[MOAB-dev] commit/MOAB: danwu: Updated NC writer for HOMME. Only the root processor should write coordinates used by requested variables.
commits-noreply at bitbucket.org
Thu Apr 24 16:51:37 CDT 2014
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/ee109806ef41/
Changeset: ee109806ef41
Branch: ncwriter
User: danwu
Date: 2014-04-24 23:51:24
Summary: Updated NC writer for HOMME. Only the root processor should write coordinates used by requested variables.
Affected #: 1 file
diff --git a/src/io/NCWriteHOMME.cpp b/src/io/NCWriteHOMME.cpp
index 36ea5c7..9320f62 100644
--- a/src/io/NCWriteHOMME.cpp
+++ b/src/io/NCWriteHOMME.cpp
@@ -148,38 +148,7 @@ ErrorCode NCWriteHOMME::write_values(std::vector<std::string>& var_names)
std::set<std::string>& dummyVarNames = _writeNC->dummyVarNames;
std::map<std::string, WriteNC::VarData>& varInfo = _writeNC->varInfo;
- // Start with coordinates
- for (std::set<std::string>::iterator setIt = usedCoordinates.begin();
- setIt != usedCoordinates.end(); ++setIt) {
- const std::string& coordName = *setIt;
- // Skip dummy coordinate variables (e.g. ncol)
- if (dummyVarNames.find(coordName) != dummyVarNames.end())
- continue;
- std::map<std::string, WriteNC::VarData>::iterator vit = varInfo.find(coordName);
- if (vit == varInfo.end())
- ERRORR(MB_FAILURE, "Can't find one coordinate variable.");
- WriteNC::VarData& varCoordData = vit->second;
- int success = 0;
- switch (varCoordData.varDataType) {
- case NC_DOUBLE:
- success = NCFUNCAP(_vara_double)(_fileId, varCoordData.varId, &varCoordData.writeStarts[0],
- &varCoordData.writeCounts[0], (double*)(varCoordData.memoryHogs[0]));
- ERRORS(success, "Failed to write double data.");
- break;
- case NC_INT:
- success = NCFUNCAP(_vara_int)(_fileId, varCoordData.varId, &varCoordData.writeStarts[0],
- &varCoordData.writeCounts[0], (int*)(varCoordData.memoryHogs[0]));
- ERRORS(success, "Failed to write int data.");
- break;
- default:
- success = 1;
- break;
+ int success;
// Now look at requested var_names; if they have time, we will have a list, and write one at a time
// Need to transpose from lev dimension
@@ -193,7 +162,10 @@ ErrorCode NCWriteHOMME::write_values(std::vector<std::string>& var_names)
WriteNC::VarData& variableData = vit->second;
int numTimeSteps = (int)variableData.varTags.size();
if (variableData.has_tsteps) {
- // Get entities of this variable
+ // Time should be the first dimension
+ assert(tDim == variableData.varDims[0]);
+ // Assume this variable is on vertices for the time being
switch (variableData.entLoc) {
case WriteNC::ENTLOCVERT:
// Vertices
@@ -223,7 +195,6 @@ ErrorCode NCWriteHOMME::write_values(std::vector<std::string>& var_names)
#endif
// Now write from memory directly
- int success = 0;
switch (variableData.varDataType) {
case NC_DOUBLE: {
std::vector<double> tmpdoubledata(nLocalVerticesOwned * variableData.numLev);
@@ -268,7 +239,6 @@ ErrorCode NCWriteHOMME::write_values(std::vector<std::string>& var_names)
} // if (variableData.has_tsteps)
else {
- int success = 0;
case NC_DOUBLE:
success = NCFUNCAP(_vara_double)(_fileId, variableData.varId, &variableData.writeStarts[0],
@@ -281,6 +251,65 @@ ErrorCode NCWriteHOMME::write_values(std::vector<std::string>& var_names)
+ // Write coordinates used by requested var_names
+ // Use independent I/O mode put, since this write is only for the root processor
+ // CAUTION: if the NetCDF ID is from a previous call to ncmpi_create rather than ncmpi_open,
+ // all processors need to call ncmpi_begin_indep_data(). If only the root processor does so,
+ // ncmpi_begin_indep_data() call will be blocked forever :(
+#ifdef PNETCDF_FILE
+ // Enter independent I/O mode
+ success = NCFUNC(begin_indep_data)(_fileId);
+ ERRORS(success, "Failed to begin independent I/O mode.");
+#endif
+ int rank = 0;
+#ifdef USE_MPI
+ bool& isParallel = _writeNC->isParallel;
+ if (isParallel) {
+ ParallelComm*& myPcomm = _writeNC->myPcomm;
+ rank = myPcomm->proc_config().proc_rank();
+#endif
+ if (0 == rank) {
+ for (std::set<std::string>::iterator setIt = usedCoordinates.begin();
+ setIt != usedCoordinates.end(); ++setIt) {
+ const std::string& coordName = *setIt;
+ // Skip dummy coordinate variables (e.g. ncol)
+ if (dummyVarNames.find(coordName) != dummyVarNames.end())
+ continue;
+ std::map<std::string, WriteNC::VarData>::iterator vit = varInfo.find(coordName);
+ if (vit == varInfo.end())
+ ERRORR(MB_FAILURE, "Can't find one coordinate variable.");
+ WriteNC::VarData& varCoordData = vit->second;
+ switch (varCoordData.varDataType) {
+ case NC_DOUBLE:
+ // Independent I/O mode put
+ success = NCFUNCP(_vara_double)(_fileId, varCoordData.varId, &varCoordData.writeStarts[0],
+ &varCoordData.writeCounts[0], (double*)(varCoordData.memoryHogs[0]));
+ ERRORS(success, "Failed to write double data.");
+ break;
+ case NC_INT:
+ success = NCFUNCP(_vara_int)(_fileId, varCoordData.varId, &varCoordData.writeStarts[0],
+ &varCoordData.writeCounts[0], (int*)(varCoordData.memoryHogs[0]));
+ ERRORS(success, "Failed to write int data.");
+ break;
+ default:
+ ERRORR(MB_FAILURE, "Not implemented yet.");
+ // End independent I/O mode
+ success = NCFUNC(end_indep_data)(_fileId);
+ ERRORS(success, "Failed to end independent I/O mode.");
+#endif
return MB_SUCCESS;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
