-DBL_MAX)
+ for (size_t i=0; i<points.size(); i++)
+ update_min( points[i].array() );
+ update_max( points[i].array() );
~BoundBox() {}
bool contains_point(const double *point, const double tol = 0.0) const;
diff --git a/test/dagmc/dagmc_pointinvol_test.cpp b/test/dagmc/dagmc_pointinvol_test.cpp
index 47ee7c1..a859b65 100644
--- a/test/dagmc/dagmc_pointinvol_test.cpp
+++ b/test/dagmc/dagmc_pointinvol_test.cpp
@@ -26,7 +26,6 @@ static const char input_file[] = STRINGIFY(MESHDIR) "/dagmc/test_geom.h5m";
#endif
void dagmc_setup_test()
ErrorCode rval = DAG->load_file(input_file); // open the Dag file
@@ -34,250 +33,247 @@ void dagmc_setup_test()
rval = DAG->init_OBBTree();
CHECK_ERR(rval);
int num_vols = DAG->num_entities(3);
EntityHandle vol;
- for ( int i = 0 ; i < num_vols ; i++ )
- vol = DAG->entity_by_index(3,i);
+ for (int i = 0; i < num_vols; i++)
+ vol = DAG->entity_by_index(3, i);
//EntityHandle volume = 12682136550675316765;
- //CHECK_EQUAL(volume,vol);
+ //CHECK_EQUAL(volume, vol);
void dagmc_point_in()
int result = 0;
- int expected_result=1;
- double xyz[3]={0.0,0.0,0.0};
- int vol_idx=1;
- EntityHandle vol_h = DAG->entity_by_index(3,vol_idx);
- ErrorCode rval = DAG->point_in_volume(vol_h,xyz,result);
+ int expected_result = 1;
+ double xyz[3] = {0.0, 0.0, 0.0};
+ int vol_idx = 1;
+ EntityHandle vol_h = DAG->entity_by_index(3, vol_idx);
+ ErrorCode rval = DAG->point_in_volume(vol_h, xyz, result);
CHECK_ERR(rval);
- CHECK_EQUAL(expected_result,result);
+ CHECK_EQUAL(expected_result, result);
-int dagmc_point_in_vol_dir(double origin[3],double dir[3],int vol_idx)
+int dagmc_point_in_vol_dir(double origin[3], double dir[3], int vol_idx)
int result = 0;
double xyz[3];
double next_surf_dist;
EntityHandle next_surf;
// normalise the vector
- double dir_norm = (dir[0]*dir[0])+(dir[1]*dir[1])+(dir[2]*dir[2]);
+ double dir_norm = (dir[0]*dir[0]) + (dir[1]*dir[1]) + (dir[2]*dir[2]);
- dir[0]=dir[0]/sqrt(dir_norm);
- dir[1]=dir[1]/sqrt(dir_norm);
- dir[2]=dir[2]/sqrt(dir_norm);
+ dir[0] = dir[0] / sqrt(dir_norm);
+ dir[1] = dir[1] / sqrt(dir_norm);
+ dir[2] = dir[2] / sqrt(dir_norm);
- ErrorCode rval = DAG->ray_fire(vol_h,origin,dir,next_surf,next_surf_dist);
- xyz[0]=origin[0]+(next_surf_dist*dir[0]);
- xyz[1]=origin[1]+(next_surf_dist*dir[1]);
- xyz[2]=origin[2]+(next_surf_dist*dir[2]);
+ ErrorCode rval = DAG->ray_fire(vol_h, origin, dir, next_surf, next_surf_dist);
+ xyz[0] = origin[0] + (next_surf_dist*dir[0]);
+ xyz[1] = origin[1] + (next_surf_dist*dir[1]);
+ xyz[2] = origin[2] + (next_surf_dist*dir[2]);
std::cout << xyz[0] << " " << xyz[1] << " " << xyz[2] << std::endl;
- rval = DAG->point_in_volume(vol_h,xyz,result,dir);
+ rval = DAG->point_in_volume(vol_h, xyz, result, dir);
CHECK_ERR(rval);
return result;
void dagmc_point_in_vol_1()
- double dir[3]={ -1.0,0.0,0.0};
- double origin[3]={0.0,0.0,0.0};
- int vol_idx=1;
- int result = dagmc_point_in_vol_dir(origin,dir,vol_idx);
+ double dir[3] = {-1.0, 0.0, 0.0};
+ double origin[3] = {0.0, 0.0, 0.0};
+ int vol_idx = 1;
+ int result = dagmc_point_in_vol_dir(origin, dir, vol_idx);
void dagmc_point_in_vol_2()
- int vol_idx=1;
- double dir[3]={ 1.0,0.0,0.0};
+ int vol_idx = 1;
+ double dir[3] = {1.0, 0.0, 0.0};
void dagmc_point_in_vol_3()
- int vol_idx=1;
- double dir[3]={ 0.0,-1.0,0.0};
+ int vol_idx = 1;
+ double dir[3] = {0.0, -1.0, 0.0};
void dagmc_point_in_vol_4()
- int vol_idx=1;
- double dir[3]={ 0.0,1.0,0.0};
+ int vol_idx = 1;
+ double dir[3] = {0.0, 1.0, 0.0};
void dagmc_point_in_vol_5()
- int vol_idx=1;
- double dir[3]={ 0.0,0.0,-1.0};
+ int vol_idx = 1;
+ double dir[3] = {0.0, 0.0, -1.0};
void dagmc_point_in_vol_6()
- int vol_idx=1;
- double dir[3]={ 0.0,0.0,1.0};
+ int vol_idx = 1;
+ double dir[3] = {0.0, 0.0, 1.0};
void dagmc_point_on_corner_1()
- int vol_idx=1;
- double dir[3]={ 1.0,1.0,1.0};
+ int vol_idx = 1;
+ double dir[3] = {1.0, 1.0, 1.0};
void dagmc_point_on_corner_2()
- int vol_idx=1;
- double dir[3]={ -1.0,1.0,1.0};
+ int vol_idx = 1;
+ double dir[3] = {-1.0, 1.0, 1.0};
void dagmc_point_on_corner_3()
- int vol_idx=1;
- double dir[3]={ 1.0,1.0,-1.0};
+ int vol_idx = 1;
+ double dir[3] = {1.0, 1.0, -1.0};
void dagmc_point_on_corner_4()
- int vol_idx=1;
- double dir[3]={ -1.0,1.0,-1.0};
+ int vol_idx = 1;
+ double dir[3] = {-1.0, 1.0, -1.0};
void dagmc_point_on_corner_5()
- int vol_idx=1;
- double dir[3]={ 1.0,-1.0,1.0};
+ int vol_idx = 1;
+ double dir[3] = {1.0, -1.0, 1.0};
void dagmc_point_on_corner_6()
- int vol_idx=1;
- double dir[3]={ -1.0,-1.0,1.0};
+ int vol_idx = 1;
+ double dir[3] = {-1.0, -1.0, 1.0};
void dagmc_point_on_corner_7()
- int vol_idx=1;
- double dir[3]={ 1.0,-1.0,-1.0};
+ int vol_idx = 1;
+ double dir[3] = {1.0, -1.0, -1.0};
void dagmc_point_on_corner_8()
- int vol_idx=1;
- double dir[3]={ -1.0,-1.0,-1.0};
+ int vol_idx = 1;
+ double dir[3] = {-1.0, -1.0, -1.0};
int main(int /* argc */, char** /* argv */)
int result = 0;
- result += RUN_TEST( dagmc_setup_test ); // setup problem
- result += RUN_TEST( dagmc_point_in ); // point in centre
+ result += RUN_TEST(dagmc_setup_test); // setup problem
+ result += RUN_TEST(dagmc_point_in); // point in centre
// rays fired along cardinal directions
- result += RUN_TEST( dagmc_point_in_vol_1); // point in centre
- result += RUN_TEST( dagmc_point_in_vol_2); // point in centre
- result += RUN_TEST( dagmc_point_in_vol_3); // point in centre
- result += RUN_TEST( dagmc_point_in_vol_4); // point in centre
- result += RUN_TEST( dagmc_point_in_vol_5); // point in centre
- result += RUN_TEST( dagmc_point_in_vol_6); // point in centre
+ result += RUN_TEST(dagmc_point_in_vol_1); // point in centre
+ result += RUN_TEST(dagmc_point_in_vol_2); // point in centre
+ result += RUN_TEST(dagmc_point_in_vol_3); // point in centre
+ result += RUN_TEST(dagmc_point_in_vol_4); // point in centre
+ result += RUN_TEST(dagmc_point_in_vol_5); // point in centre
+ result += RUN_TEST(dagmc_point_in_vol_6); // point in centre
// rays fired at nodes
- result += RUN_TEST( dagmc_point_on_corner_1);
- result += RUN_TEST( dagmc_point_on_corner_2);
- result += RUN_TEST( dagmc_point_on_corner_3);
- result += RUN_TEST( dagmc_point_on_corner_4);
- // result += RUN_TEST( dagmc_point_in({0.0,0.0,5.0}); // point in centre
- // result += RUN_TEST( dagmc_point_in({0.0,0.0,-5.0}); // point in centre
- // result += RUN_TEST( dagmc_point_in({0.0,5.0,0.0}); // point in centre
- // result += RUN_TEST( dagmc_point_in({0.0,-5.0,0.0}); // point in centre
- // result += RUN_TEST( dagmc_point_in({5.0,0.0,0.0}); // point in centre
- // result += RUN_TEST( dagmc_point_in({-5.0,0.0,0.0}); // point in centre
+ result += RUN_TEST(dagmc_point_on_corner_1);
+ result += RUN_TEST(dagmc_point_on_corner_2);
+ result += RUN_TEST(dagmc_point_on_corner_3);
+ result += RUN_TEST(dagmc_point_on_corner_4);
+ //result += RUN_TEST(dagmc_point_in({0.0, 0.0, 5.0}); // point in centre
+ //result += RUN_TEST(dagmc_point_in({0.0, 0.0, -5.0}); // point in centre
+ //result += RUN_TEST(dagmc_point_in({0.0, 5.0, 0.0}); // point in centre
+ //result += RUN_TEST(dagmc_point_in({0.0, -5.0, 0.0}); // point in centre
+ //result += RUN_TEST(dagmc_point_in({5.0, 0.0, 0.0}); // point in centre
+ //result += RUN_TEST(dagmc_point_in({-5.0, 0.0, 0.0}); // point in centre
return result;
diff --git a/test/dagmc/dagmc_rayfire_test.cpp b/test/dagmc/dagmc_rayfire_test.cpp
index 57aa625..ba5f309 100644
--- a/test/dagmc/dagmc_rayfire_test.cpp
+++ b/test/dagmc/dagmc_rayfire_test.cpp
@@ -35,80 +35,80 @@ void dagmc_setup_test()
CHECK_ERR(rval);
EntityHandle vol_h;
- vol_h = DAG->entity_by_index(3,i);
+ vol_h = DAG->entity_by_index(3, i);
// EntityHandle volume = 12682136550675316765;
- // CHECK_EQUAL(volume,vol);
+ // CHECK_EQUAL(volume, vol);
void dagmc_origin_face_rayfire()
int vol_idx = 1;
- double dir[3]={-1.0,0.0,0.0};
- DAG->ray_fire(vol_h,origin,dir,next_surf,next_surf_dist);
- double expected_next_surf_dist=5.0;
- CHECK_REAL_EQUAL(expected_next_surf_dist,next_surf_dist,eps);
+ DAG->ray_fire(vol_h, origin, dir, next_surf, next_surf_dist);
+ double expected_next_surf_dist = 5.0;
+ CHECK_REAL_EQUAL(expected_next_surf_dist, next_surf_dist, eps);
void dagmc_outside_face_rayfire()
int vol_idx = 1;
- double dir[3]={1.0,0.0,0.0}; // ray along x direction
- double origin[3]={-10.0,0.0,0.0}; // origin at -10 0 0
+ double dir[3] = {1.0, 0.0, 0.0}; // ray along x direction
+ double origin[3] = {-10.0, 0.0, 0.0}; // origin at -10 0 0
std::cout << next_surf_dist << std::endl;
- double expected_next_surf_dist=15.0;
+ double expected_next_surf_dist = 15.0;
void dagmc_outside_face_rayfire_orient_exit()
DagMC::RayHistory history;
int vol_idx = 1;
- DAG->ray_fire(vol_h,origin,dir,next_surf,next_surf_dist,&history,0,1);
+ DAG->ray_fire(vol_h, origin, dir, next_surf, next_surf_dist, &history, 0, 1);
void dagmc_outside_face_rayfire_orient_entrance()
int vol_idx = 1;
- DAG->ray_fire(vol_h,origin,dir,next_surf,next_surf_dist,&history,0.0,-1);
+ DAG->ray_fire(vol_h, origin, dir, next_surf, next_surf_dist, &history, 0.0, -1);
void dagmc_outside_face_rayfire_history_fail()
int vol_idx = 1;
double xyz[3];
@@ -119,62 +119,60 @@ void dagmc_outside_face_rayfire_history_fail()
// needs two ray_fires to cross, this is expected and ok
// first ray fire with history
// second ray fire with history
- DAG->ray_fire(vol_h,xyz,dir,next_surf,next_surf_dist,&history,0,1);
+ DAG->ray_fire(vol_h, xyz, dir, next_surf, next_surf_dist, &history, 0, 1);
// this fire should hit graveyard, i.e. next_surf = 0
// using history with this geom, there should be no next surface, i.e. 0
EntityHandle ZERO = 0;
- CHECK_EQUAL(ZERO ,next_surf);
+ CHECK_EQUAL(ZERO, next_surf);
void dagmc_outside_face_rayfire_history()
int vol_idx = 1;
double xyz[3];
history.reset();
std::cout << next_surf << " " << history.size() << std::endl;
// ray fired execacyl
int result = 0;
- result += RUN_TEST( dagmc_origin_face_rayfire ); // point in centre
- result += RUN_TEST( dagmc_outside_face_rayfire );
- result += RUN_TEST( dagmc_outside_face_rayfire_orient_exit ); // fire ray from point outside volume looking for exit intersections
- result += RUN_TEST( dagmc_outside_face_rayfire_orient_entrance ); // fire ray from point outside volume looking for entrance intersection
- result += RUN_TEST( dagmc_outside_face_rayfire_history_fail ); // fire ray from point outside geometry using ray history
- result += RUN_TEST( dagmc_outside_face_rayfire_history ); // fire ray from point outside geometry using ray history
+ result += RUN_TEST(dagmc_origin_face_rayfire); // point in centre
+ result += RUN_TEST(dagmc_outside_face_rayfire);
+ result += RUN_TEST(dagmc_outside_face_rayfire_orient_exit); // fire ray from point outside volume looking for exit intersections
+ result += RUN_TEST(dagmc_outside_face_rayfire_orient_entrance); // fire ray from point outside volume looking for entrance intersection
+ result += RUN_TEST(dagmc_outside_face_rayfire_history_fail); // fire ray from point outside geometry using ray history
+ result += RUN_TEST(dagmc_outside_face_rayfire_history); // fire ray from point outside geometry using ray history
return result;
diff --git a/test/dagmc/dagmc_simple_test.cpp b/test/dagmc/dagmc_simple_test.cpp
index bf253f6..b2a44eb 100644
--- a/test/dagmc/dagmc_simple_test.cpp
+++ b/test/dagmc/dagmc_simple_test.cpp
#endif
void dagmc_load_file()
@@ -41,97 +40,101 @@ void dagmc_build_obb()
void dagmc_num_vols()
- int expect_num_vols=2;
+ int expect_num_vols = 2;
- CHECK_EQUAL(expect_num_vols,num_vols);
+ CHECK_EQUAL(expect_num_vols, num_vols);
void dagmc_entity_handle()
- int num_vols = DAG->num_entities(3);
+ int num_vols = DAG->num_entities(3);
EntityHandle vol_h;
//EntityHandle expect_vol_h = 12682136550675316765;
- //CHECK_EQUAL(expect_vol_h,vol_h);
+ //CHECK_EQUAL(expect_vol_h, vol_h);
int result = 0;
- int expect_result=1;
- int vol_idx=1;
- CHECK_EQUAL(expect_result,result);
+ int expect_result = 1;
+ int vol_idx = 1;
+ CHECK_ERR(rval);
+ CHECK_EQUAL(expect_result, result);
void dagmc_rayfire()
const double eps = 1e-6; // epsilon for test, faceting tol?
- int vol_idx=1;
+ int vol_idx = 1;
// note model is cube of side 10, centred at 0,0,0, so ray fire along
// any unit direction should be exactly 5.0
- double dir[3]={0.0,0.0,1.0};
- double expect_next_surf_dist=5.0;
+ double expect_next_surf_dist = 5.0;
- ErrorCode rval = DAG->ray_fire(vol_h,xyz,dir,next_surf,next_surf_dist);
- CHECK_REAL_EQUAL(expect_next_surf_dist,next_surf_dist,eps);
+ ErrorCode rval = DAG->ray_fire(vol_h, xyz, dir, next_surf, next_surf_dist);
+ CHECK_ERR(rval);
+ CHECK_REAL_EQUAL(expect_next_surf_dist, next_surf_dist, eps);
void dagmc_closest_to()
- int vol_idx=1;
+ int vol_idx = 1;
- double xyz[3]={-6.0,0.0,0.0};
+ double xyz[3] = {-6.0, 0.0, 0.0};
double distance; // distance from point to nearest surface
- double expect_distance=1.0;
+ double expect_distance = 1.0;
- ErrorCode rval = DAG->closest_to_location(vol_h,xyz,distance);
+ ErrorCode rval = DAG->closest_to_location(vol_h, xyz, distance);
+ CHECK_ERR(rval);
// distance should be 1.0 cm
- CHECK_REAL_EQUAL(expect_distance,distance,eps);
+ CHECK_REAL_EQUAL(expect_distance, distance, eps);
void dagmc_test_boundary()
- int vol_idx=1;
- int surf_idx=1;
- EntityHandle surf_h = DAG->entity_by_index(2,surf_idx);
+ int vol_idx = 1;
+ int surf_idx = 1;
+ EntityHandle surf_h = DAG->entity_by_index(2, surf_idx);
- double xyz[3]={0.0,0.0,5.0};
+ double xyz[3] = {0.0, 0.0, 5.0};
int result;
- int expect_result=0;
+ int expect_result = 0;
- ErrorCode rval = DAG->test_volume_boundary(vol_h,surf_h,xyz,dir,result);
+ ErrorCode rval = DAG->test_volume_boundary(vol_h, surf_h, xyz, dir, result);
+ CHECK_ERR(rval);
// check ray leaving volume
int result = 0;
- result += RUN_TEST( dagmc_load_file ); // test ray fire
- result += RUN_TEST( dagmc_build_obb ); // build the obb
- result += RUN_TEST( dagmc_num_vols ); // make sure the num of vols correct
- // result += RUN_TEST( dagmc_entity_handle); // check the entity handle correct
- result += RUN_TEST( dagmc_point_in); // check entity by point
- result += RUN_TEST( dagmc_rayfire ) ; // ensure ray fire distance is correct
- result += RUN_TEST( dagmc_closest_to ); // check the distance to surface nearest point
- result += RUN_TEST( dagmc_test_boundary ); // check particle entering leaving
+ result += RUN_TEST(dagmc_load_file); // test ray fire
+ result += RUN_TEST(dagmc_build_obb); // build the obb
+ result += RUN_TEST(dagmc_num_vols); // make sure the num of vols correct
+ // result += RUN_TEST(dagmc_entity_handle); // check the entity handle correct
+ result += RUN_TEST(dagmc_point_in); // check entity by point
+ result += RUN_TEST(dagmc_rayfire); // ensure ray fire distance is correct
+ result += RUN_TEST(dagmc_closest_to); // check the distance to surface nearest point
+ result += RUN_TEST(dagmc_test_boundary); // check particle entering leaving
return result;
diff --git a/tools/mbcoupler/Coupler.cpp b/tools/mbcoupler/Coupler.cpp
index afee8af..fbfd8fb 100644
--- a/tools/mbcoupler/Coupler.cpp
+++ b/tools/mbcoupler/Coupler.cpp
@@ -446,7 +446,12 @@ ErrorCode Coupler::locate_points(double *xyz, int num_points,
for (int i = 0; i < num_points; i++)
if (tl_tmp->vi_rd[3*i+1] == -1)
missing_pts++;
+#ifndef NDEBUG
+ printf(" %f %f %f\n", xyz[3*i], xyz[3*i+1], xyz[3*i+2] );
+#endif
else
if (tl_tmp->vi_rd[3*i]==(int)my_rank)
local_pts++;
@@ -668,7 +673,11 @@ ErrorCode Coupler::nat_param(double xyz[3],
if (epsilon) {
std::vector<double> dists;
std::vector<EntityHandle> leaves;
- result = myTree->distance_search(xyz, epsilon, leaves, 1.0e-10, 1.0e-6, &dists, NULL, &localRoot);
+ // two tolerances
+ result = myTree->distance_search(xyz, epsilon, leaves,
+ /*iter_tol*/ epsilon,
+ /*inside_tol*/ 10*epsilon,
+ &dists, NULL, &localRoot);
if (leaves.empty())
// not found returns success here, with empty list, just like case with no epsilon
return MB_SUCCESS;
@@ -758,38 +767,53 @@ ErrorCode Coupler::nat_param(double xyz[3],
std::cout << "Problems getting coordinates of vertices\n";
return result;
+ CartVect pos(xyz);
if (etype == MBHEX) {
if (8==num_connect)
Element::LinearHex hexmap(coords_vert);
- tmp_nat_coords = hexmap.ievaluate(CartVect(xyz), epsilon);
- bool inside = hexmap.inside_nat_space(tmp_nat_coords, epsilon);
- if (!inside)
+ if (!hexmap.inside_box( pos, epsilon))
+ continue;
+ try {
+ tmp_nat_coords = hexmap.ievaluate(pos, epsilon);
+ bool inside = hexmap.inside_nat_space(tmp_nat_coords, epsilon);
+ if (!inside) continue;
+ catch (Element::Map::EvaluationError) {
continue;
else if (27==num_connect)
Element::QuadraticHex hexmap(coords_vert);
- if (!inside)
- continue;
+ continue;
+ try {
+ continue;
else // TODO this case not treated yet, no interpolation
continue;
else if (etype == MBTET){
Element::LinearTet tetmap(coords_vert);
- tmp_nat_coords = tetmap.ievaluate(CartVect(xyz));
+ // this is just a linear solve; unless degenerate, will not except
+ tmp_nat_coords = tetmap.ievaluate(pos);
bool inside = tetmap.inside_nat_space(tmp_nat_coords, epsilon);
if (!inside)
continue;
else if (etype == MBQUAD){
Element::LinearQuad quadmap(coords_vert);
+ if (!quadmap.inside_box( pos, epsilon))
+ continue;
try {
- tmp_nat_coords = quadmap.ievaluate(CartVect(xyz), epsilon);
+ tmp_nat_coords = quadmap.ievaluate(pos, epsilon);
bool inside = quadmap.inside_nat_space(tmp_nat_coords, epsilon);
diff --git a/tools/mbcoupler/ElemUtil.cpp b/tools/mbcoupler/ElemUtil.cpp
index cfc36e0..ee338c0 100644
--- a/tools/mbcoupler/ElemUtil.cpp
+++ b/tools/mbcoupler/ElemUtil.cpp
@@ -3,6 +3,7 @@
#include <assert.h>
#include "ElemUtil.hpp"
+#include "moab/BoundBox.hpp"
namespace moab {
namespace ElemUtil {
@@ -433,6 +434,15 @@ namespace Element {
this->vertex = v;
+ bool Map::inside_box(const CartVect & xi, double & tol) const
+ // bail out early, before doing an expensive NR iteration
+ // compute box
+ BoundBox box(this->vertex);
+ return box.contains_point(xi.array(), tol);
CartVect Map::ievaluate(const CartVect& x, double tol, const CartVect& x0) const {
// TODO: should differentiate between epsilons used for
@@ -448,12 +458,12 @@ namespace Element {
int iters=0;
while (delta % delta > error_tol_sqr) {
if(++iters>10)
+ throw Map::EvaluationError(x, vertex);
J = jacobian(xi);
det = J.determinant();
if (det < std::numeric_limits<double>::epsilon())
xi -= J.inverse(1.0/det) * delta;
delta = evaluate( xi ) - x;
@@ -896,7 +906,10 @@ namespace Element {
real dist = opt_findpt_3(&_data, (const real **)_xyz, x_star, r, &c);
if (dist > 0.9e+30)
+ throw Map::EvaluationError(xyz, dummy);
@@ -1184,7 +1197,11 @@ namespace Element {
real dist = opt_findpt_2(&_data, (const real **)_xyz, x_star, r, &c);
if (dist > 0.9e+30)
diff --git a/tools/mbcoupler/ElemUtil.hpp b/tools/mbcoupler/ElemUtil.hpp
index 219323b..b2a743a 100644
--- a/tools/mbcoupler/ElemUtil.hpp
+++ b/tools/mbcoupler/ElemUtil.hpp
@@ -103,10 +103,22 @@ namespace ElemUtil {
/**\brief Set vertices. */
virtual void set_vertices(const std::vector<CartVect>& v);
+ // will look at the box formed by vertex coordinates, and before doing any NR, bail out if necessary
+ virtual bool inside_box(const CartVect & xi, double & tol) const;
/* Exception thrown when an evaluation fails (e.g., ievaluate fails to converge). */
class EvaluationError {
public:
- EvaluationError(){};
+ EvaluationError(const CartVect & x, const std::vector<CartVect> & verts): p(x), vertices(verts){
+#ifndef NDEBUG
+ std::cout << "p:" << p << "\n vertices.size() " <<vertices.size() << "\n";
+ for (size_t i=0; i<vertices.size(); i++)
+ std::cout << vertices[i] << "\n";
+#endif
+ private:
+ CartVect p;
+ std::vector<CartVect> vertices;
};// class EvaluationError
/* Exception thrown when a bad argument is encountered. */
diff --git a/tools/mbcoupler/ElementTest.cpp b/tools/mbcoupler/ElementTest.cpp
index 4f37602..ca6e9e2 100644
--- a/tools/mbcoupler/ElementTest.cpp
+++ b/tools/mbcoupler/ElementTest.cpp
@@ -24,7 +24,58 @@ void test_tet() {
}// test_tet()
void test_hex() {
- moab::Element::LinearHex hex;
+ double positions[] =
+ 236.80706050970281, -139.55422526228017, 193.27999999999997,
+ 236.47511729348639, -141.33020962638582, 193.27999999999997,
+ 237.8457938295229, -142.57076074835663, 193.27999999999997,
+ 239.12702305519684, -139.96608933577852, 193.27999999999997,
+ 236.80841321361444, -139.55341321335499, 202.654,
+ 236.47655014713746, -141.32980272396816, 202.654,
+ 237.8477913707564, -142.57047282187165, 202.654,
+ 239.12865103844533, -139.96531051891105, 202.654
+ CartVect x(235.96518686964933, -142.43503000077749, 188.19999999999987);
+ for (int i=0; i<8; i++)
+ vertices.push_back(CartVect(positions+3*i));
+ moab::Element::LinearHex hex(vertices);
+ double tol(0.0001);
+ if (hex.inside_box(x, tol))
+ CartVect nat_par = hex.ievaluate(x, 0.0001);
+ std::cout <<nat_par <<"\n";
+ double positions2[] =
+ { 49.890500000000024, -20.376134375374882, 312.72000000000003,
+ 52.015875000000044, -19.149048546996006, 312.72000000000003,
+ 48.430375821458099, -18.548796774572125, 312.72000000000003,
+ 47.717616239031223, -21.191360829777231, 312.72000000000003,
+ 49.890500000000024, -20.376134375374882, 322.88,
+ 52.015875000000044, -19.149048546996006, 322.88,
+ 48.429930354643275, -18.52828610485021, 322.88,
+ 47.720552036968819, -21.167591146685712, 322.88};
+ CartVect x2(51.469000000000015, -20.145482942833631, 317.80000000000001);
+ vertices.clear();
+ vertices.push_back(CartVect(positions2+3*i));
+ moab::Element::LinearHex hex2(vertices);
+ if (hex2.inside_box(x2, tol))
+ try {
+ // nothing
}// test_hex()
#include "moab/Core.hpp"
#include "moab/Range.hpp"
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
